[QGIS Commit] r9574 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Fri Nov 7 12:23:33 EST 2008
Author: pcav
Date: 2008-11-07 12:23:33 -0500 (Fri, 07 Nov 2008)
New Revision: 9574
trunk/qgis/src/plugins/grass/modules/db.in.ogr.qgm
trunk/qgis/src/plugins/grass/modules/r.bitpattern.qgm
trunk/qgis/src/plugins/grass/modules/r.cost.qgm
trunk/qgis/src/plugins/grass/modules/r.drain.qgm
trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm
trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm
trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm
trunk/qgis/src/plugins/grass/modules/r.out.bin.qgm
trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm
trunk/qgis/src/plugins/grass/modules/r.out.gridatb.qgm
trunk/qgis/src/plugins/grass/modules/r.out.mat.qgm
trunk/qgis/src/plugins/grass/modules/r.out.tiff.qgm
trunk/qgis/src/plugins/grass/modules/r.reclass.file.qgm
trunk/qgis/src/plugins/grass/modules/r.region.alignTo.qgm
trunk/qgis/src/plugins/grass/modules/v.out.ascii.qgm
trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm
trunk/qgis/src/plugins/grass/modules/v.random.qgm
trunk/qgis/src/plugins/grass/modules/v.sample.qgm
trunk/qgis/src/plugins/grass/modules/v.transform.qgm
trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm
Initial cleanup of GRASS modules descriptions: remove "an", import/export instead of imports/exports, remove redundant "map" and "layer"
Modified: trunk/qgis/src/plugins/grass/modules/db.in.ogr.qgm
--- trunk/qgis/src/plugins/grass/modules/db.in.ogr.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/db.in.ogr.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Imports attribute tables in various formats" module="db.in.ogr">
+<qgisgrassmodule label="Import attribute tables in various formats" module="db.in.ogr">
<file key="dsn" type="old" label="Input table" filters="dbf, csv (*.csv *.dbf)" />
<option key="output"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.bitpattern.qgm
--- trunk/qgis/src/plugins/grass/modules/r.bitpattern.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.bitpattern.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Compares bit patterns with a raster map" module="r.bitpattern">
+<qgisgrassmodule label="Compares bit patterns with raster" module="r.bitpattern">
<flag key="q" />
<option key="input" />
Modified: trunk/qgis/src/plugins/grass/modules/r.cost.qgm
--- trunk/qgis/src/plugins/grass/modules/r.cost.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.cost.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Outputs a raster map layer showing the cumulative cost of moving between different geographic locations on an input raster map layer whose cell category values represent cost" module="r.cost">
+<qgisgrassmodule label="Output raster showing the cumulative cost of moving between different geographic locations based on cost input raster" module="r.cost">
<option key="input"/>
<option key="start_rast"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.drain.qgm
--- trunk/qgis/src/plugins/grass/modules/r.drain.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.drain.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Traces a flow through an elevation model on a raster map layer" module="r.drain">
+<qgisgrassmodule label="Traces a flow through an elevation model" module="r.drain">
<option key="coordinate"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer" module="r.in.arc">
+<qgisgrassmodule label="Convert ESRI ARC/INFO ascii raster (GRID) into a GRASS raster" module="r.in.arc">
<file key="input" type="old" />
<option key="type" />
<option key="mult" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert an ASCII raster text file into a (binary) raster map layer" module="r.in.ascii">
+<qgisgrassmodule label="Convert ASCII raster into GRASS raster" module="r.in.ascii">
<option key="nv" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Converts a raster map layer into an ESRI ARCGRID file" module="r.out.arc">
+<qgisgrassmodule label="Converts GRASS raster into ESRI ARCGRID" module="r.out.arc">
<option key="dp" answer="2"/>
<flag key="h" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.bin.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.bin.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.out.bin.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Exports a GRASS raster to a binary array" module="r.out.bin">
+<qgisgrassmodule label="Export GRASS raster to binary array" module="r.out.bin">
<option key="null" />
<flag key="h" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,9 +1,9 @@
-<qgisgrassmodule label="Export raster layer to Geo TIFF" module="r.out.gdal">
+<qgisgrassmodule label="Export raster to Geo TIFF" module="r.out.gdal">
<option key="input" region="no"/>
<option key="format" answer="GTiff" hidden="yes" />
- <option key="type" answer="UInt16" />
+ <option key="type" />
<file key="output" type="new" filters="Geo TIFF (*.tif *.tiff)" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.out.gridatb.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.gridatb.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.out.gridatb.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)" module="r.out.gridatb">
