[QGIS Commit] r9479 - in trunk/qgis: python/core src/app src/core/renderer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Oct 16 13:30:14 EDT 2008
Author: timlinux
Date: 2008-10-16 13:30:14 -0400 (Thu, 16 Oct 2008)
New Revision: 9479
   trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip
   trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
   trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp
   trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.h
Fix for ticket #1200 - remember state of mode in graduated symbold dialog. Also fixes symbol preview update issues. Note there still seems to be a general bug in quantile computation which is not addressed yet.
Modified: trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip
--- trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip	2008-10-16 06:31:25 UTC (rev 9478)
+++ trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip	2008-10-16 17:30:14 UTC (rev 9479)
@@ -6,42 +6,79 @@
 %End
  public:
+    enum Mode
+      EqualInterval,
+      Quantile,
+      Empty
     QgsGraduatedSymbolRenderer(QGis::GeometryType type);
     QgsGraduatedSymbolRenderer(const QgsGraduatedSymbolRenderer& other);
     virtual ~QgsGraduatedSymbolRenderer();
+    /** Get the mode - which is only really used to be able to reinstate
+     * the graduated dialog properties properly, so we
+     * dont do anything else besides accessors and mutators in
+     * this class.
+    const Mode mode() const;
+    /** Set the mode - which is only really used to be able to reinstate
+     * this class.
+    void setMode( Mode theMode );
     /**Adds a new item
     \param sy a pointer to the QgsSymbol to be inserted. It has to be created using the new operator and is automatically destroyed when 'removeItems' is called or when this object is destroyed*/
     void addSymbol(QgsSymbol* sy /Transfer/);
     /**Returns the number of the classification field*/
     int classificationField() const;
     /**Removes all symbols*/
     void removeSymbols();
     /** Determines if a feature will be rendered or not
-	@param f a pointer to the feature to determine if rendering will happen*/
+	  @param f a pointer to the feature to determine if rendering will happen*/
     bool willRenderFeature(QgsFeature *f);
     /**Renders an OGRFeature
      \param p a painter (usually the one from the current map canvas)
      \param f a pointer to a feature to render
      \param t the transform object containing the information how to transform the map coordinates to screen coordinates*/
     void renderFeature(QPainter* p, QgsFeature& f, QImage* img, bool selected, double widthScale = 1.0, double rasterScaleFactor = 1.0);
     /**Sets the number of the classicifation field
     \param field the number of the field to classify*/
     void setClassificationField(int field);
     /**Reads the renderer configuration from an XML file
      @param rnode the Dom node to read
      @param vl the vector layer which will be associated with the renderer*/
     virtual int readXML(const QDomNode& rnode, QgsVectorLayer& vl);
     /**Writes the contents of the renderer to a configuration file
      @ return true in case of success*/
     virtual bool writeXML( QDomNode & layer_node, QDomDocument & document, QgsVectorLayer& vl ) const;
     /** Returns true*/
     bool needsAttributes() const;
     /**Returns a list with the index to the classification field*/
     QList<int> classificationAttributes() const;
     /**Returns the renderers name*/
     QString name() const;
     /**Returns the symbols of the items*/
     const QList<QgsSymbol*> symbols() const;
     /**Returns a copy of the renderer (a deep copy on the heap)*/
     QgsRenderer* clone() const /Factory/;
Modified: trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
--- trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp	2008-10-16 06:31:25 UTC (rev 9478)
+++ trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp	2008-10-16 17:30:14 UTC (rev 9479)
@@ -60,13 +60,38 @@
     return;
+  //restore the correct settings
+  const QgsGraduatedSymbolRenderer* renderer = dynamic_cast < const QgsGraduatedSymbolRenderer * >( layer->renderer() );
+  // Set up the mode combo
   modeComboBox->addItem( tr( "Equal Interval" ) );
   modeComboBox->addItem( tr( "Quantiles" ) );
   modeComboBox->addItem( tr( "Empty" ) );
-  //restore the correct settings
-  const QgsGraduatedSymbolRenderer* renderer = dynamic_cast < const QgsGraduatedSymbolRenderer * >( layer->renderer() );
+  if ( renderer )
+    QString myMode = "";
