[QGIS Commit] r9474 - in trunk/qgis: resources scripts
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Oct 13 10:15:59 EDT 2008
Author: homann
Date: 2008-10-13 10:15:58 -0400 (Mon, 13 Oct 2008)
New Revision: 9474
   trunk/qgis/resources/srs.db
   trunk/qgis/scripts/postprocess_srs.sql
Fix for #728
Modified: trunk/qgis/resources/srs.db
(Binary files differ)
Modified: trunk/qgis/scripts/postprocess_srs.sql
--- trunk/qgis/scripts/postprocess_srs.sql	2008-10-10 21:36:34 UTC (rev 9473)
+++ trunk/qgis/scripts/postprocess_srs.sql	2008-10-13 14:15:58 UTC (rev 9474)
@@ -2,6 +2,7 @@
 -- Run (from Linux):
 -- sqlite3 srs.db <postprocess_srs.sql
+-- Swedish RT-90 projections with increased accuracy
 REPLACE INTO tbl_srs VALUES(984,'RT90 7.5 gon V','tmerc','GRS80',
 '+proj=tmerc +lat_0=0 +lon_0=11.306250000000 +k=1.000006000000 +x_0=1500025.141 +y_0=-667.282 +ellps=GRS80 +units=m +no_defs',3019,3019,0);
 REPLACE INTO tbl_srs VALUES(985,'RT90 5 gon V','tmerc','GRS80',
@@ -14,3 +15,6 @@
 '+proj=tmerc +lat_0=0 +lon_0=20.306316666666 +k=1.000005200000 +x_0=1500102.765 +y_0=-670.706 +ellps=GRS80 +units=m +no_defs',3023,3023,0);
 REPLACE INTO tbl_srs VALUES(989,'RT90 5 gon O','tmerc','GRS80',
 '+proj=tmerc +lat_0=0 +lon_0=22.556333333333 +k=1.000004900000 +x_0=1500121.846 +y_0=-672.557 +ellps=GRS80 +units=m +no_defs',3024,3024,0);
+-- S-JTSK/Krovak (Greenwich) (ticket #728)
+insert into tbl_srs values (3520,'S-JTSK (Greenwich) / Krovak','krovak','bessel','+proj=krovak +lat_0=49.5 +lon_0=24.83333333333333 +alpha=30.28813972222222 +k=0.9999 +x_0=0 +y_0=0 +ellps=bessel +pm=greenwich +units=m +no_defs','102067','102067','0');
\ No newline at end of file
More information about the QGIS-commit mailing list
