[QGIS Commit] r8556 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Fri May 30 12:56:26 EDT 2008
Author: timlinux
Date: 2008-05-30 12:56:26 -0400 (Fri, 30 May 2008)
New Revision: 8556
trunk/qgis/src/app/qgsattributedialog.cpp
trunk/qgis/src/app/qgsattributedialog.h
trunk/qgis/src/app/qgsmaptooladdfeature.cpp
trunk/qgis/src/ui/qgsattributedialogbase.ui
Gui cleanups for attribute capture when digitising. Create a dynamically generated dialog rather than using a table widget.
Modified: trunk/qgis/src/app/qgsattributedialog.cpp
--- trunk/qgis/src/app/qgsattributedialog.cpp 2008-05-30 16:23:40 UTC (rev 8555)
+++ trunk/qgis/src/app/qgsattributedialog.cpp 2008-05-30 16:56:26 UTC (rev 8556)
@@ -22,148 +22,142 @@
#include <QTableWidgetItem>
#include <QSettings>
#include <QLineEdit>
+#include <QSpinBox>
+#include <QLabel>
+#include <QDoubleSpinBox>
+#include <QFrame>
+#include <QScrollArea>
-QgsAttributeDialog::QgsAttributeDialog(const QgsFieldMap& fields, const QgsAttributeMap& attributes)
+QgsAttributeDialog::QgsAttributeDialog(
+ QgsFieldMap theFieldMap, QgsFeature * thepFeature)
: QDialog(),
- _settingsPath("/Windows/AttributeDialog/"),
- mRowIsDirty(attributes.size(), FALSE)
+ mSettingsPath("/Windows/AttributeDialog/"),
+ mFieldMap(theFieldMap),
+ mpFeature(thepFeature)
- restorePositionAndColumnWidth();
- setupUi(this);
- mTable->setRowCount(attributes.size());
+ setupUi(this);
+ if (mpFeature==NULL) return;
+ if (mFieldMap.isEmpty()) return;
+ QgsAttributeMap myAttributes = mpFeature->attributeMap();
+ //Set up dynamic inside a scroll box
+ QVBoxLayout * mypOuterLayout = new QVBoxLayout();
+ mypOuterLayout->setContentsMargins(0,0,0,0);
+ //transfers layout ownership so no need to call delete
+ mFrame->setLayout(mypOuterLayout);
+ QScrollArea * mypScrollArea = new QScrollArea();
+ //transfers scroll area ownership so no need to call delete
+ mypOuterLayout->addWidget(mypScrollArea);
+ QFrame * mypInnerFrame = new QFrame();
+ mypInnerFrame->setFrameShape(QFrame::NoFrame);
+ mypInnerFrame->setFrameShadow(QFrame::Plain);
+ //transfers frame ownership so no need to call delete
+ mypScrollArea->setWidget(mypInnerFrame);
+ mypScrollArea->setWidgetResizable( true );
+ QGridLayout * mypInnerLayout = new QGridLayout(mypInnerFrame);
- int index=0;
- for (QgsAttributeMap::const_iterator it = attributes.begin(); it != attributes.end(); ++it)
+ int index=0;
+ for (QgsAttributeMap::const_iterator it = myAttributes.begin();
+ it != myAttributes.end();
+ ++it)
+ QString myFieldName = mFieldMap[it.key()].name();
+ QLabel * mypLabel = new QLabel();
+ mypInnerLayout->addWidget(mypLabel,index,0);
+ QVariant myFieldValue = it.value();
+ QLineEdit * mypLineEdit = new QLineEdit();
+ //the provider may have provided a default value so use it
+ mypLineEdit->setText(myFieldValue.toString());
+ if( mFieldMap[it.key()].type()==QVariant::Int )
- // set attribute name
- QString fieldName = fields[it.key()].name();
- QTableWidgetItem * myFieldItem = new QTableWidgetItem(fieldName);
- myFieldItem->setFlags(Qt::ItemIsSelectable | Qt::ItemIsEnabled);
- mTable->setItem(index, 0, myFieldItem);
-#if QT_VERSION >= 0x040400
- // set attribute value
- QTableWidgetItem * myValueItem = new QTableWidgetItem((*it).toString());
- mTable->setItem(index, 1, myValueItem);
-#endif
- QLineEdit *le = new QLineEdit();
- le->setFrame(false);
- if( fields[it.key()].type()==QVariant::Int )
- le->setValidator( new QIntValidator(le) );
- else if( fields[it.key()].type()==QVariant::Double )
- le->setValidator( new QDoubleValidator(le) );
-#if QT_VERSION < 0x040400
- le->setText((*it).toString());
-#endif
- mTable->setCellWidget(index, 1, le);
- ++index;
+ mypLineEdit->setValidator( new QIntValidator(mypLineEdit) );
+ mypLabel->setText(myFieldName + tr(" (int)"));
- // setup the mechanism to track edited attribute values
- // if we do it this way, only edited attributes will
- // be attempted to be saved when the editing session stops.
