[QGIS Commit] r9495 - in trunk/qgis: doc python/core src/app src/core src/core/raster src/gui src/plugins/grass src/plugins/grass/modules src/plugins/grid_maker src/plugins/spit src/providers/grass src/providers/ogr src/ui tests/algorithms/projections tests/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Oct 19 15:20:42 EDT 2008
Author: timlinux
Date: 2008-10-19 15:20:42 -0400 (Sun, 19 Oct 2008)
New Revision: 9495
   trunk/qgis/doc/userguide.pdf
   trunk/qgis/python/core/qgis.sip
   trunk/qgis/python/core/qgscoordinatereferencesystem.sip
   trunk/qgis/python/core/qgscoordinatetransform.sip
   trunk/qgis/python/core/qgsgeometry.sip
   trunk/qgis/python/core/qgsrasterlayer.sip
   trunk/qgis/python/core/qgsrect.sip
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsoptions.cpp
   trunk/qgis/src/app/qgsprojectproperties.h
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/app/qgsvectorlayerproperties.cpp
   trunk/qgis/src/core/qgis.h
   trunk/qgis/src/core/qgsclipper.cpp
   trunk/qgis/src/core/qgsclipper.h
   trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
   trunk/qgis/src/core/qgscoordinatereferencesystem.h
   trunk/qgis/src/core/qgscoordinatetransform.cpp
   trunk/qgis/src/core/qgscoordinatetransform.h
   trunk/qgis/src/core/qgsgeometry.cpp
   trunk/qgis/src/core/qgsgeometry.h
   trunk/qgis/src/core/qgsmaprenderer.cpp
   trunk/qgis/src/core/qgsrect.h
   trunk/qgis/src/core/raster/qgsrasterlayer.cpp
   trunk/qgis/src/core/raster/qgsrasterlayer.h
   trunk/qgis/src/gui/qgsgenericprojectionselector.cpp
   trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm
   trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm
   trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
   trunk/qgis/src/plugins/grid_maker/graticulecreator.cpp
   trunk/qgis/src/plugins/spit/qgsshapefile.cpp
   trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
   trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
   trunk/qgis/src/ui/qgsoptionsbase.ui
   trunk/qgis/tests/algorithms/projections/projectioncshandlingtest.h
   trunk/qgis/tests/src/core/regression1141.cpp
   trunk/qgis/tests/src/core/testqgsmaprenderer.cpp
   trunk/qgis/tests/src/core/testqgsvectorfilewriter.cpp
More api cleanups
Modified: trunk/qgis/doc/userguide.pdf
(Binary files differ)
Modified: trunk/qgis/python/core/qgis.sip
--- trunk/qgis/python/core/qgis.sip	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/python/core/qgis.sip	2008-10-19 19:20:42 UTC (rev 9495)
@@ -89,8 +89,8 @@
-  /** WKT string that represents a geographic coord sys */
-  const  QString GEOWKT;
+  /** Wkt string that represents a geographic coord sys */
+  const  QString GEOWkt;
   /** PROJ4 string that represents a geographic coord sys */
   const QString GEOPROJ4;
Modified: trunk/qgis/python/core/qgscoordinatereferencesystem.sip
--- trunk/qgis/python/core/qgscoordinatereferencesystem.sip	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/python/core/qgscoordinatereferencesystem.sip	2008-10-19 19:20:42 UTC (rev 9495)
@@ -24,7 +24,7 @@
         ~QgsCoordinateReferenceSystem();
-         * Constructs a CRS object from a WKT string
+         * Constructs a CRS object from a Wkt string
          * @param theWkt A String containing a valid Wkt def
         explicit QgsCoordinateReferenceSystem(QString theWkt);
@@ -59,14 +59,14 @@
         bool createFromSrid(const long theSrid);
-        /*! Set up this srs using a WKT spatial ref sys definition.
+        /*! Set up this srs using a Wkt spatial ref sys definition.
          * The wkt will be converted to a proj4 string using OGR helper
          * functions. After this the srs databasses will be searched for matches.
          * First the system level read only srs.db will be checked
          * and then the users ~/.qgis/qgis.db database will be checked for a match.
          * @note Any members will be overwritten during this process.
          * @note SRID and EpsgCrsId may be blank if no match can be found on srs db.
-         * @param theWkt The WKT for the desired spatial reference system.
+         * @param theWkt The Wkt for the desired spatial reference system.
