[QGIS Commit] r8695 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Mon Jun 30 16:00:45 EDT 2008
Author: macho
Date: 2008-06-30 16:00:45 -0400 (Mon, 30 Jun 2008)
New Revision: 8695
docs/trunk/english_us/user_guide/plugins.tex
adjusted to new macros
Modified: docs/trunk/english_us/user_guide/plugins.tex
--- docs/trunk/english_us/user_guide/plugins.tex 2008-06-30 16:03:41 UTC (rev 8694)
+++ docs/trunk/english_us/user_guide/plugins.tex 2008-06-30 20:00:45 UTC (rev 8695)
@@ -4,16 +4,14 @@
\subsection{An Introduction to Using Plugins}\label{label_introplugin}
-QGIS has been designed with a plugin architecture. This allows new
-features/functions to be added to the application. Many of the features in
-QGIS are actually implemented as plugins.
+QGIS has been designed with a plugin architecture.
+This allows new features/functions to be added to the application.
+Many of the features in QGIS are actually implemented as plugins.
There are two types of plugins in QGIS: core and user-contributed.
-\index{plugins!types} A core plugin is maintained by the QGIS development team
-and is part of every QGIS distribution. A user-contributed plugin is an
-external plugin that is maintained by the individual author. The QGIS
-SVN website (\url{http://svn.qgis.org}) serves some user contributed
-plugins.
+\index{plugins!types} A core plugin is maintained by the QGIS development team and is part of every QGIS distribution.
+A user-contributed plugin is an external plugin that is maintained by the individual author.
+The QGIS SVN website (\url{http://svn.qgis.org}) serves some user contributed plugins.
\subsubsection{Finding and Installing a Plugin}
When you install QGIS, all of the core plugins are included (see chapter \ref{sec:core_plugins}). \index{plugins!installing}
@@ -23,19 +21,16 @@
% site (\url{http://community.qgis.org/plugins}).\index{plugins!user
% contributed}
-Typically user-contributed plugins are distributed in source form and require
-compiling. For instructions on building and installing a user-contributed
-plugin, see the documentation included with the plugin.
+Typically user-contributed plugins are distributed in source form and require compiling.
+For instructions on building and installing a user-contributed plugin, see the documentation included with the plugin.
\subsubsection{Managing Plugins}\label{sec:managing_plugins}
-\index{plugins!managing} Managing plugins consists of loading or unloading them from
-QGIS. Loaded plugins are "remembered" when you exit the application and
-restored the next time you run QGIS.
+\index{plugins!managing} Managing plugins consists of loading or unloading them from QGIS.
+Loaded plugins are "remembered" when you exit the application and restored the next time you run QGIS.
-To manage plugins, open the \textsl{Plugin Manager} from the \textsl{Tools}
-menu. \index{plugins!manager}The Plugin Manager displays all the available
-plugins and their status (loaded or unloaded). Figure \ref{fig:pluginmanager}
-shows the Plugin Manager dialog.
+To manage plugins, open \mainmenuopt{Plugins} > \dropmenuopttwo{mActionShowPluginManager}{Plugin Manager...}.
+\index{plugins!manager}The Plugin Manager displays all the available plugins and their status (loaded or unloaded).
+Figure \ref{fig:pluginmanager} shows the Plugin Manager dialog.
\begin{figure}[ht]
\begin{center}
@@ -44,42 +39,36 @@
\end{center}
\end{figure}
-Typically all QGIS plugins are installed in the same location. This location
-is shown in the Plugin Directory text field. You can tell QGIS to load plugins
-from another location by specifying a different directory.
+Typically all QGIS plugins are installed in the same location.
+This location is shown in the Plugin Directory text field.
+You can tell QGIS to load plugins from another location by specifying a different directory.
\begin{Tip}\caption{\textsc{Crashing Plugins}}\index{crashes}
\qgistip{If you find that QGIS crashes on startup, a plugin may be at fault.
-You can stop all plugins from loading by editing your stored settings file (see \ref{subsec:gui_options}
-for location).
-Locate the plugins settings and change all the plugin values to false to prevent them from loading. For
-example, to prevent the Delimited text plugin from loading, the entry in
-\$HOME/.config/QuantumGIS/qgis.conf on Linux
-should look like this:\ttfamily{Add Delimited Text Layer=false}.\normalfont Do this for each plugin in the
-[Plugins] section. You can then start QGIS and add the plugins one at a time
-from the Plugin Manger to determine which is causing the problem.
+You can stop all plugins from loading by editing your stored settings file (see \ref{subsec:gui_options} for location).
+Locate the plugins settings and change all the plugin values to false to prevent them from loading.