- connect(mTable, SIGNAL(cellChanged(int, int)),
- this, SLOT (setAttributeValueChanged(int, int)));
- mTable->resizeColumnsToContents();
+ else if( mFieldMap[it.key()].type()==QVariant::Double )
+ mypLineEdit->setValidator( new QDoubleValidator(mypLineEdit) );
+ mypLabel->setText(myFieldName + tr(" (dbl)"));
+ else //string
+ //any special behaviour for string goes here
+ mypLabel->setText(myFieldName + tr(" (txt)"));
+ mypInnerLayout->addWidget(mypLineEdit,index,1);
+ mpWidgets << mypLineEdit;
+ ++index;
+ restoreGeometry();
QgsAttributeDialog::~QgsAttributeDialog()
+ saveGeometry();
-QString QgsAttributeDialog::value(int row)
+void QgsAttributeDialog::accept()
- return static_cast<QLineEdit*>(mTable->cellWidget(row,1))->text();
-bool QgsAttributeDialog::isDirty(int row)
- return mRowIsDirty.at(row);
-bool QgsAttributeDialog::queryAttributes(const QgsFieldMap& fields, QgsFeature& f)
- QgsAttributeMap featureAttributes = f.attributeMap();
- QgsAttributeDialog attdialog(fields, featureAttributes);
- if (attdialog.exec() == QDialog::Accepted)
+ //write the new values back to the feature
+ int myIndex=0;
+ ++it)
- int i=0;
- for (QgsAttributeMap::const_iterator it = featureAttributes.begin(); it != featureAttributes.end(); ++it, i++)
+ //Q_ASSERT(myIndex <= mpWidgets.size());
+ bool myFlag=false;
+ QString myFieldValue =
+ dynamic_cast<QLineEdit *>(mpWidgets.value(myIndex))->text();
+ switch( mFieldMap[it.key()].type() )
- QString value = attdialog.value(i);
- if( attdialog.isDirty(i) )
- switch( fields[it.key()].type() )
+ case QVariant::Int:
- case QVariant::Int:
- f.changeAttribute(it.key(), value=="" ? QVariant( QString::null ) : QVariant( value.toInt() ) );
- break;
- case QVariant::Double:
- f.changeAttribute(it.key(), value=="" ? QVariant( QString::null ) : QVariant( value.toDouble() ) );
- break;
- default:
- f.changeAttribute(it.key(), value=="NULL" ? QVariant(QString::null) : QVariant(value) );
- break;
+ int myIntValue = myFieldValue.toInt(&myFlag);
+ if (myFlag && ! myFieldValue.isEmpty())
+ mpFeature->changeAttribute( it.key(), QVariant(myIntValue) );
+ else
+ mpFeature->changeAttribute( it.key(), QVariant(QString::null) );
- } else {
- f.changeAttribute(it.key(), QVariant(value) );
+ break;
+ case QVariant::Double:
+ double myDblValue = myFieldValue.toDouble(&myFlag);
+ mpFeature->changeAttribute( it.key(), QVariant(myDblValue) );
+ else
+ break;
+ default: //string
+ mpFeature->changeAttribute(it.key(),QVariant( myFieldValue ) );
+ break;
- return true;
+ ++myIndex;
- else
- return false;
+ QDialog::accept();
-void QgsAttributeDialog::savePositionAndColumnWidth()
