[QGIS Commit] r8954 - in trunk/qgis: python/gui src/app src/gui
src/ui tests/src/core
svn_qgis at osgeo.org
Thu Jul 31 16:07:07 EDT 2008
Author: timlinux
Date: 2008-07-31 16:07:07 -0400 (Thu, 31 Jul 2008)
New Revision: 8954
trunk/qgis/python/gui/qgsprojectionselector.sip
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsprojectproperties.cpp
trunk/qgis/src/gui/qgsprojectionselector.cpp
trunk/qgis/src/gui/qgsprojectionselector.h
trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui
trunk/qgis/src/ui/qgsprojectionselectorbase.ui
trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
trunk/qgis/tests/src/core/qgsrenderchecker.cpp
Fix for ticket #15 (Use term CRS instead of Projection throughout. Note this is a cosmetic fix only - internally class and var names still use the incorrect 'projection' nomenclature
Modified: trunk/qgis/python/gui/qgsprojectionselector.sip
--- trunk/qgis/python/gui/qgsprojectionselector.sip 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/python/gui/qgsprojectionselector.sip 2008-07-31 20:07:07 UTC (rev 8954)
@@ -41,7 +41,6 @@
void applyProjList(QSet<QString> * crsFilter = 0);
- void updateProjAndEllipsoidAcronyms(int theSrsid, QString theProj4String);
* \brief Make the string safe for use in SQL statements.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-07-31 20:07:07 UTC (rev 8954)
@@ -661,9 +661,9 @@
mActionOptions->setStatusTip(tr("Change various QGIS options"));
connect(mActionOptions, SIGNAL(triggered()), this, SLOT(options()));
- mActionCustomProjection= new QAction(getThemeIcon("/mActionCustomProjection.png"), tr("Custom Projection..."), this);
+ mActionCustomProjection= new QAction(getThemeIcon("/mActionCustomProjection.png"), tr("Custom CRS..."), this);
// mActionCustomProjection->setShortcut(tr("Alt+I","Manage custom projections"));
- mActionCustomProjection->setStatusTip(tr("Manage custom projections"));
+ mActionCustomProjection->setStatusTip(tr("Manage custom coordinate reference systems"));
connect(mActionCustomProjection, SIGNAL(triggered()), this, SLOT(customProjection()));
// Help Menu Related items
@@ -1237,10 +1237,11 @@
exit(0);
mOnTheFlyProjectionStatusButton->setWhatsThis(tr("This icon shows whether "
- "on the fly projection is enabled or not. Click the icon to bring up "
+ "on the fly coordinate reference system transformation is enabled or not. "
+ "Click the icon to bring up "
"the project properties dialog to alter this behaviour."));
- mOnTheFlyProjectionStatusButton->setToolTip(tr("Projection status - Click "
- "to open projection dialog"));
+ mOnTheFlyProjectionStatusButton->setToolTip(tr("CRS status - Click "
+ "to open coordinate reference system dialog"));
connect(mOnTheFlyProjectionStatusButton, SIGNAL(clicked()),
this, SLOT(projectPropertiesProjections()));//bring up the project props dialog when clicked
statusBar()->addPermanentWidget(mOnTheFlyProjectionStatusButton,0);
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp 2008-07-31 20:07:07 UTC (rev 8954)
@@ -59,7 +59,6 @@
bool myProjectionEnabled = myRender->projectionsEnabled();
cbxProjectionEnabled->setChecked(myProjectionEnabled);
- // set the default wkt to WGS 84
long mySRSID = myRender->destinationSrs().srsid();
QgsDebugMsg("Read project SRSID: " + QString::number(mySRSID));
projectionSelector->setSelectedSRSID(mySRSID);
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp 2008-07-31 20:07:07 UTC (rev 8954)
@@ -27,7 +27,12 @@
#include <QTextStream>
#include <QHeaderView>
#include <QResizeEvent>
+#include <QMessageBox>
+const int NAME_COLUMN=0;
+const int EPSG_COLUMN=1;
+const int QGIS_SRS_ID_COLUMN=2;
QgsProjectionSelector::QgsProjectionSelector(QWidget* parent,
const char * name,
Qt::WFlags fl)
@@ -45,7 +50,9 @@
// Get the full path name to the sqlite3 spatial reference database.
