[QGIS Commit] r9610 - trunk/code_examples/3_basic_labelling
svn_qgis at osgeo.org
Sun Nov 9 04:46:54 EST 2008
Author: timlinux
Date: 2008-11-09 04:46:54 -0500 (Sun, 09 Nov 2008)
New Revision: 9610
trunk/code_examples/3_basic_labelling/tutorial3.t2t
Minor formatting tweaks
Modified: trunk/code_examples/3_basic_labelling/tutorial3.t2t
--- trunk/code_examples/3_basic_labelling/tutorial3.t2t 2008-11-09 09:44:11 UTC (rev 9609)
+++ trunk/code_examples/3_basic_labelling/tutorial3.t2t 2008-11-09 09:46:54 UTC (rev 9610)
@@ -58,12 +58,9 @@
including c++ sources, icons and a simple data file under data. There is also
the .ui file for the main window.
-**Note:** You will need to edit the .pro file in the above svn directory to
-match your system.
+**Labelling Specifics**
-** Labelling Specifics **
If you look in mainwindow.cpp you will notice a couple of new includes
introduced since the last tutorial:
@@ -210,7 +207,7 @@
-== Mac Specific Notes ==
+**Mac Specific Notes**
After building the application bundle (cmake; make) you can copy the spatial
reference system database into the bundle to avoid 'cant find resource' type