+void QgsAttributeDialog::saveGeometry()
QSettings settings;
- settings.setValue(_settingsPath+"geometry", saveGeometry());
+ settings.setValue(mSettingsPath+"geometry", QDialog::saveGeometry());
-void QgsAttributeDialog::resizeEvent(QResizeEvent *event)
- savePositionAndColumnWidth();
- QWidget::resizeEvent(event);
-void QgsAttributeDialog::moveEvent(QMoveEvent *event)
- QWidget::moveEvent(event);
-void QgsAttributeDialog::restorePositionAndColumnWidth()
+void QgsAttributeDialog::restoreGeometry()
QSettings settings;
- restoreGeometry(settings.value(_settingsPath+"geometry").toByteArray());
+ QDialog::restoreGeometry(settings.value(mSettingsPath+"geometry").toByteArray());
-void QgsAttributeDialog::setAttributeValueChanged(int row, int column)
- QgsDebugMsg("Entered with row " + QString::number(row) +
- ", column " + QString::number(column) + ".");
- mRowIsDirty.at(row) = TRUE;
Modified: trunk/qgis/src/app/qgsattributedialog.h
--- trunk/qgis/src/app/qgsattributedialog.h 2008-05-30 16:23:40 UTC (rev 8555)
+++ trunk/qgis/src/app/qgsattributedialog.h 2008-05-30 16:56:26 UTC (rev 8556)
@@ -25,49 +25,36 @@
class QDialog;
class QgsFeature;
+class QLayout;
class QgsField;
typedef QMap<int, QgsField> QgsFieldMap;
class QgsAttributeDialog: public QDialog, private Ui::QgsAttributeDialogBase
- Q_OBJECT
+ Q_OBJECT;
public:
- QgsAttributeDialog(const QgsFieldMap& fields, const QgsAttributeMap& attributes);
+ QgsAttributeDialog(const QgsFieldMap thepFieldMap, QgsFeature * thepFeature);
+ ~QgsAttributeDialog();
- ~QgsAttributeDialog();
+ /** Overloaded accept method which will write the feature field
+ * values, then delegate to QDialog::accept()
+ void accept();
+ /** Saves the size and position for the next time
+ * this dialog box was used.
+ void saveGeometry();
+ /** Restores the size and position from the last time
+ void restoreGeometry();
- /** Returns if the field value of a row was edited since this dialog opened */
- bool isDirty(int row);
- /** Opens an attribute dialog and queries the attributes for a given feature. The
- attribute values are set to the feature if the dialog is accepted.
- \retval true if accepted
- \retval false if canceled */
- static bool queryAttributes(const QgsFieldMap& fields, QgsFeature& f);
- // Saves and restores the size and position from the last time
- // this dialog box was used.
- void savePositionAndColumnWidth();
- void restorePositionAndColumnWidth();
- void resizeEvent(QResizeEvent *event);
- void moveEvent(QMoveEvent *event);
- public slots:
- //! Slot to be called when an attribute value is edited in the table.