mSrsDatabaseFileName = QgsApplication::srsDbFilePath();
- lstCoordinateSystems->header()->setResizeMode(1,QHeaderView::Stretch);
+ lstCoordinateSystems->header()->setResizeMode(EPSG_COLUMN,QHeaderView::Stretch);
+ lstCoordinateSystems->header()->resizeSection(QGIS_SRS_ID_COLUMN,0);
+ lstCoordinateSystems->header()->setResizeMode(QGIS_SRS_ID_COLUMN,QHeaderView::Fixed);
@@ -56,8 +63,9 @@
void QgsProjectionSelector::resizeEvent ( QResizeEvent * theEvent )
- lstCoordinateSystems->header()->resizeSection(0,(theEvent->size().width()-120));
- lstCoordinateSystems->header()->resizeSection(1,120);
+ lstCoordinateSystems->header()->resizeSection(NAME_COLUMN,(theEvent->size().width()-120));
+ lstCoordinateSystems->header()->resizeSection(EPSG_COLUMN,120);
void QgsProjectionSelector::showEvent ( QShowEvent * theEvent )
@@ -223,7 +231,7 @@
QString mySRSIDString = QString::number(mSRSIDSelection);
- QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems(mySRSIDString, Qt::MatchExactly|Qt::MatchRecursive, 1);
+ QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems(mySRSIDString, Qt::MatchExactly|Qt::MatchRecursive, QGIS_SRS_ID_COLUMN);
if (nodes.count() > 0)
@@ -268,10 +276,10 @@
if(myItem)
- if(myItem->text(1).length() > 0)
+ if(myItem->text(QGIS_SRS_ID_COLUMN).length() > 0)
QString myDatabaseFileName;
- QString mySrsId = myItem->text(1);
+ QString mySrsId = myItem->text(QGIS_SRS_ID_COLUMN);
QgsDebugMsg("mySrsId = " + mySrsId);
QgsDebugMsg("USER_PROJECTION_START_ID = " + QString::number(USER_PROJECTION_START_ID));
@@ -306,10 +314,8 @@
rc = sqlite3_open(myDatabaseFileName.toUtf8().data(), &db);
if(rc)
- QgsLogger::warning("Can't open database: " + QString(sqlite3_errmsg(db)));
- // XXX This will likely never happen since on open, sqlite creates the
- // database if it does not exist.
- assert(rc == 0);
+ showDBMissingWarning(myDatabaseFileName );
+ return QString("");
// prepare the sql statement
const char *pzTail;
@@ -333,10 +339,6 @@
sqlite3_finalize(ppStmt);
// close the database
sqlite3_close(db);
-#ifdef QGISDEBUG
- std::cout << "Item selected : " << myItem->text(0).toLocal8Bit().data() << std::endl;
- std::cout << "Item selected full string : " << myProjString.toLocal8Bit().data() << std::endl;
-#endif
assert(myProjString.length() > 0);
return myProjString;
@@ -366,14 +368,14 @@
if(lvi)
// Make sure the selected node is a srs and not a top-level projection node
- if(lvi->text(1).length() > 0)
+ if(lvi->text(QGIS_SRS_ID_COLUMN).length() > 0)
// Determine if this is a user projection or a system on
// user projection defs all have srs_id >= 100000
- if (lvi->text(1).toLong() >= USER_PROJECTION_START_ID)
+ if (lvi->text(QGIS_SRS_ID_COLUMN).toLong() >= USER_PROJECTION_START_ID)
myDatabaseFileName = QgsApplication::qgisUserDbFilePath();
QFileInfo myFileInfo;
@@ -398,10 +400,8 @@
if(rc)
- std::cout << "Can't open database: " << sqlite3_errmsg(db) << std::endl;
- assert(rc == 0);
+ return 0;
const char *pzTail;
@@ -409,7 +409,7 @@
QString sql = "select ";
sql += attributeName;
sql += " from tbl_srs where srs_id = ";
- sql += lvi->text(1);
+ sql += lvi->text(QGIS_SRS_ID_COLUMN);
#ifdef QGISDEBUG
