[QGIS Commit] r8269 - in trunk/qgis/src/core: . renderer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Mar 25 16:06:25 EDT 2008
Author: jef
Date: 2008-03-25 16:06:25 -0400 (Tue, 25 Mar 2008)
New Revision: 8269
   trunk/qgis/src/core/qgsmaplayer.cpp
   trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp
   trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp
   trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp
code reindentation
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp	2008-03-25 18:55:19 UTC (rev 8268)
+++ trunk/qgis/src/core/qgsmaplayer.cpp	2008-03-25 20:06:25 UTC (rev 8269)
@@ -49,29 +49,29 @@
         mLayerType(type)
-    QgsDebugMsg("QgsMapLayer::QgsMapLayer - lyrname is '" + lyrname + "'");
-    mSRS = new QgsSpatialRefSys();
+  QgsDebugMsg("QgsMapLayer::QgsMapLayer - lyrname is '" + lyrname + "'");
-    // Set the display name = internal name
-    mLayerName = capitaliseLayerName(lyrname);
-    QgsDebugMsg("QgsMapLayer::QgsMapLayer - layerName is '" + mLayerName + "'");
+  mSRS = new QgsSpatialRefSys();
-    // Generate the unique ID of this layer
-    QDateTime dt = QDateTime::currentDateTime();
-    mID = lyrname + dt.toString("yyyyMMddhhmmsszzz");
-    // Tidy the ID up to avoid characters that may cause problems
-    // elsewhere (e.g in some parts of XML). Replaces every non-word
-    // character (word characters are the alphabet, numbers and
-    // underscore) with an underscore.
-    // Note that the first backslashe in the regular expression is
-    // there for the compiler, so the pattern is actually \W
-    mID.replace(QRegExp("[\\W]"), "_");
+  // Set the display name = internal name
+  mLayerName = capitaliseLayerName(lyrname);
+  QgsDebugMsg("QgsMapLayer::QgsMapLayer - layerName is '" + mLayerName + "'");
-    //set some generous  defaults for scale based visibility
-    mMinScale = 0;
-    mMaxScale = 100000000;
-    mScaleBasedVisibility = false;
+  // Generate the unique ID of this layer
+  QDateTime dt = QDateTime::currentDateTime();
+  mID = lyrname + dt.toString("yyyyMMddhhmmsszzz");
+  // Tidy the ID up to avoid characters that may cause problems
+  // elsewhere (e.g in some parts of XML). Replaces every non-word
+  // character (word characters are the alphabet, numbers and
+  // underscore) with an underscore.
+  // Note that the first backslashe in the regular expression is
+  // there for the compiler, so the pattern is actually \W
+  mID.replace(QRegExp("[\\W]"), "_");
+  //set some generous  defaults for scale based visibility
+  mMinScale = 0;
+  mMaxScale = 100000000;
+  mScaleBasedVisibility = false;
@@ -83,13 +83,13 @@
 int QgsMapLayer::type() const
-    return mLayerType;
+  return mLayerType;
 /** Get this layer's unique ID */
 QString QgsMapLayer::getLayerID() const
-    return mID;
+  return mID;
 /** Write property of QString layerName. */
@@ -119,178 +119,178 @@
 QString const & QgsMapLayer::source() const
-    return mDataSource;
+  return mDataSource;
 const QgsRect QgsMapLayer::extent()
-    return mLayerExtent;
+  return mLayerExtent;
 bool QgsMapLayer::draw(QPainter *, QgsRect &, QgsMapToPixel *, QgsCoordinateTransform *, bool)
-    //  std::cout << "In QgsMapLayer::draw" << std::endl;
-    return false;
+  //  std::cout << "In QgsMapLayer::draw" << std::endl;
+  return false;
 void QgsMapLayer::drawLabels(QPainter *, QgsRect &, QgsMapToPixel *, QgsCoordinateTransform *)
 bool QgsMapLayer::readXML( QDomNode & layer_node )
-    QDomElement element = layer_node.toElement();
+  QDomElement element = layer_node.toElement();
-    // XXX not needed? QString type = element.attribute("type");
+  // XXX not needed? QString type = element.attribute("type");
-    // set data source
-    QDomNode mnl = layer_node.namedItem("datasource");
-    QDomElement mne = mnl.toElement();
-    mDataSource = mne.text();
+  // set data source
+  QDomNode mnl = layer_node.namedItem("datasource");
+  QDomElement mne = mnl.toElement();
+  mDataSource = mne.text();
-    // Set the SRS so that we don't ask the user.
