[QGIS Commit] r8223 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Mar 14 11:17:30 EDT 2008
Author: jef
Date: 2008-03-14 11:17:29 -0400 (Fri, 14 Mar 2008)
New Revision: 8223
   trunk/qgis/src/app/qgsdbsourceselect.cpp
qgsdbsourceselect.cpp reindented
Modified: trunk/qgis/src/app/qgsdbsourceselect.cpp
--- trunk/qgis/src/app/qgsdbsourceselect.cpp	2008-03-14 14:09:18 UTC (rev 8222)
+++ trunk/qgis/src/app/qgsdbsourceselect.cpp	2008-03-14 15:17:29 UTC (rev 8223)
@@ -66,7 +66,7 @@
   mSearchGroupBox->hide();
   connect(mTablesTreeView, SIGNAL(doubleClicked(const QModelIndex&)), this, SLOT(setSql(const QModelIndex&)));
-   //for Qt < 4.3.2, passing -1 to include all model columns
+  //for Qt < 4.3.2, passing -1 to include all model columns
   //in search does not seem to work
   mSearchColumnComboBox->setCurrentIndex(2);
@@ -109,53 +109,53 @@
 void QgsDbSourceSelect::on_mSearchOptionsButton_clicked()
   if(mSearchGroupBox->isVisible())
-      mSearchGroupBox->hide();
+    mSearchGroupBox->hide();
   else
-      mSearchGroupBox->show();
+    mSearchGroupBox->show();
 void QgsDbSourceSelect::on_mSearchTableEdit_textChanged(const QString & text)
   if(mSearchModeComboBox->currentText() == tr("Wildcard"))
-      mProxyModel._setFilterWildcard(text);
+    mProxyModel._setFilterWildcard(text);
   else if(mSearchModeComboBox->currentText() == tr("RegExp"))
-      mProxyModel._setFilterRegExp(text);
+    mProxyModel._setFilterRegExp(text);
 void QgsDbSourceSelect::on_mSearchColumnComboBox_currentIndexChanged(const QString & text)
   if(text == tr("All"))
-      mProxyModel.setFilterKeyColumn(-1);
+    mProxyModel.setFilterKeyColumn(-1);
   else if(text == tr("Schema"))
-      mProxyModel.setFilterKeyColumn(0);
+    mProxyModel.setFilterKeyColumn(0);
   else if(text == tr("Table"))
-      mProxyModel.setFilterKeyColumn(1);
+    mProxyModel.setFilterKeyColumn(1);
   else if(text == tr("Type"))
-      mProxyModel.setFilterKeyColumn(2);
+    mProxyModel.setFilterKeyColumn(2);
   else if(text == tr("Geometry column"))
-      mProxyModel.setFilterKeyColumn(3);
+    mProxyModel.setFilterKeyColumn(3);
   else if(text == tr("Sql"))
-      mProxyModel.setFilterKeyColumn(4);
+    mProxyModel.setFilterKeyColumn(4);
 void QgsDbSourceSelect::on_mSearchModeComboBox_currentIndexChanged(const QString & text)
@@ -169,24 +169,24 @@
   mTableModel.setGeometryTypesForTable(schema, table, column, type);
   mTablesTreeView->sortByColumn(1, Qt::AscendingOrder);
-   mTablesTreeView->sortByColumn(0, Qt::AscendingOrder);
+  mTablesTreeView->sortByColumn(0, Qt::AscendingOrder);
 QString QgsDbSourceSelect::makeGeomQuery(QString schema,
                                                 QString table, QString column)
   return QString("select distinct "
-		  "case"
-		  " when geometrytype(%1) IN ('POINT','MULTIPOINT') THEN 'POINT'"
-		  " when geometrytype(%1) IN ('LINESTRING','MULTILINESTRING') THEN 'LINESTRING'"
-		  " when geometrytype(%1) IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON'"
-		  " end "
-		  "from \"%2\".\"%3\"").arg("\""+column+"\"").arg(schema).arg(table);
+    "case"
+    " when geometrytype(%1) IN ('POINT','MULTIPOINT') THEN 'POINT'"
+    " when geometrytype(%1) IN ('LINESTRING','MULTILINESTRING') THEN 'LINESTRING'"
+    " when geometrytype(%1) IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON'"
+    " end "
+    "from \"%2\".\"%3\"").arg("\""+column+"\"").arg(schema).arg(table);
