[QGIS Commit] r8193 - trunk/qgis
svn_qgis at osgeo.org
Fri Mar 7 12:00:58 EST 2008
Author: timlinux
Date: 2008-03-07 12:00:57 -0500 (Fri, 07 Mar 2008)
New Revision: 8193
trunk/qgis/INSTALL.t2t
Updated osx build procedure with notes from William
Modified: trunk/qgis/INSTALL.t2t
--- trunk/qgis/INSTALL.t2t 2008-03-06 21:04:44 UTC (rev 8192)
+++ trunk/qgis/INSTALL.t2t 2008-03-07 17:00:57 UTC (rev 8193)
@@ -639,40 +639,56 @@
I suggest you press 'p' to accept the key permanently.
== Configure the build ==
CMake supports out of source build so we will create a 'build' dir for the
-build process . By convention I build my software into a dir called 'apps'
-in my home directory. If you have the correct permissions you may want to
-build straight into your /Applications folder (although personally I dont
-really recommend this). The instructions below assume you are building into
-a pre-existing ${HOME}/apps directory ...
+build process . By convention I build my software into a dir called 'apps' in
+my home directory. If you have the correct permissions you may want to build
+straight into your /Applications folder. The instructions below assume you are
+building into a pre-existing ${HOME}/apps directory ...
-cd qgis
-mkdir build
-cd build
+cd qgis
+mkdir build
+cd build
cmake -D CMAKE_INSTALL_PREFIX=$HOME/apps/ -D CMAKE_BUILD_TYPE=Release ..
-__Leopard note:__ To find the custom install of SIP on Leopard, add ""-D SIP_BINARY_PATH=/usr/local/bin/sip"" to the cmake command above, before the "".."" at the end, ie:
+__Leopard note:__ To find the custom install of SIP on Leopard, add ""-
+D SIP_BINARY_PATH=/usr/local/bin/sip"" to the cmake command above,
+before the "".."" at the end, ie:
-cmake -D CMAKE_INSTALL_PREFIX=$HOME/apps/ -D CMAKE_BUILD_TYPE=Release -D SIP_BINARY_PATH=/usr/local/bin/sip ..
+cmake -D CMAKE_INSTALL_PREFIX=$HOME/apps/ -D CMAKE_BUILD_TYPE=Release -
+D SIP_BINARY_PATH=/usr/local/bin/sip ..
-To use a specific GRASS version, You can optionally use the following
-cmake invocation (with modifications to suite your system (thanks William
-Kyngesburye for this hint):
+To use the application build of GRASS on OSX, you can optionally use the
+following cmake invocation (minimum GRASS 6.3 required, substitute the GRASS
+version as required):
cmake -D CMAKE_INSTALL_PREFIX=${HOME}/apps/ \
- -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.3.app/Contents/Resources/include \
- -D GRASS_PREFIX=/Applications/GRASS-6.3.app/Contents/Resources \
+ -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.3.app/Contents/MacOS/
+ include \
+ -D GRASS_PREFIX=/Applications/GRASS-6.3.app/Contents/MacOS \
-D CMAKE_BUILD_TYPE=Release \
+Or, to use a Unix-style build of GRASS, use the following cmake invocation
+(minimum GRASS version as stated in the Qgis requirements, substitute the GRASS
+path and version as required):
+cmake -D CMAKE_INSTALL_PREFIX=${HOME}/apps/ \
+ -D GRASS_INCLUDE_DIR=/user/local/grass-6.3.0/include \
+ -D GRASS_PREFIX=/user/local/grass-6.3.0 \
+ -D CMAKE_BUILD_TYPE=Release \
== Building ==
Now we can start the build process:
