[QGIS Commit] r9456 - in trunk/qgis/src: app core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Oct 8 01:46:44 EDT 2008
Author: timlinux
Date: 2008-10-08 01:46:44 -0400 (Wed, 08 Oct 2008)
New Revision: 9456
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/core/qgsproject.cpp
Bugfix: when saving a project and there is insufficient space on the volume, handle the problem gracefully. Also fixed qgisapp so that failed project saving before app exiting halts app exit properly
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-10-08 05:41:46 UTC (rev 9455)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-10-08 05:46:44 UTC (rev 9456)
@@ -3133,6 +3133,7 @@
       QMessageBox::critical( this,
                              tr( "Unable to save project" ),
                              tr( "Unable to save project to " ) + QgsProject::instance()->fileName() );
+      return false;
   catch ( std::exception & e )
@@ -3140,6 +3141,7 @@
                            tr( "Unable to save project " ) + QgsProject::instance()->fileName(),
                            QString::fromLocal8Bit( e.what() ) );
+    return false;
   return true;
 } // QgisApp::fileSave
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp	2008-10-08 05:41:46 UTC (rev 9455)
+++ trunk/qgis/src/core/qgsproject.cpp	2008-10-08 05:46:44 UTC (rev 9456)
@@ -1015,6 +1015,18 @@
   doc->save( projectFileStream, 4 );  // save as utf-8
   imp_->file.close();
+  // check if the text stream had no error - if it does
+  // the user will get a message so they can try to resolve the
+  // situation e.g. by saving project to a volume with more space
+  if ( projectFileStream.pos() == -1  || imp_->file.error() != QFile::NoError)
+    throw QgsIOException( QObject::tr( "Unable to save to file. Your project "
+          "may be corrupted on disk. Try clearing some space on the volume and "
+          "check file permissions before pressing save again." ) +
+        imp_->file.fileName() );
+    return false;
   dirty( false );               // reset to pristine state
More information about the QGIS-commit mailing list