- void setAttributeValueChanged(int row, int column);
private:
- QString _settingsPath;
- /** Returns the field value of a row */
- QString value(int row);
- std::vector<bool> mRowIsDirty;
+ QString mSettingsPath;
+ QList<QWidget *> mpWidgets;
+ QgsFieldMap mFieldMap;
+ QgsFeature * mpFeature;
#endif
Modified: trunk/qgis/src/app/qgsmaptooladdfeature.cpp
--- trunk/qgis/src/app/qgsmaptooladdfeature.cpp 2008-05-30 16:23:40 UTC (rev 8555)
+++ trunk/qgis/src/app/qgsmaptooladdfeature.cpp 2008-05-30 16:56:26 UTC (rev 8556)
@@ -170,16 +170,23 @@
// add the fields to the QgsFeature
const QgsFieldMap fields=provider->fields();
for(QgsFieldMap::const_iterator it = fields.constBegin(); it != fields.constEnd(); ++it)
- f->addAttribute(it.key(), provider->getDefaultValue(it.key()) );
+ f->addAttribute(it.key(), provider->getDefaultValue(it.key()) );
// show the dialog to enter attribute values
- if (QgsAttributeDialog::queryAttributes(fields, *f))
+ QgsAttributeDialog * mypDialog = new QgsAttributeDialog(fields,f );
+ if (mypDialog->exec())
+ qDebug("Adding feature to layer");
vlayer->addFeature(*f);
else
+ qDebug("Adding feature to layer failed");
delete f;
+ delete mypDialog;
mCanvas->refresh();
@@ -429,19 +436,21 @@
f->addAttribute(it.key(), provider->getDefaultValue(it.key()));
- if(vlayer->addFeature(*f))
- //add points to other features to keep topology up-to-date
- int topologicalEditing = QgsProject::instance()->readNumEntry("Digitizing", "/TopologicalEditing", 0);
- if(topologicalEditing)
- vlayer->addTopologicalPoints(f->geometry());
+ if(vlayer->addFeature(*f))
+ //add points to other features to keep topology up-to-date
+ int topologicalEditing = QgsProject::instance()->readNumEntry("Digitizing", "/TopologicalEditing", 0);
+ if(topologicalEditing)
+ vlayer->addTopologicalPoints(f->geometry());
delete f;
+ delete mypDialog;
// delete the elements of mCaptureList
mCaptureList.clear();
Modified: trunk/qgis/src/ui/qgsattributedialogbase.ui
--- trunk/qgis/src/ui/qgsattributedialogbase.ui 2008-05-30 16:23:40 UTC (rev 8555)
+++ trunk/qgis/src/ui/qgsattributedialogbase.ui 2008-05-30 16:56:26 UTC (rev 8556)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>329</width>
- <height>330</height>
+ <width>447</width>
+ <height>343</height>
</rect>
</property>
<property name="windowTitle" >
@@ -14,28 +14,16 @@
</property>
<layout class="QGridLayout" >
<item row="0" column="0" >
- <widget class="QTableWidget" name="mTable" >
- <property name="columnCount" >
- <number>2</number>
+ <widget class="QFrame" name="mFrame" >
+ <property name="frameShape" >
+ <enum>QFrame::StyledPanel</enum>
</property>
- <row>
- <property name="text" >
- <string>1</string>
- </property>
- </row>
- <column>
- <string>Attribute</string>
- </property>
- </column>
- <column>
- <string>Value</string>
- </property>
- </column>
+ <property name="frameShadow" >
+ <enum>QFrame::Raised</enum>
+ </property>
</widget>
</item>
- <item row="1" column="0" >
+ <item row="2" column="0" >
<widget class="QDialogButtonBox" name="buttonBox" >
<property name="standardButtons" >
<set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
@@ -45,9 +33,6 @@
</layout>
</widget>
<layoutdefault spacing="6" margin="11" />
- <tabstops>
- <tabstop>mTable</tabstop>
- </tabstops>
<resources/>
<connections>
<connection>
@@ -58,7 +43,7 @@
<hints>
<hint type="sourcelabel" >
<x>277</x>
- <y>305</y>
+ <y>318</y>
</hint>
<hint type="destinationlabel" >
<x>325</x>