+\nix {For example, to prevent the Delimited text plugin from loading, the entry in \$HOME/.config/QuantumGIS/qgis.conf on Linux
+should look like this:\ttfamily{Add Delimited Text Layer=false}.}
+\normalfont
+Do this for each plugin in the [Plugins] section.
+You can then start QGIS and add the plugins one at a time from the Plugin Manger to determine which is causing the problem.
\end{Tip}
\subsubsection{Data Providers}\index{data providers}
-Data Providers are "special" plugins that provides access to a data store. By
-default, QGIS supports PostGIS layers and disk-based data stores supported by
-the GDAL/OGR library (Appendix \ref{appdx_ogr}). A Data Provider plugin extends the
-ability of QGIS to use other data sources.
+Data Providers are "special" plugins that provides access to a data store.
+By default, QGIS supports PostGIS layers and disk-based data stores supported by the GDAL/OGR library (Appendix \ref{appdx_ogr}).
+A Data Provider plugin extends the ability of QGIS to use other data sources.
-Data Provider plugins are registered automatically by QGIS at startup. They
-are not managed by the Plugin Manager but are used behind the scenes when a
-corresponding data type is added as a layer in QGIS.
+Data Provider plugins are registered automatically by QGIS at startup.
+They are not managed by the Plugin Manager but are used behind the scenes when a corresponding data type is added as a layer in QGIS.
\subsubsection{Core Plugins}\label{sec:core_plugins}\index{plugins!core}
-QGIS currently contains 9 core plugins that can be loaded using the Plugin
-Manager. Table \ref{tab:core_plugins} lists each of the core plugins along
-with a description of their purpose and the toolbar-icon.
-Note the GRASS plugin is not included below
-because it installs its own toolbar (see section \ref{sec:grass} for a
-discussion of available features in the GRASS plugin).
+QGIS currently contains 9 core plugins that can be loaded using the Plugin Manager.
+Table \ref{tab:core_plugins} lists each of the core plugins along with a description of their purpose and the toolbar-icon.
+Note the GRASS plugin is not included below because it installs its own toolbar (see section \ref{sec:grass} for a discussion of available features in the GRASS plugin).
% minipage is needed to appear the footnote under the table
% SH
@@ -120,9 +109,7 @@
\begin{Tip}\caption{\textsc{Plugins Settings Saved to Project}}\index{plugins
settings}
-\qgistip{When you save a .qgs project, any changes you have made to
-NorthArrow, ScaleBar and Copyright plugins will be saved in the project and
-restored next time you load the project.
+\qgistip{When you save a .qgs project, any changes you have made to NorthArrow, ScaleBar and Copyright plugins will be saved in the project and restored next time you load the project.
\end{Tip}
@@ -131,32 +118,29 @@
\subsubsection{External Plugins}\label{sec:external_plugins}\index{plugins!external}
-QGIS also comes with some externally developed plugins. They are not shipped with the
-default distribution. However, they can be compiled and used within QGIS.
+QGIS also comes with some externally developed plugins.
+They are not shipped with the default distribution.
+However, they can be compiled and used within QGIS.
-Currently the external plugins are only available directly from SVN.
+Currently the external plugins are only available directly from SVN.
To check out all available external plugins do the following:
\begin{verbatim}
svn co https://svn.osgeo.org/qgis/trunk/external_plugins external_qgis_plugins
\end{verbatim}
This will create a folder \texttt{external\_qgis\_plugins} in your current folder.
-Each subdirectory has its own compile and install instructions. Read them carefully
-in order to build the plugin.
+Each subdirectory has its own compile and install instructions.
+Read them carefully in order to build the plugin.
% Plugin template
\subsubsection{Plugin templates}\label{sec:plugin_template}\index{plugins!template}
-If you like to develop your own QGIS-plugin the main sources include a nice script
-which guides you through the process of creating your own template-directory-structure
-within the QGIS-source-tree.
+If you like to develop your own QGIS-plugin the main sources include a nice script which guides you through the process of creating your own template-directory-structure within the QGIS-source-tree.
The script lives in \texttt{QGIS/src/plugins/plugin\_builder.pl}.
-The only thing to do is coding your functions into the plugin (and of course contribute
-your plugin to the QGIS-development-team).
+The only thing to do is coding your functions into the plugin (and of course contribute your plugin to the QGIS-development-team).
-Beside that the QGIS-wiki (\url{http://wiki.qgis.org}) and the QGIS-blog (\url{http://blog.qgis.org})
-provide useful articles about writing your own plugin as well.
-Check the websites for details!
+Beside that the QGIS-wiki (\url{http://wiki.qgis.org}) and the QGIS-blog (\url{http://blog.qgis.org}) provide useful articles about writing your own plugin as well.
+Check the websites for details!
\ No newline at end of file