 QgsDbSourceSelect::~QgsDbSourceSelect()
-    PQfinish(pd);
+  PQfinish(pd);
 void QgsDbSourceSelect::populateConnectionList()
@@ -212,7 +212,6 @@
 void QgsDbSourceSelect::editConnection()
   QgsNewConnection *nc = new QgsNewConnection(this, cmbConnections->currentText());
   if (nc->exec())
@@ -257,87 +256,87 @@
   QModelIndexList::const_iterator selected_it = selectedIndices.constBegin();
   for(; selected_it != selectedIndices.constEnd(); ++selected_it)
+    if(!selected_it->parent().isValid())
-      if(!selected_it->parent().isValid())
-	  //top level items only contain the schema names
-	  continue;
-      currentItem = mTableModel.itemFromIndex(mProxyModel.mapToSource(*selected_it));
-      if(!currentItem)
-	  continue;
-      QString currentSchemaName = currentItem->parent()->text();
-      int currentRow = currentItem->row();
-      int currentColumn = currentItem->column();
+      //top level items only contain the schema names
+      continue;
+    currentItem = mTableModel.itemFromIndex(mProxyModel.mapToSource(*selected_it));
+    if(!currentItem)
+      continue;
-      if(dbInfo[currentSchemaName][currentRow].size() == 0)
-	  dbInfo[currentSchemaName][currentRow].resize(5);
+    QString currentSchemaName = currentItem->parent()->text();
-      dbInfo[currentSchemaName][currentRow][currentColumn] = currentItem->text();
+    int currentRow = currentItem->row();
+    int currentColumn = currentItem->column();
+    if(dbInfo[currentSchemaName][currentRow].size() == 0)
+      dbInfo[currentSchemaName][currentRow].resize(5);
+    dbInfo[currentSchemaName][currentRow][currentColumn] = currentItem->text();
   //now traverse all the schemas and table infos
   QString schemaName, tableName, geomColumnName, sql;
   QString query;
   QMap<QString, schemaInfo>::const_iterator schema_it = dbInfo.constBegin();
   for(; schema_it != dbInfo.constEnd(); ++schema_it)
+    schemaInfo scheme = schema_it.value();
+    schemaInfo::const_iterator entry_it = scheme.constBegin();
+    for(; entry_it != scheme.constEnd(); ++entry_it)
-      schemaInfo scheme = schema_it.value();
-      schemaInfo::const_iterator entry_it = scheme.constBegin();
-      for(; entry_it != scheme.constEnd(); ++entry_it)
-	  schemaName = entry_it->at(0);
-	  tableName = entry_it->at(1);
-	  geomColumnName = entry_it->at(3);
-	  sql = entry_it->at(4);
-	  if(geomColumnName.contains(" AS "))
-	      int a = geomColumnName.find(" AS ");
-	      QString typeName = geomColumnName.mid(a+4); //only the type name
-	      geomColumnName = geomColumnName.mid(0, a); //only the geom column name
-	      if(!sql.isEmpty())
-		  sql += " AND ";
-	      if( typeName=="POINT" )
-		  sql += QString("GeometryType(\"%1\") IN ('POINT','MULTIPOINT')").arg(geomColumnName);
-	      else if(typeName=="LINESTRING")
-		  sql += QString("GeometryType(\"%1\") IN ('LINESTRING','MULTILINESTRING')").arg(geomColumnName);
-	      else if(typeName=="POLYGON")
-		  sql += QString("GeometryType(\"%1\") IN ('POLYGON','MULTIPOLYGON')").arg(geomColumnName);
-	      else
-		  continue;
-	  query = "\"" + schemaName + "\".\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
-	  m_selectedTables.push_back(query);
+      schemaName = entry_it->at(0);
+      tableName = entry_it->at(1);
+      geomColumnName = entry_it->at(3);
+      sql = entry_it->at(4);
+      if(geomColumnName.contains(" AS "))
+        int a = geomColumnName.find(" AS ");
+        QString typeName = geomColumnName.mid(a+4); //only the type name
