[QGIS Commit] r8776 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jul 14 16:23:14 EDT 2008
Author: jef
Date: 2008-07-14 16:23:14 -0400 (Mon, 14 Jul 2008)
New Revision: 8776
   trunk/qgis/src/app/qgsattributedialog.cpp
   trunk/qgis/src/app/qgsattributedialog.h
   trunk/qgis/src/app/qgsmaptooladdfeature.cpp
select value for classification in attribute dialog from unique value renderer classes
Modified: trunk/qgis/src/app/qgsattributedialog.cpp
--- trunk/qgis/src/app/qgsattributedialog.cpp	2008-07-14 20:21:57 UTC (rev 8775)
+++ trunk/qgis/src/app/qgsattributedialog.cpp	2008-07-14 20:23:14 UTC (rev 8776)
@@ -19,26 +19,33 @@
 #include "qgsfield.h"
 #include "qgslogger.h"
+#include "qgsvectorlayer.h"
+#include "qgsvectordataprovider.h"
+#include "qgsuniquevaluerenderer.h"
+#include "qgssymbol.h"
 #include <QTableWidgetItem>
 #include <QSettings>
 #include <QLineEdit>
-#include <QSpinBox>
+#include <QComboBox>
 #include <QLabel>
-#include <QDoubleSpinBox>
 #include <QFrame>
 #include <QScrollArea>
-QgsAttributeDialog::QgsAttributeDialog(
-    QgsFieldMap theFieldMap, QgsFeature * thepFeature)
+QgsAttributeDialog::QgsAttributeDialog(QgsVectorLayer *vl, QgsFeature * thepFeature)
   : QDialog(),
     mSettingsPath("/Windows/AttributeDialog/"),
-    mFieldMap(theFieldMap),
-    mpFeature(thepFeature)
+    mpFeature(thepFeature),
+    mLayer(vl)
+  setupUi(this);
+  if (mpFeature==NULL || vl->getDataProvider()==NULL )
+    return;
-  setupUi(this);
-  if (mpFeature==NULL) return;
-  if (mFieldMap.isEmpty()) return;
+  const QgsFieldMap &theFieldMap = vl->getDataProvider()->fields();
+  if (theFieldMap.isEmpty()) return;
   QgsAttributeMap myAttributes = mpFeature->attributeMap();
   //Set up dynamic inside a scroll box
@@ -58,26 +65,79 @@
   mypScrollArea->setWidgetResizable( true );
   QGridLayout * mypInnerLayout = new QGridLayout(mypInnerFrame);
+  int classificationField = -1;
+  QStringList values;
+  const QgsUniqueValueRenderer *uvr = dynamic_cast<const QgsUniqueValueRenderer *>( mLayer->renderer() );
+  if( uvr )
+    classificationField = uvr->classificationField();
+    const QList<QgsSymbol *> symbols = uvr->symbols();
+    for(int i=0; i<symbols.size(); i++)
+      values.append( symbols[i]->lowerValue() );
   int index=0;
   for (QgsAttributeMap::const_iterator it = myAttributes.begin();
       it != myAttributes.end();
       ++it)
-    QString myFieldName = mFieldMap[it.key()].name();
+    QString myFieldName = theFieldMap[it.key()].name();
+    int myFieldType = theFieldMap[it.key()].type();
     QLabel * mypLabel = new QLabel();
     mypInnerLayout->addWidget(mypLabel,index,0);
     QVariant myFieldValue = it.value();
-    QLineEdit * mypLineEdit = new QLineEdit();
-    //the provider may have provided a default value so use it
-    mypLineEdit->setText(myFieldValue.toString());
-    if( mFieldMap[it.key()].type()==QVariant::Int )
+    QWidget *myWidget;
+    if(classificationField!=it.key())
-      mypLineEdit->setValidator( new QIntValidator(mypLineEdit) );
+      QLineEdit *le = new QLineEdit();
+      //the provider may have provided a default value so use it
+      le->setText(myFieldValue.toString());
+      if( myFieldType==QVariant::Int )