          * @return bool TRUE if sucess else false
         bool createFromWkt(const QString theWkt);
@@ -161,10 +161,6 @@
          *  is inconclusive.
          bool equals(QString theProj4String);
-         /*! A helper to get an wkt representation of this srs
-          * @return string containing Wkt of the srs
-         QString toWkt() const;
          /*! Restores state from the given Dom node.
          * @param theNode The node from which state will be restored
@@ -188,12 +184,6 @@
           bool writeXML( QDomNode & theNode, QDomDocument & theDoc );
-         /** A static helper function to find out the proj4 string for a srsid
-           * @param int theSrsId The srsid used for the lookup
-           * @return QString The proj4 string
-         static QString getProj4FromSrsId(const int theSrsId);
          /** Sets custom function to force valid CRS
           *  QGIS uses implementation in QgisGui::customSrsValidation
@@ -229,13 +219,17 @@
          * @note A zero length string will be returned if the ellipsoidAcronym is uninitialised
         QString ellipsoidAcronym () const;
+         /*! A helper to get an wkt representation of this srs
+          * @return string containing Wkt of the srs
+         QString toWkt() const;
         /** Get the Proj Proj4String. If proj and ellps keys are found in the parameters,
          * they will be stripped out and the Projection and ellipsoid acronyms will be
          * overridden with these.
          * @return  QString theProj4String Proj4 format specifies that define this srs.
-         * @note A zero length string will be returned if the proj4String is uninitialised
+         * @note A zero length string will be returned if the toProj4 is uninitialised
-        QString proj4String() const;
+        QString toProj4() const;
         /*! Get this Geographic? flag
          * @return  bool theGeoFlag Whether this is a geographic or projected coordinate system
Modified: trunk/qgis/python/core/qgscoordinatetransform.sip
--- trunk/qgis/python/core/qgscoordinatetransform.sip	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/python/core/qgscoordinatetransform.sip	2008-10-19 19:20:42 UTC (rev 9495)
@@ -35,20 +35,20 @@
      * Constructs a QgsCoordinateTransform using the Well Known Text representation
      * of the layer and map canvas coordinate systems
-     * @param theSourceWKT WKT, typically of the layer's coordinate system
-     * @param theDestWKT WKT, typically of the map canvas coordinate system
+     * @param theSourceWkt Wkt, typically of the layer's coordinate system
+     * @param theDestWkt Wkt, typically of the map canvas coordinate system
-    QgsCoordinateTransform(QString theSourceWKT, QString theDestWKT  );
+    QgsCoordinateTransform(QString theSourceWkt, QString theDestWkt  );
      * Constructs a QgsCoordinateTransform using a Spatial Reference Id
      * of the layer and map canvas coordinate system as Wkt
      * @param theSourceSrid Spatial Ref Id of the layer's coordinate system
-     * @param theSourceWKT WKT of the map canvas coordinate system
+     * @param theSourceWkt Wkt of the map canvas coordinate system
      * @param theSourceCRSType On of the enum members defined in QgsCoordinateReferenceSystem::CrsType
     QgsCoordinateTransform(long theSourceSrid,
-                           QString theDestWKT,
+                           QString theDestWkt,
                            QgsCoordinateReferenceSystem::CrsType theSourceCRSType = QgsCoordinateReferenceSystem::PostgisCrsId  );
      //! destructor
Modified: trunk/qgis/python/core/qgsgeometry.sip
--- trunk/qgis/python/core/qgsgeometry.sip	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/python/core/qgsgeometry.sip	2008-10-19 19:20:42 UTC (rev 9495)
@@ -34,7 +34,7 @@
     ~QgsGeometry();
-    /** static method that creates geometry from WKT */
+    /** static method that creates geometry from Wkt */
