[QGIS Commit] r8417 - trunk/qgis/src/app/composer
svn_qgis at osgeo.org
Fri May 9 10:55:43 EDT 2008
Author: StevenB
Date: 2008-05-09 10:55:43 -0400 (Fri, 09 May 2008)
New Revision: 8417
trunk/qgis/src/app/composer/qgscomposerlabel.cpp
trunk/qgis/src/app/composer/qgscomposermap.cpp
trunk/qgis/src/app/composer/qgscomposerpicture.cpp
trunk/qgis/src/app/composer/qgscomposerscalebar.cpp
trunk/qgis/src/app/composer/qgscomposervectorlegend.cpp
trunk/qgis/src/app/composer/qgscomposerview.cpp
trunk/qgis/src/app/composer/qgscomposition.cpp
Cleaned up a bunch of debug statments.
Modified: trunk/qgis/src/app/composer/qgscomposerlabel.cpp
--- trunk/qgis/src/app/composer/qgscomposerlabel.cpp 2008-05-08 21:45:52 UTC (rev 8416)
+++ trunk/qgis/src/app/composer/qgscomposerlabel.cpp 2008-05-09 14:55:43 UTC (rev 8417)
@@ -31,7 +31,9 @@
setupUi(this);
- //std::cout << "QgsComposerLabel::QgsComposerLabel()" << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "QgsComposerLabel::QgsComposerLabel()" << std::endl;
+#endif
mComposition = composition;
mId = id;
@@ -64,7 +66,9 @@
QgsComposerLabel::QgsComposerLabel ( QgsComposition *composition, int id )
: QAbstractGraphicsShapeItem(0)
+#ifdef QGISDEBUG
+#endif
setupUi(this);
@@ -86,7 +90,10 @@
QgsComposerLabel::~QgsComposerLabel()
- //std::cout << "QgsComposerLabel::~QgsComposerLabel" << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "QgsComposerLabel::~QgsComposerLabel" << std::endl;
+#endif
+ //make ourselves disappear so there aren't any interesting effects when we get destroyed
QGraphicsItem::hide();
@@ -96,7 +103,9 @@
#define WIDTH_EXTENSION 1.0
void QgsComposerLabel::paint ( QPainter* painter, const QStyleOptionGraphicsItem* itemStyle, QWidget* pWidget )
- //std::cout << "QgsComposerLabel::paint" << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "QgsComposerLabel::paint" << std::endl;
+#endif
float size = 25.4 * mComposition->scale() * mFont.pointSizeF() / 72;
@@ -234,7 +243,9 @@
QPolygonF QgsComposerLabel::areaPoints() const
- //std::cout << "QgsComposerLabel::areaPoints" << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "QgsComposerLabel::areaPoints" << std::endl;
+#endif
QRectF r = boundingRect();
QPolygonF pa;
@@ -268,11 +279,12 @@
void QgsComposerLabel::setSelected ( bool s )
- //std::cout << "QgsComposerLabel::setSelected" << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "QgsComposerLabel::setSelected" << std::endl;
+#endif
mSelected = s;
QAbstractGraphicsShapeItem::update(); // show highlight
- std::cout << "mSelected = " << mSelected << std::endl;
bool QgsComposerLabel::selected( void )
Modified: trunk/qgis/src/app/composer/qgscomposermap.cpp
--- trunk/qgis/src/app/composer/qgscomposermap.cpp 2008-05-08 21:45:52 UTC (rev 8416)
+++ trunk/qgis/src/app/composer/qgscomposermap.cpp 2008-05-09 14:55:43 UTC (rev 8417)
@@ -42,8 +42,9 @@
QgsComposerMap::QgsComposerMap ( QgsComposition *composition, int id, int x, int y, int width, int height )
: QWidget(), QGraphicsRectItem(0,0,width,height,0)
-std::cout << "QgsComposerMap::QgsComposerMap()" << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "QgsComposerMap::QgsComposerMap()" << std::endl;
+#endif
setupUi(this);
@@ -119,7 +120,9 @@
QgsComposerMap::~QgsComposerMap()
+#ifdef QGISDEBUG
std::cerr << "QgsComposerMap::~QgsComposerMap" << std::endl;
+#endif
/* This function is called by paint() and cache() to render the map. It does not override any functions
@@ -265,7 +268,9 @@
void QgsComposerMap::cache ( void )
+#ifdef QGISDEBUG
std::cout << "QgsComposerMap::cache()" << std::endl;
+#endif
// Create preview on some reasonable size. It was slow with cca 1500x1500 points on 2x1.5GHz
// Note: The resolution should also respect the line widths, it means that
@@ -278,8 +283,10 @@
// It can happen that extent is not initialised well -> check
if ( h < 1 || h > 10000 ) h = w;
+#ifdef QGISDEBUG
std::cout << "extent = " << mExtent.width() << " x " << mExtent.height() << std::endl;
std::cout << "cache = " << w << " x " << h << std::endl;
+#endif
mCacheExtent = QgsRect ( mExtent );
double scale = mExtent.width() / w;
@@ -299,7 +306,9 @@
* on both the cache, screen render, and print.
