[QGIS Commit] r8476 - in trunk/qgis/src: plugins/grass providers/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue May 20 18:09:40 EDT 2008
Author: jef
Date: 2008-05-20 18:09:40 -0400 (Tue, 20 May 2008)
New Revision: 8476
   trunk/qgis/src/plugins/grass/qgsgrassselect.cpp
   trunk/qgis/src/providers/grass/qgsgrass.cpp
   trunk/qgis/src/providers/grass/qgsgrass.h
   trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
fix grass crash:
  setlocale to "C" in getSRS() and catch fatal errors
  (probably needed at much more places).
Modified: trunk/qgis/src/plugins/grass/qgsgrassselect.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassselect.cpp	2008-05-20 19:19:00 UTC (rev 8475)
+++ trunk/qgis/src/plugins/grass/qgsgrassselect.cpp	2008-05-20 22:09:40 UTC (rev 8476)
@@ -397,6 +397,7 @@
     level = Vect_open_old_head (&map, (char *) mapName.ascii(),
       (char *) mapset.ascii());
+  QgsGrass::clearErrorEnv();
   if ( QgsGrass::getError() == QgsGrass::FATAL ) {
     std::cerr << "Cannot open GRASS vector: " << QgsGrass::getErrorMessage().toLocal8Bit().data() << std::endl;
Modified: trunk/qgis/src/providers/grass/qgsgrass.cpp
--- trunk/qgis/src/providers/grass/qgsgrass.cpp	2008-05-20 19:19:00 UTC (rev 8475)
+++ trunk/qgis/src/providers/grass/qgsgrass.cpp	2008-05-20 22:09:40 UTC (rev 8476)
@@ -16,6 +16,7 @@
 /* $Id$ */
 #include <iostream>
+#include <qgslogger.h>
 #include "QString"
 #include "q3process.h"
@@ -375,6 +376,7 @@
 QString QgsGrass::mTmp;
 jmp_buf QgsGrass::mFatalErrorEnv;
+bool QgsGrass::mFatalErrorEnvActive=false;
 int QgsGrass::error_routine ( char *msg, int fatal)
@@ -383,15 +385,21 @@
 int QgsGrass::error_routine ( const char *msg, int fatal)
-  std::cerr << "error_routine (fatal = " << fatal << "): " << msg << std::endl;
+  QgsDebugMsg(QString("error_routine (fatal = %1): %2").arg(fatal).arg(msg));
   error_message = msg;
   if ( fatal )
     error = FATAL;
     // we have to do a long jump here, otherwise GRASS >= 6.3 will kill our process
-    longjmp(mFatalErrorEnv, 1);
+    if( mFatalErrorEnvActive )
+      longjmp(mFatalErrorEnv, 1);
+    else
+      QMessageBox::warning( 0, QObject::tr("Uncatched fatal GRASS error"), msg );
+      abort();
   else
     error = WARNING;
@@ -416,9 +424,18 @@
 jmp_buf GRASS_EXPORT &QgsGrass::fatalErrorEnv()
+  if(mFatalErrorEnvActive)
+    QgsDebugMsg("fatal error environment already active.");
+  mFatalErrorEnvActive = true;
   return mFatalErrorEnv;
+void GRASS_EXPORT QgsGrass::clearErrorEnv()
+  if(!mFatalErrorEnvActive)
+    QgsDebugMsg("fatal error environment already deactive.");
+  mFatalErrorEnvActive = false;
 QString GRASS_EXPORT QgsGrass::openMapset ( QString gisdbase, QString location, QString mapset )
Modified: trunk/qgis/src/providers/grass/qgsgrass.h
--- trunk/qgis/src/providers/grass/qgsgrass.h	2008-05-20 19:19:00 UTC (rev 8475)
+++ trunk/qgis/src/providers/grass/qgsgrass.h	2008-05-20 22:09:40 UTC (rev 8476)
@@ -155,6 +155,7 @@
     static GRASS_EXPORT QString versionString();
     static GRASS_EXPORT jmp_buf& fatalErrorEnv();
+    static GRASS_EXPORT void clearErrorEnv();
 private:
@@ -184,6 +185,7 @@
     // Context saved before a call to routine that can produce a fatal error
     static jmp_buf mFatalErrorEnv;
+    static bool mFatalErrorEnvActive;
 #endif // QGSGRASS_H
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2008-05-20 19:19:00 UTC (rev 8475)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2008-05-20 22:09:40 UTC (rev 8476)
@@ -1250,8 +1250,24 @@
   struct Cell_head cellhd;
+  QgsGrass::resetError();
   QgsGrass::setLocation ( mGisdbase, mLocation );
-  G_get_default_window(&cellhd);
+  char *oldlocale = setlocale(LC_ALL, NULL);
+  setlocale(LC_ALL, "C");
+  if ( setjmp(QgsGrass::fatalErrorEnv()) == 0 )
+    G_get_default_window(&cellhd);
+  if ( QgsGrass::getError() == QgsGrass::FATAL ) {
+    setlocale(LC_ALL, oldlocale);
+    QgsDebugMsg(QString("Cannot get default window: %1").arg(QgsGrass::getErrorMessage()));
+    return QgsSpatialRefSys();
   if (cellhd.proj != PROJECTION_XY) {
     struct Key_Value *projinfo = G_get_projinfo();
     struct Key_Value *projunits = G_get_projunits();
@@ -1260,6 +1276,8 @@
     free ( wkt);
   QgsSpatialRefSys srs;
   srs.createFromWkt(WKT);
More information about the QGIS-commit mailing list
