[QGIS Commit] r8548 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri May 30 11:46:41 EDT 2008
Author: timlinux
Date: 2008-05-30 11:46:41 -0400 (Fri, 30 May 2008)
New Revision: 8548
   trunk/qgis/src/app/CMakeLists.txt
   trunk/qgis/src/ui/CMakeLists.txt
Remove references to deleted uis
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt	2008-05-30 15:43:18 UTC (rev 8547)
+++ trunk/qgis/src/app/CMakeLists.txt	2008-05-30 15:46:41 UTC (rev 8548)
@@ -1,12 +1,3 @@
-# TODO: delete from SVN
-#   qgslinestyledialog.(cpp|h)
-#   qgslinestylewidget.(cpp|h)
-#   qgsmarkerdialog.(cpp|h)
-#   qgspatterndialog.(cpp|h)
-#   qgspointstylewidget.(cpp|h)
-#   qgsvectorsymbologywidget.(cpp|h)
 SET(QGIS_APP_SRCS
   main.cpp
   qgisapp.cpp
@@ -25,7 +16,6 @@
   qgsdbfilterproxymodel.cpp
   qgsdbtablemodel.cpp
   qgsdelattrdialog.cpp
-  qgsfillstylewidget.cpp
   qgsgeomtypedialog.cpp
   qgsgraduatedsymboldialog.cpp
   qgshelpviewer.cpp
@@ -102,7 +92,6 @@
   qgscontinuouscolordialog.h
   qgscustomprojectiondialog.h
   qgsdelattrdialog.h
-  qgsfillstylewidget.h
   qgsgeomtypedialog.h
   qgsgraduatedsymboldialog.h
   qgshelpviewer.h
Modified: trunk/qgis/src/ui/CMakeLists.txt
--- trunk/qgis/src/ui/CMakeLists.txt	2008-05-30 15:43:18 UTC (rev 8547)
+++ trunk/qgis/src/ui/CMakeLists.txt	2008-05-30 15:46:41 UTC (rev 8548)
@@ -1,12 +1,3 @@
-#   qgslinestyledialog.ui
-#   qgslinestylewidget.ui
-#   qgsmarkerdialog.ui
-#   qgspatterndialog.ui
-#   qgspointstylewidget.ui
-#   qgsvectorsymbologywidget.ui
 SET(QGIS_UIS
   qgisappbase.ui
   qgsabout.ui
@@ -27,7 +18,6 @@
   qgsdbsourceselectbase.ui
   qgsdelattrdialogbase.ui
   qgsdetaileditemwidgetbase.ui
-  qgsfillstylewidgetbase.ui
   qgsgeomtypedialogbase.ui
   qgsgraduatedsymboldialogbase.ui
   qgshelpviewerbase.ui
@@ -51,12 +41,9 @@
   qgssnappingdialogbase.ui
   qgsuniquevaluedialogbase.ui
   qgsvectorlayerpropertiesbase.ui
+  qgspythondialog.ui
-IF (PYTHON_FOUND)
-  SET (QGIS_UIS ${QGIS_UIS} ../ui/qgspythondialog.ui)
-ENDIF (PYTHON_FOUND)
 QT4_WRAP_UI(QGIS_UIS_H ${QGIS_UIS})
 ADD_CUSTOM_TARGET(ui ALL DEPENDS ${QGIS_UIS_H})
More information about the QGIS-commit mailing list