-    // Make it the saved SRS to have WMS layer projected correctly.
-    // We will still overwrite whatever GDAL etc picks up anyway
-    // further down this function.
-    QDomNode srsNode = layer_node.namedItem("srs");
-    mSRS->readXML(srsNode);
+  // Set the SRS so that we don't ask the user.
+  // Make it the saved SRS to have WMS layer projected correctly.
+  // We will still overwrite whatever GDAL etc picks up anyway
+  // further down this function.
+  QDomNode srsNode = layer_node.namedItem("srs");
+  mSRS->readXML(srsNode);
-    // now let the children grab what they need from the DOM node.
-    if (!readXML_( layer_node ))
-      return false;
+  // now let the children grab what they need from the DOM node.
+  if (!readXML_( layer_node ))
+    return false;
-    // the internal name is just the data source basename
-    QFileInfo dataSourceFileInfo( mDataSource );
-    //internalName = dataSourceFileInfo.baseName();
+  // the internal name is just the data source basename
+  QFileInfo dataSourceFileInfo( mDataSource );
+  //internalName = dataSourceFileInfo.baseName();
-    // set ID
-    mnl = layer_node.namedItem("id");
-    if ( ! mnl.isNull() )
+  // set ID
+  mnl = layer_node.namedItem("id");
+  if ( ! mnl.isNull() )
+    mne = mnl.toElement();
+    if ( ! mne.isNull() && mne.text().length() > 10 ) // should be at least 17 (yyyyMMddhhmmsszzz)
-        mne = mnl.toElement();
-        if ( ! mne.isNull() && mne.text().length() > 10 ) // should be at least 17 (yyyyMMddhhmmsszzz)
-            mID = mne.text();
+      mID = mne.text();
-    // use scale dependent visibility flag
-    QString scaleBasedVisibility = element.attribute("scaleBasedVisibilityFlag");
-    if ( "1" == scaleBasedVisibility )
-        setScaleBasedVisibility(true);
-    else
-        setScaleBasedVisibility(false);
-    setMinScale(element.attribute("minScale").toFloat());
-    setMaxScale(element.attribute("maxScale").toFloat());
+  // use scale dependent visibility flag
+  QString scaleBasedVisibility = element.attribute("scaleBasedVisibilityFlag");
+  if ( "1" == scaleBasedVisibility )
+    setScaleBasedVisibility(true);
+  else
+    setScaleBasedVisibility(false);
+  setMinScale(element.attribute("minScale").toFloat());
+  setMaxScale(element.attribute("maxScale").toFloat());
-    // set name
-    mnl = layer_node.namedItem("layername");
-    setLayerName( mne.text() );
+  // set name
+  mnl = layer_node.namedItem("layername");
+  setLayerName( mne.text() );
-    // overwrite srs
-    // FIXME: is this necessary?
-    //read transparency level
-    QDomNode transparencyNode = layer_node.namedItem("transparencyLevelInt");
-    if ( ! transparencyNode.isNull() )
-      // set transparency level only if it's in project
-      // (otherwise it sets the layer transparent)
-      QDomElement myElement = transparencyNode.toElement();
-      setTransparency(myElement.text().toInt());
+  // overwrite srs
+  // FIXME: is this necessary?
