[QGIS Commit] r8586 - trunk/qgis/src/app
svn_qgis at osgeo.org
Wed Jun 4 11:00:23 EDT 2008
Author: jef
Date: 2008-06-04 11:00:23 -0400 (Wed, 04 Jun 2008)
New Revision: 8586
trunk/qgis/src/app/qgsdbsourceselect.cpp
strip current schema from selected tables to match postgres provider behaviour
Modified: trunk/qgis/src/app/qgsdbsourceselect.cpp
--- trunk/qgis/src/app/qgsdbsourceselect.cpp 2008-06-04 10:03:07 UTC (rev 8585)
+++ trunk/qgis/src/app/qgsdbsourceselect.cpp 2008-06-04 15:00:23 UTC (rev 8586)
@@ -247,6 +247,14 @@
m_selectedTables.clear();
+ QString currentSchema;
+ QString sql = "select current_schema()";
+ PGresult *result = PQexec(pd, sql.toUtf8());
+ if (result && PQresultStatus(result)==PGRES_TUPLES_OK && PQntuples(result)==1 )
+ currentSchema = QString::fromUtf8(PQgetvalue(result, 0, 0));
typedef QMap<int, QVector<QString> > schemaInfo;
QMap<QString, schemaInfo> dbInfo;
@@ -282,7 +290,7 @@
//now traverse all the schemas and table infos
- QString schemaName, tableName, geomColumnName, sql;
+ QString schemaName, tableName, geomColumnName;
QString query;
QMap<QString, schemaInfo>::const_iterator schema_it = dbInfo.constBegin();
@@ -324,7 +332,14 @@
continue;
- query = "\"" + schemaName + "\".\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
+ if(schemaName!=currentSchema)
+ query += "\"" + schemaName + "\".";
+ query += "\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
m_selectedTables.push_back(query);