+#ifdef QGISDEBUG
std::cout << "transform = " << transform.showParameters().toLocal8Bit().data() << std::endl;
+#endif
mCachePixmap.fill(QColor(255,255,255));
@@ -317,12 +326,12 @@
if ( mDrawing ) return;
mDrawing = true;
+#ifdef QGISDEBUG
std::cout << "QgsComposerMapt::paint mPlotStyle = " << plotStyle()
<< " mPreviewMode = " << mPreviewMode << std::endl;
+#endif
if ( plotStyle() == QgsComposition::Preview && mPreviewMode == Cache ) { // Draw from cache
- std::cout << "use cache" << std::endl;
if ( !mCacheUpdated || mMapCanvas->layerCount() != mNumCachedLayers )
cache();
@@ -330,8 +339,10 @@
// Scale so that the cache fills the map rectangle
double scale = 1.0 * QGraphicsRectItem::rect().width() / mCachePixmap.width();
+ #ifdef QGISDEBUG
std::cout << "scale = " << scale << std::endl;
+ #endif
painter->save();
painter->translate(0, 0); //do we need this?
@@ -346,7 +357,9 @@
plotStyle() == QgsComposition::Print ||
plotStyle() == QgsComposition::Postscript )
+ #ifdef QGISDEBUG
std::cout << "render" << std::endl;
+ #endif
double scale = mExtent.width() / QGraphicsRectItem::rect().width();
QgsMapToPixel transform(scale, QGraphicsRectItem::rect().height(), mExtent.yMin(), mExtent.xMin() );
@@ -503,8 +516,9 @@
void QgsComposerMap::mapCanvasChanged ( void )
+#ifdef QGISDEBUG
std::cout << "QgsComposerMap::canvasChanged" << std::endl;
+#endif
mCacheUpdated = false;
QGraphicsRectItem::update();
@@ -562,9 +576,11 @@
mExtent.setYmax ( yc + height/2 );
+#ifdef QGISDEBUG
std::cout << "mUserExtent = " << mUserExtent.stringRep().toLocal8Bit().data() << std::endl;
std::cout << "mScale = " << mScale << std::endl;
std::cout << "mExtent = " << mExtent.stringRep().toLocal8Bit().data() << std::endl;
+#endif
setOptions();
@@ -581,8 +597,10 @@
void QgsComposerMap::setOptions ( void )
+#ifdef QGISDEBUG
std::cout << "QgsComposerMap::setOptions" << std::endl;
+#endif
mNameLabel->setText ( mName );
Modified: trunk/qgis/src/app/composer/qgscomposerpicture.cpp
--- trunk/qgis/src/app/composer/qgscomposerpicture.cpp 2008-05-08 21:45:52 UTC (rev 8416)
+++ trunk/qgis/src/app/composer/qgscomposerpicture.cpp 2008-05-09 14:55:43 UTC (rev 8417)
@@ -33,8 +33,6 @@
#define PI 3.14159265358979323846
-#define QGISDEBUG 1
QgsComposerPicture::QgsComposerPicture ( QgsComposition *composition,
int id, QString file )
: QWidget(composition),
Modified: trunk/qgis/src/app/composer/qgscomposerscalebar.cpp
--- trunk/qgis/src/app/composer/qgscomposerscalebar.cpp 2008-05-08 21:45:52 UTC (rev 8416)
+++ trunk/qgis/src/app/composer/qgscomposerscalebar.cpp 2008-05-09 14:55:43 UTC (rev 8417)
@@ -36,7 +36,10 @@
setupUi(this);
+#ifdef QGISDEBUG
std::cout << "QgsComposerScalebar::QgsComposerScalebar()" << std::endl;
+#endif
mId = id;
mSelected = false;
@@ -120,7 +123,9 @@
mMap(0),
mBrush(QColor(150,150,150))
+#ifdef QGISDEBUG
+#endif
setupUi(this);
@@ -410,7 +415,9 @@
void QgsComposerScalebar::recalculate(void)
+#ifdef QGISDEBUG
std::cout << "QgsComposerScalebar::recalculate" << std::endl;
+#endif
// !!! prepareGeometryChange() MUST BE called before the value returned by areaPoints() changes
//Is this still true after the port to GraphicsView?