-    return true;
+  //read transparency level
+  QDomNode transparencyNode = layer_node.namedItem("transparencyLevelInt");
+  if ( ! transparencyNode.isNull() )
+    // set transparency level only if it's in project
+    // (otherwise it sets the layer transparent)
+    QDomElement myElement = transparencyNode.toElement();
+    setTransparency(myElement.text().toInt());
+  return true;
 } // void QgsMapLayer::readXML
 bool QgsMapLayer::readXML_( QDomNode & layer_node )
-    // NOP by default; children will over-ride with behavior specific to them
+  // NOP by default; children will over-ride with behavior specific to them
-    return true;
+  return true;
 } // void QgsMapLayer::readXML_
 bool QgsMapLayer::writeXML( QDomNode & layer_node, QDomDocument & document )
-    // general layer metadata
-    QDomElement maplayer = document.createElement( "maplayer" );
+  // general layer metadata
+  QDomElement maplayer = document.createElement( "maplayer" );
-    if ( scaleBasedVisibility() )
-        maplayer.setAttribute( "scaleBasedVisibilityFlag", 1 );
-    else
-        maplayer.setAttribute( "scaleBasedVisibilityFlag", 0 );
-    maplayer.setAttribute( "minScale", minScale() );
-    maplayer.setAttribute( "maxScale", maxScale() );
+  if ( scaleBasedVisibility() )
+    maplayer.setAttribute( "scaleBasedVisibilityFlag", 1 );
+  else
+    maplayer.setAttribute( "scaleBasedVisibilityFlag", 0 );
+  maplayer.setAttribute( "minScale", minScale() );
+  maplayer.setAttribute( "maxScale", maxScale() );
-    // ID
-    QDomElement id = document.createElement( "id" );
-    QDomText idText = document.createTextNode( getLayerID() );
-    id.appendChild( idText );
+  // ID
+  QDomElement id = document.createElement( "id" );
+  QDomText idText = document.createTextNode( getLayerID() );
+  id.appendChild( idText );
-    maplayer.appendChild( id );
+  maplayer.appendChild( id );
-    // data source
-    QDomElement dataSource = document.createElement( "datasource" );
-    QDomText dataSourceText = document.createTextNode( source() );
-    dataSource.appendChild( dataSourceText );
+  // data source
+  QDomElement dataSource = document.createElement( "datasource" );
+  QDomText dataSourceText = document.createTextNode( source() );
+  dataSource.appendChild( dataSourceText );
-    maplayer.appendChild( dataSource );
+  maplayer.appendChild( dataSource );
-    // layer name
-    QDomElement layerName = document.createElement( "layername" );
-    QDomText layerNameText = document.createTextNode( name() );
-    layerName.appendChild( layerNameText );
+  // layer name
+  QDomElement layerName = document.createElement( "layername" );
+  QDomText layerNameText = document.createTextNode( name() );
+  layerName.appendChild( layerNameText );
-    maplayer.appendChild( layerName );
+  maplayer.appendChild( layerName );
-    // zorder
-    // This is no longer stored in the project file. It is superflous since the layers
-    // are written and read in the proper order.
+  // zorder
+  // This is no longer stored in the project file. It is superflous since the layers
+  // are written and read in the proper order.
-    // spatial reference system id
-    QDomElement mySrsElement = document.createElement( "srs" );
-    mSRS->writeXML(mySrsElement, document);
-    maplayer.appendChild(mySrsElement);
-    // <transparencyLevelInt>
-    QDomElement transparencyLevelIntElement = document.createElement( "transparencyLevelInt" );
-    QDomText    transparencyLevelIntText    = document.createTextNode( QString::number(getTransparency()) );
-    transparencyLevelIntElement.appendChild( transparencyLevelIntText );
-    maplayer.appendChild( transparencyLevelIntElement );
-    // now append layer node to map layer node
+  // spatial reference system id
+  QDomElement mySrsElement = document.createElement( "srs" );
+  mSRS->writeXML(mySrsElement, document);
+  maplayer.appendChild(mySrsElement);
-    layer_node.appendChild( maplayer );
+  // <transparencyLevelInt>
+  QDomElement transparencyLevelIntElement = document.createElement( "transparencyLevelInt" );
+  QDomText    transparencyLevelIntText    = document.createTextNode( QString::number(getTransparency()) );
