[QGIS Commit] r9463 - in docs/trunk/english_us/user_guide: . plugins_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Oct 9 05:33:09 EDT 2008
Author: dassau
Date: 2008-10-09 05:33:08 -0400 (Thu, 09 Oct 2008)
New Revision: 9463
Added:
   docs/trunk/english_us/user_guide/plugins_screenies/ogrconverter_dialog.png
   docs/trunk/english_us/user_guide/plugins_ogr_converter.tex
   docs/trunk/english_us/user_guide/plugins_screenies/Makefile
wrote a section for the OGR converter plugin
Modified: docs/trunk/english_us/user_guide/plugins_ogr_converter.tex
--- docs/trunk/english_us/user_guide/plugins_ogr_converter.tex	2008-10-08 22:14:47 UTC (rev 9462)
+++ docs/trunk/english_us/user_guide/plugins_ogr_converter.tex	2008-10-09 09:33:08 UTC (rev 9463)
@@ -2,10 +2,34 @@
 % when the revision of a section has been finalized,
 % comment out the following line:
-\updatedisclaimer
+% \updatedisclaimer
+The OGR layer converter plugin allows to convert vector data from one OGR-supported
+vector format to another OGR-supported vector format. It is very simple to handle and
+provides functionalities as shown in Figure \ref{fig:ogrconverter_dialog}. The
+supported formats can vary according to the installed GDAL/OGR package.
+\begin{itemize}
+\item \textbf{Source Format/Datset/Layer}: Enter OGR format and path to the vector file to be converted
+\item \textbf{Target Format/Datset/Layer}: Enter OGR format and path to the vector output file
+\end{itemize}
+\begin{figure}[ht]
+   \begin{center}
+   \caption{OGR Layer Converter Plugin \nixcaption}\label{fig:ogrconverter_dialog}\smallskip
+   \includegraphics[clip=true, width=9cm]{ogrconverter_dialog}
+\end{center}
+\end{figure}
+\begin{enumerate}
+  \item Start QGIS, load the OGR converter plugin in the Plugin Manager (see Section
+  \ref{sec:load_core_plugin}) and click on the \toolbtntwo{ogr_converter}{OGR Layer Converter}
+  icon which appears in the QGIS toolbar menu. The OGR Layer Converter plugin dialog appears as shown in Figure \ref{fig:ogrconverter_dialog}.
+  \item Select the OGR-supported format \selectstring{ESRI Shapefile}{\ldots} and the path to the vector input file \filename{alaska.shp} in the Source area.
+  \item Select the OGR-supported format \selectstring{GML}{\ldots} and define a path and the vector output filename \filename{alaska.gml} in the Target area.
+  \item Click \button{Ok}.
+\end{enumerate}
 \newpage
Modified: docs/trunk/english_us/user_guide/plugins_screenies/Makefile
--- docs/trunk/english_us/user_guide/plugins_screenies/Makefile	2008-10-08 22:14:47 UTC (rev 9462)
+++ docs/trunk/english_us/user_guide/plugins_screenies/Makefile	2008-10-09 09:33:08 UTC (rev 9463)
@@ -17,8 +17,8 @@
 	mapserver_export_dialog.eps\
 	mapserver_export_test.eps\
 	coordinate_capture_dialog.eps\
+	ogrconverter_dialog.eps\
 ##### TARGETS #####
 all: $(PNG) $(JPG)
Added: docs/trunk/english_us/user_guide/plugins_screenies/ogrconverter_dialog.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_screenies/ogrconverter_dialog.png
___________________________________________________________________
   + application/octet-stream
More information about the QGIS-commit mailing list
