[QGIS Commit] r9431 - trunk/qgis/src/core/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Oct 4 04:54:16 EDT 2008
Author: mhugent
Date: 2008-10-04 04:54:16 -0400 (Sat, 04 Oct 2008)
New Revision: 9431
   trunk/qgis/src/core/composer/qgslegendmodel.cpp
Take the label for the composer legend if there is one
Modified: trunk/qgis/src/core/composer/qgslegendmodel.cpp
--- trunk/qgis/src/core/composer/qgslegendmodel.cpp	2008-10-04 01:02:15 UTC (rev 9430)
+++ trunk/qgis/src/core/composer/qgslegendmodel.cpp	2008-10-04 08:54:16 UTC (rev 9431)
@@ -132,46 +132,6 @@
       continue;
-#if 0
-    //label
-    QString label;
-    QString lowerValue = ( *symbolIt )->lowerValue();
-    QString upperValue = ( *symbolIt )->upperValue();
-    if ( lowerValue == upperValue || upperValue.isEmpty() )
-      label = lowerValue;
-    else
-      label = lowerValue + " - " + upperValue;
-    //icon item
-    switch (( *symbolIt )->type() )
-      case QGis::Point:
-        currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage(( *symbolIt )->getPointSymbolAsImage() ) ), label );
-        break;
-      case QGis::Line:
-        currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage(( *symbolIt )->getLineSymbolAsImage() ) ), label );
-        break;
-      case QGis::Polygon:
-        currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage(( *symbolIt )->getPolygonSymbolAsImage() ) ), label );
-        break;
-      default:
-        currentSymbolItem = 0;
-        break;
-    //Pass deep copy of QgsSymbol as user data. Cast to void* necessary such that QMetaType handles it
-    QgsSymbol* symbolCopy = new QgsSymbol( **symbolIt );
-    currentSymbolItem->setData( QVariant::fromValue(( void* )symbolCopy ) );
-    insertSymbol( symbolCopy );
-    currentSymbolItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
-#endif //0
     QStandardItem* currentSymbolItem = itemFromSymbol( *symbolIt );
     if ( !currentSymbolItem )
@@ -465,30 +425,40 @@
   QStandardItem* currentSymbolItem = 0;
   //label
+  QString itemText;
   QString label;
   QString lowerValue = s->lowerValue();
   QString upperValue = s->upperValue();
+  label = s->label();
+  //Take the label as item text if it is there
+  if(!label.isEmpty())
+      itemText = label;
+  //take single value
+  else if ( lowerValue == upperValue || upperValue.isEmpty() )
+    itemText = lowerValue;
-  else
+  else //or value range
+    itemText = lowerValue + " - " + upperValue;
   //icon item
   switch ( s->type() )
     case QGis::Point:
-      currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage( s->getPointSymbolAsImage() ) ), label );
+      currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage( s->getPointSymbolAsImage() ) ), itemText );
       break;
     case QGis::Line:
-      currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage( s->getLineSymbolAsImage() ) ), label );
+      currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage( s->getLineSymbolAsImage() ) ), itemText );
       break;
     case QGis::Polygon:
-      currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage( s->getPolygonSymbolAsImage() ) ), label );
+      currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage( s->getPolygonSymbolAsImage() ) ), itemText );
       break;
     default:
More information about the QGIS-commit mailing list