+    if ( renderer->mode() == QgsGraduatedSymbolRenderer::Empty )
+      myMode = tr( "Empty" );
+    else if ( renderer->mode() == QgsGraduatedSymbolRenderer::Quantile )
+      myMode = tr( "Quantiles" );
+    else
+      myMode = tr( "Equal Interval" );
+    modeComboBox->setCurrentIndex( modeComboBox->findText( myMode ) );
+  // Set up the classfield combo
   if ( renderer )
     QList < QgsSymbol * >list = renderer->symbols();
@@ -81,7 +106,7 @@
         break;
-    classificationComboBox->setItemText( classificationComboBox->currentIndex(), classfield );
+    classificationComboBox->setCurrentIndex( classificationComboBox->findText( classfield ) );
     numberofclassesspinbox->setValue( list.size() );
     //fill the items of the renderer into mValues
@@ -98,7 +123,9 @@
       sym->setScaleClassificationField(( *it )->scaleClassificationField() );
       sym->setRotationClassificationField(( *it )->rotationClassificationField() );
       mEntries.insert( std::make_pair( classbreak, sym ) );
-      mClassListWidget->addItem( classbreak );
+      QListWidgetItem * mypItem = new QListWidgetItem( classbreak );
+      updateEntryIcon( sym , mypItem );
+      mClassListWidget->addItem( mypItem );
@@ -149,6 +176,25 @@
   QgsGraduatedSymbolRenderer* renderer = new QgsGraduatedSymbolRenderer( mVectorLayer->type() );
+  // First the mode
+  if ( modeComboBox->currentText() == tr( "Empty" ) )
+    renderer->setMode( QgsGraduatedSymbolRenderer::Empty );
+  else if ( modeComboBox->currentText() == tr( "Quantiles" ) )
+    renderer->setMode( QgsGraduatedSymbolRenderer::Quantile );
+  else //equal interval by default//equal interval by default
+    renderer->setMode( QgsGraduatedSymbolRenderer::EqualInterval );
+  // Now the class breaks
   for ( int item = 0;item < mClassListWidget->count();++item )
     QString classbreak = mClassListWidget->item( item )->text();
@@ -251,7 +297,8 @@
   if ( provider )
-    if ( modeComboBox->currentText() == tr( "Equal Interval" ) )
+    if ( modeComboBox->currentText() == tr( "Equal Interval" ) ||
+        modeComboBox->currentText() == tr( "Quantiles" ) )
       minimum = provider->minimumValue( field ).toDouble();
       maximum = provider->maximumValue( field ).toDouble();
Modified: trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp
--- trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp	2008-10-16 06:31:25 UTC (rev 9478)
+++ trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp	2008-10-16 17:30:14 UTC (rev 9479)
@@ -31,13 +31,14 @@
 #include <QPainter>
-QgsGraduatedSymbolRenderer::QgsGraduatedSymbolRenderer( QGis::GeometryType type )
+QgsGraduatedSymbolRenderer::QgsGraduatedSymbolRenderer( QGis::GeometryType type, Mode mode )
   mGeometryType = type;
 QgsGraduatedSymbolRenderer::QgsGraduatedSymbolRenderer( const QgsGraduatedSymbolRenderer& other )
+  mMode = other.mMode;
   mGeometryType = other.mGeometryType;
   mClassificationField = other.mClassificationField;
   const QList<QgsSymbol*> s = other.symbols();
@@ -52,6 +53,7 @@
   if ( this != &other )
     removeSymbols();
@@ -71,6 +73,25 @@
+const QgsGraduatedSymbolRenderer::Mode QgsGraduatedSymbolRenderer::mode() const
+  //mode is only really used to be able to reinstate
+  //the graduated dialog properties properly, so we
+  //dont do anything else besides accessors and mutators in
+  //this class
+  return mMode;
+void QgsGraduatedSymbolRenderer::setMode( QgsGraduatedSymbolRenderer::Mode theMode )
+  //this class
+  mMode = theMode;
 const QList<QgsSymbol*> QgsGraduatedSymbolRenderer::symbols() const
   return mSymbols;
@@ -197,6 +218,8 @@
 int QgsGraduatedSymbolRenderer::readXML( const QDomNode& rnode, QgsVectorLayer& vl )
   mGeometryType = vl.type();
+  QDomNode modeNode = rnode.namedItem( "mode" );
+  QString modeValue = modeNode.toElement().text();
   QDomNode classnode = rnode.namedItem( "classificationfield" );
   QString classificationField = classnode.toElement().text();
@@ -205,6 +228,19 @@
     return 1;
+  if ( modeValue == "Empty" )
+    mMode = QgsGraduatedSymbolRenderer::Empty;
+  else if ( modeValue == "Quantile" )
+    mMode = QgsGraduatedSymbolRenderer::Quantile;
+  else //default
+    mMode = QgsGraduatedSymbolRenderer::EqualInterval;
   int classificationId = theProvider->fieldNameIndex( classificationField );
   if ( classificationId == -1 )
@@ -269,6 +305,35 @@
   bool returnval = true;
   QDomElement graduatedsymbol = document.createElement( "graduatedsymbol" );
   layer_node.appendChild( graduatedsymbol );
+  // Mode field first ...
