[QGIS Commit] r8301 - in branches/rendercontext-branch/src: app/composer core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Mar 30 10:18:39 EDT 2008
Author: mhugent
Date: 2008-03-30 10:18:38 -0400 (Sun, 30 Mar 2008)
New Revision: 8301
   branches/rendercontext-branch/src/app/composer/qgscomposer.cpp
   branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp
   branches/rendercontext-branch/src/app/composer/qgscomposermap.h
   branches/rendercontext-branch/src/core/qgsmaprender.cpp
Started to work on width scaling. Still incomplete and buggy at the moment
Modified: branches/rendercontext-branch/src/app/composer/qgscomposer.cpp
--- branches/rendercontext-branch/src/app/composer/qgscomposer.cpp	2008-03-28 21:52:51 UTC (rev 8300)
+++ branches/rendercontext-branch/src/app/composer/qgscomposer.cpp	2008-03-30 14:18:38 UTC (rev 8301)
@@ -366,7 +366,7 @@
       std::cout << "Resolution = " << resolution << std::endl;
-      double scale = resolution / 25.4 / mComposition->scale();
+      //double scale = resolution / 25.4 / mComposition->scale();
       mComposition->setPlotStyle(QgsComposition::Postscript);
@@ -398,12 +398,12 @@
             QPainter p(mPrinter);
-            p.scale(scale, scale);
+            //p.scale(scale, scale);
-            QRectF renderArea(0, 0, (mComposition->paperWidth() * mComposition->scale()),
-                              (mComposition->paperHeight() * mComposition->scale()));
+            //QRectF renderArea(0, 0, (mComposition->paperWidth() * mComposition->scale()),
+	    //(mComposition->paperHeight() * mComposition->scale()));
-            mComposition->canvas()->render(&p, renderArea);
+            mComposition->canvas()->render(&p/*, renderArea*/);
             p.end();
@@ -608,12 +608,13 @@
               std::cout << "Printing ... " << std::endl;
+	      //MH: is this necessary?
               p.end();
               std::cout << "... printing finished" << std::endl;
Modified: branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp
--- branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp	2008-03-28 21:52:51 UTC (rev 8300)
+++ branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp	2008-03-30 14:18:38 UTC (rev 8301)
@@ -125,139 +125,34 @@
 /* This function is called by paint() and cache() to render the map.  It does not override any functions
 from QGraphicsItem. */
-void QgsComposerMap::draw ( QPainter *painter, QgsRect &extent, QgsMapToPixel *transform)
+void QgsComposerMap::draw ( QPainter *painter, const QgsRect& extent, const QSize& size, int dpi)
   mMapCanvas->freeze(true);  // necessary ?
-  int nlayers = mMapCanvas->layerCount();
-    QgsCoordinateTransform* ct;
-    QgsRenderContext theRenderContext;
-    theRenderContext.setPainter(painter);
-    theRenderContext.setExtent(extent);
-    theRenderContext.setMapToPixel(*transform);
-  for ( int i = nlayers - 1; i >= 0; i-- ) {
-    QgsMapLayer *layer = mMapCanvas->getZpos(i);
-    //if ( !layer->visible() ) continue;
-    if (mMapCanvas->projectionsEnabled())
+  if(!painter)
-      ct = new QgsCoordinateTransform(layer->srs(), mMapCanvas->mapRender()->destinationSrs());
+      return;
-    else
+  QgsMapRender* canvasMapRender = mMapCanvas->mapRender();
+  if(!canvasMapRender)
-      ct = NULL;
+      return;
-    theRenderContext.setCoordTransform(ct);
-    if ( layer->type() == QgsMapLayer::VECTOR ) {
-      QgsVectorLayer *vector = dynamic_cast <QgsVectorLayer*> (layer);
-      double widthScale = mWidthScale;
-      double symbolScale = mSymbolScale;
-      theRenderContext.setScaleFactor( (widthScale + symbolScale) / 2);
-//TODO: attempt to scale cache lines and point symbols to be larger as we zoom in
-/*    if(creating cache pixmap)
-        widthScale *= (cachePixmap.width / map.rect.width);
-        symbolScale *= (cachePixmap.width / map.rect.width);
-      //QgsRect r1, r2;
-      //r1 = extent;
-      //bool split = layer->projectExtent(r1, r2);
-      //todo: implement with QgsMapRender
-      vector->draw(theRenderContext);
-      //if ( split )
-      //theRenderContext.setExtent(r2);
-      //vector->draw(theRenderContext);
-    } else {
-      // raster
-      if ( plotStyle() == QgsComposition::Print || plotStyle() == QgsComposition::Postscript ) {
-        // we have to rescale the raster to get requested resolution
-        // calculate relation between composition point size and requested resolution (in mm)
-        double multip = (1. / mComposition->scale()) / (25.4 / mComposition->resolution()) ;
-        double sc = mExtent.width() / (multip*QGraphicsRectItem::rect().width());
-        QgsMapToPixel trans ( sc, multip*QGraphicsRectItem::rect().height(), mExtent.yMin(), mExtent.xMin() );
-	theRenderContext.setMapToPixel(trans);
-        painter->save();
-        painter->scale( 1./multip, 1./multip);
-        layer->draw(theRenderContext);
-        painter->restore();
-      else
-  // Draw vector labels
+  QgsMapRender theMapRender;
+  theMapRender.setExtent(extent);
+  theMapRender.setOutputSize(size, dpi);
+  theMapRender.setLayerSet(canvasMapRender->layerSet());
+  QgsRenderContext* theRenderContext = theMapRender.renderContext();
+  if(theRenderContext)
+      theRenderContext->setDrawEditingInformation(false);
+      theRenderContext->setRenderingStopped(false);
-    else
-      ct = NULL;
-//    if ( !layer->visible() ) continue; //this doesn't work with the newer map layer code
-      if ( vector->labelOn() ) {
-        double fontScale = 25.4 * mFontScale * mComposition->scale() / 72;
-        if ( plotStyle() == QgsComposition::Postscript )
-          //fontScale = QgsComposition::psFontScaleFactor() * 72.0 / mComposition->resolution();
-          // TODO
-          // This is not completely correct because fonts written to postscript
-          // should use size metrics.ascent() * 72.0 / mComposition->resolution();
-          // We could add a factor for metrics.ascent()/size but it is variable
-          // Add a parrameter in drawLables() ?
