[QGIS Commit] r9587 - in branches/advanced_printing_branch2/src: app/composer ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 8 04:53:54 EST 2008
Author: mhugent
Date: 2008-11-08 04:53:53 -0500 (Sat, 08 Nov 2008)
New Revision: 9587
   branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.cpp
   branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.h
   branches/advanced_printing_branch2/src/ui/qgscomposerpicturewidgetbase.ui
Add and remove directories for composer picture preview
Modified: branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.cpp
--- branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.cpp	2008-11-08 09:37:18 UTC (rev 9586)
+++ branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.cpp	2008-11-08 09:53:53 UTC (rev 9587)
@@ -160,6 +160,38 @@
   mPicture->update();
+void QgsComposerPictureWidget::on_mAddDirectoryButton_clicked()
+  //let user select a directory
+  QString directory = QFileDialog::getExistingDirectory(0, tr("Select new preview directory"));
+  if(directory.isNull())
+    return; //dialog canceled by user
+  //add entry to mSearchDirectoriesComboBox
+  mSearchDirectoriesComboBox->addItem(directory);
+  //and add icons to the preview
+  addDirectoryToPreview(directory);
+void QgsComposerPictureWidget::on_mRemoveDirectoryButton_clicked()
+  QString directoryToRemove = mSearchDirectoriesComboBox->currentText();
+  mSearchDirectoriesComboBox->removeItem(mSearchDirectoriesComboBox->currentIndex());
+  //remove entries from back to front (to have the indices of existing items constant)
+  for(int i = (mPreviewListWidget->count() - 1); i >=0; --i)
+    QListWidgetItem* currentItem = mPreviewListWidget->item(i);
+    if(currentItem && currentItem->data(Qt::UserRole).toString().startsWith(directoryToRemove))
+      delete(mPreviewListWidget->takeItem(i));
 void QgsComposerPictureWidget::setGuiElementValues()
   //set initial gui values
@@ -217,7 +249,7 @@
       return; //error
-  QFileInfoList directoryList = svgDirectory.entryInfoList(QDir::Dirs);
+  QFileInfoList directoryList = svgDirectory.entryInfoList(QDir::Dirs | QDir::NoDotAndDotDot);
   QFileInfoList::const_iterator dirIt = directoryList.constBegin();
   for(; dirIt != directoryList.constEnd(); ++dirIt)
Modified: branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.h
--- branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.h	2008-11-08 09:37:18 UTC (rev 9586)
+++ branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.h	2008-11-08 09:53:53 UTC (rev 9587)
@@ -40,6 +40,8 @@
     void on_mWidthLineEdit_editingFinished();
     void on_mHeightLineEdit_editingFinished();
     void on_mPreviewListWidget_currentItemChanged( QListWidgetItem* current, QListWidgetItem* previous );
+    void on_mAddDirectoryButton_clicked();
+    void on_mRemoveDirectoryButton_clicked();
     /**Sets the GUI elements to the values of mPicture*/
     void setGuiElementValues();
Modified: branches/advanced_printing_branch2/src/ui/qgscomposerpicturewidgetbase.ui
--- branches/advanced_printing_branch2/src/ui/qgscomposerpicturewidgetbase.ui	2008-11-08 09:37:18 UTC (rev 9586)
+++ branches/advanced_printing_branch2/src/ui/qgscomposerpicturewidgetbase.ui	2008-11-08 09:53:53 UTC (rev 9587)
@@ -5,8 +5,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>317</width>
-    <height>547</height>
+    <width>342</width>
+    <height>613</height>
    </rect>
   </property>
   <property name="sizePolicy" >
@@ -32,26 +32,42 @@
      </property>
      <layout class="QGridLayout" >
       <item row="0" column="0" >
-       <layout class="QHBoxLayout" >
-        <item>
-         <widget class="QComboBox" name="mSearchDirectoriesComboBox" >
-          <property name="sizePolicy" >
-           <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
-            <horstretch>0</horstretch>
-            <verstretch>0</verstretch>
-           </sizepolicy>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QPushButton" name="mAddDirectoryButton" >
-          <property name="text" >
-           <string>Add...</string>
-          </property>
-         </widget>
-        </item>
-       </layout>
+       <spacer>
+        <property name="orientation" >
+         <enum>Qt::Horizontal</enum>
+        </property>
+        <property name="sizeHint" >
+         <size>
+          <width>101</width>
+          <height>20</height>
+         </size>
+        </property>
+       </spacer>
       </item>
+      <item row="0" column="1" >
+       <widget class="QPushButton" name="mAddDirectoryButton" >
+        <property name="text" >
+         <string>Add...</string>
+        </property>
+       </widget>
+      </item>
+      <item row="0" column="2" >
+       <widget class="QPushButton" name="mRemoveDirectoryButton" >
+         <string>Remove</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="0" colspan="3" >
+       <widget class="QComboBox" name="mSearchDirectoriesComboBox" >
+        <property name="sizePolicy" >
+         <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+          <horstretch>0</horstretch>
+          <verstretch>0</verstretch>
+         </sizepolicy>
+        </property>
+       </widget>
+      </item>
      </layout>
     </widget>
    </item>
More information about the QGIS-commit mailing list