@@ -423,13 +430,17 @@
QRectF QgsComposerScalebar::boundingRect(void) const
+#ifdef QGISDEBUG
std::cout << "QgsComposerScalebar::boundingRect" << std::endl;
+#endif
return mBoundingRect;
QPolygonF QgsComposerScalebar::areaPoints(void) const
+#ifdef QGISDEBUG
std::cout << "QgsComposerScalebar::areaPoints" << std::endl;
+#endif
QPolygonF pa;
@@ -496,7 +507,10 @@
bool QgsComposerScalebar::writeSettings(void)
+#ifdef QGISDEBUG
std::cout << "QgsComposerScalebar::writeSettings" << std::endl;
+#endif
QString path;
path.sprintf("/composition_%d/scalebar_%d/", mComposition->id(), mId);
Modified: trunk/qgis/src/app/composer/qgscomposervectorlegend.cpp
--- trunk/qgis/src/app/composer/qgscomposervectorlegend.cpp 2008-05-08 21:45:52 UTC (rev 8416)
+++ trunk/qgis/src/app/composer/qgscomposervectorlegend.cpp 2008-05-09 14:55:43 UTC (rev 8417)
@@ -41,7 +41,9 @@
setupUi(this);
- //std::cout << "QgsComposerVectorLegend::QgsComposerVectorLegend()" << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "QgsComposerVectorLegend::QgsComposerVectorLegend()" << std::endl;
+#endif
mId = id;
@@ -76,7 +78,9 @@
QgsComposerVectorLegend::QgsComposerVectorLegend ( QgsComposition *composition, int id )
: QGraphicsRectItem(0,0,10,10,0)
+#ifdef QGISDEBUG
+#endif
setupUi(this);
@@ -142,7 +146,9 @@
#define FONT_WORKAROUND_SCALE 10
QRectF QgsComposerVectorLegend::render ( QPainter *p )
- //std::cout << "QgsComposerVectorLegend::render p = " << p << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "QgsComposerVectorLegend::render p = " << p << std::endl;
+#endif
// Painter can be 0, create dummy to avoid many if below
QPainter *painter = NULL;
@@ -350,7 +356,7 @@
double groupStartHeight = height;
for ( int j = groupLayers.size()-1; j >= 0; j-- )
- std::cout << "layer = " << groupLayers[j] << std::endl;
+ //std::cout << "layer = " << groupLayers[j] << std::endl;
double localHeight = groupStartHeight;
@@ -463,9 +469,11 @@
void QgsComposerVectorLegend::cache ( void )
+#ifdef QGISDEBUG
std::cout << "QgsComposerVectorLegend::cache()" << std::endl;
+#endif
-//typical boundingRect size is 15 units wide,
+ //typical boundingRect size is 15 units wide,
mCachePixmap = QPixmap((int)QGraphicsRectItem::rect().width(), (int)QGraphicsRectItem::rect().height() );
@@ -552,7 +560,9 @@
void QgsComposerVectorLegend::on_mPreviewModeComboBox_activated ( int i )
mPreviewMode = (PreviewMode) i;
+#ifdef QGISDEBUG
std::cout << "mPreviewMode = " << mPreviewMode << std::endl;
+#endif
writeSettings();
@@ -586,7 +596,9 @@
void QgsComposerVectorLegend::recalculate ( void )
+#ifdef QGISDEBUG
std::cout << "QgsComposerVectorLegend::recalculate" << std::endl;
+#endif
// Recalculate sizes according to current font size
@@ -596,9 +608,6 @@
mSectionFont = mFont;
mSectionFont.setPointSizeFloat ( 1.2 * mFont.pointSizeFloat() );
- std::cout << "font size = " << mFont.pointSizeFloat() << std::endl;
- std::cout << "title font size = " << mTitleFont.pointSizeFloat() << std::endl;
// Font size in canvas units
float size = 25.4 * mComposition->scale() * mFont.pointSizeFloat() / 72;
@@ -607,9 +616,14 @@
mSymbolWidth = 3.5 * size;