+        le->setValidator( new QIntValidator(le) );
+      else if( myFieldType==QVariant::Double )
+      myWidget = le;
+    else
+      QComboBox *cb = new QComboBox();
+      cb->addItems(values);
+      cb->setEditable(true);
+      cb->setEditText(myFieldValue.toString());
+      if( myFieldType==QVariant::Int ) {
+        cb->setValidator( new QIntValidator(cb) );
+      myWidget = cb;
       mypLabel->setText(myFieldName + tr(" (int)"));
-    else if( mFieldMap[it.key()].type()==QVariant::Double )
-      mypLineEdit->setValidator( new QDoubleValidator(mypLineEdit) );
       mypLabel->setText(myFieldName + tr(" (dbl)"));
     else //string
@@ -85,8 +145,9 @@
       //any special behaviour for string goes here
       mypLabel->setText(myFieldName + tr(" (txt)"));
-    mypInnerLayout->addWidget(mypLineEdit,index,1);
-    mpWidgets << mypLineEdit;
+    mypInnerLayout->addWidget(myWidget, index, 1);
+    mpWidgets << myWidget;
     ++index;
   restoreGeometry();
@@ -107,13 +168,27 @@
       ++it)
+    const QgsFieldMap &theFieldMap = mLayer->getDataProvider()->fields();
     //Q_ASSERT(myIndex <= mpWidgets.size());
     bool myFlag=false;
-    QString myFieldValue =
-      dynamic_cast<QLineEdit *>(mpWidgets.value(myIndex))->text();
-    switch( mFieldMap[it.key()].type() )
+    QString myFieldValue;
+    QLineEdit *le = dynamic_cast<QLineEdit *>(mpWidgets.value(myIndex));
+    if(le)
+      myFieldValue = le->text();
+    QComboBox *cb = dynamic_cast<QComboBox *>(mpWidgets.value(myIndex));
+    if(cb)
+      myFieldValue = cb->currentText();
+    switch( theFieldMap[it.key()].type() )
       case QVariant::Int:
           int myIntValue = myFieldValue.toInt(&myFlag);
Modified: trunk/qgis/src/app/qgsattributedialog.h
--- trunk/qgis/src/app/qgsattributedialog.h	2008-07-14 20:21:57 UTC (rev 8775)
+++ trunk/qgis/src/app/qgsattributedialog.h	2008-07-14 20:23:14 UTC (rev 8776)
@@ -27,14 +27,14 @@
 class QgsFeature;
 class QLayout;
 class QgsField;
-typedef QMap<int, QgsField> QgsFieldMap;
+class QgsVectorLayer;
 class QgsAttributeDialog: public QDialog, private Ui::QgsAttributeDialogBase
   Q_OBJECT;
   public:
-  QgsAttributeDialog(const QgsFieldMap thepFieldMap, QgsFeature * thepFeature);
+  QgsAttributeDialog(QgsVectorLayer *vl, QgsFeature * thepFeature);
   ~QgsAttributeDialog();
   /** Overloaded accept method which will write the feature field
@@ -53,7 +53,7 @@
   private:
   QString mSettingsPath;
   QList<QWidget *> mpWidgets;
-  QgsFieldMap mFieldMap;
+  QgsVectorLayer *mLayer;
   QgsFeature *  mpFeature;
Modified: trunk/qgis/src/app/qgsmaptooladdfeature.cpp
--- trunk/qgis/src/app/qgsmaptooladdfeature.cpp	2008-07-14 20:21:57 UTC (rev 8775)
+++ trunk/qgis/src/app/qgsmaptooladdfeature.cpp	2008-07-14 20:23:14 UTC (rev 8776)
@@ -175,7 +175,7 @@
 	  // show the dialog to enter attribute values
-    QgsAttributeDialog * mypDialog = new QgsAttributeDialog(fields,f );
+    QgsAttributeDialog * mypDialog = new QgsAttributeDialog( vlayer, f );
 	  if (mypDialog->exec())
       qDebug("Adding feature to layer");
@@ -436,7 +436,7 @@
 	      f->addAttribute(it.key(), provider->getDefaultValue(it.key()));
       if(vlayer->addFeature(*f))
More information about the QGIS-commit mailing list