+  transparencyLevelIntElement.appendChild( transparencyLevelIntText );
+  maplayer.appendChild( transparencyLevelIntElement );
+  // now append layer node to map layer node
-    return writeXML_( maplayer, document );
+  layer_node.appendChild( maplayer );
+  return writeXML_( maplayer, document );
 } // bool QgsMapLayer::writeXML
 bool QgsMapLayer::writeXML_( QDomNode & layer_node, QDomDocument & document )
-    return true;
+  return true;
 } // void QgsMapLayer::writeXML_
@@ -298,7 +298,7 @@
 bool QgsMapLayer::isValid()
-    return mValid;
+  return mValid;
@@ -321,7 +321,7 @@
 void QgsMapLayer::connectNotify( const char * signal )
-    QgsDebugMsg("QgsMapLayer connected to " + QString(signal));
+  QgsDebugMsg("QgsMapLayer connected to " + QString(signal));
 } //  QgsMapLayer::connectNotify
@@ -365,12 +365,12 @@
 void QgsMapLayer::setLayerOrder(QStringList layers)
-      // NOOP
+  // NOOP
 void QgsMapLayer::setSubLayerVisibility(QString name, bool vis)
-      // NOOP
+  // NOOP
 const QgsSpatialRefSys& QgsMapLayer::srs()
@@ -410,7 +410,6 @@
 QString QgsMapLayer::loadDefaultStyle ( bool & theResultFlag )
   QString myURI = publicSource();
   QFileInfo myFileInfo ( myURI );
   //get the file name for our .qml style file
@@ -426,7 +425,7 @@
   QFileInfo myFileInfo ( theURI );
   if ( !myFileInfo.isFile() )
-     return QObject::tr( "Currently only filebased datasets are supported" );
+    return QObject::tr( "Currently only filebased datasets are supported" );
   QFile myFile ( theURI );
   if ( myFile.open(QFile::ReadOnly ) )
@@ -439,7 +438,7 @@
       myFile.close();
       return myErrorMessage + " at line " + QString::number( line ) +
-          " column " + QString::number( column );
+	" column " + QString::number( column );
     else //dom parsed in ok
@@ -450,17 +449,17 @@
       QDomElement myRoot = myDocument.firstChildElement("qgis");
       if (myRoot.isNull())
-        myErrorMessage = "Error: qgis element could not be found in " + theURI;
-        return myErrorMessage;
+	myErrorMessage = "Error: qgis element could not be found in " + theURI;
+	return myErrorMessage;
       QDomElement myLayer = myRoot.firstChildElement("maplayer");
       if (myLayer.isNull())
-        myErrorMessage = "Error: maplayer element could not be found in " + theURI;
+	myErrorMessage = "Error: maplayer element could not be found in " + theURI;
       // we need to ensure the data source matches the layers
       // current datasource not the one specified in the qml
@@ -468,14 +467,14 @@
       QDomElement myDataSource = myLayer.firstChildElement("datasource");
       if (myDataSource.isNull())
-        myErrorMessage = "Error: datasource element could not be found in " + theURI;
+	myErrorMessage = "Error: datasource element could not be found in " + theURI;
       QDomElement myNewDataSource = myDocument.createElement( "datasource" );
       QDomText myDataSourceText = myDocument.createTextNode( source() );
       myNewDataSource.appendChild( myDataSourceText );
       myLayer.replaceChild( myNewDataSource ,
-          myLayer.firstChildElement("datasource") );
+	  myLayer.firstChildElement("datasource") );
       // Now go on to parse the xml (QDomElement inherits QDomNode
@@ -489,7 +488,6 @@
 QString QgsMapLayer::saveDefaultStyle ( bool & theResultFlag )
@@ -537,5 +535,4 @@
     return QObject::tr( "ERROR: Failed to created default style file as " ) + myFileName +
       tr( " Check file permissions and retry." );
Modified: trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp
--- trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp	2008-03-25 18:55:19 UTC (rev 8268)
+++ trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp	2008-03-25 20:06:25 UTC (rev 8269)
@@ -32,60 +32,60 @@
 QgsGraduatedSymbolRenderer::QgsGraduatedSymbolRenderer(QGis::VectorType type)
-    mVectorType=type;
+  mVectorType=type;
 QgsGraduatedSymbolRenderer::QgsGraduatedSymbolRenderer(const QgsGraduatedSymbolRenderer& other)
-    mVectorType = other.mVectorType;
+  mVectorType = other.mVectorType;
+  mClassificationField = other.mClassificationField;
+  const QList<QgsSymbol*> s = other.symbols();
+  for(QList<QgsSymbol*>::const_iterator it=s.begin(); it!=s.end(); ++it)