+        geomColumnName = geomColumnName.mid(0, a); //only the geom column name
+        if(!sql.isEmpty())
+          sql += " AND ";
+        if( typeName=="POINT" )
+          sql += QString("GeometryType(\"%1\") IN ('POINT','MULTIPOINT')").arg(geomColumnName);
+        else if(typeName=="LINESTRING")
+          sql += QString("GeometryType(\"%1\") IN ('LINESTRING','MULTILINESTRING')").arg(geomColumnName);
+        else if(typeName=="POLYGON")
+          sql += QString("GeometryType(\"%1\") IN ('POLYGON','MULTIPOLYGON')").arg(geomColumnName);
+        else
+          continue;
+      query = "\"" + schemaName + "\".\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
+      m_selectedTables.push_back(query);
   if(m_selectedTables.empty())
-      QMessageBox::information(this, tr("Select Table"), tr("You must select a table in order to add a Layer."));
+    QMessageBox::information(this, tr("Select Table"), tr("You must select a table in order to add a Layer."));
   else
-      accept();
+    accept();
 void QgsDbSourceSelect::on_btnConnect_clicked()
@@ -366,17 +365,17 @@
     // get password from user
     makeConnection = false;
     password = QInputDialog::getText(tr("Password for ") + username,
-        tr("Please enter your password:"),
-        QLineEdit::Password, QString::null, &makeConnection, this);
+      tr("Please enter your password:"),
+      QLineEdit::Password, QString::null, &makeConnection, this);
     // allow null password entry in case its valid for the database
   QgsDataSourceURI uri;
   uri.setConnection( settings.readEntry(key + "/host"),
-		     settings.readEntry(key + "/port"),
-		     database,
-		     settings.readEntry(key + "/username"),
-		     password );
+    settings.readEntry(key + "/port"),
+    database,
+    settings.readEntry(key + "/username"),
+    password );
   bool searchPublicOnly = settings.readBoolEntry(key + "/publicOnly");
   bool searchGeometryColumnsOnly = settings.readBoolEntry(key + "/geometryColumnsOnly");
@@ -410,13 +409,13 @@
         // may take a long time to return
         if (mColumnTypeThread != NULL)
-           connect(mColumnTypeThread, SIGNAL(setLayerType(QString,QString,QString,QString)),
-                   this, SLOT(setLayerType(QString,QString,QString,QString)));
-	   connect(this, SIGNAL(finished()),
-	           mColumnTypeThread, SLOT(stop()) );
+          connect(mColumnTypeThread, SIGNAL(setLayerType(QString,QString,QString,QString)),
+            this, SLOT(setLayerType(QString,QString,QString,QString)));
+          connect(this, SIGNAL(finished()),
+            mColumnTypeThread, SLOT(stop()) );
-            // Do it in a thread.
-            mColumnTypeThread->start();
+          // Do it in a thread.
+          mColumnTypeThread->start();
       else
@@ -432,9 +431,9 @@
     else
       QMessageBox::warning(this, tr("Connection failed"),
-          tr
-          ("Connection to %1 on %2 failed. Either the database is down or your settings are incorrect.%3Check your username and password and try again.%4The database said:%5%6").
-          arg(settings.readEntry(key + "/database")).arg(settings.readEntry(key + "/host")).arg("\n\n").arg("\n\n").arg("\n").arg(QString::fromLocal8Bit(PQerrorMessage(pd))));
+        tr
+        ("Connection to %1 on %2 failed. Either the database is down or your settings are incorrect.%3Check your username and password and try again.%4The database said:%5%6").