-          QFont tempFont;
-          tempFont.setFamily(vector->label()->layerAttributes()->family());
-          double size = vector->label()->layerAttributes()->size();
-          size = 25.4 * size / 72;
-          tempFont.setPointSizeF(size);
-          QFontMetricsF tempMetrics(tempFont);
-          fontScale = tempMetrics.ascent() * 72.0 / mComposition->resolution();
-          //std::cout << "fontScale: " << fontScale << std::endl;
-          fontScale *= mFontScale;
-          //divide out the font size, since it will be multiplied back in when drawing the labels
-          fontScale /= vector->label()->layerAttributes()->size();
-        vector->drawLabels (  painter, extent, transform, ct, fontScale );
+  theMapRender.render(painter);
   mMapCanvas->freeze(false);
@@ -313,7 +208,7 @@
     QPainter p(&mCachePixmap);
-    draw( &p, mCacheExtent, &transform);
+    draw( &p, mCacheExtent, QSize(w, h), mCachePixmap.logicalDpiX());
     p.end();
     mNumCachedLayers = mMapCanvas->layerCount();
@@ -355,18 +250,16 @@
     std::cout << "render" << std::endl;
-    double scale = mExtent.width() / QGraphicsRectItem::rect().width();
-    QgsMapToPixel transform(scale, QGraphicsRectItem::rect().height(), mExtent.yMin(), mExtent.xMin() );
+    QPaintDevice* thePaintDevice = painter->device();
+    if(!thePaintDevice)
+	return;
-    painter->save();
-    painter->translate(0, 0); //do we need this?
-    // TODO: Qt4 appears to force QPainter::CoordDevice - need to check if this is actually valid.
-    painter->setClipRect (QRectF( 0, 0, QGraphicsRectItem::rect().width(), QGraphicsRectItem::rect().height() ));
-    draw( painter, mExtent, &transform);
+    QRectF bRect = boundingRect();
+    QSize theSize(bRect.width(), bRect.height());
+    draw( painter, mExtent, theSize, 25.4); //scene coordinates seem to be in mm
   // Draw frame around
Modified: branches/rendercontext-branch/src/app/composer/qgscomposermap.h
--- branches/rendercontext-branch/src/app/composer/qgscomposermap.h	2008-03-28 21:52:51 UTC (rev 8300)
+++ branches/rendercontext-branch/src/app/composer/qgscomposermap.h	2008-03-30 14:18:38 UTC (rev 8301)
@@ -72,7 +72,7 @@
     bool readXML( QDomNode & node );
     /** \brief Draw to paint device */
-    void draw(QPainter *painter, QgsRect &extent, QgsMapToPixel *transform);
+    void draw(QPainter *painter, const QgsRect& extent, const QSize& size, int dpi);
     /** \brief Reimplementation of QCanvasItem::paint - draw on canvas */
     void paint (QPainter* painter, const QStyleOptionGraphicsItem* itemStyle, QWidget* pWidget);
Modified: branches/rendercontext-branch/src/core/qgsmaprender.cpp
--- branches/rendercontext-branch/src/core/qgsmaprender.cpp	2008-03-28 21:52:51 UTC (rev 8300)
+++ branches/rendercontext-branch/src/core/qgsmaprender.cpp	2008-03-30 14:18:38 UTC (rev 8301)
@@ -230,6 +230,13 @@
   //so must be false at every new render operation
   mRenderContext.setRenderingStopped(false);
+  //calculate scale factor
+  //use the specified dpi and not those from the paint device
+  //because sometimes QPainter units are in a local coord sys (e.g. in case of QGraphicsScene)
+  double meanDpi = mScaleCalculator->dpi();
+  double scaleFactor = meanDpi/25.4;
+  mRenderContext.setScaleFactor(scaleFactor);
   // render all layers in the stack, starting at the base
   QListIterator<QString> li(mLayerSet);
   li.toBack();
More information about the QGIS-commit mailing list