+    addSymbol(new QgsSymbol(**it));
+  updateSymbolAttributes();
+QgsGraduatedSymbolRenderer& QgsGraduatedSymbolRenderer::operator=(const QgsGraduatedSymbolRenderer& other)
+  if(this != &other)
+    removeSymbols();
-	addSymbol(new QgsSymbol(**it));
-QgsGraduatedSymbolRenderer& QgsGraduatedSymbolRenderer::operator=(const QgsGraduatedSymbolRenderer& other)
-    if(this != &other)
-        mClassificationField = other.mClassificationField;
-        removeSymbols();
-        const QList<QgsSymbol*> s = other.symbols();
-        for(QList<QgsSymbol*>::const_iterator it=s.begin(); it!=s.end(); ++it)
-        updateSymbolAttributes();
-    return *this;
+  return *this;
 QgsGraduatedSymbolRenderer::~QgsGraduatedSymbolRenderer()
 const QList<QgsSymbol*> QgsGraduatedSymbolRenderer::symbols() const
-    return mSymbols;
+  return mSymbols;
 void QgsGraduatedSymbolRenderer::removeSymbols()
-    //free the memory first
-    for (QList<QgsSymbol*>::iterator it = mSymbols.begin(); it != mSymbols.end(); ++it)
-	delete *it;
+  //free the memory first
+  for (QList<QgsSymbol*>::iterator it = mSymbols.begin(); it != mSymbols.end(); ++it)
+    delete *it;
-    //and remove the pointers then
-    mSymbols.clear();
+  //and remove the pointers then
+  mSymbols.clear();
 bool QgsGraduatedSymbolRenderer::willRenderFeature(QgsFeature *f)
@@ -98,18 +98,18 @@
   QgsSymbol* theSymbol = symbolForFeature(&f);
   if(!theSymbol)
+    if ( img && mVectorType == QGis::Point )
-      if ( img && mVectorType == QGis::Point )
-	  img->fill(0);
-      else if ( mVectorType != QGis::Point )
-	  p->setPen(Qt::NoPen);
-	  p->setBrush(Qt::NoBrush);
-      return;
+      img->fill(0);
+    else if ( mVectorType != QGis::Point )
+      p->setPen(Qt::NoPen);
+      p->setBrush(Qt::NoBrush);
+    return;
   //set the qpen and qpainter to the right values
   // Point
@@ -132,30 +132,30 @@
       QgsDebugMsg(QString("Feature has rotation factor %1").arg(rotation));
     *img = theSymbol->getPointSymbolAsImage( widthScale, selected, mSelectionColor,
-                                            *scalefactor * fieldScale, rotation);
+      *scalefactor * fieldScale, rotation);
   // Line, polygon
+    if( !selected )
-      if( !selected )
-	  QPen pen=theSymbol->pen();
-	  pen.setWidthF ( widthScale * pen.width() );
-	  p->setPen(pen);
-	  p->setBrush(theSymbol->brush());
-      else
-	  pen.setColor(mSelectionColor);
-	  QBrush brush=theSymbol->brush();
-	  brush.setColor(mSelectionColor);
-	  p->setPen(pen);
-	  p->setBrush(brush);
+      QPen pen=theSymbol->pen();
+      pen.setWidthF ( widthScale * pen.width() );
+      p->setPen(pen);
+      p->setBrush(theSymbol->brush());
+    else
+      pen.setColor(mSelectionColor);
+      QBrush brush=theSymbol->brush();
+      brush.setColor(mSelectionColor);
+      p->setPen(pen);
+      p->setBrush(brush);
@@ -176,31 +176,31 @@
   if (it == mSymbols.end())      //only draw features which are covered by a render item
-      return 0;
+    return 0;
   return (*it);
 void QgsGraduatedSymbolRenderer::readXML(const QDomNode& rnode, QgsVectorLayer& vl)
-    mVectorType = vl.vectorType();
-    QDomNode classnode = rnode.namedItem("classificationfield");
-    int classificationfield = classnode.toElement().text().toInt();
-    this->setClassificationField(classificationfield);
+  mVectorType = vl.vectorType();
+  QDomNode classnode = rnode.namedItem("classificationfield");
+  int classificationfield = classnode.toElement().text().toInt();
-    QDomNode symbolnode = rnode.namedItem("symbol");
-    while (!symbolnode.isNull())
-	QgsSymbol* sy = new QgsSymbol(mVectorType);
-	sy->readXML ( symbolnode );
-	this->addSymbol(sy);
+  this->setClassificationField(classificationfield);
-	symbolnode = symbolnode.nextSibling();
-    vl.setRenderer(this);
+  QDomNode symbolnode = rnode.namedItem("symbol");
+  while (!symbolnode.isNull())
+    QgsSymbol* sy = new QgsSymbol(mVectorType);
+    sy->readXML ( symbolnode );
+    this->addSymbol(sy);
+    symbolnode = symbolnode.nextSibling();
+  vl.setRenderer(this);
 QgsAttributeList QgsGraduatedSymbolRenderer::classificationAttributes() const
@@ -238,30 +238,30 @@
