[QGIS Commit] r8812 - branches/grass-tidyup-branch/src/plugins/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jul 17 18:04:38 EDT 2008
Author: timlinux
Date: 2008-07-17 18:04:38 -0400 (Thu, 17 Jul 2008)
New Revision: 8812
Added:
   branches/grass-tidyup-branch/src/plugins/grass/grass_add_map.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_add_raster.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_add_vector.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_add_vertex.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_browser_raster_layer.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_browser_vector_layer.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_close_edit.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_copy_map.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_delete_line.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_delete_map.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_delete_vertex.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_edit_attributes.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_module_error.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_module_warning.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_move_line.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_move_vertex.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_new_boundary.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_new_centroid.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_new_line.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_new_point.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_refresh.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_rename_map.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_set_region.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_shell.png
   branches/grass-tidyup-branch/src/plugins/grass/grass_split_line.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_add_connection.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_add_constant.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_add_function.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_add_map.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_delete.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_open.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_save.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_save_as.png
   branches/grass-tidyup-branch/src/plugins/grass/mapcalc_select.png
Removed:
   branches/grass-tidyup-branch/src/plugins/grass/images/
   branches/grass-tidyup-branch/src/plugins/grass/themes/
   branches/grass-tidyup-branch/src/plugins/grass/CMakeLists.txt
   branches/grass-tidyup-branch/src/plugins/grass/qgsgrass_plugin.qrc
   branches/grass-tidyup-branch/src/plugins/grass/qgsgrassplugin.cpp
   branches/grass-tidyup-branch/src/plugins/grass/qgsgrassplugin.h
Rearranged grass icons (this is a transitional commit - they will be put into images/ after this commit)
Modified: branches/grass-tidyup-branch/src/plugins/grass/CMakeLists.txt
--- branches/grass-tidyup-branch/src/plugins/grass/CMakeLists.txt	2008-07-17 21:40:23 UTC (rev 8811)
+++ branches/grass-tidyup-branch/src/plugins/grass/CMakeLists.txt	2008-07-17 22:04:38 UTC (rev 8812)
@@ -1,5 +1,5 @@
-SUBDIRS(config modules themes)
+SUBDIRS(config modules )
 ADD_DEFINITIONS(-DGRASS_BASE=\\\"${GRASS_PREFIX}\\\")
 ADD_DEFINITIONS(-DHAVE_OPENPTY=${HAVE_OPENPTY})
@@ -141,5 +141,5 @@
 FILE (GLOB GMLS *.gml)
-INSTALL (FILES ${GMLS} images/world.png
+INSTALL (FILES ${GMLS}
          DESTINATION ${QGIS_DATA_DIR}/grass)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_add_map.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_add_map.png)
(Binary files differ)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_add_raster.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_add_raster.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_add_vector.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_add_vector.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_add_vertex.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_add_vertex.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_browser_raster_layer.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_browser_raster_layer.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_browser_vector_layer.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_browser_vector_layer.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_close_edit.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_close_edit.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_copy_map.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_copy_map.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_delete_line.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_delete_line.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_delete_map.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_delete_map.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_delete_vertex.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_delete_vertex.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_edit_attributes.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_edit_attributes.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_module_error.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_module_error.