+<qgisgrassmodule label="Export GRASS raster to GRIDATB.FOR map file (TOPMODEL)" module="r.out.gridatb">
<file key="output" type="new" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.out.mat.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.mat.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.out.mat.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Exports a GRASS raster to a binary MAT-File" module="r.out.mat">
+<qgisgrassmodule label="Export GRASS raster to binary MAT-File" module="r.out.mat">
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.out.tiff.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.tiff.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.out.tiff.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region" module="r.out.tiff">
+<qgisgrassmodule label="Export GRASS raster to 8/24bit TIFF image at the resolution of the current region" module="r.out.tiff">
<option key="compression" />
<flag key="p" />
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.file.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.file.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.file.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Creates a new map layer whose category values are based upon the user's reclassification of categories in an existing raster map layer" module="r.reclass.file">
+<qgisgrassmodule label="Create new layer with category values based upon user's reclassification of categories in existing raster" module="r.reclass.file">
<file key="rules_file" type="new" fileoption="olayer" label="Text file" filters="Txt (*.txt), Csv (*.csv)" />
<option key="output" />
Modified: trunk/qgis/src/plugins/grass/modules/r.region.alignTo.qgm
--- trunk/qgis/src/plugins/grass/modules/r.region.alignTo.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/r.region.alignTo.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sets region to align to a raster map" module="r.region">
+<qgisgrassmodule label="Sets region to align to a raster" module="r.region">
<option key="map" />
<option key="align" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.out.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.ascii.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/v.out.ascii.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert a GRASS binary vector map to a GRASS ASCII vector map" module="v.out.ascii">
+<qgisgrassmodule label="Convert GRASS binary vector to GRASS ASCII vector" module="v.out.ascii">
<option key="format"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Converts a GRASS vector map to DXF" module="v.out.dxf">
+<qgisgrassmodule label="Converts GRASS vector to DXF" module="v.out.dxf">
<file key="output" type="new" filters="DXF (*.dxf)"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.random.qgm
--- trunk/qgis/src/plugins/grass/modules/v.random.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/v.random.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Randomly generate a 2D/3D GRASS vector points map" module="v.random">
+<qgisgrassmodule label="Randomly generate 2D/3D GRASS vector points" module="v.random">
<option key="n" answer="1" hidden="no"/>
<option key="zmin" answer="0.0" hidden="no"/>
<option key="zmax" answer="0.0" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.sample.qgm
--- trunk/qgis/src/plugins/grass/modules/v.sample.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/v.sample.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sample a raster file at site locations" module="v.sample">
+<qgisgrassmodule label="Sample raster at site locations" module="v.sample">
<option key="input" typemask="point"/>
<field key="column" layer="vector" type="integer,double"/>
<option key="raster"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.transform.qgm
--- trunk/qgis/src/plugins/grass/modules/v.transform.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/v.transform.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map" module="v.transform">
+<qgisgrassmodule label="Perform affine transformation (shift, scale and rotate, or GPCs) on vector" module="v.transform">
<option key="input" layeroption="layer"/>
<option key="xshift"/>
<option key="yshift"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm
--- trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm 2008-11-07 16:46:20 UTC (rev 9573)
+++ trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm 2008-11-07 17:23:33 UTC (rev 9574)
@@ -1,9 +1,9 @@
-<qgisgrassmodule label="Uploads map for which to edit attribute table" module="v.what.vect">
+<qgisgrassmodule label="Uploads vector values at positions of vector points to the table" module="v.what.vect">
<option key="vector" layeroption="layer" typemask="point"/>
<field key="column" layer="vector" type="integer,double,string"/>
<option key="qvector" layeroption="layer" typemask="area"/>
- <option key="qcolumn" layer="qvector"/>
+ <option key="qcolumn" layer="qvector" type="string"/>
</qgisgrassmodule>