     static QgsGeometry* fromWkt(QString wkt) /Factory/;
     /** construct geometry from a point */
Modified: trunk/qgis/python/core/qgsrasterlayer.sip
--- trunk/qgis/python/core/qgsrasterlayer.sip	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/python/core/qgsrasterlayer.sip	2008-10-19 19:20:42 UTC (rev 9495)
@@ -90,8 +90,8 @@
     QString identifyAsText(const QgsPoint & point);
-    /** \brief Query gdal to find out the WKT projection string for this layer. This implements the virtual method of the same name defined in QgsMapLayer*/
-    QString getProjectionWKT();
+    /** \brief Query gdal to find out the Wkt projection string for this layer. This implements the virtual method of the same name defined in QgsMapLayer*/
+    QString getProjectionWkt();
     /** \brief Returns the number of raster units per each raster pixel. For rasters with world file, this is normally the first row (without the sign) in that file */
     double rasterUnitsPerPixel();
Modified: trunk/qgis/python/core/qgsrect.sip
--- trunk/qgis/python/core/qgsrect.sip	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/python/core/qgsrect.sip	2008-10-19 19:20:42 UTC (rev 9495)
@@ -67,7 +67,7 @@
     void combineExtentWith(double x, double y);
     //! test if rectangle is empty
     bool isEmpty() const;
-    //! returns string representation in WKT form
+    //! returns string representation in Wkt form
     QString asWktCoordinates() const;
     //! returns string representation of form xmin,ymin xmax,ymax
     QString toString(bool automaticPrecision = false) const;
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -260,7 +260,7 @@
 static void customSrsValidation_( QgsCoordinateReferenceSystem* srs )
-  QString proj4String;
+  QString toProj4;
   QSettings mySettings;
   QString myDefaultProjectionOption =
     mySettings.value( "/Projections/defaultBehaviour" ).toString();
@@ -271,9 +271,9 @@
     QgsGenericProjectionSelector * mySelector = new QgsGenericProjectionSelector();
     mySelector->setMessage( srs->validationHint() ); //shows a generic message, if not speficied
-    proj4String = QgsProject::instance()->readEntry( "SpatialRefSys", "//ProjectCRSProj4String", GEOPROJ4 );
+    toProj4 = QgsProject::instance()->readEntry( "SpatialRefSys", "//ProjectCRSProj4String", GEOPROJ4 );
     QgsCoordinateReferenceSystem defaultCRS;
-    if ( defaultCRS.createFromProj4( proj4String ) )
+    if ( defaultCRS.createFromProj4( toProj4 ) )
       mySelector->setSelectedCrsId( defaultCRS.srsid() );
@@ -291,10 +291,10 @@
   else if ( myDefaultProjectionOption == "useProject" )
-    // XXX TODO: Change project to store selected CS as 'projectCRS' not 'selectedWKT'
-    QgsDebugMsg( "Layer srs set from project: " + proj4String );
-    srs->createFromProj4( proj4String );
+    // XXX TODO: Change project to store selected CS as 'projectCRS' not 'selectedWkt'
+    QgsDebugMsg( "Layer srs set from project: " + toProj4 );
+    srs->createFromProj4( toProj4 );
   else ///Projections/defaultBehaviour==useGlobal
@@ -2309,7 +2309,7 @@
     QApplication::setOverrideCursor( Qt::WaitCursor );
     QString connInfo = dbs->connInfo();
-    // for each selected table, connect to the database, parse the WKT geometry,
+    // for each selected table, connect to the database, parse the Wkt geometry,
     // and build a canvasitem for it
     // readWKB(connInfo,tables);
     QStringList::Iterator it = tables.begin();
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/app/qgsoptions.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -80,7 +80,7 @@
     radUseGlobalProjection->setChecked( true );
-  txtGlobalWKT->setText( settings.value( "/Projections/defaultProjectionString", GEOPROJ4 ).toString() );
+  txtGlobalWkt->setText( settings.value( "/Projections/defaultProjectionString", GEOPROJ4 ).toString() );
   // populate combo box with ellipsoids
   getEllipsoidList();
@@ -291,7 +291,7 @@
     settings.setValue( "/Projections/defaultBehaviour", "useGlobal" );
