[QGIS Commit] r9643 - trunk/qgis/images/svg/north_arrows
svn_qgis at osgeo.org
Sat Nov 15 16:03:52 EST 2008
Author: timlinux
Date: 2008-11-15 16:03:52 -0500 (Sat, 15 Nov 2008)
New Revision: 9643
Added:
trunk/qgis/images/svg/north_arrows/NorthArrow10.svg
trunk/qgis/images/svg/north_arrows/NorthArrow11.svg
trunk/qgis/images/svg/north_arrows/NorthArrow12.svg
trunk/qgis/images/svg/north_arrows/NorthArrow13.svg
trunk/qgis/images/svg/north_arrows/NorthArrow14.svg
trunk/qgis/images/svg/north_arrows/NorthArrow15.svg
trunk/qgis/images/svg/north_arrows/NorthArrow16.svg
Added north arrows contributed by Nikos Alexandris <nikos.alexandris @ uranus.uni-freiburg.de>
Added: trunk/qgis/images/svg/north_arrows/NorthArrow10.svg
--- trunk/qgis/images/svg/north_arrows/NorthArrow10.svg (rev 0)
+++ trunk/qgis/images/svg/north_arrows/NorthArrow10.svg 2008-11-15 21:03:52 UTC (rev 9643)
@@ -0,0 +1,67 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Generator: Adobe Illustrator 9.0, SVG Export Plug-In -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ width="112.02pt"
+ height="113.641pt"
+ viewBox="0 0 112.02 113.641"
+ xml:space="preserve"
+ id="svg2495"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ sodipodi:docname="NorthArrow17.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"><metadata
+ id="metadata2509"><rdf:RDF><cc:Work
+ rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
+ id="defs2507"><inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 71.025627 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="140.02499 : 71.025627 : 1"
+ inkscape:persp3d-origin="70.012497 : 47.350418 : 1"
+ id="perspective2511" /></defs><sodipodi:namedview
+ inkscape:window-height="786"
+ inkscape:window-width="1278"
+ inkscape:pageshadow="2"
+ inkscape:pageopacity="0.0"
+ guidetolerance="10.0"
+ gridtolerance="10.0"
+ objecttolerance="10.0"
+ borderopacity="1.0"
+ bordercolor="#666666"
+ pagecolor="#ffffff"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="4.1252193"
+ inkscape:cx="70.156057"
+ inkscape:cy="70.953176"
+ inkscape:window-x="0"
+ inkscape:window-y="1050"
+ inkscape:current-layer="svg2495"
+ showguides="true"
+ inkscape:guide-bbox="true" />
+<g
+ id="g2382"><g
+ id="g3725"><g
+ id="g3115"
+ transform="matrix(0.9967843,0,0,0.9968324,0.1611099,0.3592317)"><path
+ transform="matrix(1.0561497,0,0,1.0552631,-6.8865399,-4.1245799)"
+ d="M 112.57141,57.638145 A 52.89159,53.74012 0 1 1 6.7882271,57.638145 A 52.89159,53.74012 0 1 1 112.57141,57.638145 z"
+ sodipodi:ry="53.74012"
+ sodipodi:rx="52.89159"
+ sodipodi:cy="57.638145"
+ sodipodi:cx="59.679817"
+ id="path3021"
+ style="opacity:1;fill:#00ff00;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ sodipodi:type="arc" /><path
+ id="path3086"
+ d="M 56.044281,11.640064 L 18.944281,48.915064 L 40.144281,48.815064 L 40.144281,97.065064 L 40.144281,98.61506 C 40.140271,98.67019 40.119281,98.70958 40.119281,98.76506 C 40.119281,98.82056 40.140271,98.88494 40.144281,98.94006 L 40.144281,99.09006 L 40.169281,99.09006 C 40.597801,102.25039 47.568561,104.76505 56.119281,104.76506 C 64.668781,104.76507 71.638961,102.24976 72.069281,99.09006 L 72.119281,99.09006 L 72.119281,98.76506 L 72.119281,97.265064 C 72.133061,97.196032 72.144281,97.134968 72.144281,97.065064 C 72.144281,96.995144 72.158101,96.909096 72.144281,96.840064 L 72.144281,48.640064 L 93.344281,48.540064 L 56.044281,11.640064 z"
+ style="opacity:0.7;fill:#0000ff;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1" /></g></g></g></svg>
\ No newline at end of file
Added: trunk/qgis/images/svg/north_arrows/NorthArrow11.svg
--- trunk/qgis/images/svg/north_arrows/NorthArrow11.svg (rev 0)
+++ trunk/qgis/images/svg/north_arrows/NorthArrow11.svg 2008-11-15 21:03:52 UTC (rev 9643)