mSymbolSpace = 0.4 * size;
+#ifdef QGISDEBUG
+ std::cout << "font size = " << mFont.pointSizeFloat() << std::endl;
+ std::cout << "title font size = " << mTitleFont.pointSizeFloat() << std::endl;
std::cout << "mMargin = " << mMargin << " mSymbolHeight = " << mSymbolHeight
<< "mSymbolWidth = " << mSymbolWidth << " mSymbolSpace = " << mSymbolSpace << std::endl;
+#endif
QRectF r = render(0);
QGraphicsRectItem::setRect(0, 0, r.width(), r.height() );
@@ -695,7 +709,9 @@
void QgsComposerVectorLegend::contextMenuEvent( QContextMenuEvent *event)
+#ifdef QGISDEBUG
std::cout << "QgsComposerVectorLegend::contextMenuEvent" << std::endl;
+#endif
QMenu layersPopupMenu( this);
layersPopupMenu.addAction( tr("Combine selected layers"), this, SLOT(groupLayers()) );
@@ -748,7 +764,9 @@
void QgsComposerVectorLegend::layerChanged ( QTreeWidgetItem *lvi )
+#ifdef QGISDEBUG
std::cout << "QgsComposerVectorLegend::layerChanged" << std::endl;
+#endif
if ( lvi == 0 ) return;
@@ -764,7 +782,9 @@
void QgsComposerVectorLegend::groupLayers ( void )
+#ifdef QGISDEBUG
std::cout << "QgsComposerVectorLegend::groupLayers" << std::endl;
+#endif
QTreeWidgetItemIterator it( mLayersListView );
int count = 0;
@@ -772,7 +792,9 @@
QString id;
while ( *it ) {
if ( (*it)->isSelected() ) {
+ #ifdef QGISDEBUG
std::cout << "selected: " << (*it)->text(0).toLocal8Bit().data() << " " << (*it)->text(2).toLocal8Bit().data() << std::endl;
+ #endif
id = (*it)->text(2);
setLayerGroup ( id, mNextLayerGroup );
@@ -787,11 +809,13 @@
lastItem->setText(1,"" );
+#ifdef QGISDEBUG
std::cout << "Groups:" << std::endl;
for ( std::map<QString,int>::iterator it3 = mLayersGroups.begin(); it3 != mLayersGroups.end(); ++it3 ) {
std::cout << "layer: " << (it3->first).toLocal8Bit().data() << " group: " << it3->second << std::endl;
+#endif
mNextLayerGroup++;
@@ -810,7 +834,10 @@
bool QgsComposerVectorLegend::writeSettings ( void )
+#ifdef QGISDEBUG
std::cout << "QgsComposerVectorLegend::writeSettings" << std::endl;
+#endif
QString path;
path.sprintf("/composition_%d/vectorlegend_%d/", mComposition->id(), mId );
Modified: trunk/qgis/src/app/composer/qgscomposerview.cpp
--- trunk/qgis/src/app/composer/qgscomposerview.cpp 2008-05-08 21:45:52 UTC (rev 8416)
+++ trunk/qgis/src/app/composer/qgscomposerview.cpp 2008-05-09 14:55:43 UTC (rev 8417)
@@ -72,7 +72,9 @@
* Really, we should do something like re-center the window.
//mComposer->zoomFull();
-std::cout << "resize anchor: " << resizeAnchor() << std::endl;
+#ifdef QGISDEBUG
+ std::cout << "resize anchor: " << resizeAnchor() << std::endl;
+#endif
//TODO: add mouse wheel event forwarding
Modified: trunk/qgis/src/app/composer/qgscomposition.cpp
--- trunk/qgis/src/app/composer/qgscomposition.cpp 2008-05-08 21:45:52 UTC (rev 8416)
+++ trunk/qgis/src/app/composer/qgscomposition.cpp 2008-05-09 14:55:43 UTC (rev 8417)
@@ -388,11 +388,10 @@
void QgsComposition::mouseMoveEvent(QMouseEvent* e)
#ifdef QGISDEBUG
-#endif
std::cerr << "QgsComposition::mouseMoveEvent() mTool = " << mTool << " mToolStep = "
<< mToolStep << std::endl;
+#endif
QPointF p = mView->mapToScene(e->pos());
switch ( mTool ) {