std::cout << "Finding selected attribute using : " << sql.toLocal8Bit().data() << std::endl;
@@ -456,9 +456,9 @@
QTreeWidgetItem* item = lstCoordinateSystems->currentItem();
- if(item != NULL && item->text(1).length() > 0)
+ if(item != NULL && item->text(QGIS_SRS_ID_COLUMN).length() > 0)
- return lstCoordinateSystems->currentItem()->text(1).toLong();
+ return lstCoordinateSystems->currentItem()->text(QGIS_SRS_ID_COLUMN).toLong();
else
@@ -487,7 +487,7 @@
// User defined coordinate system node
// Make in an italic font to distinguish them from real projections
- mUserProjList = new QTreeWidgetItem(lstCoordinateSystems,QStringList("User Defined Coordinate Systems"));
+ mUserProjList = new QTreeWidgetItem(lstCoordinateSystems,QStringList(tr("User Defined Coordinate Systems")));
QFont fontTemp = mUserProjList->font(0);
fontTemp.setItalic(TRUE);
@@ -519,22 +519,19 @@
myResult = sqlite3_open(QString(myDatabaseFileName).toUtf8().data(), &myDatabase);
if(myResult)
- std::cout << "Can't open database: " << sqlite3_errmsg(myDatabase) << std::endl;
// database if it does not exist. But we checked earlier for its existance
// and aborted in that case. This is because we may be runnig from read only
// media such as live cd and dont want to force trying to create a db.
- assert(myResult == 0);
+ return;
// Set up the query to retrieve the projection information needed to populate the list
- QString mySql = "select description, srs_id, is_geo, name, parameters from vw_srs ";
+ QString mySql = "select description, srs_id, epsg, is_geo, name, parameters from vw_srs ";
mySql += "where ";
mySql += sqlFilter;
-#ifdef QGISDEBUG
- std::cout << "User projection list sql" << mySql.toLocal8Bit().data() << std::endl;
-#endif
myResult = sqlite3_prepare(myDatabase, mySql.toUtf8(), mySql.length(), &myPreparedStatement, &myTail);
// XXX Need to free memory from the error msg if one is set
if(myResult == SQLITE_OK)
@@ -543,8 +540,10 @@
while(sqlite3_step(myPreparedStatement) == SQLITE_ROW)
newItem = new QTreeWidgetItem(mUserProjList, QStringList(QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,0))));
- // display the qgis srs_id in the second column of the list view
- newItem->setText(1,QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement, 1)));
+ // display the epsg (field 2) in the second column of the list view
+ newItem->setText(EPSG_COLUMN,QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,2 )));
+ // display the qgis srs_id (field 1) in the third column of the list view
+ newItem->setText(QGIS_SRS_ID_COLUMN,QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement, 1)));
// close the sqlite3 statement
@@ -563,14 +562,14 @@
// Geographic coordinate system node
- mGeoList = new QTreeWidgetItem(lstCoordinateSystems,QStringList("Geographic Coordinate Systems"));
+ mGeoList = new QTreeWidgetItem(lstCoordinateSystems,QStringList(tr("Geographic Coordinate Systems")));
QFont fontTemp = mGeoList->font(0);
mGeoList->setFont(0, fontTemp);
// Projected coordinate system node
- mProjList = new QTreeWidgetItem(lstCoordinateSystems,QStringList("Projected Coordinate Systems"));
