[QGIS Commit] r8550 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Fri May 30 11:51:24 EDT 2008
Author: timlinux
Date: 2008-05-30 11:51:24 -0400 (Fri, 30 May 2008)
New Revision: 8550
trunk/qgis/src/app/qgsludialog.cpp
trunk/qgis/src/ui/qgsludialogbase.ui
Use button box for cross platform consistency
Modified: trunk/qgis/src/app/qgsludialog.cpp
--- trunk/qgis/src/app/qgsludialog.cpp 2008-05-30 15:48:52 UTC (rev 8549)
+++ trunk/qgis/src/app/qgsludialog.cpp 2008-05-30 15:51:24 UTC (rev 8550)
@@ -23,8 +23,6 @@
: QDialog(parent, fl)
setupUi(this);
- connect(mOkButton, SIGNAL(clicked()), this, SLOT(accept()));
- connect(mCancelButton, SIGNAL(clicked()), this, SLOT(reject()));
QgsLUDialog::~QgsLUDialog()
Modified: trunk/qgis/src/ui/qgsludialogbase.ui
--- trunk/qgis/src/ui/qgsludialogbase.ui 2008-05-30 15:48:52 UTC (rev 8549)
+++ trunk/qgis/src/ui/qgsludialogbase.ui 2008-05-30 15:51:24 UTC (rev 8550)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>340</width>
- <height>159</height>
+ <width>324</width>
+ <height>133</height>
</rect>
</property>
<property name="windowTitle" >
@@ -16,15 +16,24 @@
<bool>true</bool>
</property>
<layout class="QGridLayout" >
- <property name="margin" >
- <number>10</number>
+ <property name="leftMargin" >
+ <number>4</number>
</property>
- <property name="spacing" >
- <number>6</number>
+ <property name="topMargin" >
</property>
- <item row="1" column="0" >
- <widget class="QLineEdit" name="mLowerEdit" />
- </item>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <property name="horizontalSpacing" >
+ <number>-1</number>
+ </property>
+ <property name="verticalSpacing" >
+ </property>
<item row="0" column="0" >
<widget class="QLabel" name="mLowerLabel" >
<property name="text" >
@@ -46,11 +55,24 @@
<property name="sizeHint" >
<size>
<width>16</width>
- <height>21</height>
+ <height>49</height>
</size>
</property>
</spacer>
</item>
+ <item row="0" column="2" >
+ <widget class="QLabel" name="mUpperLabel" >
+ <property name="text" >
+ <string>Upper value</string>
+ </property>
+ <property name="buddy" >
+ <cstring>mUpperEdit</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QLineEdit" name="mLowerEdit" />
+ </item>
<item row="1" column="1" >
<widget class="QLabel" name="mBetweenLabel" >
@@ -65,74 +87,48 @@
<widget class="QLineEdit" name="mUpperEdit" />
</item>
<item row="2" column="0" colspan="3" >
- <layout class="QHBoxLayout" >
- <number>0</number>
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
</property>
- </property>
- <item>
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeType" >
- <enum>QSizePolicy::Expanding</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>100</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QPushButton" name="mOkButton" >
- <property name="text" >
- <string>OK</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="mCancelButton" >
- <string>Cancel</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer>
- </property>
- </property>
- <size>
- <width>31</width>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
- </item>
- <item row="0" column="2" >
- <widget class="QLabel" name="mUpperLabel" >
- <string>Upper value</string>
- </property>
- <property name="buddy" >
- <cstring>mUpperEdit</cstring>
- </property>
</widget>
</item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11" />
<resources/>
- <connections/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsLUDialogBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>285</x>
+ <y>120</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>321</x>
+ <y>35</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>209</x>
+ <y>116</y>
+ </hint>
+ <x>151</x>
+ <y>7</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
