[QGIS Commit] r8232 - trunk/qgis/src/providers/ogr
svn_qgis at osgeo.org
Sun Mar 16 12:35:51 EDT 2008
Author: jef
Date: 2008-03-16 12:35:51 -0400 (Sun, 16 Mar 2008)
New Revision: 8232
trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
more reindents
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2008-03-16 16:25:27 UTC (rev 8231)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2008-03-16 16:35:51 UTC (rev 8232)
@@ -157,62 +157,62 @@
void QgsOgrProvider::setEncoding(const QString& e)
- QgsVectorDataProvider::setEncoding(e);
- loadFields();
+ QgsVectorDataProvider::setEncoding(e);
+ loadFields();
void QgsOgrProvider::loadFields()
- //the attribute fields need to be read again when the encoding changes
- mAttributeFields.clear();
- OGRFeatureDefnH fdef = OGR_L_GetLayerDefn(ogrLayer);
- if(fdef)
- geomType = OGR_FD_GetGeomType(fdef);
+ //the attribute fields need to be read again when the encoding changes
+ mAttributeFields.clear();
+ OGRFeatureDefnH fdef = OGR_L_GetLayerDefn(ogrLayer);
+ if(fdef)
+ geomType = OGR_FD_GetGeomType(fdef);
- //Some ogr drivers (e.g. GML) are not able to determine the geometry type of a layer like this.
- //In such cases, we examine the first feature
- if(geomType == wkbUnknown)
- OGR_L_ResetReading(ogrLayer);
- OGRFeatureH firstFeature = OGR_L_GetNextFeature(ogrLayer);
- if(firstFeature)
- OGRGeometryH firstGeometry = OGR_F_GetGeometryRef(firstFeature);
- if(firstGeometry)
- geomType = OGR_G_GetGeometryType(firstGeometry);
- OGR_F_Destroy( firstFeature );
- for(int i=0;i<OGR_FD_GetFieldCount(fdef);++i)
+ //Some ogr drivers (e.g. GML) are not able to determine the geometry type of a layer like this.
+ //In such cases, we examine the first feature
+ if(geomType == wkbUnknown)
+ OGR_L_ResetReading(ogrLayer);
+ OGRFeatureH firstFeature = OGR_L_GetNextFeature(ogrLayer);
+ if(firstFeature)
- OGRFieldDefnH fldDef = OGR_FD_GetFieldDefn(fdef,i);
- OGRFieldType ogrType = OGR_Fld_GetType(fldDef);
- QVariant::Type varType;
- switch (ogrType)
+ OGRGeometryH firstGeometry = OGR_F_GetGeometryRef(firstFeature);
+ if(firstGeometry)
- case OFTInteger: varType = QVariant::Int; break;
- case OFTReal: varType = QVariant::Double; break;
- // unsupported in OGR 1.3
- //case OFTDateTime: varType = QVariant::DateTime; break;
+ geomType = OGR_G_GetGeometryType(firstGeometry);
+ OGR_F_Destroy( firstFeature );
+ for(int i=0;i<OGR_FD_GetFieldCount(fdef);++i)
+ OGRFieldDefnH fldDef = OGR_FD_GetFieldDefn(fdef,i);
+ OGRFieldType ogrType = OGR_Fld_GetType(fldDef);
+ QVariant::Type varType;
+ switch (ogrType)
+ case OFTInteger: varType = QVariant::Int; break;
+ case OFTReal: varType = QVariant::Double; break;
+ // unsupported in OGR 1.3
+ //case OFTDateTime: varType = QVariant::DateTime; break;
#if GDAL_VERSION_NUM >= 1400
- case OFTString: varType = QVariant::String; break;
+ case OFTString: varType = QVariant::String; break;
#endif
- default: varType = QVariant::String; // other unsupported, leave it as a string
- mAttributeFields.insert(
- i, QgsField(
- mEncoding->toUnicode(OGR_Fld_GetNameRef(fldDef)), varType,
- mEncoding->toUnicode(OGR_GetFieldTypeName(ogrType)),
- OGR_Fld_GetWidth(fldDef),
- OGR_Fld_GetPrecision(fldDef) ));
+ default: varType = QVariant::String; // other unsupported, leave it as a string
+ mAttributeFields.insert(
+ i, QgsField(
+ mEncoding->toUnicode(OGR_Fld_GetNameRef(fldDef)), varType,
+ mEncoding->toUnicode(OGR_GetFieldTypeName(ogrType)),
+ OGR_Fld_GetWidth(fldDef),
+ OGR_Fld_GetPrecision(fldDef) ));
@@ -223,7 +223,6 @@
bool QgsOgrProvider::getFeatureAtId(int featureId,
QgsFeature& feature,
bool fetchGeometry,
@@ -232,18 +231,18 @@
OGRFeatureH fet = OGR_L_GetFeature(ogrLayer,featureId);
if (fet == NULL)
return false;
feature.setFeatureId(OGR_F_GetFID(fet));
/* fetch geometry */
if (fetchGeometry)
OGRGeometryH geom = OGR_F_GetGeometryRef(fet);
// get the wkb representation
unsigned char *wkb = new unsigned char[OGR_G_WkbSize(geom)];
OGR_G_ExportToWkb(geom,(OGRwkbByteOrder) QgsApplication::endian(), wkb);
feature.setGeometryAndOwnership(wkb, OGR_G_WkbSize(geom));