+ mProjList = new QTreeWidgetItem(lstCoordinateSystems,QStringList(tr("Projected Coordinate Systems")));
fontTemp = mProjList->font(0);
@@ -595,10 +594,10 @@
rc = sqlite3_open(mSrsDatabaseFileName.toUtf8().data(), &db);
if(rc)
- assert(rc == 0);
+ showDBMissingWarning(mSrsDatabaseFileName );
+ return ;
const char *pzTail;
@@ -610,31 +609,20 @@
assert(rc == SQLITE_OK);
sqlite3_step(ppStmt);
-#ifdef QGISDEBUG
- int myEntriesCount = sqlite3_column_int(ppStmt, 0);
- std::cout << "Projection entries found in srs.db: " << myEntriesCount << std::endl;
-#endif
// Set up the query to retreive the projection information needed to populate the list
//note I am giving the full field names for clarity here and in case someown
//changes the underlying view TS
- sql = "select description, srs_id, is_geo, name, parameters from vw_srs ";
+ sql = "select description, srs_id, epsg, is_geo, name, parameters from vw_srs ";
sql += "where ";
sql += sqlFilter;
sql += " order by name, description";
-#ifdef QGISDEBUG
- std::cout << "SQL for projection list:\n" << sql.toLocal8Bit().data() << std::endl;
-#endif
rc = sqlite3_prepare(db, sql.toUtf8(), sql.length(), &ppStmt, &pzTail);
if(rc == SQLITE_OK)
-#ifdef QGISDEBUG
- std::cout << "SQL for projection list executed ok..." << std::endl;
-#endif
QTreeWidgetItem *newItem;
// Cache some stuff to speed up creating of the list of projected
// spatial reference systems
@@ -648,59 +636,57 @@
if(isGeo)
// this is a geographic coordinate system
- // Add it to the tree
+ // Add it to the tree (field 0)
newItem = new QTreeWidgetItem(mGeoList, QStringList(QString::fromUtf8((char *)sqlite3_column_text(ppStmt,0))));
- newItem->setText(1,QString::fromUtf8((char *)sqlite3_column_text(ppStmt, 1)));
+ newItem->setText(EPSG_COLUMN,QString::fromUtf8((char *)sqlite3_column_text(ppStmt, 2)));
+ newItem->setText(QGIS_SRS_ID_COLUMN,QString::fromUtf8((char *)sqlite3_column_text(ppStmt, 1)));
else
// This is a projected srs
- QTreeWidgetItem *node;
- QString srsType = QString::fromUtf8((char*)sqlite3_column_text(ppStmt, 3));
+ QTreeWidgetItem *node;
+ QString srsType = QString::fromUtf8((char*)sqlite3_column_text(ppStmt, 3));
// Find the node for this type and add the projection to it
// If the node doesn't exist, create it
- if (srsType == previousSrsType)
- node = previousSrsTypeNode;
- else
- { // Different from last one, need to search
- QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems(srsType,Qt::MatchExactly|Qt::MatchRecursive,0);
- if(nodes.count() == 0)
- // the node doesn't exist -- create it
+ if (srsType == previousSrsType)
+ node = previousSrsTypeNode;
+ else
+ { // Different from last one, need to search
+ QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems(srsType,Qt::MatchExactly|Qt::MatchRecursive,0);
+ if(nodes.count() == 0)
+ // the node doesn't exist -- create it
- node = new QTreeWidgetItem(mProjList, QStringList(srsType));
+ node = new QTreeWidgetItem(mProjList, QStringList(srsType));
QFont fontTemp = node->font(0);
node->setFont(0, fontTemp);
- else
- node = nodes.first();
- // Update the cache.
- previousSrsType = srsType;
- previousSrsTypeNode = node;
+ else
+ node = nodes.first();
+ // Update the cache.
