[QGIS Commit] r8751 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jul 11 06:06:37 EDT 2008
Author: timlinux
Date: 2008-07-11 06:06:37 -0400 (Fri, 11 Jul 2008)
New Revision: 8751
   trunk/qgis/src/app/qgsmaptooladdvertex.cpp
Formatting changes only
Modified: trunk/qgis/src/app/qgsmaptooladdvertex.cpp
--- trunk/qgis/src/app/qgsmaptooladdvertex.cpp	2008-07-11 00:20:16 UTC (rev 8750)
+++ trunk/qgis/src/app/qgsmaptooladdvertex.cpp	2008-07-11 10:06:37 UTC (rev 8751)
@@ -26,7 +26,7 @@
 QgsMapToolAddVertex::~QgsMapToolAddVertex()
   delete mRubberBand;
@@ -35,42 +35,42 @@
 void QgsMapToolAddVertex::canvasMoveEvent(QMouseEvent * e)
   if(mRubberBand)
+    QList<QgsSnappingResult> snapResults;
+    if(mSnapper.snapToBackgroundLayers(e->pos(), snapResults) == 0)
-      QList<QgsSnappingResult> snapResults;
-      if(mSnapper.snapToBackgroundLayers(e->pos(), snapResults) == 0)
-	  QgsPoint posMapCoord = snapPointFromResults(snapResults, e->pos());
-	  mRubberBand->movePoint(2, posMapCoord); //consider that the first rubber band point is added twice
+      QgsPoint posMapCoord = snapPointFromResults(snapResults, e->pos());
+      mRubberBand->movePoint(2, posMapCoord); //consider that the first rubber band point is added twice
 void QgsMapToolAddVertex::canvasPressEvent(QMouseEvent * e)
   delete mRubberBand;
   mRubberBand = 0;
   //snap to segments of the current layer
   if(mSnapper.snapToCurrentLayer(e->pos(), mRecentSnappingResults, QgsSnapper::SNAP_TO_SEGMENT) != 0)
-      //error
+    //error
   if(mRecentSnappingResults.size() > 0)
-      mRubberBand = createRubberBand();
-      //take first snapping result and create the rubber band
-      QgsSnappingResult firstResult = *(mRecentSnappingResults.begin());
-      mRubberBand->addPoint(firstResult.beforeVertex, false);
-      mRubberBand->addPoint(firstResult.snappedVertex, false);
-      mRubberBand->addPoint(firstResult.afterVertex, true);
+    mRubberBand = createRubberBand();
+    //take first snapping result and create the rubber band
+    QgsSnappingResult firstResult = *(mRecentSnappingResults.begin());
+    mRubberBand->addPoint(firstResult.beforeVertex, false);
+    mRubberBand->addPoint(firstResult.snappedVertex, false);
+    mRubberBand->addPoint(firstResult.afterVertex, true);
   else
-      displaySnapToleranceWarning();
+    displaySnapToleranceWarning();
 void QgsMapToolAddVertex::canvasReleaseEvent(QMouseEvent * e)
@@ -78,36 +78,36 @@
   QgsMapLayer* currentLayer = mCanvas->currentLayer();
   QgsVectorLayer* vlayer = 0;
   if(currentLayer)
-      vlayer = dynamic_cast<QgsVectorLayer*>(currentLayer);
+    vlayer = dynamic_cast<QgsVectorLayer*>(currentLayer);
   if(vlayer && mRecentSnappingResults.size() > 0)
+    //snap point to background layers
+    QgsPoint snappedPointMapCoord;
+    QgsPoint snappedPointLayerCoord;
-      //snap point to background layers
-      QgsPoint snappedPointMapCoord;
-      QgsPoint snappedPointLayerCoord;
-	  snappedPointMapCoord = snapPointFromResults(snapResults, e->pos());
-	  snappedPointLayerCoord = toLayerCoords(vlayer, snappedPointMapCoord);
+      snappedPointMapCoord = snapPointFromResults(snapResults, e->pos());
+      snappedPointLayerCoord = toLayerCoords(vlayer, snappedPointMapCoord);
-	  int topologicalEditing = QgsProject::instance()->readNumEntry("Digitizing", "/TopologicalEditing", 0);
-	  if(topologicalEditing)
-	      insertSegmentVerticesForSnap(snapResults, vlayer);
-	  //and change the feature points
-	  QList<QgsSnappingResult>::iterator sr_it = mRecentSnappingResults.begin();
-	  for(; sr_it != mRecentSnappingResults.end(); ++sr_it)
-	      vlayer->insertVertexBefore(snappedPointLayerCoord.x(), snappedPointLayerCoord.y(), sr_it->snappedAtGeometry, sr_it->afterVertexNr);
+      int topologicalEditing = QgsProject::instance()->readNumEntry("Digitizing", "/TopologicalEditing", 0);
+      if(topologicalEditing)
+        insertSegmentVerticesForSnap(snapResults, vlayer);
+      //and change the feature points
+      QList<QgsSnappingResult>::iterator sr_it = mRecentSnappingResults.begin();
+      for(; sr_it != mRecentSnappingResults.end(); ++sr_it)
+        vlayer->insertVertexBefore(snappedPointLayerCoord.x(), snappedPointLayerCoord.y(), sr_it->snappedAtGeometry, sr_it->afterVertexNr);
   delete mRubberBand;
   mRubberBand = 0;
More information about the QGIS-commit mailing list