@@ -252,90 +251,90 @@
getFeatureAttribute(fet,feature,*it);
return true;
bool QgsOgrProvider::getNextFeature(QgsFeature& feature)
if (!valid)
- QgsLogger::warning("Read attempt on an invalid shapefile data source");
- return false;
+ QgsLogger::warning("Read attempt on an invalid shapefile data source");
+ return false;
OGRFeatureH fet;
QgsRect selectionRect;
while ((fet = OGR_L_GetNextFeature(ogrLayer)) != NULL)
+ // skip features without geometry
+ if (OGR_F_GetGeometryRef(fet) == NULL && !mFetchFeaturesWithoutGeom)
- // skip features without geometry
- if (OGR_F_GetGeometryRef(fet) == NULL && !mFetchFeaturesWithoutGeom)
- OGR_F_Destroy( fet );
- continue;
- OGRFeatureDefnH featureDefinition = OGR_F_GetDefnRef(fet);
- QString featureTypeName = featureDefinition ? QString(OGR_FD_GetName(featureDefinition)) : QString("");
- feature.setFeatureId(OGR_F_GetFID(fet));
- feature.setTypeName(featureTypeName);
- /* fetch geometry */
- if (mFetchGeom)
- OGRGeometryH geom = OGR_F_GetGeometryRef(fet);
- // get the wkb representation
- unsigned char *wkb = new unsigned char[OGR_G_WkbSize(geom)];
- OGR_G_ExportToWkb(geom,(OGRwkbByteOrder) QgsApplication::endian(), wkb);
- feature.setGeometryAndOwnership(wkb, OGR_G_WkbSize(geom));
- if (mUseIntersect)
- //precise test for intersection with search rectangle
- //first make QgsRect from OGRPolygon
+ OGR_F_Destroy( fet );
+ continue;
+ OGRFeatureDefnH featureDefinition = OGR_F_GetDefnRef(fet);
+ QString featureTypeName = featureDefinition ? QString(OGR_FD_GetName(featureDefinition)) : QString("");
+ feature.setFeatureId(OGR_F_GetFID(fet));
+ feature.setTypeName(featureTypeName);
+ /* fetch geometry */
+ if (mFetchGeom)
+ OGRGeometryH geom = OGR_F_GetGeometryRef(fet);
+ // get the wkb representation
+ unsigned char *wkb = new unsigned char[OGR_G_WkbSize(geom)];
+ OGR_G_ExportToWkb(geom,(OGRwkbByteOrder) QgsApplication::endian(), wkb);
+ feature.setGeometryAndOwnership(wkb, OGR_G_WkbSize(geom));
+ if (mUseIntersect)
+ //precise test for intersection with search rectangle
+ //first make QgsRect from OGRPolygon
OGREnvelope env;
memset( &env, 0, sizeof(env) );
if(mSelectionRectangle)
OGR_G_GetEnvelope(mSelectionRectangle,&env);
if(env.MinX != 0 || env.MinY != 0 || env.MaxX != 0 || env.MaxY != 0 ) //if envelope is invalid, skip the precise intersection test
- selectionRect.set(env.MinX, env.MinY, env.MaxX, env.MaxY);
- if(!feature.geometry()->intersects(selectionRect))
- continue;
- /* fetch attributes */
- for(QgsAttributeList::iterator it = mAttributesToFetch.begin(); it != mAttributesToFetch.end(); ++it)
- getFeatureAttribute(fet,feature,*it);
- /* we have a feature, end this cycle */
- break;
- } /* while */
- if (fet)
- return true;
+ selectionRect.set(env.MinX, env.MinY, env.MaxX, env.MaxY);
+ if(!feature.geometry()->intersects(selectionRect))
+ continue;
- else
+ /* fetch attributes */
+ for(QgsAttributeList::iterator it = mAttributesToFetch.begin(); it != mAttributesToFetch.end(); ++it)
- QgsDebugMsg("Feature is null");
- // probably should reset reading here
- return false;
+ getFeatureAttribute(fet,feature,*it);
+ /* we have a feature, end this cycle */
+ break;
+ } /* while */
+ if (fet)
+ return true;
+ else
+ QgsDebugMsg("Feature is null");
+ // probably should reset reading here
+ return false;
void QgsOgrProvider::select(QgsAttributeList fetchAttributes, QgsRect rect, bool fetchGeometry, \
@@ -347,32 +346,32 @@
// spatial query to select features
if(rect.isEmpty())
- OGR_L_SetSpatialFilter(ogrLayer,0);
+ OGR_L_SetSpatialFilter(ogrLayer,0);
else
+ OGRGeometryH filter = 0;
+ QString wktExtent = QString("POLYGON ((%1))").arg(rect.asPolygon());
+ const char *wktText = (const char *)wktExtent;
+ if(useIntersect)
- OGRGeometryH filter = 0;
- QString wktExtent = QString("POLYGON ((%1))").arg(rect.asPolygon());
- const char *wktText = (const char *)wktExtent;
- if(useIntersect)
- // store the selection rectangle for use in filtering features during
- // an identify and display attributes
- if( mSelectionRectangle )
- OGR_G_DestroyGeometry( mSelectionRectangle );