+ previousSrsType = srsType;
+ previousSrsTypeNode = node;
// add the item, setting the projection name in the first column of the list view
newItem = new QTreeWidgetItem(node, QStringList(QString::fromUtf8((char *)sqlite3_column_text(ppStmt,0))));
- // set the srs_id in the second column on the list view
- //Only enable thse lines temporarily if you want to generate a script
- //to update proj an ellipoid fields in the srs.db
- //updateProjAndEllipsoidAcronyms(QString::fromUtf8((char *)sqlite3_column_text(ppStmt, 1)).toLong(),
- // QString::fromUtf8((char *)sqlite3_column_text(ppStmt, 4))) ;
-#ifdef QGISDEBUG
- std::cout << "Size of projection list widget : " << sizeof(*lstCoordinateSystems) << std::endl;
-#endif
@@ -709,69 +695,7 @@
mProjListDone = TRUE;
-//this is a little helper function to populate the (well give you a sql script to populate)
-//the projection_acronym and ellipsoid_acronym fields in the srs.db backend
-//To cause it to be run, uncomment or add the line:
-// updateProjAndEllipsoidAcronyms(QString::fromUtf8((char *)sqlite3_column_text(ppStmt, 1)).toLong(),
-// QString:.fromUtf8((char *)sqlite3_column_text(ppStmt, 4))) ;
-//to the above method. NOTE it will cause a huge slow down in population of the proj selector dialog so
-//remember to disable it again!
-void QgsProjectionSelector::updateProjAndEllipsoidAcronyms(int theSrsid,QString theProj4String)
- //temporary hack
- QFile myFile( "/tmp/srs_updates.sql" );
- myFile.open( QIODevice::WriteOnly | QIODevice::Append );
- QTextStream myStream( &myFile );
- QRegExp myProjRegExp( "proj=[a-zA-Z]* " );
- int myStart= 0;
- int myLength=0;
- myStart = myProjRegExp.indexIn(theProj4String, myStart);
- QString myProjectionAcronym;
- if (myStart==-1)
- std::cout << "proj string supplied has no +proj argument" << std::endl;
- myProjectionAcronym = "";
- else
- myLength = myProjRegExp.matchedLength();
- myProjectionAcronym = theProj4String.mid(myStart+PROJ_PREFIX_LEN,myLength-(PROJ_PREFIX_LEN+1));//+1 for space
- QRegExp myEllipseRegExp( "ellps=[a-zA-Z0-9\\-]* " );
- myStart= 0;
- myLength=0;
- myStart = myEllipseRegExp.indexIn(theProj4String, myStart);
- QString myEllipsoidAcronym;
- if (myStart==-1)
- std::cout << "proj string supplied has no +ellps argument" << std::endl;
- myEllipsoidAcronym="";
- else
- myLength = myEllipseRegExp.matchedLength();
- myEllipsoidAcronym = theProj4String.mid(myStart+ELLPS_PREFIX_LEN,myLength-(ELLPS_PREFIX_LEN+1));
- //now create the update statement
- QString mySql = "update tbl_srs set projection_acronym='" + myProjectionAcronym +
- "', ellipsoid_acronym='" + myEllipsoidAcronym + "' where " +
- "srs_id=" + QString::number(theSrsid)+";";
- //tmporary hack
- myStream << mySql << "\n";
- myFile.close();
- //std::cout
// New coordinate system selected from the list
void QgsProjectionSelector::coordinateSystemSelected( QTreeWidgetItem * theItem)
@@ -780,17 +704,11 @@
if (theItem != NULL && theItem->childCount() == 0)
// Found a real SRS
- QString myDescription = tr("QGIS SRSID: ") + QString::number(getCurrentSRSID()) +"\n";
- myDescription += tr("PostGIS SRID: ") + QString::number(getCurrentSRID()) +"\n";
+ QString myDescription;
emit sridSelected(QString::number(getCurrentSRSID()));
QString myProjString = getCurrentProj4String();
- if (!myProjString.isNull())
- myDescription+=(myProjString);
lstCoordinateSystems->scrollToItem(theItem);
- teProjection->setText(myDescription);
+ teProjection->setText(myProjString);
else
@@ -810,12 +728,8 @@
QString mySearchString(stringSQLSafe(leSearch->text()));
QString mySql;
- if (radSRID->isChecked())
+ if (radEPSGID->isChecked())
- mySql= "select srs_id from tbl_srs where srid=" + mySearchString;
- else if (radEPSGID->isChecked())
mySql= "select srs_id from tbl_srs where epsg=" + mySearchString;
else if (radName->isChecked()) //name search
@@ -843,12 +757,6 @@
" and srs_id > " + QString::number(getCurrentSRSID()) + " order by srs_id limit 1";
- else //qgis srsid
- //no need to try too look up srsid in db as user has already entered it!
