[QGIS Commit] r8454 - trunk/qgis/src/core
svn_qgis at osgeo.org
Sat May 17 15:32:13 EDT 2008
Author: jef
Date: 2008-05-17 15:32:13 -0400 (Sat, 17 May 2008)
New Revision: 8454
trunk/qgis/src/core/qgsvectorlayer.cpp
fix rendering off added features
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2008-05-17 19:28:19 UTC (rev 8453)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2008-05-17 19:32:13 UTC (rev 8454)
@@ -819,13 +819,13 @@
sel = FALSE;
- //QgsDebugMsg(QString("markerScale before renderFeature(): %1").arg(markerScaleFactor));
- // markerScalerFactore reflects the wanted scaling of the marker
+ //QgsDebugMsg(QString("markerScale before renderFeature(): %1").arg(markerScaleFactor));
+ // markerScalerFactore reflects the wanted scaling of the marker
mRenderer->renderFeature(renderContext.painter(), fet, &marker, sel, renderContext.scaleFactor(), renderContext.rasterScaleFactor());
- // markerScalerFactore now reflects the actual scaling of the marker that the render performed.
- //QgsDebugMsg(QString("markerScale after renderFeature(): %1").arg(markerScaleFactor));
+ // markerScalerFactore now reflects the actual scaling of the marker that the render performed.
+ //QgsDebugMsg(QString("markerScale after renderFeature(): %1").arg(markerScaleFactor));
- double scale = renderContext.scaleFactor() / markerScaleFactor;
+ //double scale = renderContext.scaleFactor() / markerScaleFactor;
drawFeature(renderContext.painter() , fet, &(renderContext.mapToPixel()), renderContext.coordTransform(), &marker, renderContext.scaleFactor(), renderContext.rasterScaleFactor(), renderContext.drawEditingInformation());
++featureCount;
@@ -838,12 +838,11 @@
for(; it != mAddedFeatures.end(); ++it)
bool sel = mSelectedFeatureIds.contains((*it).featureId());
- QgsDebugMsg(QString("markerScale before renderFeature(): %1").arg(markerScaleFactor));
- mRenderer->renderFeature(renderContext.painter(), *it, &marker, &markerScaleFactor,
- sel, renderContext.scaleFactor());
- QgsDebugMsg(QString("markerScale after renderFeature(): %1").arg(markerScaleFactor));
+ mRenderer->renderFeature(renderContext.painter(), *it, &marker, sel, renderContext.scaleFactor(), renderContext.rasterScaleFactor());
@@ -2797,7 +2796,7 @@
-int QgsVectorLayer::snapWithContext(const QgsPoint& startPoint, double snappingTolerance, QMultiMap<double, QgsSnappingResult>& snappingResults, \
+int QgsVectorLayer::snapWithContext(const QgsPoint& startPoint, double snappingTolerance, QMultiMap<double, QgsSnappingResult>& snappingResults,
QgsSnapper::SNAP_TO snap_to)
if (snappingTolerance<=0 || !mDataProvider)
@@ -2806,7 +2805,7 @@
QList<QgsFeature> featureList;
- QgsRect searchRect(startPoint.x()-snappingTolerance, startPoint.y()-snappingTolerance, \
+ QgsRect searchRect(startPoint.x()-snappingTolerance, startPoint.y()-snappingTolerance,
startPoint.x()+snappingTolerance, startPoint.y()+snappingTolerance);
double sqrSnappingTolerance = snappingTolerance * snappingTolerance;
@@ -2824,7 +2823,7 @@
return 0;
-void QgsVectorLayer::snapToGeometry(const QgsPoint& startPoint, int featureId, QgsGeometry* geom, double sqrSnappingTolerance, \
+void QgsVectorLayer::snapToGeometry(const QgsPoint& startPoint, int featureId, QgsGeometry* geom, double sqrSnappingTolerance,
QMultiMap<double, QgsSnappingResult>& snappingResults, QgsSnapper::SNAP_TO snap_to) const
if(!geom)