+ // store the selection rectangle for use in filtering features during
+ // an identify and display attributes
+ if( mSelectionRectangle )
+ OGR_G_DestroyGeometry( mSelectionRectangle );
- OGR_G_CreateFromWkt( (char **)&wktText,
- NULL, &mSelectionRectangle);
+ OGR_G_CreateFromWkt( (char **)&wktText,
+ NULL, &mSelectionRectangle);
- wktText = (const char *) wktExtent;
- OGR_G_CreateFromWkt( (char **)&wktText, NULL, &filter );
- QgsDebugMsg("Setting spatial filter using " + wktExtent);
- OGR_L_SetSpatialFilter( ogrLayer, filter );
- OGR_G_DestroyGeometry( filter );
+ wktText = (const char *) wktExtent;
+ OGR_G_CreateFromWkt( (char **)&wktText, NULL, &filter );
+ QgsDebugMsg("Setting spatial filter using " + wktExtent);
+ OGR_L_SetSpatialFilter( ogrLayer, filter );
+ OGR_G_DestroyGeometry( filter );
@@ -382,7 +381,7 @@
unsigned char *gPtr=0;
if( geom == NULL )
- return NULL;
+ return NULL;
gPtr = new unsigned char[OGR_G_WkbSize(geom)];
@@ -402,7 +401,7 @@
size_t QgsOgrProvider::layerCount() const
- return OGR_DS_GetLayerCount(ogrDataSource);
+ return OGR_DS_GetLayerCount(ogrDataSource);
} // QgsOgrProvider::layerCount()
@@ -444,14 +443,14 @@
QByteArray cstr(OGR_F_GetFieldAsString(ogrFet,attindex));
QString str = mEncoding->toUnicode(cstr);
QVariant value;
switch (mAttributeFields[attindex].type())
- case QVariant::String: value = QVariant(str); break;
- case QVariant::Int: value = QVariant(str.toInt()); break;
- case QVariant::Double: value = QVariant(str.toDouble()); break;
+ case QVariant::String: value = QVariant(str); break;
+ case QVariant::Int: value = QVariant(str.toInt()); break;
+ case QVariant::Double: value = QVariant(str.toDouble()); break;
//case QVariant::DateTime: value = QVariant(QDateTime::fromString(str)); break;
- default: assert(NULL && "unsupported field type");
+ default: assert(NULL && "unsupported field type");
f.addAttribute(attindex, value);
@@ -488,54 +487,54 @@
if( f.geometry()->wkbSize() > 0 )
- OGRGeometryH geom = NULL;
+ OGRGeometryH geom = NULL;
- if( OGR_G_CreateFromWkb( wkb, NULL, &geom, f.geometry()->wkbSize() )
- != OGRERR_NONE )
- return false;
+ if( OGR_G_CreateFromWkb( wkb, NULL, &geom, f.geometry()->wkbSize() )
+ != OGRERR_NONE )
+ return false;
- OGR_F_SetGeometryDirectly( feature, geom );
+ OGR_F_SetGeometryDirectly( feature, geom );
QgsAttributeMap attrs = f.attributeMap();
//add possible attribute information
for(QgsAttributeMap::iterator it = attrs.begin(); it != attrs.end(); ++it)
int targetAttributeId = it.key();
// don't try to set field from attribute map if it's not present in layer
if (targetAttributeId >= OGR_FD_GetFieldCount(fdef))
continue;
//if(!s.isEmpty())
// continue;
OGRFieldDefnH fldDef = OGR_FD_GetFieldDefn( fdef, targetAttributeId );
switch( OGR_Fld_GetType(fldDef) )
- case OFTInteger:
- OGR_F_SetFieldInteger(feature,targetAttributeId,it->toInt());
- break;
+ case OFTInteger:
+ OGR_F_SetFieldInteger(feature,targetAttributeId,it->toInt());
+ break;
- case OFTReal:
- OGR_F_SetFieldDouble(feature,targetAttributeId,it->toDouble());
- break;
+ case OFTReal:
+ OGR_F_SetFieldDouble(feature,targetAttributeId,it->toDouble());
+ break;
- case OFTString:
- QgsDebugMsg( QString("Writing string attribute %1 with %2, encoding %3")
- .arg( targetAttributeId )
- .arg( it->toString() )
- .arg( mEncoding->name().data() ) );
- OGR_F_SetFieldString(feature,targetAttributeId,mEncoding->fromUnicode(it->toString()).constData());
- break;
+ case OFTString:
+ QgsDebugMsg( QString("Writing string attribute %1 with %2, encoding %3")
+ .arg( targetAttributeId )
+ .arg( it->toString() )
+ .arg( mEncoding->name().data() ) );
+ OGR_F_SetFieldString(feature,targetAttributeId,mEncoding->fromUnicode(it->toString()).constData());
+ break;
- default:
- QgsLogger::warning("QgsOgrProvider::addFeature, no type found");
- break;
+ default:
+ QgsLogger::warning("QgsOgrProvider::addFeature, no type found");
+ break;
@@ -569,41 +568,41 @@
bool QgsOgrProvider::addAttributes(const QgsNewAttributesMap & attributes)
- bool returnvalue=true;
+ bool returnvalue=true;