-  settings.setValue( "/Projections/defaultProjectionString", txtGlobalWKT->toPlainText() );
+  settings.setValue( "/Projections/defaultProjectionString", txtGlobalWkt->toPlainText() );
   settings.setValue( "/qgis/measure/ellipsoid", getEllipsoidAcronym( cmbEllipsoid->currentText() ) );
@@ -356,7 +356,7 @@
   //find out srs id of current proj4 string
   QgsCoordinateReferenceSystem refSys;
-  if ( refSys.createFromProj4( txtGlobalWKT->toPlainText() ) )
+  if ( refSys.createFromProj4( txtGlobalWkt->toPlainText() ) )
     mySelector->setSelectedCrsId( refSys.srsid() );
@@ -364,8 +364,8 @@
   if ( mySelector->exec() )
     //! @todo changes this control name in gui to txtGlobalProjString
-    txtGlobalWKT->setText( mySelector->selectedProj4String() );
-    QgsDebugMsg( QString( "------ Global Default Projection Selection set to ----------\n%1" ).arg( txtGlobalWKT->toPlainText() ) );
+    txtGlobalWkt->setText( mySelector->selectedProj4String() );
+    QgsDebugMsg( QString( "------ Global Default Projection Selection set to ----------\n%1" ).arg( txtGlobalWkt->toPlainText() ) );
   else
Modified: trunk/qgis/src/app/qgsprojectproperties.h
--- trunk/qgis/src/app/qgsprojectproperties.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/app/qgsprojectproperties.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -57,7 +57,7 @@
     void title( QString const & title );
     /*! Accessor for projection */
-    QString projectionWKT();
+    QString projectionWkt();
     /*! Indicates that the projection switch is on */
     bool isProjected();
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -299,7 +299,7 @@
     tabBar->setTabEnabled( tabBar->indexOf( tabPageHistogram ), FALSE );
-  leSpatialRefSys->setText( mRasterLayer->srs().proj4String() );
+  leSpatialRefSys->setText( mRasterLayer->srs().toProj4() );
   // Set text for pyramid info box
   QString pyramidFormat( "<h2>%1</h2><p>%2 %3 %4</p><b><font color='red'><p>%5</p><p>%6</p>" );
@@ -1696,7 +1696,7 @@
   delete mySelector;
 void QgsRasterLayerProperties::on_cboxColorMap_currentIndexChanged( const QString& theText )
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -129,7 +129,7 @@
   updateButtons();
-  leSpatialRefSys->setText( layer->srs().proj4String() );
+  leSpatialRefSys->setText( layer->srs().toProj4() );
   leSpatialRefSys->setCursorPosition( 0 );
   connect( sliderTransparency, SIGNAL( valueChanged( int ) ), this, SLOT( sliderTransparency_valueChanged( int ) ) );
@@ -763,7 +763,7 @@
     myMetadata += tr( "Layer Spatial Reference System:" );
     myMetadata += "</td></tr>";
     myMetadata += "<tr><td>";
-    myMetadata += layer->srs().proj4String().replace( QRegExp( "\"" ), " \"" );
+    myMetadata += layer->srs().toProj4().replace( QRegExp( "\"" ), " \"" );
@@ -775,7 +775,7 @@
     myMetadata += tr("Project (Output) Spatial Reference System:");
-    myMetadata += coordinateTransform->destCRS().proj4String().replace(QRegExp("\"")," \"");
+    myMetadata += coordinateTransform->destCRS().toProj4().replace(QRegExp("\"")," \"");
@@ -875,7 +875,7 @@
   delete mySelector;
Modified: trunk/qgis/src/core/qgis.h
--- trunk/qgis/src/core/qgis.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgis.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -112,8 +112,8 @@
   return u.f;
-/** WKT string that represents a geographic coord sys */
-const  QString GEOWKT =
+/** Wkt string that represents a geographic coord sys */
+const  QString GEOWkt =
   "GEOGCS[\"WGS 84\", "
   "  DATUM[\"WGS_1984\", "
   "    SPHEROID[\"WGS 84\",6378137,298.257223563, "
Modified: trunk/qgis/src/core/qgsclipper.cpp
--- trunk/qgis/src/core/qgsclipper.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgsclipper.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -21,7 +21,7 @@
 // Where has all the code gone?
-// It's been inlined, so is in the qgsclipper.h file.
+// It's been inlined, so its in the qgsclipper.h file.
