[QGIS Commit] r8489 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed May 21 13:45:57 EDT 2008
Author: timlinux
Date: 2008-05-21 13:45:57 -0400 (Wed, 21 May 2008)
New Revision: 8489
   trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui
   trunk/qgis/src/ui/qgsprojectionselectorbase.ui
Revisions to improve gui layout and useability. Note the custom projection navigation buttons are temporary and will be updated shortly with icons.
Modified: trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui
--- trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui	2008-05-21 17:42:24 UTC (rev 8488)
+++ trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui	2008-05-21 17:45:57 UTC (rev 8489)
@@ -5,8 +5,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>718</width>
-    <height>323</height>
+    <width>474</width>
+    <height>548</height>
    </rect>
   </property>
   <property name="windowTitle" >
@@ -16,306 +16,237 @@
    <iconset/>
   </property>
   <layout class="QGridLayout" >
-   <property name="margin" >
-    <number>9</number>
-   </property>
-   <property name="spacing" >
-    <number>6</number>
-   </property>
    <item row="0" column="0" >
-    <widget class="QTabWidget" name="tabWidget2" >
-     <property name="currentIndex" >
-      <number>0</number>
+    <widget class="QGroupBox" name="groupBox" >
+     <property name="title" >
+      <string>Define</string>
      </property>
-     <widget class="QWidget" name="tab1" >
-      <attribute name="title" >
-       <string>Define</string>
-      </attribute>
-      <layout class="QGridLayout" >
-       </property>
-       </property>
-       <item row="1" column="0" colspan="2" >
-        <widget class="QTextBrowser" name="textBrowser" >
-         <property name="html" >
-          <string>You can define your own custom projection here. The definition must conform to the proj4 format for specifying a Spatial Reference System.</string>
-         </property>
-        </widget>
-       </item>
-       <item row="0" column="0" colspan="2" >
-        <widget class="QLabel" name="textLabel5" >
-         <property name="font" >
-          <font>
-           <family>Arial</family>
-           <pointsize>18</pointsize>
-           <weight>50</weight>
-           <italic>false</italic>
-           <bold>false</bold>
-           <underline>false</underline>
-           <strikeout>false</strikeout>
-          </font>
-         </property>
-         <property name="text" >
-          <string>Custom Projection Definition</string>
-         </property>
-        </widget>
-       </item>
-       <item row="3" column="1" >
-        <widget class="QLineEdit" name="leParameters" />
-       </item>
-       <item row="3" column="0" >
-        <widget class="QLabel" name="textLabel3_2" >
-          <string>Parameters:</string>
-         </property>
-        </widget>
-       </item>
-       <item row="4" column="0" colspan="2" >
-        <layout class="QHBoxLayout" >
-         </property>
-         </property>
-         <item>
-          <widget class="QPushButton" name="pbnFirst" >
-            <string>|&lt;</string>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QPushButton" name="pbnPrevious" >
-            <string>&lt;</string>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QLabel" name="lblRecordNo" >
-            <string>1 of 1</string>
-           </property>
-           <property name="alignment" >
-            <set>Qt::AlignCenter</set>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QPushButton" name="pbnNext" >
-            <string>></string>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QPushButton" name="pbnLast" >
-            <string>>|</string>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QPushButton" name="pbnNew" >
-            <string>New</string>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QPushButton" name="pbnSave" >
-            <string>Save</string>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QPushButton" name="pbnDelete" >
-            <string>Delete</string>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QPushButton" name="pbnClose" >
-            <string>Close</string>
-           </property>
-          </widget>
-         </item>
-        </layout>
-       </item>
-       <item row="2" column="0" >
-        <widget class="QLabel" name="textLabel1" >
-          <string>Name:</string>
-         </property>
-        </widget>
-       </item>
-       <item row="2" column="1" >
-        <widget class="QLineEdit" name="leName" />
-       </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="tab2" >
-       <string>Test</string>
-      </attribute>
-       </property>
-       </property>
-       <item row="0" column="0" colspan="3" >
-        <widget class="QLabel" name="textLabel1_2" >
-          <font>
-          </font>
-         </property>
-          <string>Transform from WGS84 to the chosen projection</string>
-         </property>
-        </widget>
-       </item>
-       <item row="1" column="0" colspan="3" >
-        <widget class="QTextBrowser" name="textBrowser_2" >
-          <string>Use the text boxes below to test the projection definition you are creating. Enter a coordinate where both the lat/long and the projected result are known (for example by reading off a map). Then press the calculate button to see if the projection definition you are creating is accurate.</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QLabel" name="textLabel3_2_2" >
-         </property>