- for(QgsNewAttributesMap::const_iterator iter = attributes.begin(); iter != attributes.end(); ++iter)
+ for(QgsNewAttributesMap::const_iterator iter = attributes.begin(); iter != attributes.end(); ++iter)
+ OGRFieldDefnH fielddefn =
+ OGR_Fld_Create(mEncoding->fromUnicode(iter.key()).data(),OFTInteger);
+ if(*iter=="OFTInteger")
- OGRFieldDefnH fielddefn =
- OGR_Fld_Create(mEncoding->fromUnicode(iter.key()).data(),OFTInteger);
+ OGR_Fld_SetType( fielddefn, OFTInteger );
+ else if(*iter=="OFTReal")
+ OGR_Fld_SetType( fielddefn, OFTReal );
+ else if(*iter=="OFTString")
+ OGR_Fld_SetType( fielddefn, OFTString );
+ else
+ QgsLogger::warning("QgsOgrProvider::addAttributes, type not found");
+ returnvalue=false;
+ continue;
- if(*iter=="OFTInteger")
- OGR_Fld_SetType( fielddefn, OFTInteger );
- else if(*iter=="OFTReal")
- OGR_Fld_SetType( fielddefn, OFTReal );
- else if(*iter=="OFTString")
- OGR_Fld_SetType( fielddefn, OFTString );
- else
- QgsLogger::warning("QgsOgrProvider::addAttributes, type not found");
- returnvalue=false;
- continue;
- if( OGR_L_CreateField(ogrLayer,fielddefn,TRUE) != OGRERR_NONE)
- QgsLogger::warning("QgsOgrProvider.cpp: writing of OFTInteger field failed");
- OGR_Fld_Destroy( fielddefn );
+ if( OGR_L_CreateField(ogrLayer,fielddefn,TRUE) != OGRERR_NONE)
+ QgsLogger::warning("QgsOgrProvider.cpp: writing of OFTInteger field failed");
+ OGR_Fld_Destroy( fielddefn );
- return returnvalue;
+ return returnvalue;
bool QgsOgrProvider::changeAttributeValues(const QgsChangedAttributesMap & attr_map)
@@ -625,29 +624,29 @@
for( QgsAttributeMap::const_iterator it2 = attr.begin(); it2 != attr.end(); ++it2 )
int f = it2.key();
OGRFieldDefnH fd = OGR_F_GetFieldDefnRef( of, f );
if (fd == NULL)
QgsLogger::warning("QgsOgrProvider::changeAttributeValues, Field " + QString::number(f) + " doesn't exist");
continue;
OGRFieldType type = OGR_Fld_GetType( fd );
switch ( type )
- case OFTInteger:
- OGR_F_SetFieldInteger ( of, f, it2->toInt() );
- break;
- case OFTReal:
- OGR_F_SetFieldDouble ( of, f, it2->toDouble() );
- break;
- case OFTString:
- OGR_F_SetFieldString ( of, f, mEncoding->fromUnicode(it2->toString()).constData() );
- break;
- default:
- QgsLogger::warning("QgsOgrProvider::changeAttributeValues, Unknown field type, cannot change attribute");
- break;
+ case OFTInteger:
+ OGR_F_SetFieldInteger ( of, f, it2->toInt() );
+ break;
+ case OFTReal:
+ OGR_F_SetFieldDouble ( of, f, it2->toDouble() );
+ break;
+ case OFTString:
+ OGR_F_SetFieldString ( of, f, mEncoding->fromUnicode(it2->toString()).constData() );
+ break;
+ default:
+ QgsLogger::warning("QgsOgrProvider::changeAttributeValues, Unknown field type, cannot change attribute");
+ break;
@@ -676,9 +675,9 @@
//create an OGRGeometry
if (OGR_G_CreateFromWkb(it->wkbBuffer(),
- OGR_L_GetSpatialRef(ogrLayer),
- &theNewGeometry,
- it->wkbSize()) != OGRERR_NONE)
+ OGR_L_GetSpatialRef(ogrLayer),
+ &theNewGeometry,
+ it->wkbSize()) != OGRERR_NONE)
QgsLogger::warning("QgsOgrProvider::changeGeometryValues, error while creating new OGRGeometry");
OGR_G_DestroyGeometry( theNewGeometry );
@@ -691,7 +690,7 @@
QgsLogger::warning("QgsOgrProvider::changeGeometryValues, new geometry is NULL");
continue;
//set the new geometry
if(OGR_F_SetGeometryDirectly(theOGRFeature, theNewGeometry) != OGRERR_NONE)
@@ -700,7 +699,7 @@
theNewGeometry = 0;
continue;
OGR_L_SetFeature(ogrLayer,theOGRFeature);
OGR_F_Destroy( theOGRFeature);
@@ -710,23 +709,23 @@
bool QgsOgrProvider::createSpatialIndex()
- QString filename=dataSourceUri().section('/',-1,-1);//find out the filename from the uri
- QString layername=filename.section('.',0,0);
- QString sql="CREATE SPATIAL INDEX ON "+layername;
- OGR_DS_ExecuteSQL (ogrDataSource,sql.ascii(), OGR_L_GetSpatialFilter(ogrLayer),"");
- //find out, if the .qix file is there
- QString indexname = dataSourceUri();
- indexname.truncate(dataSourceUri().length()-filename.length());
- indexname=indexname+layername+".qix";
- QFile indexfile(indexname);
- if(indexfile.exists())
- return true;
- else
- return false;