 QString QgsGraduatedSymbolRenderer::name() const
-    return "Graduated Symbol";
+  return "Graduated Symbol";
 bool QgsGraduatedSymbolRenderer::writeXML( QDomNode & layer_node, QDomDocument & document ) const
-    bool returnval=true;
-    QDomElement graduatedsymbol=document.createElement("graduatedsymbol");
-    layer_node.appendChild(graduatedsymbol);
-    QDomElement classificationfield=document.createElement("classificationfield");
-    QDomText classificationfieldtxt=document.createTextNode(QString::number(mClassificationField));
-    classificationfield.appendChild(classificationfieldtxt);
-    graduatedsymbol.appendChild(classificationfield);
-    for (QList<QgsSymbol*>::const_iterator it = mSymbols.begin(); it != mSymbols.end(); ++it)
+  bool returnval=true;
+  QDomElement graduatedsymbol=document.createElement("graduatedsymbol");
+  layer_node.appendChild(graduatedsymbol);
+  QDomElement classificationfield=document.createElement("classificationfield");
+  QDomText classificationfieldtxt=document.createTextNode(QString::number(mClassificationField));
+  classificationfield.appendChild(classificationfieldtxt);
+  graduatedsymbol.appendChild(classificationfield);
+  for (QList<QgsSymbol*>::const_iterator it = mSymbols.begin(); it != mSymbols.end(); ++it)
+    if(!(*it)->writeXML(graduatedsymbol,document))
-	if(!(*it)->writeXML(graduatedsymbol,document))
-	    returnval=false;
+      returnval=false;
-    return returnval;
+  return returnval;
 QgsRenderer* QgsGraduatedSymbolRenderer::clone() const
-    QgsGraduatedSymbolRenderer* r = new QgsGraduatedSymbolRenderer(*this);
-    return r;
+  QgsGraduatedSymbolRenderer* r = new QgsGraduatedSymbolRenderer(*this);
+  return r;
Modified: trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp
--- trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp	2008-03-25 18:55:19 UTC (rev 8268)
+++ trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp	2008-03-25 20:06:25 UTC (rev 8269)
@@ -33,60 +33,60 @@
 QgsSingleSymbolRenderer::QgsSingleSymbolRenderer(QGis::VectorType type)
-    mVectorType=type;
-    //initial setting based on random color
-    //random fill colors for points and polygons and pen colors for lines
-    int red = 1 + (int) (255.0 * rand() / (RAND_MAX + 1.0));
-    int green = 1 + (int) (255.0 * rand() / (RAND_MAX + 1.0));
-    int blue = 1 + (int) (255.0 * rand() / (RAND_MAX + 1.0));
+  mVectorType=type;
-    if (type == QGis::Line)
-	sy->setColor(QColor(red, green, blue));
-    else
-	sy->setFillColor(QColor(red, green, blue));
-	sy->setFillStyle(Qt::SolidPattern);
-	sy->setColor(QColor(0, 0, 0));
-    sy->setLineWidth(1);
-    mSymbol=sy;
+  //initial setting based on random color
+  //random fill colors for points and polygons and pen colors for lines
+  int red = 1 + (int) (255.0 * rand() / (RAND_MAX + 1.0));
+  int green = 1 + (int) (255.0 * rand() / (RAND_MAX + 1.0));
+  int blue = 1 + (int) (255.0 * rand() / (RAND_MAX + 1.0));
+  if (type == QGis::Line)
+    sy->setColor(QColor(red, green, blue));
+  else
+    sy->setFillColor(QColor(red, green, blue));
+    sy->setFillStyle(Qt::SolidPattern);
+    sy->setColor(QColor(0, 0, 0));
+  sy->setLineWidth(1);
+  mSymbol=sy;
 QgsSingleSymbolRenderer::QgsSingleSymbolRenderer(const QgsSingleSymbolRenderer& other)
-    mSymbol = new QgsSymbol(*other.mSymbol);
+  mSymbol = new QgsSymbol(*other.mSymbol);
 QgsSingleSymbolRenderer& QgsSingleSymbolRenderer::operator=(const QgsSingleSymbolRenderer& other)
-    if(this!=&other)
-      delete mSymbol;
-    return *this;
+  if(this!=&other)
+    delete mSymbol;
+  return *this;
 QgsSingleSymbolRenderer::~QgsSingleSymbolRenderer()
-    delete mSymbol;
+  delete mSymbol;
 void QgsSingleSymbolRenderer::addSymbol(QgsSymbol* sy)
-    delete mSymbol;
-    mSymbol=sy;
+  delete mSymbol;
+  mSymbol=sy;
 void QgsSingleSymbolRenderer::renderFeature(QPainter * p, QgsFeature & f, QImage* img,
@@ -145,25 +145,25 @@
 void QgsSingleSymbolRenderer::readXML(const QDomNode& rnode, QgsVectorLayer& vl)
-    QDomNode synode = rnode.namedItem("symbol");
-    if ( synode.isNull() )
-        QgsDebugMsg("No symbol node in project file's renderitem DOM");
-        // XXX abort?