 // But the static members must be initialised outside the class! (or GCC 4 dies)
Modified: trunk/qgis/src/core/qgsclipper.h
--- trunk/qgis/src/core/qgsclipper.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgsclipper.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -67,7 +67,7 @@
     // A handy way to refer to the four boundaries
-    enum boundary {Xmax, Xmin, Ymax, Ymin};
+    enum Boundary {XMax, XMin, YMax, YMin};
     // Trims the given feature to a rectangular box. Returns the trimmed
     // feature in x and y. The shapeOpen parameter determines whether
@@ -88,17 +88,17 @@
                                        const std::vector<double>& inY,
                                        std::vector<double>& outX,
                                        std::vector<double>& outY,
-                                       boundary b,
+                                       Boundary b,
                                        bool shapeOpen );
     // Determines if a point is inside or outside the given boundary
-    static bool inside( const double x, const double y, boundary b );
+    static bool inside( const double x, const double y, Boundary b );
     // Calculates the intersection point between a line defined by a
     // (x1, y1), and (x2, y2) and the given boundary
     static QgsPoint intersect( const double x1, const double y1,
                                const double x2, const double y2,
-                               boundary b );
+                               Boundary b );
 // The inline functions
@@ -119,19 +119,19 @@
   std::vector<double> tmpX;
   std::vector<double> tmpY;
-  trimFeatureToBoundary( x, y, tmpX, tmpY, Xmax, shapeOpen );
+  trimFeatureToBoundary( x, y, tmpX, tmpY, XMax, shapeOpen );
   x.clear();
   y.clear();
-  trimFeatureToBoundary( tmpX, tmpY, x, y, Ymax, shapeOpen );
+  trimFeatureToBoundary( tmpX, tmpY, x, y, YMax, shapeOpen );
   tmpX.clear();
   tmpY.clear();
-  trimFeatureToBoundary( x, y, tmpX, tmpY, Xmin, shapeOpen );
+  trimFeatureToBoundary( x, y, tmpX, tmpY, XMin, shapeOpen );
   x.clear();
   y.clear();
-  trimFeatureToBoundary( tmpX, tmpY, x, y, Ymin, shapeOpen );
+  trimFeatureToBoundary( tmpX, tmpY, x, y, YMin, shapeOpen );
 // An auxilary function that is part of the polygon trimming
@@ -144,7 +144,7 @@
-  boundary b, bool shapeOpen )
+  Boundary b, bool shapeOpen )
   // The shapeOpen parameter selects whether this function treats the
   // shape as open or closed. False is appropriate for polygons and
@@ -197,23 +197,23 @@
 // An auxilary function to trimPolygonToBoundarY() that returns
 // whether a point is inside or outside the given boundary.
-inline bool QgsClipper::inside( const double x, const double y, boundary b )
+inline bool QgsClipper::inside( const double x, const double y, Boundary b )
   switch ( b )
-    case Xmax: // x < MAX_X is inside
+    case XMax: // x < MAX_X is inside
       if ( x < MAX_X )
         return true;
       break;
-    case Xmin: // x > MIN_X is inside
+    case XMin: // x > MIN_X is inside
       if ( x > MIN_X )
         return true;
       break;
-    case Ymax: // y < MAX_Y is inside
+    case YMax: // y < MAX_Y is inside
       if ( y < MAX_Y )
         return true;
       break;
-    case Ymin: // y > MIN_Y is inside
+    case YMin: // y > MIN_Y is inside
       if ( y > MIN_Y )
         return true;
       break;
@@ -228,7 +228,7 @@
 inline QgsPoint QgsClipper::intersect( const double x1, const double y1,
-                                       boundary b )
+                                       Boundary b )
   // This function assumes that the two given points (x1, y1), and
   // (x2, y2) cross the given boundary. Making this assumption allows
@@ -238,19 +238,19 @@
   switch ( b )
-    case Xmax: // x = MAX_X boundary
+    case XMax: // x = MAX_X boundary
       r_n = -( x1 - MAX_X ) * ( MAX_Y - MIN_Y );
       r_d = ( x2 - x1 )   * ( MAX_Y - MIN_Y );
       break;
-    case Xmin: // x = MIN_X boundary
+    case XMin: // x = MIN_X boundary
       r_n = -( x1 - MIN_X ) * ( MAX_Y - MIN_Y );
       break;
-    case Ymax: // y = MAX_Y boundary
+    case YMax: // y = MAX_Y boundary
       r_n = ( y1 - MAX_Y ) * ( MAX_X - MIN_X );
       r_d = -( y2 - y1 )   * ( MAX_X - MIN_X );
       break;
-    case Ymin: // y = MIN_Y boundary
+    case YMin: // y = MIN_Y boundary
       r_n = ( y1 - MIN_Y ) * ( MAX_X - MIN_X );
