[QGIS Commit] r9585 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Sat Nov 8 03:35:38 EST 2008
Author: pcav
Date: 2008-11-08 03:35:37 -0500 (Sat, 08 Nov 2008)
New Revision: 9585
Added:
trunk/qgis/src/plugins/grass/modules/db.connect.which.1.png
trunk/qgis/src/plugins/grass/modules/db.connect.which.qgm
Removed:
trunk/qgis/src/plugins/grass/modules/db.connect.wich.1.png
trunk/qgis/src/plugins/grass/modules/db.connect.wich.qgm
Changed name of a module (unused currently, as it is not in the default config)
Added: trunk/qgis/src/plugins/grass/modules/db.connect.which.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules/db.connect.which.1.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules/db.connect.which.qgm
--- trunk/qgis/src/plugins/grass/modules/db.connect.which.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/db.connect.which.qgm 2008-11-08 08:35:37 UTC (rev 9585)
@@ -0,0 +1,6 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Print general DB connection" module="db.connect">
+ <flag key="p" answer="on" hidden="yes"/>
+</qgisgrassmodule>
Deleted: trunk/qgis/src/plugins/grass/modules/db.connect.wich.1.png
Deleted: trunk/qgis/src/plugins/grass/modules/db.connect.wich.qgm
--- trunk/qgis/src/plugins/grass/modules/db.connect.wich.qgm 2008-11-08 08:28:42 UTC (rev 9584)
+++ trunk/qgis/src/plugins/grass/modules/db.connect.wich.qgm 2008-11-08 08:35:37 UTC (rev 9585)
@@ -1,6 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Prints general DB connection mapset" module="db.connect">
- <flag key="p" answer="on" hidden="yes"/>
-</qgisgrassmodule>