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_module_warning.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_module_warning.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_move_line.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_move_line.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_move_vertex.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_move_vertex.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_new_boundary.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_new_boundary.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_new_centroid.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_new_centroid.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_new_line.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_new_line.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_new_point.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_new_point.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_refresh.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_refresh.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_rename_map.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_rename_map.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_set_region.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_set_region.png)
Added: branches/grass-tidyup-branch/src/plugins/grass/grass_shell.png
Property changes on: branches/grass-tidyup-branch/src/plugins/grass/grass_shell.png
___________________________________________________________________
   + application/octet-stream
Copied: branches/grass-tidyup-branch/src/plugins/grass/grass_split_line.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/grass_split_line.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_add_connection.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_add_connection.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_add_constant.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_add_constant.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_add_function.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_add_function.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_add_map.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_add_map.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_delete.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_delete.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_open.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_open.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_save.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_save.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_save_as.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_save_as.png)
Copied: branches/grass-tidyup-branch/src/plugins/grass/mapcalc_select.png (from rev 8807, branches/grass-tidyup-branch/src/plugins/grass/themes/default/mapcalc_select.png)
Modified: branches/grass-tidyup-branch/src/plugins/grass/qgsgrass_plugin.qrc
--- branches/grass-tidyup-branch/src/plugins/grass/qgsgrass_plugin.qrc	2008-07-17 21:40:23 UTC (rev 8811)
+++ branches/grass-tidyup-branch/src/plugins/grass/qgsgrass_plugin.qrc	2008-07-17 22:04:38 UTC (rev 8812)
@@ -1,16 +1,50 @@
 <RCC>
-    <qresource prefix="/grass" >
-        <file>add_raster.png</file>
-        <file>add_vector.png</file>
-        <file>clearInput.png</file>
-        <file>grass_close_mapset.png</file>
-        <file>grass_edit.png</file>
-        <file>grass_new_mapset.png</file>
-        <file>grass_new_vector_layer.png</file>
-        <file>grass_open_mapset.png</file>
-        <file>grass_region.png</file>
-        <file>grass_region_edit.png</file>
-        <file>grass_tools.png</file>
-        <file>world.png</file>
-    </qresource>
+  <qresource prefix="/grass" >
+    <file>add_raster.png</file>
+    <file>add_vector.png</file>
+    <file>clearInput.png</file>
+    <file>grass_add_map.png</file>
+    <file>grass_add_raster.png</file>
+    <file>grass_add_vector.png</file>
+    <file>grass_add_vertex.png</file>
+    <file>grass_browser_raster_layer.png</file>
+    <file>grass_browser_vector_layer.png</file>
+    <file>grass_close_edit.png</file>
+    <file>grass_close_mapset.png</file>
+    <file>grass_copy_map.png</file>
+    <file>grass_delete_line.png</file>
+    <file>grass_delete_map.png</file>
+    <file>grass_delete_vertex.png</file>
+    <file>grass_edit_attributes.png</file>
+    <file>grass_edit.png</file>
+    <file>grass_module_error.png</file>
+    <file>grass_module_warning.png</file>
+    <file>grass_move_line.png</file>
+    <file>grass_move_vertex.png</file>
+    <file>grass_new_boundary.png</file>
+    <file>grass_new_centroid.png</file>
+    <file>grass_new_line.png</file>
+    <file>grass_new_mapset.png</file>
+    <file>grass_new_point.png</file>
+    <file>grass_new_vector_layer.png</file>
+    <file>grass_open_mapset.png</file>
+    <file>grass_refresh.png</file>
+    <file>grass_region_edit.png</file>
+    <file>grass_region.png</file>
+    <file>grass_rename_map.png</file>
+    <file>grass_set_region.png</file>
+    <file>grass_shell.png</file>
+    <file>grass_split_line.png</file>
+    <file>grass_tools.png</file>
+    <file>mapcalc_add_connection.png</file>
+    <file>mapcalc_add_constant.png</file>
+    <file>mapcalc_add_function.png</file>