+        arg(settings.readEntry(key + "/database")).arg(settings.readEntry(key + "/host")).arg("\n\n").arg("\n\n").arg("\n").arg(QString::fromLocal8Bit(PQerrorMessage(pd))));
@@ -444,13 +443,13 @@
   //if we have only one schema item, expand it by default
   int numTopLevelItems = mTableModel.invisibleRootItem()->rowCount();
   if(numTopLevelItems < 2 || mTableModel.tableCount() < 20)
+    //expand all the toplevel items
+    for(int i = 0; i < numTopLevelItems; ++i)
-      //expand all the toplevel items
-      for(int i = 0; i < numTopLevelItems; ++i)
-	  mTablesTreeView->expand(mProxyModel.mapFromSource(mTableModel.indexFromItem(mTableModel.invisibleRootItem()->child(i))));
+      mTablesTreeView->expand(mProxyModel.mapFromSource(mTableModel.indexFromItem(mTableModel.invisibleRootItem()->child(i))));
 QStringList QgsDbSourceSelect::selectedTables()
@@ -466,23 +465,23 @@
 void QgsDbSourceSelect::setSql(const QModelIndex& index)
   if(!index.parent().isValid())
-      qWarning("schema item found");
-      return;
+    qWarning("schema item found");
+    return;
   if(pd == 0)
-      return;
+    return;
   //create "Schema"."Table" and find out existing sql string
   QModelIndex schemaSibling = index.sibling(index.row(), 0);
   QModelIndex tableSibling = index.sibling(index.row(), 1);
   if(!schemaSibling.isValid() || !tableSibling.isValid())
-      return;
+    return;
   QString schemaName = mTableModel.itemFromIndex(mProxyModel.mapToSource(schemaSibling))->text();
   QString tableName = mTableModel.itemFromIndex(mProxyModel.mapToSource(tableSibling))->text();
@@ -492,9 +491,9 @@
   QString currentSql;
   QModelIndex sqlSibling = index.sibling(index.row(), 4);
   if(sqlSibling.isValid())
-      currentSql = mTableModel.itemFromIndex(mProxyModel.mapToSource(sqlSibling))->text();
+    currentSql = mTableModel.itemFromIndex(mProxyModel.mapToSource(sqlSibling))->text();
   // create a query builder object
   QgsPgQueryBuilder * pgb = new QgsPgQueryBuilder(tableString, pd, this);
@@ -525,15 +524,15 @@
   bool ok = false;
   QApplication::setOverrideCursor(Qt::waitCursor);
-    // The following query returns only tables that exist and the user has SELECT privilege on.
-    // Can't use regclass here because table must exist, else error occurs.
-    QString sql = "select * from geometry_columns,pg_class,pg_namespace "
-      "where relname=f_table_name and f_table_schema=nspname "
-      "and pg_namespace.oid = pg_class.relnamespace "
-      "and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select')"	// user has select privilege
-      "order by f_table_schema,f_table_name";
+  // The following query returns only tables that exist and the user has SELECT privilege on.
+  // Can't use regclass here because table must exist, else error occurs.
+  QString sql = "select * from geometry_columns,pg_class,pg_namespace "
+    "where relname=f_table_name and f_table_schema=nspname "
+    "and pg_namespace.oid = pg_class.relnamespace "
+    "and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select')"	// user has select privilege
+    "order by f_table_schema,f_table_name";
   PGresult *result = PQexec(pg, sql.toUtf8());
   if (result)
@@ -559,15 +558,15 @@
   PQclear(result);
   //search for geometry columns in tables that are not in the geometry_columns metatable
   QApplication::restoreOverrideCursor();
   if (searchGeometryColumnsOnly)
-      return ok;
+    return ok;
-   // Now have a look for geometry columns that aren't in the
+  // Now have a look for geometry columns that aren't in the
   // geometry_columns table. This code is specific to postgresql,
   // but an equivalent query should be possible in other
   // databases.