+  QString modeValue="";
+  if ( mMode == QgsGraduatedSymbolRenderer::Empty )
+      modeValue == "Empty";
+  else if ( QgsGraduatedSymbolRenderer::Quantile )
+    modeValue = "Quantile";
+  else //default
+    modeValue = "Equal Interval";
+  QDomElement modeElement = document.createElement( "mode" );
+  QDomText modeText = document.createTextNode( modeValue );
+  modeElement.appendChild( modeText );
+  graduatedsymbol.appendChild( modeElement );
+  // classification field now ...
   QDomElement classificationfield = document.createElement( "classificationfield" );
   const QgsVectorDataProvider* theProvider = vl.dataProvider();
Modified: trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.h
--- trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.h	2008-10-16 06:31:25 UTC (rev 9478)
+++ trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.h	2008-10-16 17:30:14 UTC (rev 9479)
@@ -27,57 +27,99 @@
 class CORE_EXPORT QgsGraduatedSymbolRenderer: public QgsRenderer
   public:
-    QgsGraduatedSymbolRenderer( QGis::GeometryType type );
+    enum Mode
+      EqualInterval,
+      Quantile,
+      Empty
+    QgsGraduatedSymbolRenderer( QGis::GeometryType type, Mode theMode = EqualInterval );
     QgsGraduatedSymbolRenderer( const QgsGraduatedSymbolRenderer& other );
     QgsGraduatedSymbolRenderer& operator=( const QgsGraduatedSymbolRenderer& other );
+     * this class.
+     * this class.
     /**Adds a new item
     void addSymbol( QgsSymbol* sy );
     /**Returns the indes of the classification field*/
     virtual bool willRenderFeature( QgsFeature *f );
     void renderFeature( QPainter* p, QgsFeature& f, QImage* img, bool selected, double widthScale = 1.0, double rasterScaleFactor = 1.0 );
     /**Sets the classicifation field by index
     void setClassificationField( int );
      @return 0 in case of success, 1 if vector layer has no renderer, 2 if classification field not found
     virtual int readXML( const QDomNode& rnode, QgsVectorLayer& vl );
     virtual bool writeXML( QDomNode & layer_node, QDomDocument & document, const QgsVectorLayer& vl ) const;
     /** Returns true*/
     /**Returns a list of all needed attributes*/
     QgsAttributeList classificationAttributes() const;
     void updateSymbolAttributes();
     QgsRenderer* clone() const;
   protected:
+    /** The graduation mode */
+    Mode mMode;
     /**Index of the classification field (it must be a numerical field)*/
     int mClassificationField;
     /**List holding the symbols for the individual classes*/
     QList<QgsSymbol*> mSymbols;
     QgsSymbol *symbolForFeature( const QgsFeature* f );
     /**Cached copy of all underlying symbols required attribute fields*/
     QgsAttributeList mSymbolAttributes;
 inline void QgsGraduatedSymbolRenderer::addSymbol( QgsSymbol* sy )
More information about the QGIS-commit mailing list
