[QGIS Commit] r8271 - trunk/qgis/src/core
svn_qgis at osgeo.org
Tue Mar 25 16:16:03 EDT 2008
Author: jef
Date: 2008-03-25 16:16:03 -0400 (Tue, 25 Mar 2008)
New Revision: 8271
trunk/qgis/src/core/qgsmaplayer.cpp
fix msvc warning
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2008-03-25 20:08:26 UTC (rev 8270)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2008-03-25 20:16:03 UTC (rev 8271)
@@ -428,62 +428,64 @@
return QObject::tr( "Currently only filebased datasets are supported" );
QFile myFile ( theURI );
- if ( myFile.open(QFile::ReadOnly ) )
+ if ( !myFile.open(QFile::ReadOnly ) )
- QDomDocument myDocument ( "qgis" );
- // location of problem associated with errorMsg
- int line, column;
- QString myErrorMessage;
- if ( !myDocument.setContent ( &myFile, &myErrorMessage, &line, &column ) )
+ return QObject::tr( "File could not been opened." );
+ QDomDocument myDocument ( "qgis" );
+ // location of problem associated with errorMsg
+ int line, column;
+ QString myErrorMessage;
+ if ( !myDocument.setContent ( &myFile, &myErrorMessage, &line, &column ) )
+ myFile.close();
+ return myErrorMessage + " at line " + QString::number( line ) +
+ " column " + QString::number( column );
+ else //dom parsed in ok
+ myFile.close();
+ // now get the layer node out and pass it over to the layer
+ // to deserialise...
+ QDomElement myRoot = myDocument.firstChildElement("qgis");
+ if (myRoot.isNull())
- myFile.close();
- return myErrorMessage + " at line " + QString::number( line ) +
- " column " + QString::number( column );
+ myErrorMessage = "Error: qgis element could not be found in " + theURI;
+ return myErrorMessage;
- else //dom parsed in ok
+ QDomElement myLayer = myRoot.firstChildElement("maplayer");
+ if (myLayer.isNull())
- myFile.close();
+ myErrorMessage = "Error: maplayer element could not be found in " + theURI;
- // now get the layer node out and pass it over to the layer
- // to deserialise...
- QDomElement myRoot = myDocument.firstChildElement("qgis");
- if (myRoot.isNull())
- myErrorMessage = "Error: qgis element could not be found in " + theURI;
- return myErrorMessage;
+ // we need to ensure the data source matches the layers
+ // current datasource not the one specified in the qml
+ QDomElement myDataSource = myLayer.firstChildElement("datasource");
+ if (myDataSource.isNull())
+ myErrorMessage = "Error: datasource element could not be found in " + theURI;
+ QDomElement myNewDataSource = myDocument.createElement( "datasource" );
+ QDomText myDataSourceText = myDocument.createTextNode( source() );
+ myNewDataSource.appendChild( myDataSourceText );
+ myLayer.replaceChild( myNewDataSource ,
+ myLayer.firstChildElement("datasource") );
- QDomElement myLayer = myRoot.firstChildElement("maplayer");
- if (myLayer.isNull())
- myErrorMessage = "Error: maplayer element could not be found in " + theURI;
+ // Now go on to parse the xml (QDomElement inherits QDomNode
+ // so we can just pass along the element to readXML)
+ theResultFlag = readXML ( myLayer );
- // we need to ensure the data source matches the layers
- // current datasource not the one specified in the qml
- QDomElement myDataSource = myLayer.firstChildElement("datasource");
- if (myDataSource.isNull())
- myErrorMessage = "Error: datasource element could not be found in " + theURI;
- QDomElement myNewDataSource = myDocument.createElement( "datasource" );
- QDomText myDataSourceText = myDocument.createTextNode( source() );
- myNewDataSource.appendChild( myDataSourceText );
- myLayer.replaceChild( myNewDataSource ,
- myLayer.firstChildElement("datasource") );
- // Now go on to parse the xml (QDomElement inherits QDomNode
- // so we can just pass along the element to readXML)
- theResultFlag = readXML ( myLayer );
- return QObject::tr( "Loaded default style file from " ) + theURI;
+ return QObject::tr( "Loaded default style file from " ) + theURI;
QString QgsMapLayer::saveDefaultStyle ( bool & theResultFlag )
@@ -497,7 +499,6 @@
QString QgsMapLayer::saveNamedStyle ( const QString theURI , bool & theResultFlag )
QFileInfo myFileInfo ( theURI );
//now check if we can write to the dir where the layer
//exists...