-         <property name="buddy" >
-          <cstring>leTestParameters</cstring>
-         </property>
-        </widget>
-       </item>
-       <item row="2" column="1" colspan="2" >
-        <widget class="QLineEdit" name="leTestParameters" />
-       </item>
-        <spacer>
-         <property name="orientation" >
-          <enum>Qt::Horizontal</enum>
-         </property>
-         <property name="sizeType" >
-          <enum>QSizePolicy::Expanding</enum>
-         </property>
-         <property name="sizeHint" >
-          <size>
-           <width>41</width>
-           <height>21</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
-       <item row="3" column="2" >
-        <widget class="QLabel" name="textLabel2_3" >
-          <string>Projected Coordinate System</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QLabel" name="textLabel1_3" >
-          <string>Geographic / WGS84</string>
-         </property>
-        </widget>
-       </item>
-       <item row="5" column="2" >
-        <widget class="QLabel" name="projectedY" >
-         <property name="enabled" >
-          <bool>true</bool>
-         </property>
-         <property name="frameShape" >
-          <enum>QFrame::Box</enum>
-         </property>
-          <string/>
-         </property>
-          <number>1</number>
-         </property>
-        </widget>
-       </item>
-       <item row="5" column="1" >
-        <widget class="QLineEdit" name="eastWGS84" />
-       </item>
-       <item row="5" column="0" >
-        <widget class="QLabel" name="textLabel2_2_2" >
-          <string>East:</string>
-         </property>
-          <cstring>eastWGS84</cstring>
-         </property>
-        </widget>
-       </item>
-       <item row="4" column="0" >
-        <widget class="QLabel" name="textLabel2_2" >
-          <string>North:</string>
-         </property>
-          <cstring>northWGS84</cstring>
-         </property>
-        </widget>
-       </item>
-       <item row="4" column="1" >
-        <widget class="QLineEdit" name="northWGS84" >
-          <bool>true</bool>
-         </property>
-        </widget>
-       </item>
-       <item row="4" column="2" >
-        <widget class="QLabel" name="projectedX" >
-          <bool>true</bool>
-         </property>
-         </property>
-          <string/>
-         </property>
-        </widget>
-       </item>
-       <item row="6" column="0" colspan="3" >
-        <widget class="QPushButton" name="pbnCalculate" >
-          <string>Calculate</string>
-         </property>
-        </widget>
-       </item>
-      </layout>
-     </widget>
+     <layout class="QGridLayout" >
+      <item row="0" column="0" colspan="2" >
+       <widget class="QLabel" name="label" >
+        <property name="text" >
+         <string>You can define your own custom projection here. The definition must conform to the proj4 format for specifying a Spatial Reference System.</string>
+        </property>
+        <property name="wordWrap" >
+         <bool>true</bool>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="0" >
+       <widget class="QLabel" name="textLabel1" >
+         <string>Name</string>
+        </property>
+        <property name="buddy" >
+         <cstring>leName</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="1" >
+       <widget class="QLineEdit" name="leName" />
+      </item>
+      <item row="2" column="0" >
+       <widget class="QLabel" name="textLabel3_2" >
+         <string>Parameters</string>
+        </property>
+         <cstring>leParameters</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1" >
+       <widget class="QLineEdit" name="leParameters" />
+      </item>
+      <item row="3" column="1" >
+       <layout class="QHBoxLayout" >
+        <item>
+         <widget class="QToolButton" name="pbnFirst" >
+           <string>|&lt;</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QToolButton" name="pbnPrevious" >
+           <string>&lt;</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QLabel" name="lblRecordNo" >
+           <string>1 of 1</string>
+          </property>
+          <property name="alignment" >
+           <set>Qt::AlignCenter</set>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QToolButton" name="pbnNext" >
+           <string>></string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QToolButton" name="pbnLast" >
+           <string>>|</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QToolButton" name="pbnNew" >
+           <string>*</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QToolButton" name="pbnSave" >
+           <string>S</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QToolButton" name="pbnDelete" >
+           <string>X</string>
+          </property>
+         </widget>
+        </item>
+       </layout>
+      </item>
+     </layout>
     </widget>
    </item>
+    <widget class="QGroupBox" name="groupBox_2" >
+      <string>Test</string>
+     </property>
+      <item row="0" column="0" colspan="3" >
+       <widget class="QLabel" name="label_2" >
+         <string>Use the text boxes below to test the projection definition you are creating. Enter a coordinate where both the lat/long and the projected result are known (for example by reading off a map). Then press the calculate button to see if the projection definition you are creating is accurate.</string>
+        </property>
+         <bool>true</bool>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLabel" name="textLabel3_2_2" >
+        </property>
