[QGIS Commit] r8648 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sun Jun 15 14:37:58 EDT 2008
Author: timlinux
Date: 2008-06-15 14:37:57 -0400 (Sun, 15 Jun 2008)
New Revision: 8648
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
Added global proxy configuration to options dialog. Use the follow qsettings keys to obtain proxy configs: proxy/proxyEnabled, proxy/proxyHost, proxy/proxyPort, proxy/proxyUser and proxy/proxyPassword. Note that the proxy password is not encrypted in any way when stored in Qt config file / win registry.
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2008-06-11 15:08:07 UTC (rev 8647)
+++ trunk/qgis/src/app/qgsoptions.cpp 2008-06-15 18:37:57 UTC (rev 8648)
@@ -61,6 +61,12 @@
#endif
spinBoxIdentifyValue->setValue(identifyValue);
+ //Web proxy settings
+ grpProxy->setChecked(settings.value("proxy/proxyEnabled", "0").toBool());
+ leProxyHost->setText(settings.value("proxy/proxyHost", "").toString());
+ leProxyPort->setText(settings.value("proxy/proxyPort", "").toString());
+ leProxyUser->setText(settings.value("proxy/proxyUser", "").toString());
+ leProxyPassword->setText(settings.value("proxy/proxyPassword", "").toString());
// set the current theme
cmbTheme->setItemText(cmbTheme->currentIndex(), settings.value("/Themes").toString());
// set the display update threshold
@@ -246,6 +252,13 @@
void QgsOptions::saveOptions()
QSettings settings;
+ settings.setValue("proxy/proxyEnabled", grpProxy->isChecked());
+ settings.setValue("proxy/proxyHost", leProxyHost->text());
+ settings.setValue("proxy/proxyPort", leProxyPort->text());
+ settings.setValue("proxy/proxyUser", leProxyUser->text());
+ settings.setValue("proxy/proxyPassword", leProxyPassword->text());
+ //general settings
settings.setValue("/Map/identifyRadius", spinBoxIdentifyValue->value());
settings.setValue("/qgis/showLegendClassifiers",cbxLegendClassifiers->isChecked());
settings.setValue("/qgis/hideSplash",cbxHideSplash->isChecked());
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2008-06-11 15:08:07 UTC (rev 8647)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2008-06-15 18:37:57 UTC (rev 8648)
@@ -938,6 +938,104 @@
</item>
</layout>
</widget>
+ <widget class="QWidget" name="tab" >
+ <attribute name="title" >
+ <string>Proxy</string>
+ </attribute>
+ <layout class="QGridLayout" >
+ <item row="0" column="0" >
+ <widget class="QGroupBox" name="grpProxy" >
+ <property name="title" >
+ <string>Use proxy for web access</string>
+ </property>
+ <property name="flat" >
+ <bool>false</bool>
+ </property>
+ <property name="checkable" >
+ <bool>true</bool>
+ </property>
+ <widget class="QLabel" name="lblProxyHost" >
+ <property name="text" >
+ <string>Host</string>
+ </property>
+ <property name="buddy" >
+ <cstring>cboModellerPluginName</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1" >
+ <widget class="QLineEdit" name="leProxyHost" />
+ </item>
+ <item row="1" column="0" >
+ <widget class="QLabel" name="lblProxyPort" >
+ <string>Port</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1" >
+ <widget class="QLineEdit" name="leProxyPort" />
+ </item>
+ <item row="2" column="0" >
+ <widget class="QLabel" name="lblUser" >
+ <string>User</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1" >
+ <widget class="QLineEdit" name="leProxyUser" >
+ <property name="toolTip" >
+ <string>Leave this blank if no proxy username / password are required</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="0" >
+ <widget class="QLabel" name="lblPassword" >
+ <string>Password</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="1" >
+ <widget class="QLineEdit" name="leProxyPassword" >
+ </property>
+ <property name="echoMode" >
+ <enum>QLineEdit::Password</enum>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <spacer>
+ <property name="orientation" >
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" >
+ <size>
+ <width>20</width>
+ <height>40</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