-    else
-        sy->readXML ( synode );
+  QDomNode synode = rnode.namedItem("symbol");
-    //create a renderer and add it to the vector layer
+  if ( synode.isNull() )
+    QgsDebugMsg("No symbol node in project file's renderitem DOM");
+    // XXX abort?
+  else
+    sy->readXML ( synode );
+  //create a renderer and add it to the vector layer
 bool QgsSingleSymbolRenderer::writeXML( QDomNode & layer_node, QDomDocument & document ) const
Modified: trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp
--- trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp	2008-03-25 18:55:19 UTC (rev 8268)
+++ trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp	2008-03-25 20:06:25 UTC (rev 8269)
@@ -30,71 +30,71 @@
 QgsUniqueValueRenderer::QgsUniqueValueRenderer(QGis::VectorType type): mClassificationField(0)
-    mVectorType = type;
+  mVectorType = type;
 QgsUniqueValueRenderer::QgsUniqueValueRenderer(const QgsUniqueValueRenderer& other)
-    QMap<QString, QgsSymbol*> s = other.mSymbols;
-    for(QMap<QString, QgsSymbol*>::iterator it=s.begin(); it!=s.end(); ++it)
-	QgsSymbol* s = new QgsSymbol(* it.value());
-	insertValue(it.key(), s);
+  QMap<QString, QgsSymbol*> s = other.mSymbols;
+  for(QMap<QString, QgsSymbol*>::iterator it=s.begin(); it!=s.end(); ++it)
+    QgsSymbol* s = new QgsSymbol(* it.value());
+    insertValue(it.key(), s);
 QgsUniqueValueRenderer& QgsUniqueValueRenderer::operator=(const QgsUniqueValueRenderer& other)
+    clearValues();
+    for(QMap<QString, QgsSymbol*>::iterator it=mSymbols.begin(); it!=mSymbols.end(); ++it)
-        clearValues();
-        for(QMap<QString, QgsSymbol*>::iterator it=mSymbols.begin(); it!=mSymbols.end(); ++it)
-            QgsSymbol* s = new QgsSymbol(*it.value());
+      QgsSymbol* s = new QgsSymbol(*it.value());
-    return *this;
+  return *this;
 QgsUniqueValueRenderer::~QgsUniqueValueRenderer()
-    for(QMap<QString,QgsSymbol*>::iterator it=mSymbols.begin();it!=mSymbols.end();++it)
-	delete it.value();
+  for(QMap<QString,QgsSymbol*>::iterator it=mSymbols.begin();it!=mSymbols.end();++it)
+    delete it.value();
 const QList<QgsSymbol*> QgsUniqueValueRenderer::symbols() const
-    QList <QgsSymbol*> symbollist;
-    for(QMap<QString, QgsSymbol*>::const_iterator it = mSymbols.begin(); it!=mSymbols.end(); ++it)
-	symbollist.append(it.value());
-    return symbollist;
+  QList <QgsSymbol*> symbollist;
+  for(QMap<QString, QgsSymbol*>::const_iterator it = mSymbols.begin(); it!=mSymbols.end(); ++it)
+    symbollist.append(it.value());
+  return symbollist;
 void QgsUniqueValueRenderer::insertValue(QString name, QgsSymbol* symbol)
-    mSymbols.insert(name, symbol);
+  mSymbols.insert(name, symbol);
 void QgsUniqueValueRenderer::setClassificationField(int field)
-    mClassificationField=field;
+  mClassificationField=field;
 int QgsUniqueValueRenderer::classificationField() const
-    return mClassificationField;
+  return mClassificationField;
 bool QgsUniqueValueRenderer::willRenderFeature(QgsFeature *f)