+ QString filename=dataSourceUri().section('/',-1,-1);//find out the filename from the uri
+ QString layername=filename.section('.',0,0);
+ QString sql="CREATE SPATIAL INDEX ON "+layername;
+ OGR_DS_ExecuteSQL (ogrDataSource,sql.ascii(), OGR_L_GetSpatialFilter(ogrLayer),"");
+ //find out, if the .qix file is there
+ QString indexname = dataSourceUri();
+ indexname.truncate(dataSourceUri().length()-filename.length());
+ indexname=indexname+layername+".qix";
+ QFile indexfile(indexname);
+ if(indexfile.exists())
+ return true;
+ else
+ return false;
bool QgsOgrProvider::deleteFeatures(const QgsFeatureIds & id)
@@ -770,9 +769,9 @@
// the #defines we want to test for here.
if (OGR_L_TestCapability(ogrLayer,"RandomRead"))
- // TRUE if the GetFeature() method works *efficiently* for this layer.
- // TODO: Perhaps influence if QGIS caches into memory
- // (vs read from disk every time) based on this setting.
+ // TRUE if the GetFeature() method works *efficiently* for this layer.
+ // TODO: Perhaps influence if QGIS caches into memory
+ // (vs read from disk every time) based on this setting.
ability |= QgsVectorDataProvider::RandomSelectGeometryAtId;
@@ -783,19 +782,19 @@
ability |= QgsVectorDataProvider::SelectGeometryAtId;
if (OGR_L_TestCapability(ogrLayer,"SequentialWrite"))
- // TRUE if the CreateFeature() method works for this layer.
+ // TRUE if the CreateFeature() method works for this layer.
ability |= QgsVectorDataProvider::AddFeatures;
if (OGR_L_TestCapability(ogrLayer,"DeleteFeature"))
- // TRUE if this layer can delete its features
+ // TRUE if this layer can delete its features
ability |= DeleteFeatures;
if (OGR_L_TestCapability(ogrLayer,"RandomWrite"))
- // TRUE if the SetFeature() method is operational on this layer.
+ // TRUE if the SetFeature() method is operational on this layer.
// TODO According to http://shapelib.maptools.org/ (Shapefile C Library V1.2)
// TODO "You can't modify the vertices of existing structures".
@@ -807,35 +806,35 @@
if (OGR_L_TestCapability(ogrLayer,"FastSpatialFilter"))
- // TRUE if this layer implements spatial filtering efficiently.
- // Layers that effectively read all features, and test them with the
- // OGRFeature intersection methods should return FALSE.
- // This can be used as a clue by the application whether it should build
- // and maintain it's own spatial index for features in this layer.
+ // TRUE if this layer implements spatial filtering efficiently.
+ // Layers that effectively read all features, and test them with the
+ // OGRFeature intersection methods should return FALSE.
+ // This can be used as a clue by the application whether it should build
+ // and maintain it's own spatial index for features in this layer.
// TODO: Perhaps use as a clue by QGIS whether it should build and maintain it's own spatial index for features in this layer.
if (OGR_L_TestCapability(ogrLayer,"FastFeatureCount"))
- // TRUE if this layer can return a feature count
- // (via OGRLayer::GetFeatureCount()) efficiently ... ie. without counting
- // the features. In some cases this will return TRUE until a spatial
- // filter is installed after which it will return FALSE.
+ // TRUE if this layer can return a feature count
+ // (via OGRLayer::GetFeatureCount()) efficiently ... ie. without counting
+ // the features. In some cases this will return TRUE until a spatial
+ // filter is installed after which it will return FALSE.
// TODO: Perhaps use as a clue by QGIS whether it should spawn a thread to count features.
if (OGR_L_TestCapability(ogrLayer,"FastGetExtent"))
- // TRUE if this layer can return its data extent
- // (via OGRLayer::GetExtent()) efficiently ... ie. without scanning
- // all the features. In some cases this will return TRUE until a
- // spatial filter is installed after which it will return FALSE.
+ // TRUE if this layer can return its data extent
+ // (via OGRLayer::GetExtent()) efficiently ... ie. without scanning
+ // all the features. In some cases this will return TRUE until a
+ // spatial filter is installed after which it will return FALSE.