@@ -0,0 +1,66 @@
+<svg
+ width="112.02pt"
+ id="svg2495"
+ sodipodi:docname="NorthArrow18.svg"
+ inkscape:window-height="1013"
+ inkscape:window-width="1678"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="4.4535136"
+ inkscape:cx="57.759659"
+ inkscape:cy="78.16933"
+ inkscape:window-y="23"
+ showguides="true"
+<g
+ id="g3159"><g
+ id="g3115"><path
+ style="opacity:1;fill:#00ff00;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.1;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="path3021"
+ transform="matrix(1.0561497,0,0,1.0552631,-6.8865399,-4.1245799)" /><path
+ style="opacity:1;fill:#ff0000;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.1;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="path3086" /></g></g></svg>
Added: trunk/qgis/images/svg/north_arrows/NorthArrow12.svg
--- trunk/qgis/images/svg/north_arrows/NorthArrow12.svg (rev 0)
+++ trunk/qgis/images/svg/north_arrows/NorthArrow12.svg 2008-11-15 21:03:52 UTC (rev 9643)
@@ -0,0 +1,66 @@
+<svg
+ width="112.02pt"
+ id="svg2495"
+ sodipodi:docname="NorthArrow19.svg"
+ id="base"
+ showgrid="false"
+ showguides="true"
+<g
+ id="g3725"><g
+ id="g3115"><path
+ style="opacity:1;fill:#ffff00;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="path3021"
+ style="opacity:1;fill:#2b0000;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
Added: trunk/qgis/images/svg/north_arrows/NorthArrow13.svg
--- trunk/qgis/images/svg/north_arrows/NorthArrow13.svg (rev 0)
+++ trunk/qgis/images/svg/north_arrows/NorthArrow13.svg 2008-11-15 21:03:52 UTC (rev 9643)
@@ -0,0 +1,66 @@
+<svg
+ width="112.02pt"
+ id="svg2495"
+ sodipodi:docname="NorthArrow20.svg"
+ id="base"
+ showgrid="false"
+ inkscape:cx="65.394081"
+ showguides="true"
+<g
+ id="g3725"><g
+ id="g3115"><path
+ style="opacity:1;fill:#000000;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="path3021"
Added: trunk/qgis/images/svg/north_arrows/NorthArrow14.svg
--- trunk/qgis/images/svg/north_arrows/NorthArrow14.svg (rev 0)
+++ trunk/qgis/images/svg/north_arrows/NorthArrow14.svg 2008-11-15 21:03:52 UTC (rev 9643)
@@ -0,0 +1,66 @@
+<svg
+ width="112.02pt"
+ id="svg2495"
+ sodipodi:docname="NorthArrow21.svg"
+ id="base"
+ showgrid="false"
+ inkscape:cx="81.753902"
+ inkscape:cy="75.595179"
+ showguides="true"
+<g
+ id="g3725"><g
+ id="g3115"><path
+ style="opacity:1;fill:#b3b3b3;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="path3021"
+ style="opacity:1;fill:#d40000;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
Added: trunk/qgis/images/svg/north_arrows/NorthArrow15.svg
--- trunk/qgis/images/svg/north_arrows/NorthArrow15.svg (rev 0)
+++ trunk/qgis/images/svg/north_arrows/NorthArrow15.svg 2008-11-15 21:03:52 UTC (rev 9643)
@@ -0,0 +1,66 @@
+<svg
+ width="112.02pt"
+ id="svg2495"
+ sodipodi:docname="NorthArrow22.svg"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="5.7314367"
+ showguides="true"
+<g
+ id="g3725"><g
+ id="g3115"><path
+ style="opacity:0.85;fill:#b3b3b3;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="path3021"
+ style="opacity:1;fill:#0000d4;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
Added: trunk/qgis/images/svg/north_arrows/NorthArrow16.svg
--- trunk/qgis/images/svg/north_arrows/NorthArrow16.svg (rev 0)
+++ trunk/qgis/images/svg/north_arrows/NorthArrow16.svg 2008-11-15 21:03:52 UTC (rev 9643)
@@ -0,0 +1,66 @@
+<svg
+ width="112.02pt"
+ id="svg2495"
+ sodipodi:docname="NorthArrow23.svg"
+ id="base"
+ showgrid="false"
+ showguides="true"
+<g
+ id="g3725"><g
+ id="g3115"><path
+ id="path3021"
+ style="opacity:1;fill:#ffffff;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.10000000000000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