@@ -107,19 +107,19 @@
   QgsSymbol* symbol = symbolForFeature(&f);
   if(!symbol) //no matching symbol
-	  img->fill(0);
-      return;
+      img->fill(0);
+    return;
   // Point
@@ -140,29 +140,29 @@
     *img = symbol->getPointSymbolAsImage( widthScale, selected, mSelectionColor,
   // Line, polygon
+    if( !selected )
-      if( !selected )
-	  QPen pen=symbol->pen();
-	  p->setPen(pen);
-	  p->setBrush(symbol->brush());
-      else
-	  QBrush brush=symbol->brush();
-		p->setPen(pen);
+      QPen pen=symbol->pen();
+      p->setPen(pen);
+      p->setBrush(symbol->brush());
+    else
+      QBrush brush=symbol->brush();
+      p->setPen(pen);
 QgsSymbol* QgsUniqueValueRenderer::symbolForFeature(const QgsFeature* f)
@@ -170,44 +170,44 @@
   //first find out the value
   const QgsAttributeMap& attrs = f->attributeMap();
   QString value = attrs[mClassificationField].toString();
   QMap<QString,QgsSymbol*>::iterator it=mSymbols.find(value);
   if(it == mSymbols.end())
-      return 0;
+    return 0;
   else
-      return it.value();
+    return it.value();
 void QgsUniqueValueRenderer::readXML(const QDomNode& rnode, QgsVectorLayer& vl)
-	QgsSymbol* msy = new QgsSymbol(mVectorType);
-	msy->readXML ( symbolnode );
-	this->insertValue(msy->lowerValue(),msy);
+    QgsSymbol* msy = new QgsSymbol(mVectorType);
+    msy->readXML ( symbolnode );
+    this->insertValue(msy->lowerValue(),msy);
 void QgsUniqueValueRenderer::clearValues()
-    mSymbols.clear();
+  mSymbols.clear();
 void QgsUniqueValueRenderer::updateSymbolAttributes()
@@ -240,35 +240,35 @@
 QgsAttributeList QgsUniqueValueRenderer::classificationAttributes() const
-    QgsAttributeList list(mSymbolAttributes);
-    if ( ! list.contains(mClassificationField) )
-      list.append(mClassificationField);
-    return list;
+  QgsAttributeList list(mSymbolAttributes);
+  if ( ! list.contains(mClassificationField) )
+    list.append(mClassificationField);
+  return list;
 bool QgsUniqueValueRenderer::writeXML( QDomNode & layer_node, QDomDocument & document ) const
-    QDomElement uniquevalue=document.createElement("uniquevalue");
-    layer_node.appendChild(uniquevalue);
-    uniquevalue.appendChild(classificationfield);
-    for(QMap<QString,QgsSymbol*>::const_iterator it=mSymbols.begin();it!=mSymbols.end();++it)
+  QDomElement uniquevalue=document.createElement("uniquevalue");
+  layer_node.appendChild(uniquevalue);
+  uniquevalue.appendChild(classificationfield);
+  for(QMap<QString,QgsSymbol*>::const_iterator it=mSymbols.begin();it!=mSymbols.end();++it)
+    if(!(it.value()->writeXML(uniquevalue,document)))
-	if(!(it.value()->writeXML(uniquevalue,document)))
-	    returnval=false;
+      returnval=false;
-    return returnval;
+  return returnval;
 QgsRenderer* QgsUniqueValueRenderer::clone() const
-    QgsUniqueValueRenderer* r = new QgsUniqueValueRenderer(*this);
-    return r;
+  QgsUniqueValueRenderer* r = new QgsUniqueValueRenderer(*this);
+  return r;
More information about the QGIS-commit mailing list