// TODO: Perhaps use as a clue by QGIS whether it should spawn a thread to calculate extent.
if (OGR_L_TestCapability(ogrLayer,"FastSetNextByIndex"))
- // TRUE if this layer can perform the SetNextByIndex() call efficiently.
+ // TRUE if this layer can perform the SetNextByIndex() call efficiently.
// No use required for this QGIS release.
@@ -857,32 +856,26 @@
return ability;
- return (QgsVectorDataProvider::AddFeatures
- | QgsVectorDataProvider::ChangeAttributeValues
- | QgsVectorDataProvider::CreateSpatialIndex);
+ return (QgsVectorDataProvider::AddFeatures
+ | QgsVectorDataProvider::ChangeAttributeValues
+ | QgsVectorDataProvider::CreateSpatialIndex);
-QString QgsOgrProvider::name() const
+QString QgsOgrProvider::name() const
- return TEXT_PROVIDER_KEY;
+ return TEXT_PROVIDER_KEY;
} // QgsOgrProvider::name()
QString QgsOgrProvider::description() const
- return TEXT_PROVIDER_DESCRIPTION;
+ return TEXT_PROVIDER_DESCRIPTION;
} // QgsOgrProvider::description()
Convenience function for readily creating file filters.
@@ -902,8 +895,8 @@
static QString createFileFilter_(QString const &longName, QString const &glob)
- return "[OGR] " +
- longName + " (" + glob.lower() + " " + glob.upper() + ");;";
+ return "[OGR] " +
+ longName + " (" + glob.lower() + " " + glob.upper() + ");;";
} // createFileFilter_
@@ -912,164 +905,159 @@
QGISEXTERN QString fileVectorFilters()
- static QString myFileFilters;
+ static QString myFileFilters;
- // if we've already built the supported vector string, just return what
- // we've already built
- if ( ! ( myFileFilters.isEmpty() || myFileFilters.isNull() ) )
- return myFileFilters;
- // register ogr plugins
- OGRRegisterAll();
+ // if we've already built the supported vector string, just return what
+ // we've already built
+ if ( ! ( myFileFilters.isEmpty() || myFileFilters.isNull() ) )
+ return myFileFilters;
- // first get the GDAL driver manager
+ // register ogr plugins
+ OGRRegisterAll();
- OGRSFDriverH driver; // current driver
+ // first get the GDAL driver manager
- QString driverName; // current driver name
+ OGRSFDriverH driver; // current driver
- // Grind through all the drivers and their respective metadata.
- // We'll add a file filter for those drivers that have a file
- // extension defined for them; the others, welll, even though
- // theoreticaly we can open those files because there exists a
- // driver for them, the user will have to use the "All Files" to
- // open datasets with no explicitly defined file name extension.
- QgsDebugMsg( QString("Driver count: %1").arg( OGRGetDriverCount() ) );
+ QString driverName; // current driver name
- for (int i = 0; i < OGRGetDriverCount(); ++i)
- driver = OGRGetDriver(i);
+ // Grind through all the drivers and their respective metadata.
+ // We'll add a file filter for those drivers that have a file
+ // extension defined for them; the others, welll, even though
+ // theoreticaly we can open those files because there exists a
+ // driver for them, the user will have to use the "All Files" to
+ // open datasets with no explicitly defined file name extension.
+ QgsDebugMsg( QString("Driver count: %1").arg( OGRGetDriverCount() ) );
- Q_CHECK_PTR(driver);
+ for (int i = 0; i < OGRGetDriverCount(); ++i)
+ driver = OGRGetDriver(i);
- if (!driver)
- QgsLogger::warning("unable to get driver " + QString::number(i));
- continue;
+ Q_CHECK_PTR(driver);
- driverName = OGR_Dr_GetName(driver);
+ if (!driver)
+ QgsLogger::warning("unable to get driver " + QString::number(i));
+ continue;
+ driverName = OGR_Dr_GetName(driver);
- if (driverName.startsWith("ESRI"))
- myFileFilters += createFileFilter_("ESRI Shapefiles", "*.shp");
- else if (driverName.startsWith("UK"))
- // XXX needs file filter extension
- else if (driverName.startsWith("SDTS"))
- myFileFilters += createFileFilter_( "Spatial Data Transfer Standard",
- "*catd.ddf" );
- else if (driverName.startsWith("TIGER"))
- else if (driverName.startsWith("S57"))
- else if (driverName.startsWith("MapInfo"))
- myFileFilters += createFileFilter_("MapInfo", "*.mif *.tab");
- else if (driverName.startsWith("DGN"))
- else if (driverName.startsWith("VRT"))
- else if (driverName.startsWith("AVCBin"))
- else if (driverName.startsWith("REC"))
