[QGIS Commit] r9639 - branches/advanced_printing_branch2/src/app/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 15 05:29:31 EST 2008
Author: mhugent
Date: 2008-11-15 05:29:31 -0500 (Sat, 15 Nov 2008)
New Revision: 9639
   branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.cpp
   branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.h
Improvements for composer picture preview
Modified: branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.cpp
--- branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.cpp	2008-11-15 06:10:32 UTC (rev 9638)
+++ branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.cpp	2008-11-15 10:29:31 UTC (rev 9639)
@@ -234,46 +234,59 @@
   QFileInfoList::const_iterator fileIt = fileList.constBegin();
   QProgressDialog progress("Adding Icons...", "Abort", 0, fileList.size() - 1, this);
-  progress.setWindowModality(Qt::WindowModal);
+  //cancel button does not seem to work properly with modal dialog
+  //progress.setWindowModality(Qt::WindowModal);
   int counter = 0;
   for(; fileIt != fileList.constEnd(); ++fileIt)
     progress.setLabelText(tr("Creating icon for file ") + fileIt->fileName());
-    QCoreApplication::processEvents(); //for abort button
+    progress.setValue(counter);
+    QCoreApplication::processEvents();
     if(progress.wasCanceled())
       break;
-    progress.setValue(counter);
     QString filePath = fileIt->absoluteFilePath();
-    //exclude non-picture files
-    if(!testPictureFile(filePath))
+    //test if file is svg or pixel format
+    bool fileIsPixel = false;
+    bool fileIsSvg = testSvgFile(filePath);
+    if(!fileIsSvg)
+	fileIsPixel = testImageFile(filePath);
+    //exclude files that are not svg or image
+    if(!fileIsSvg && !fileIsPixel)
-      ++counter;
-      continue;
+      ++counter; continue;
     QListWidgetItem * listItem = new QListWidgetItem(mPreviewListWidget);
-    if(filePath.endsWith(".svg")) //for svg files: create the icon directly
+    if(fileIsSvg)
       QIcon icon(filePath);
       listItem->setIcon(icon);
-    else //for pixel formats: create icon from scaled pixmap
+    else if(fileIsPixel) //for pixel formats: create icon from scaled pixmap
       QPixmap iconPixmap(filePath);
       if(iconPixmap.isNull())
-        continue; //unknown file format or other problem
+        ++counter; continue; //unknown file format or other problem
       //set pixmap hardcoded to 30/30, same as icon size for mPreviewListWidget
       QPixmap scaledPixmap(iconPixmap.scaled(QSize(30, 30), Qt::KeepAspectRatio));
       QIcon icon(scaledPixmap);
+    else
     listItem->setText( "" );
     //store the absolute icon file path as user data
@@ -297,7 +310,6 @@
   QFileInfoList::const_iterator dirIt = directoryList.constBegin();
   for(; dirIt != directoryList.constEnd(); ++dirIt)
-    qWarning(dirIt->absoluteFilePath().toLocal8Bit().data());
     if(addDirectoryToPreview(dirIt->absoluteFilePath()) == 0)
        mSearchDirectoriesComboBox->addItem(dirIt->absoluteFilePath());
@@ -305,23 +317,22 @@
-bool QgsComposerPictureWidget::testPictureFile(const QString& filename) const
+bool QgsComposerPictureWidget::testSvgFile(const QString& filename) const
-  bool pixelFormat = false;
-  bool svgFormat = false;
+  QSvgRenderer svgRenderer(filename);
+  if(svgRenderer.isValid())
+    return true;
+  return false;
+bool QgsComposerPictureWidget::testImageFile(const QString& filename) const
   QString formatName = QString(QImageReader::imageFormat(filename));
-  qWarning(formatName.toLocal8Bit().data());
   if(!formatName.isEmpty())
     return true; //file is in a supported pixel format
-  QSvgRenderer svgRenderer(filename);
-  if(svgRenderer.isValid())
-    return true;
   return false;
Modified: branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.h
--- branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.h	2008-11-15 06:10:32 UTC (rev 9638)
+++ branches/advanced_printing_branch2/src/app/composer/qgscomposerpicturewidget.h	2008-11-15 10:29:31 UTC (rev 9639)
@@ -51,8 +51,10 @@
     int addDirectoryToPreview(const QString& path);
     /**Add the icons of the standard directories to the preview*/
     void addStandardDirectoriesToPreview();
-    /**Returns true if a file is in a supported image format or in svg*/
-    bool testPictureFile(const QString& filename) const;
+    /**Tests if a file is valid svg*/
+    bool testSvgFile(const QString& filename) const;
+    /**Tests if a file is a valid pixel format*/
+    bool testImageFile(const QString& filename) const;
 #endif
More information about the QGIS-commit mailing list