+    <file>mapcalc_add_map.png</file>
+    <file>mapcalc_delete.png</file>
+    <file>mapcalc_open.png</file>
+    <file>mapcalc_save_as.png</file>
+    <file>mapcalc_save.png</file>
+    <file>mapcalc_select.png</file>
+    <file>world.png</file>
+  </qresource>
 </RCC>
Modified: branches/grass-tidyup-branch/src/plugins/grass/qgsgrassplugin.cpp
--- branches/grass-tidyup-branch/src/plugins/grass/qgsgrassplugin.cpp	2008-07-17 21:40:23 UTC (rev 8811)
+++ branches/grass-tidyup-branch/src/plugins/grass/qgsgrassplugin.cpp	2008-07-17 22:04:38 UTC (rev 8812)
@@ -158,8 +158,8 @@
     tr("Add GRASS vector layer"), this);
   mAddRasterAction = new QAction(QIcon(":/grass/add_raster.png"),
     tr("Add GRASS raster layer"), this);
-  //mOpenToolsAction = new QAction(QIcon(":/grass/grass_tools.png"),
-  //  tr("Open GRASS tools"), this);
+  mOpenShellAction = new QAction(QIcon(":/grass/grass_tools.png"),
+    tr("Open GRASS shell"), this);
   mRegionAction = new QAction(QIcon(":/grass/grass_region.png"),
     tr("Display Current Grass Region"), this);
@@ -173,7 +173,7 @@
   mAddVectorAction->setWhatsThis(tr("Adds a GRASS vector layer to the map canvas"));
   mAddRasterAction->setWhatsThis(tr("Adds a GRASS raster layer to the map canvas"));
-  //mOpenToolsAction->setWhatsThis(tr("Open GRASS tools"));
+  mOpenShellAction->setWhatsThis(tr("Open GRASS shell"));
   mRegionAction->setWhatsThis(tr("Displays the current GRASS region as a rectangle on the map canvas"));
   mEditRegionAction->setWhatsThis(tr("Edit the current GRASS region"));
   mEditAction->setWhatsThis(tr("Edit the currently selected GRASS vector layer."));
@@ -181,7 +181,7 @@
   // Connect the action
   connect(mAddVectorAction, SIGNAL(triggered()), this, SLOT(addVector()));
   connect(mAddRasterAction, SIGNAL(triggered()), this, SLOT(addRaster()));
-  //connect(mOpenToolsAction, SIGNAL(triggered()), this, SLOT(openTools()));
+  connect(mOpenShellAction, SIGNAL(triggered()), this, SLOT(openShell()));
   connect(mEditAction, SIGNAL(triggered()), this, SLOT(edit()));
   connect(mNewVectorAction, SIGNAL(triggered()), this, SLOT(newVector()));
   connect(mRegionAction, SIGNAL(toggled(bool)), this, SLOT(switchRegion(bool)));
@@ -198,7 +198,7 @@
   qGisInterface->addPluginMenu(tr("&GRASS"), mAddRasterAction);
   qGisInterface->addPluginMenu(tr("&GRASS"), mNewVectorAction);
   qGisInterface->addPluginMenu(tr("&GRASS"), mEditAction);
-  //qGisInterface->addPluginMenu(tr("&GRASS"), mOpenToolsAction);
+  qGisInterface->addPluginMenu(tr("&GRASS"), mOpenShellAction);
   qGisInterface->addPluginMenu(tr("&GRASS"), mRegionAction);
   qGisInterface->addPluginMenu(tr("&GRASS"), mEditRegionAction);
@@ -216,7 +216,7 @@
   mAddRasterAction->addTo(toolBarPointer);
   mNewVectorAction->addTo(toolBarPointer);
   mEditAction->addTo(toolBarPointer);
-  //mOpenToolsAction->addTo(toolBarPointer);
+  mOpenShellAction->addTo(toolBarPointer);
   mRegionAction->addTo(toolBarPointer);
   mEditRegionAction->addTo(toolBarPointer);
@@ -240,7 +240,7 @@
   if ( !QgsGrass::activeMode() )
-    //mOpenToolsAction->setEnabled(false);
+    //mOpenShellAction->setEnabled(false);
     mRegionAction->setEnabled(false);
     mEditRegionAction->setEnabled(false);
     mRegionBand->reset();
@@ -257,7 +257,7 @@
   else
-    //mOpenToolsAction->setEnabled(true);
+    mOpenShellAction->setEnabled(true);
     mRegionAction->setEnabled(true);
     mEditRegionAction->setEnabled(true);
     mCloseMapsetAction->setEnabled(true);
@@ -412,7 +412,10 @@
     qGisInterface->addRasterLayer(uri, sel->map);
+void QgsGrassPlugin::openShell()
+  QMessageBox::warning( 0, tr("Info"), tr("If I was a shell you would sea me...ssssshweessshh.") );
 // Open tools
 void QgsGrassPlugin::openTools()
@@ -797,7 +800,7 @@
   qGisInterface->removePluginMenu(tr("&GRASS"), mCloseMapsetAction);
   qGisInterface->removePluginMenu(tr("&GRASS"), mAddVectorAction);
   qGisInterface->removePluginMenu(tr("&GRASS"), mAddRasterAction);
-  qGisInterface->removePluginMenu(tr("&GRASS"), mOpenToolsAction);
+  qGisInterface->removePluginMenu(tr("&GRASS"), mOpenShellAction);
   qGisInterface->removePluginMenu(tr("&GRASS"), mRegionAction);
   qGisInterface->removePluginMenu(tr("&GRASS"), mEditRegionAction);
   qGisInterface->removePluginMenu(tr("&GRASS"), mEditAction);
@@ -808,7 +811,7 @@
   delete mCloseMapsetAction;
   delete mAddVectorAction;
   delete mAddRasterAction;
-  delete mOpenToolsAction;
+  delete mOpenShellAction;
   delete mRegionAction;
   delete mEditRegionAction;
   delete mEditAction;
Modified: branches/grass-tidyup-branch/src/plugins/grass/qgsgrassplugin.h
--- branches/grass-tidyup-branch/src/plugins/grass/qgsgrassplugin.h	2008-07-17 21:40:23 UTC (rev 8811)
+++ branches/grass-tidyup-branch/src/plugins/grass/qgsgrassplugin.h	2008-07-17 22:04:38 UTC (rev 8812)
@@ -98,6 +98,8 @@
   void redrawRegion(void);
   //! Post render
   void postRender(QPainter *);
+  //! Open GRASS shell
+  void openShell();
   //! Open tools
   void openTools(void);
   //! Create new mapset
@@ -155,7 +157,7 @@
   QAction *mCloseMapsetAction;
   QAction *mAddVectorAction;
   QAction *mAddRasterAction;
-  QAction *mOpenToolsAction;
+  QAction *mOpenShellAction;
   QAction *mEditRegionAction;
   QAction *mEditAction;
   QAction *mNewVectorAction;
More information about the QGIS-commit mailing list