- else if (driverName.startsWith("Memory"))
- else if (driverName.startsWith("Jis"))
- else if (driverName.startsWith("GML"))
- // XXX not yet supported; post 0.1 release task
- myFileFilters += createFileFilter_( "Geography Markup Language",
- "*.gml" );
- else if (driverName.startsWith("CSV"))
- else if (driverName.startsWith("PostgreSQL"))
- else if (driverName.startsWith("GRASS"))
- else if (driverName.startsWith("KML"))
- else if (driverName.startsWith("Interlis 1"))
- else if (driverName.startsWith("Interlis 2"))
- else if (driverName.startsWith("SQLite"))
- else if (driverName.startsWith("MySQL"))
- else
- // NOP, we don't know anything about the current driver
- // with regards to a proper file filter string
- QgsLogger::debug("fileVectorFilters, unknown driver: " + driverName);
- } // each loaded GDAL driver
+ if (driverName.startsWith("ESRI"))
+ myFileFilters += createFileFilter_("ESRI Shapefiles", "*.shp");
+ else if (driverName.startsWith("UK"))
+ // XXX needs file filter extension
+ else if (driverName.startsWith("SDTS"))
+ myFileFilters += createFileFilter_( "Spatial Data Transfer Standard",
+ "*catd.ddf" );
+ else if (driverName.startsWith("TIGER"))
+ else if (driverName.startsWith("S57"))
+ else if (driverName.startsWith("MapInfo"))
+ myFileFilters += createFileFilter_("MapInfo", "*.mif *.tab");
+ else if (driverName.startsWith("DGN"))
+ else if (driverName.startsWith("VRT"))
+ else if (driverName.startsWith("AVCBin"))
+ else if (driverName.startsWith("REC"))
+ else if (driverName.startsWith("Memory"))
+ else if (driverName.startsWith("Jis"))
+ else if (driverName.startsWith("GML"))
+ // XXX not yet supported; post 0.1 release task
+ myFileFilters += createFileFilter_( "Geography Markup Language",
+ "*.gml" );
+ else if (driverName.startsWith("CSV"))
+ else if (driverName.startsWith("PostgreSQL"))
+ else if (driverName.startsWith("GRASS"))
+ else if (driverName.startsWith("KML"))
+ else if (driverName.startsWith("Interlis 1"))
+ else if (driverName.startsWith("Interlis 2"))
+ else if (driverName.startsWith("SQLite"))
+ else if (driverName.startsWith("MySQL"))
+ else
+ // NOP, we don't know anything about the current driver
+ // with regards to a proper file filter string
+ QgsLogger::debug("fileVectorFilters, unknown driver: " + driverName);
- // can't forget the default case
+ } // each loaded GDAL driver
- myFileFilters += "All files (*.*)";
+ // can't forget the default case
+ myFileFilters += "All files (*.*)";
} // fileVectorFilters() const
QString QgsOgrProvider::fileVectorFilters() const
- return fileVectorFilters();
+ return fileVectorFilters();
} // QgsOgrProvider::fileVectorFilters() const
* Class factory to return a pointer to a newly created
* QgsOgrProvider object
@@ -1094,7 +1082,7 @@
QGISEXTERN QString description()
@@ -1119,124 +1107,123 @@
QGis::WKBTYPE vectortype,
const std::list<std::pair<QString, QString> >& attributes)
- OGRRegisterAll();
- driver = OGRGetDriverByName(format);
- if(driver == NULL)
- return false;
+ OGRRegisterAll();
+ driver = OGRGetDriverByName(format);
+ if(driver == NULL)
+ return false;
- OGRDataSourceH dataSource;
- dataSource = OGR_Dr_CreateDataSource(driver,QFile::encodeName(uri).constData(), NULL);
- if(dataSource == NULL)
- return false;
+ OGRDataSourceH dataSource;
+ dataSource = OGR_Dr_CreateDataSource(driver,QFile::encodeName(uri).constData(), NULL);
+ if(dataSource == NULL)
+ return false;
- //consider spatial reference system
- OGRSpatialReferenceH reference = NULL;
- QgsSpatialRefSys mySpatialRefSys;
- mySpatialRefSys.validate();
- QString myWKT = mySpatialRefSys.toWkt();
- if( !myWKT.isNull() && myWKT.length() != 0 )
+ //consider spatial reference system
+ OGRSpatialReferenceH reference = NULL;
+ QgsSpatialRefSys mySpatialRefSys;
+ mySpatialRefSys.validate();
+ QString myWKT = mySpatialRefSys.toWkt();
+ if( !myWKT.isNull() && myWKT.length() != 0 )
+ reference = OSRNewSpatialReference(myWKT.toLocal8Bit().data());
+ // Map the qgis geometry type to the OGR geometry type
+ OGRwkbGeometryType OGRvectortype = wkbUnknown;
+ switch (vectortype)
+ case QGis::WKBPoint:
+ OGRvectortype = wkbPoint;
+ break;
+ case QGis::WKBLineString:
+ OGRvectortype = wkbLineString;