- setSelectedSRSID(mySearchString.toLong());
- return;
#ifdef QGISDEBUG
std::cout << " Search sql: " << mySql.toLocal8Bit().data() << std::endl;
#endif
@@ -865,12 +773,12 @@
myResult = sqlite3_open(mSrsDatabaseFileName.toUtf8().data(), &myDatabase);
if(myResult)
+ return;
@@ -945,12 +853,12 @@
myResult = sqlite3_open(myDatabaseFileName.toUtf8().data(), &myDatabase);
if(myResult)
+ return 0;
else
@@ -1016,3 +924,12 @@
myRetval.replace("%","\\%");
return myRetval;
+const void QgsProjectionSelector::showDBMissingWarning(const QString theFileName)
+ QMessageBox::critical(this, tr("Resource Location Error"),
+ tr("Error reading database file from: \n %1\n"
+ "Because of this the projection selector will not work...")
+ .arg(theFileName));
Modified: trunk/qgis/src/gui/qgsprojectionselector.h
--- trunk/qgis/src/gui/qgsprojectionselector.h 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/src/gui/qgsprojectionselector.h 2008-07-31 20:07:07 UTC (rev 8954)
@@ -52,7 +52,6 @@
@@ -156,6 +155,8 @@
long getCurrentLongAttribute(QString attributeName);
+ /** Show the user a warning if the srs database could not be found */
+ const void showDBMissingWarning(const QString theFileName);
// List view nodes for the tree view of projections
//! User defined projections node
QTreeWidgetItem *mUserProjList;
Modified: trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui
--- trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui 2008-07-31 20:07:07 UTC (rev 8954)
@@ -10,7 +10,7 @@
</rect>
</property>
<property name="windowTitle" >
- <string>Custom Projection Definition</string>
+ <string>Custom Coordinate Reference System Definition</string>
</property>
<property name="windowIcon" >
<iconset/>
@@ -25,7 +25,7 @@
<item row="0" column="0" colspan="2" >
<widget class="QLabel" name="label" >
<property name="text" >
- <string>You can define your own custom projection here. The definition must conform to the proj4 format for specifying a Spatial Reference System.</string>
+ <string>You can define your own custom Coordinate Reference System (CRS) here. The definition must conform to the proj4 format for specifying a CRS.</string>
</property>
<property name="wordWrap" >
<bool>true</bool>
@@ -154,7 +154,7 @@
<item row="0" column="0" colspan="3" >
<widget class="QLabel" name="label_2" >
- <string>Use the text boxes below to test the projection definition you are creating. Enter a coordinate where both the lat/long and the projected result are known (for example by reading off a map). Then press the calculate button to see if the projection definition you are creating is accurate.</string>
+ <string>Use the text boxes below to test the CRS definition you are creating. Enter a coordinate where both the lat/long and the transformed result are known (for example by reading off a map). Then press the calculate button to see if the CRS definition you are creating is accurate.</string>
</property>
<bool>true</bool>
@@ -184,7 +184,7 @@
<item row="2" column="2" >
<widget class="QLabel" name="textLabel2_3" >
- <string>Projected Coordinate System</string>
+ <string>Destination CRS </string>
</property>
</widget>
</item>
Modified: trunk/qgis/src/ui/qgsprojectionselectorbase.ui
--- trunk/qgis/src/ui/qgsprojectionselectorbase.ui 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/src/ui/qgsprojectionselectorbase.ui 2008-07-31 20:07:07 UTC (rev 8954)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>468</width>
- <height>428</height>
+ <width>457</width>
