[QGIS Commit] r8459 - trunk/qgis/mac
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon May 19 09:04:29 EDT 2008
Author: timlinux
Date: 2008-05-19 09:04:29 -0400 (Mon, 19 May 2008)
New Revision: 8459
   trunk/qgis/mac/1-release-extra.sh
   trunk/qgis/mac/2-release-extra-qt.sh
Updates for tims post install mac scripts
Modified: trunk/qgis/mac/1-release-extra.sh
--- trunk/qgis/mac/1-release-extra.sh	2008-05-19 13:03:31 UTC (rev 8458)
+++ trunk/qgis/mac/1-release-extra.sh	2008-05-19 13:04:29 UTC (rev 8459)
@@ -4,7 +4,8 @@
 APP_PREFIX=/Applications/qgis0.11.0.app
 BUNDLE_DIR=${APP_PREFIX}/Contents/MacOS
-LIB_DIR=/usr/local/qgis_universal_deps/lib
+DEPS_BASE=/usr/local/qgis_universal_deps
+LIB_DIR=${DEPS_BASE}/lib
 #set -x
 cp -r ${LIB_DIR}/libexpat.dylib  ${BUNDLE_DIR}/lib
 cp -r ${LIB_DIR}/libgdal.1.dylib  ${BUNDLE_DIR}/lib
@@ -22,15 +23,15 @@
 #ln -s libsqlite3.0.dylib libsqlite3.dylib
 popd
+set -x
 install_name_tool -change ${LIB_DIR}/libgdal.1.dylib \
                    @executable_path/lib/libgdal.1.dylib \
                    ${BUNDLE_DIR}/qgis
 install_name_tool -change ${LIB_DIR}/libproj.dylib \
                    @executable_path/lib/libproj.dylib \
                    ${BUNDLE_DIR}/qgis
+set +x
 LIBS="lib/libqgis_core.dylib \
       lib/libqgis_gui.dylib \
       lib/libexpat.1.dylib \
@@ -106,3 +107,21 @@
   #echo "----------------------------------"
 done
+# Strip binaries - disable for debugging
+#pushd .
+#cd ${APP_PREFIX}
+#for FILE in `find . -name *.dylib`; do echo "Stripping $FILE"; strip -x $FILE;  done
+#for FILE in `find . -name *.so`; do echo "Stripping $FILE"; strip -x $FILE;  done
+#strip -x ${APP_PREFIX}/Contents/MacOS/qgis
+#popd
+# Install GDAL and Proj support files
+cp -r ${DEPS_BASE}/share/proj ${APP_PREFIX}/Contents/MacOS/share/
+cp -r ${DEPS_BASE}/share/*.wkt ${APP_PREFIX}/Contents/MacOS/share/
+cp -r ${DEPS_BASE}/share/*.csv ${APP_PREFIX}/Contents/MacOS/share/
+cp -r ${DEPS_BASE}/share/*.dgn ${APP_PREFIX}/Contents/MacOS/share/
Modified: trunk/qgis/mac/2-release-extra-qt.sh
--- trunk/qgis/mac/2-release-extra-qt.sh	2008-05-19 13:03:31 UTC (rev 8458)
+++ trunk/qgis/mac/2-release-extra-qt.sh	2008-05-19 13:04:29 UTC (rev 8459)
@@ -13,7 +13,7 @@
 # Edit version when any library is upgraded
 UNIVERSAL_LIBS_PREFIX=/usr/local/qgis_universal_deps
 QTPREFIX=${UNIVERSAL_LIBS_PREFIX}/lib
-QTFRAMEWORKS="QtCore QtGui QtNetwork QtSql QtSvg QtXml"
+QTFRAMEWORKS="QtCore QtGui QtNetwork QtSql QtSvg QtXml QtDesigner"
 # Copy supporting frameworks to application bundle
@@ -55,7 +55,7 @@
 FILES="qgis
-  lib/libomg_widgets.dylib
+  lib/qgis/libcatalogue.so
   lib/qgis/libcopyrightlabelplugin.so
   lib/qgis/libgpxprovider.so
   lib/qgis/libscalebarplugin.so
@@ -75,7 +75,6 @@
 do
  for FRAMEWORK in QtCore QtGui QtNetwork QtSql QtSvg QtXml
 	do
-    set -x
 		install_name_tool -change ${QTPREFIX}/${FRAMEWORK}.framework/Versions/4/$FRAMEWORK \
 			@executable_path/../Frameworks/$FRAMEWORK.framework/Versions/4/$FRAMEWORK \
 			$MACOS_PREFIX/$FILE
@@ -141,3 +140,16 @@
 fi
 popd
+# Strip the qt libs
+strip -x ${FRAMEWORKPREFIX}/QtGui.framework/Versions/4/QtGui
+strip -x ${FRAMEWORKPREFIX}/QtCore.framework/Versions/4/QtCore
+strip -x ${FRAMEWORKPREFIX}/Qt3Support.framework/Versions/4/Qt3Support
+strip -x ${FRAMEWORKPREFIX}/QtSql.framework/Versions/4/QtSql
+strip -x ${FRAMEWORKPREFIX}/QtSvg.framework/Versions/4/QtSvg
+strip -x ${FRAMEWORKPREFIX}/QtXml.framework/Versions/4/QtXml
+strip -x ${FRAMEWORKPREFIX}/QtNetwork.framework/Versions/4/QtNetwork
+strip -x ${FRAMEWORKPREFIX}/QtDesigner.framework/Versions/4/QtDesigner
More information about the QGIS-commit mailing list