+ break;
+ case QGis::WKBPolygon:
+ OGRvectortype = wkbPolygon;
+ break;
+ case QGis::WKBMultiPoint:
+ OGRvectortype = wkbMultiPoint;
+ break;
+ case QGis::WKBMultiLineString:
+ OGRvectortype = wkbMultiLineString;
+ break;
+ case QGis::WKBMultiPolygon:
+ OGRvectortype = wkbMultiPolygon;
+ break;
+ default:
- reference = OSRNewSpatialReference(myWKT.toLocal8Bit().data());
+ QgsLogger::debug("Unknown vector type of: ", (int)(vectortype), 1,
+ __FILE__, __FUNCTION__, __LINE__);
+ return false;
+ break;
- // Map the qgis geometry type to the OGR geometry type
- OGRwkbGeometryType OGRvectortype = wkbUnknown;
- switch (vectortype)
+ OGRLayerH layer;
+ layer = OGR_DS_CreateLayer(dataSource,QFile::encodeName(QFileInfo(uri).baseName()).constData(), reference, OGRvectortype, NULL);
+ if(layer == NULL)
+ return false;
+ //create the attribute fields
+ QTextCodec* codec=QTextCodec::codecForName(encoding.toLocal8Bit().data());
+ for(std::list<std::pair<QString, QString> >::const_iterator it= attributes.begin(); it != attributes.end(); ++it)
+ if(it->second == "Real")
- case QGis::WKBPoint:
- OGRvectortype = wkbPoint;
- break;
- case QGis::WKBLineString:
- OGRvectortype = wkbLineString;
- break;
- case QGis::WKBPolygon:
- OGRvectortype = wkbPolygon;
- break;
- case QGis::WKBMultiPoint:
- OGRvectortype = wkbMultiPoint;
- break;
- case QGis::WKBMultiLineString:
- OGRvectortype = wkbMultiLineString;
- break;
- case QGis::WKBMultiPolygon:
- OGRvectortype = wkbMultiPolygon;
- break;
- default:
+ OGRFieldDefnH field = OGR_Fld_Create(codec->fromUnicode(it->first).data(), OFTReal);
+ OGR_Fld_SetPrecision(field,3);
+ OGR_Fld_SetWidth(field,32);
+ if( OGR_L_CreateField(layer,field,TRUE) != OGRERR_NONE)
- QgsLogger::debug("Unknown vector type of: ", (int)(vectortype), 1,
- __FILE__, __FUNCTION__, __LINE__);
- return false;
- break;
+ QgsLogger::warning("creation of OFTReal field failed");
- OGRLayerH layer;
- layer = OGR_DS_CreateLayer(dataSource,QFile::encodeName(QFileInfo(uri).baseName()).constData(), reference, OGRvectortype, NULL);
- if(layer == NULL)
+ else if(it->second == "Integer")
- return false;
+ OGRFieldDefnH field = OGR_Fld_Create(codec->fromUnicode(it->first).data(), OFTInteger);
+ if(OGR_L_CreateField(layer,field,TRUE) != OGRERR_NONE)
+ QgsLogger::warning("creation of OFTInteger field failed");
- //create the attribute fields
- QTextCodec* codec=QTextCodec::codecForName(encoding.toLocal8Bit().data());
- for(std::list<std::pair<QString, QString> >::const_iterator it= attributes.begin(); it != attributes.end(); ++it)
+ else if(it->second == "String")
- if(it->second == "Real")
- OGRFieldDefnH field = OGR_Fld_Create(codec->fromUnicode(it->first).data(), OFTReal);
- OGR_Fld_SetPrecision(field,3);
- OGR_Fld_SetWidth(field,32);
- if( OGR_L_CreateField(layer,field,TRUE) != OGRERR_NONE)
- QgsLogger::warning("creation of OFTReal field failed");
- else if(it->second == "Integer")
- OGRFieldDefnH field = OGR_Fld_Create(codec->fromUnicode(it->first).data(), OFTInteger);
- if(OGR_L_CreateField(layer,field,TRUE) != OGRERR_NONE)
- QgsLogger::warning("creation of OFTInteger field failed");
- else if(it->second == "String")
- OGRFieldDefnH field = OGR_Fld_Create(codec->fromUnicode(it->first).data(), OFTString);
- QgsLogger::warning("creation of OFTString field failed");
+ OGRFieldDefnH field = OGR_Fld_Create(codec->fromUnicode(it->first).data(), OFTString);
+ QgsLogger::warning("creation of OFTString field failed");
- OGR_DS_Destroy(dataSource);
+ OGR_DS_Destroy(dataSource);
- QgsDebugMsg( QString("GDAL Version number %1").arg( GDAL_VERSION_NUM ) );
+ QgsDebugMsg( QString("GDAL Version number %1").arg( GDAL_VERSION_NUM ) );
#if GDAL_VERSION_NUM >= 1310
- if(reference)
- OSRRelease( reference );
+ if(reference)
+ OSRRelease( reference );
#endif //GDAL_VERSION_NUM
- return true;
+ return true;
QgsSpatialRefSys QgsOgrProvider::getSRS()
QgsDebugMsg("QgsOgrProvider::getSRS()");
QgsSpatialRefSys srs;
OGRSpatialReferenceH mySpatialRefSys = OGR_L_GetSpatialRef(ogrLayer);
if (mySpatialRefSys == NULL)
@@ -1252,7 +1239,7 @@
OSRExportToWkt(mySpatialRefSys, &pszWKT );
QString myWKTString = QString(pszWKT);
OGRFree(pszWKT);
// create SRS from WKT
srs.createFromWkt( myWKTString );