+ <height>403</height>
</rect>
</property>
<property name="sizePolicy" >
@@ -16,218 +16,150 @@
</sizepolicy>
</property>
- <string>Projection Selector</string>
+ <string>Coordinate Reference System Selector</string>
</property>
<iconset/>
</property>
<layout class="QGridLayout" >
<property name="leftMargin" >
- <number>0</number>
+ <number>3</number>
</property>
<property name="topMargin" >
</property>
<property name="rightMargin" >
</property>
<property name="bottomMargin" >
</property>
- <property name="horizontalSpacing" >
- </property>
- <property name="verticalSpacing" >
- </property>
<item row="0" column="0" >
- <widget class="QGroupBox" name="groupBox_2" >
+ <widget class="QTreeWidget" name="lstCoordinateSystems" >
+ <property name="alternatingRowColors" >
+ <bool>true</bool>
+ </property>
+ <property name="uniformRowHeights" >
+ <bool>true</bool>
+ </property>
+ <property name="columnCount" >
+ </property>
+ <column>
+ <property name="text" >
+ <string>Coordinate Reference System</string>
+ </property>
+ </column>
+ <column>
+ <string>EPSG</string>
+ </property>
+ </column>
+ <column>
+ <string>ID</string>
+ </property>
+ </column>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QTextEdit" name="teProjection" >
<sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
+ <property name="minimumSize" >
+ <size>
+ <width>0</width>
+ <height>100</height>
+ </size>
+ </property>
+ <property name="maximumSize" >
+ <size>
+ <width>16777215</width>
+ </size>
+ </property>
+ <property name="autoFormatting" >
+ <set>QTextEdit::AutoBulletList</set>
+ </property>
+ <property name="readOnly" >
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0" >
+ <widget class="QGroupBox" name="groupBox" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Minimum" hsizetype="MinimumExpanding" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
<property name="title" >
- <string>Projection</string>
+ <string>Search</string>
</property>
- <property name="leftMargin" >
- <number>12</number>
- </property>
- <property name="topMargin" >
- </property>
- <property name="rightMargin" >
- </property>
- <property name="bottomMargin" >
- </property>
- </property>
- </property>
- <item row="2" column="0" >
- <widget class="QGroupBox" name="groupBox" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Minimum" hsizetype="MinimumExpanding" >
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
+ <item row="0" column="0" >
+ <widget class="QRadioButton" name="radEPSGID" >
+ <string>EPSG ID</string>
</property>
- <property name="title" >
- <string>Search</string>
+ <property name="iconSize" >
+ <size>
+ <width>16</width>
+ <height>10</height>
+ </size>
</property>
- <layout class="QGridLayout" >
- <number>2</number>
- </property>
- </property>
- </property>
- </property>
- <number>3</number>
- </property>
- </property>
- <item row="1" column="3" >
- <widget class="QPushButton" name="pbnFind" >
- <property name="maximumSize" >
- <size>
- <width>100</width>
- <height>16777215</height>
- </size>
- </property>
- <property name="text" >
- <string>Find</string>
- </property>
- <property name="default" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item row="1" column="0" colspan="3" >
- <widget class="QLineEdit" name="leSearch" />
- </item>
- <item row="0" column="3" >
- <widget class="QRadioButton" name="radName" >
- <string>Name</string>
- </property>
- <property name="iconSize" >
- <size>
- <width>16</width>
- <height>10</height>
- </size>
- </property>