@@ -577,14 +576,14 @@
     "and pg_attribute.atttypid = regtype('geometry') "
     "and pg_attribute.attrelid = pg_class.oid "
     "and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select') ";
-	// user has select privilege
+  // user has select privilege
   if (searchPublicOnly)
     sql += "and pg_namespace.nspname = 'public' ";
   sql += "and pg_namespace.nspname||'.'||pg_class.relname not in "	//  needs to be table and schema
     "(select f_table_schema||'.'||f_table_name from geometry_columns) "
     "and pg_class.relkind in ('v', 'r')"; // only from views and relations (tables)
   for (int i = 0; i < PQntuples(result); i++)
@@ -613,7 +612,7 @@
 #if 0	// this function is never called - smizuno
 bool QgsDbSourceSelect::getGeometryColumnInfo(PGconn *pg,
-                geomCol& details, bool searchGeometryColumnsOnly,
+                                              geomCol& details, bool searchGeometryColumnsOnly,
                                               bool searchPublicOnly)
   bool ok = false;
@@ -642,22 +641,22 @@
       QString schemaName = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, "f_table_schema")));
       sql = "select oid from pg_class where relname = '" + tableName + "'";
       if (schemaName.length() > 0)
-	sql +=" and relnamespace = (select oid from pg_namespace where nspname = '" +
-	  schemaName + "')";
+        sql +=" and relnamespace = (select oid from pg_namespace where nspname = '" +
+        schemaName + "')";
       PGresult* exists = PQexec(pg, sql.toUtf8());
       if (PQntuples(exists) == 1)
         QString column = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, "f_geometry_column")));
         QString type = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, "type")));
-	QString as = "";
-	if(type=="GEOMETRY" && !searchGeometryColumnsOnly) {
-	  addSearchGeometryColumn(schemaName, tableName,  column);
-	  as=type="WAITING";
-	details.push_back(geomPair(fullDescription(schemaName, tableName, column, as), type));
+        QString as = "";
+        if(type=="GEOMETRY" && !searchGeometryColumnsOnly) {
+          addSearchGeometryColumn(schemaName, tableName,  column);
+          as=type="WAITING";
+        details.push_back(geomPair(fullDescription(schemaName, tableName, column, as), type));
       PQclear(exists);
@@ -686,7 +685,7 @@
     "(select f_table_name from geometry_columns) "
@@ -718,8 +717,9 @@
   QgsContextHelp::run(context_id);
 QString QgsDbSourceSelect::fullDescription(QString schema, QString table,
-					   QString column, QString type)
+                                           QString column, QString type)
   QString full_desc = "";
   if (schema.length() > 0)
@@ -727,12 +727,13 @@
   full_desc += table + "\" (" + column + ") " + type;
   return full_desc;
 void QgsDbSourceSelect::dbChanged()
   // Remember which database was selected.
   QSettings settings;
   settings.writeEntry("/PostgreSQL/connections/selected",
-		      cmbConnections->currentText());
+    cmbConnections->currentText());
 void QgsDbSourceSelect::setConnectionListPosition()
@@ -749,29 +750,27 @@
       set = true;
       break;
-  // If we couldn't find the stored item, but there are some,
-  // default to the last item (this makes some sense when deleting
-  // items as it allows the user to repeatidly click on delete to
-  // remove a whole lot of items).
-  if (!set && cmbConnections->count() > 0)
-    // If toSelect is null, then the selected connection wasn't found
-    // by QSettings, which probably means that this is the first time
-    // the user has used qgis with database connections, so default to
-    // the first in the list of connetions. Otherwise default to the last.
-    if (toSelect.isNull())
-      cmbConnections->setCurrentItem(0);
-    else
-      cmbConnections->setCurrentItem(cmbConnections->count()-1);
+    // If we couldn't find the stored item, but there are some,
+    // default to the last item (this makes some sense when deleting
+    // items as it allows the user to repeatidly click on delete to
+    // remove a whole lot of items).
+    if (!set && cmbConnections->count() > 0)
+      // If toSelect is null, then the selected connection wasn't found
+      // by QSettings, which probably means that this is the first time
+      // the user has used qgis with database connections, so default to
+      // the first in the list of connetions. Otherwise default to the last.
+      if (toSelect.isNull())
+        cmbConnections->setCurrentItem(0);
+      else
+        cmbConnections->setCurrentItem(cmbConnections->count()-1);
 void QgsDbSourceSelect::setSearchExpression(const QString& regexp)
 void QgsGeomColumnTypeThread::setConnInfo(QString s)
   mConnInfo = s;
@@ -801,20 +800,20 @@
     for (uint i = 0; i<schemas.size(); i++)
       QString query = QgsDbSourceSelect::makeGeomQuery(schemas[i],
-                                                       tables[i],
-                                                       columns[i]);
+        tables[i],
+        columns[i]);
       PGresult* gresult = PQexec(pd, query.toUtf8());
       QString type;
       if (PQresultStatus(gresult) == PGRES_TUPLES_OK) {
-	QStringList types;
+        QStringList types;
-	for(int j=0; j<PQntuples(gresult); j++) {
-		QString type = QString::fromUtf8(PQgetvalue(gresult, j, 0));
-		if(type!="")
-		  types += type;
+        for(int j=0; j<PQntuples(gresult); j++) {
+          QString type = QString::fromUtf8(PQgetvalue(gresult, j, 0));
+          if(type!="")
+            types += type;
-	type = types.join(",");
+        type = types.join(",");
       PQclear(gresult);
More information about the QGIS-commit mailing list
