[QGIS Commit] r8264 - trunk/qgis/src/app/composer
svn_qgis at osgeo.org
Tue Mar 25 03:50:49 EDT 2008
Author: telwertowski
Date: 2008-03-25 03:50:49 -0400 (Tue, 25 Mar 2008)
New Revision: 8264
trunk/qgis/src/app/composer/qgscomposer.cpp
Patch #878 for PrintComposer SVG Export from Steven Bell with conditional compilation directives added to use QSvgGenerator for Qt4.3 or greater while continuing to use Q3Picture for Qt 4.2 or lower.
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp 2008-03-24 18:31:08 UTC (rev 8263)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp 2008-03-25 07:50:49 UTC (rev 8264)
@@ -37,7 +37,11 @@
#include <QSettings>
#include <QIcon>
#include <QPixmap>
+#if QT_VERSION < 0x040300
#include <Q3Picture>
+#else
+#include <QSvgGenerator>
+#endif
#include <QToolBar>
#include <QImageWriter>
#include <QCheckBox>
@@ -773,9 +777,6 @@
void QgsComposer::on_mActionExportAsSVG_activated(void)
-// QT 4 QPicture does not support export to SVG, so we're still using Q3Picture.
-// When QGIS moves to Qt 4.3, we can use QSvgGenerator instead.
QString myQSettingsLabel = "/UI/displaySVGWarning";
QSettings myQSettings;
@@ -791,10 +792,16 @@
m->setCheckBoxQSettingsLabel(myQSettingsLabel);
m->setMessageAsHtml(tr("<p>The SVG export function in Qgis has several "
"problems due to bugs and deficiencies in the "
"Qt4 svg code. Of note, text does not "
"appear in the SVG file and there are problems "
"with the map bounding box clipping other items "
"such as the legend or scale bar.</p>"
+#else
+ "Qt4 svg code. In particular, there are problems "
+ "with layers not being clipped to the map"
+ "bounding box.</p>"
+#endif
"If you require a vector-based output file from "
"Qgis it is suggested that you try printing "
"to PostScript if the SVG output is not "
@@ -822,20 +829,30 @@
mView->setScene(0);//don't redraw the scene on the display while we render
mComposition->setPlotStyle ( QgsComposition::Print );
Q3Picture pic;
QPainter p(&pic);
QRectF renderArea(0,0, (mComposition->paperWidth() * mComposition->scale()), (mComposition->paperHeight() * mComposition->scale()) );
+#else
+ QSvgGenerator generator;
+ generator.setFileName(myOutputFileNameQString);
+ generator.setSize(QSize( (int)mComposition->paperWidth(), (int)mComposition->paperHeight() ));
+ generator.setResolution((int)(mComposition->resolution() / 25.4)); //because the rendering is done in mm, convert the dpi
+ QPainter p(&generator);
+ QRectF renderArea(0,0, mComposition->paperWidth(), mComposition->paperHeight());
+#endif
mComposition->canvas()->render(&p, renderArea);
p.end();
mComposition->setPlotStyle ( QgsComposition::Preview );
mView->setScene(mComposition->canvas()); //now that we're done, set the view to show the scene again
QRect br = pic.boundingRect();
pic.save ( myOutputFileNameQString, "svg" );
+#endif