- </widget>
- </item>
- <item row="0" column="2" >
- <widget class="QRadioButton" name="radSRSID" >
- <string>QGIS SRSID</string>
- </property>
- <size>
- <width>16</width>
- </size>
- </property>
- </widget>
- </item>
- <item row="0" column="1" >
- <widget class="QRadioButton" name="radEPSGID" >
- <string>EPSG ID</string>
- </property>
- <size>
- <width>16</width>
- </size>
- </property>
- </widget>
- </item>
- <item row="0" column="0" >
- <widget class="QRadioButton" name="radSRID" >
- <string>Postgis SRID</string>
- </property>
- <size>
- <width>16</width>
- </size>
- </property>
- <property name="checked" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- </layout>
</widget>
</item>
- <item row="1" column="0" >
- <widget class="QTextEdit" name="teProjection" >
- <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
- </sizepolicy>
+ <item row="0" column="1" >
+ <widget class="QRadioButton" name="radName" >
+ <string>Name</string>
</property>
- <property name="minimumSize" >
<size>
- <width>0</width>
- <height>100</height>
+ <width>16</width>
</size>
</property>
+ </widget>
+ </item>
+ <item row="0" column="2" colspan="2" >
+ <spacer>
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" >
+ <size>
+ <width>231</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="1" column="0" colspan="3" >
+ <widget class="QLineEdit" name="leSearch" />
+ </item>
+ <item row="1" column="3" >
+ <widget class="QPushButton" name="pbnFind" >
<size>
- <width>16777215</width>
+ <width>100</width>
+ <height>16777215</height>
</size>
</property>
- <property name="autoFormatting" >
- <set>QTextEdit::AutoBulletList</set>
+ <string>Find</string>
</property>
- <property name="readOnly" >
+ <property name="default" >
<bool>true</bool>
</property>
</widget>
</item>
- <widget class="QTreeWidget" name="lstCoordinateSystems" >
- <property name="alternatingRowColors" >
- <bool>true</bool>
- </property>
- <property name="uniformRowHeights" >
- <bool>true</bool>
- </property>
- <property name="columnCount" >
- </property>
- <column>
- <string>Spatial Reference System</string>
- </property>
- </column>
- <column>
- <string>Id</string>
- </property>
- </column>
- </widget>
- </item>
</layout>
</widget>
</item>
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2008-07-31 20:07:07 UTC (rev 8954)
@@ -279,17 +279,17 @@
</widget>
<widget class="QWidget" name="tab2" >
<attribute name="title" >
+ <string>Coordinate Reference System (CRS)</string>
</attribute>
- <number>11</number>
</property>
<number>11</number>
</property>
</property>
<number>11</number>
@@ -297,7 +297,7 @@
<widget class="QCheckBox" name="cbxProjectionEnabled" >
- <string>Enable on the fly projection</string>
+ <string>Enable 'on the fly' CRS transformation</string>
</property>
</widget>
</item>
Modified: trunk/qgis/tests/src/core/qgsrenderchecker.cpp
--- trunk/qgis/tests/src/core/qgsrenderchecker.cpp 2008-07-31 09:19:47 UTC (rev 8953)
+++ trunk/qgis/tests/src/core/qgsrenderchecker.cpp 2008-07-31 20:07:07 UTC (rev 8954)
@@ -56,7 +56,8 @@
QImage myImage( myExpectedImage.width() , myExpectedImage.height(), QImage::Format_RGB32 );
myImage.fill ( qRgb( 152,219,249 ) );
QPainter myPainter( &myImage );
- mpMapRenderer->setOutputSize( QSize ( myExpectedImage.width(),myExpectedImage.height() ),72 );
+ mpMapRenderer->setOutputSize( QSize (
+ myExpectedImage.width(),myExpectedImage.height() ),myExpectedImage.logicalDpiX() );
QTime myTime;
myTime.start();
mpMapRenderer->render( &myPainter );