+         <cstring>leTestParameters</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="1" colspan="2" >
+       <widget class="QLineEdit" name="leTestParameters" />
+      </item>
+       <widget class="QLabel" name="textLabel1_3" >
+         <string>Geographic / WGS84</string>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="2" >
+       <widget class="QLabel" name="textLabel2_3" >
+         <string>Projected Coordinate System</string>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="0" >
+       <widget class="QLabel" name="textLabel2_2" >
+         <string>North</string>
+        </property>
+         <cstring>northWGS84</cstring>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLineEdit" name="northWGS84" >
+        <property name="enabled" >
+         <bool>true</bool>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="2" >
+       <widget class="QLabel" name="projectedX" >
+         <bool>true</bool>
+        </property>
+        <property name="frameShape" >
+         <enum>QFrame::Box</enum>
+        </property>
+         <string/>
+        </property>
+       </widget>
+      </item>
+      <item row="4" column="0" >
+       <widget class="QLabel" name="textLabel2_2_2" >
+         <string>East</string>
+        </property>
+         <cstring>eastWGS84</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="4" column="1" >
+       <widget class="QLineEdit" name="eastWGS84" />
+      </item>
+      <item row="4" column="2" >
+       <widget class="QLabel" name="projectedY" >
+         <bool>true</bool>
+        </property>
+        </property>
+         <string/>
+        </property>
+        <property name="margin" >
+         <number>1</number>
+        </property>
+       </widget>
+      </item>
+      <item row="5" column="0" colspan="3" >
+       <widget class="QPushButton" name="pbnCalculate" >
+         <string>Calculate</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+    <widget class="QDialogButtonBox" name="buttonBox" >
+     <property name="standardButtons" >
+      <set>QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11" />
  <tabstops>
-  <tabstop>tabWidget2</tabstop>
-  <tabstop>textBrowser</tabstop>
   <tabstop>leName</tabstop>
   <tabstop>leParameters</tabstop>
   <tabstop>pbnFirst</tabstop>
@@ -325,13 +256,29 @@
   <tabstop>pbnNew</tabstop>
   <tabstop>pbnSave</tabstop>
   <tabstop>pbnDelete</tabstop>
-  <tabstop>pbnClose</tabstop>
-  <tabstop>textBrowser_2</tabstop>
   <tabstop>leTestParameters</tabstop>
   <tabstop>northWGS84</tabstop>
   <tabstop>eastWGS84</tabstop>
   <tabstop>pbnCalculate</tabstop>
+  <tabstop>buttonBox</tabstop>
  </tabstops>
  <resources/>
- <connections/>
+ <connections>
+  <connection>
+   <sender>buttonBox</sender>
+   <signal>accepted()</signal>
+   <receiver>QgsCustomProjectionDialogBase</receiver>
+   <slot>accept()</slot>
+   <hints>
+    <hint type="sourcelabel" >
+     <x>436</x>
+     <y>522</y>
+    </hint>
+    <hint type="destinationlabel" >
+     <x>471</x>
+     <y>501</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
 </ui>
Modified: trunk/qgis/src/ui/qgsprojectionselectorbase.ui
--- trunk/qgis/src/ui/qgsprojectionselectorbase.ui	2008-05-21 17:42:24 UTC (rev 8488)
+++ trunk/qgis/src/ui/qgsprojectionselectorbase.ui	2008-05-21 17:45:57 UTC (rev 8489)
@@ -1,7 +1,4 @@
 <ui version="4.0" >
- <author></author>
- <comment></comment>
- <exportmacro></exportmacro>
  <class>QgsProjectionSelectorBase</class>
  <widget class="QWidget" name="QgsProjectionSelectorBase" >
   <property name="geometry" >
@@ -13,9 +10,7 @@
    </rect>
   </property>
   <property name="sizePolicy" >
-   <sizepolicy>
-    <hsizetype>7</hsizetype>
-    <vsizetype>5</vsizetype>
+   <sizepolicy vsizetype="Preferred" hsizetype="Expanding" >
     <horstretch>0</horstretch>
     <verstretch>0</verstretch>
    </sizepolicy>
@@ -27,18 +22,28 @@
    <iconset/>
   </property>
+   <property name="leftMargin" >
+    <number>0</number>
    </property>
+   <property name="topMargin" >
    </property>
+   <property name="rightMargin" >
+   </property>
+   <property name="bottomMargin" >
+   </property>
+   <property name="horizontalSpacing" >
+   </property>
+   <property name="verticalSpacing" >
+   </property>
-      <sizepolicy>
-       <vsizetype>7</vsizetype>
+      <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
       </sizepolicy>
@@ -47,18 +52,28 @@
       <string>Projection</string>
      </property>
+       <number>12</number>
       </property>
       </property>
+      </property>
+      </property>
+      </property>
+      </property>
-         <sizepolicy>
-          <hsizetype>3</hsizetype>
-          <vsizetype>1</vsizetype>
+         <sizepolicy vsizetype="Minimum" hsizetype="MinimumExpanding" >
          </sizepolicy>
@@ -67,12 +82,24 @@
          <string>Search</string>
         </property>
           <number>2</number>
          </property>
+          <number>2</number>
          </property>
+         </property>
+         </property>
+          <number>3</number>
+         </property>
+         </property>
          <item row="1" column="3" >
           <widget class="QPushButton" name="pbnFind" >
            <property name="maximumSize" >
@@ -153,9 +180,7 @@
        <widget class="QTextEdit" name="teProjection" >
-         <sizepolicy>
          </sizepolicy>
@@ -209,7 +234,6 @@
   </layout>
  </widget>
- <pixmapfunction></pixmapfunction>
  <resources/>
  <connections/>
 </ui>
More information about the QGIS-commit mailing list