       break;
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
--- trunk/qgis/src/core/qgscoordinatereferencesystem.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -228,12 +228,12 @@
     mDescription = QString::fromUtf8(( char * )sqlite3_column_text( myPreparedStatement, 1 ) );
     mProjectionAcronym = QString::fromUtf8(( char * )sqlite3_column_text( myPreparedStatement, 2 ) );
     mEllipsoidAcronym = QString::fromUtf8(( char * )sqlite3_column_text( myPreparedStatement, 3 ) );
-    QString proj4String = QString::fromUtf8(( char * )sqlite3_column_text( myPreparedStatement, 4 ) );
+    QString toProj4 = QString::fromUtf8(( char * )sqlite3_column_text( myPreparedStatement, 4 ) );
     mSRID = QString::fromUtf8(( char * )sqlite3_column_text( myPreparedStatement, 5 ) ).toLong();
     mEpsg = QString::fromUtf8(( char * )sqlite3_column_text( myPreparedStatement, 6 ) ).toLong();
     int geo = QString::fromUtf8(( char * )sqlite3_column_text( myPreparedStatement, 7 ) ).toInt();
     mGeoFlag = ( geo == 0 ? false : true );
-    setProj4String( proj4String );
+    setProj4String( toProj4 );
     setMapUnits();
   else
@@ -264,7 +264,7 @@
   if ( myInputResult != OGRERR_NONE )
     QgsDebugMsg( "\n---------------------------------------------------------------" );
-    QgsDebugMsg( "This CRS could *** NOT *** be set from the supplied WKT " );
+    QgsDebugMsg( "This CRS could *** NOT *** be set from the supplied Wkt " );
     QgsDebugMsg( "INPUT: " + theWkt );
     QgsDebugMsg( "---------------------------------------------------------------\n" );
     return mIsValidFlag;
@@ -593,18 +593,18 @@
-QString QgsCoordinateReferenceSystem::proj4String() const
+QString QgsCoordinateReferenceSystem::toProj4() const
   if ( !mIsValidFlag )
     return "";
+  QString toProj4;
   char *proj4src = NULL;
   OSRExportToProj4( mCRS, &proj4src );
-  proj4String = proj4src;
+  toProj4 = proj4src;
   CPLFree( proj4src );
-  return proj4String;
+  return toProj4;
 bool QgsCoordinateReferenceSystem::geographicFlag() const
@@ -864,11 +864,11 @@
 QString QgsCoordinateReferenceSystem::toWkt() const
   QString myWkt;
-  char* WKT;
-  if ( OSRExportToWkt( mCRS, &WKT ) == OGRERR_NONE )
+  char* Wkt;
+  if ( OSRExportToWkt( mCRS, &Wkt ) == OGRERR_NONE )
-    myWkt = WKT;
-    OGRFree( WKT );
+    myWkt = Wkt;
+    OGRFree( Wkt );
   return myWkt;
@@ -941,7 +941,7 @@
   QDomElement mySrsElement  = theDoc.createElement( "spatialrefsys" );
   QDomElement myProj4Element  = theDoc.createElement( "proj4" );
-  myProj4Element.appendChild( theDoc.createTextNode( proj4String() ) );
+  myProj4Element.appendChild( theDoc.createTextNode( toProj4() ) );
   mySrsElement.appendChild( myProj4Element );
   QDomElement mySrsIdElement  = theDoc.createElement( "srsid" );
@@ -991,8 +991,8 @@
 // Returns the whole proj4 string for the selected srsid
-//this is a static method!
-QString QgsCoordinateReferenceSystem::getProj4FromSrsId( const int theSrsId )
+//this is a static method! NOTE I've made it private for now to reduce API clutter TS
+QString QgsCoordinateReferenceSystem::proj4FromSrsId( const int theSrsId )
   QString myDatabaseFileName;
@@ -1091,7 +1091,7 @@
   QgsDebugMsg( "***SpatialRefSystem***" );
   QgsDebugMsg( "* Valid : " + ( mIsValidFlag ? QString( "true" ) : QString( "false" ) ) );
   QgsDebugMsg( "* SrsId : " + QString::number( mSrsId ) );
-  QgsDebugMsg( "* Proj4 : " + proj4String() );
+  QgsDebugMsg( "* Proj4 : " + toProj4() );
   QgsDebugMsg( "* Desc. : " + mDescription );
   if ( mapUnits() == QGis::Meters )
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.h
--- trunk/qgis/src/core/qgscoordinatereferencesystem.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -57,14 +57,14 @@
     explicit QgsCoordinateReferenceSystem( QString theWkt );
     /*! Use this constructor when you want to create a CRS object using
      *  a postgis SRID, an EpsgCrsId id or a QGIS CRS_ID.
-     * @note We encourage you to use EpsgCrsId, WKT or Proj4 to describe CRS's in your code
+     * @note We encourage you to use EpsgCrsId, Wkt or Proj4 to describe CRS's in your code
      * wherever possible. QGSI CRS_IDs are not guaranteed to be permanent / involatile.
      * @param theId The ID no valid for the chosen coordinate system id type
      * @param theType One of the types described in QgsCoordinateReferenceSystem::CrsType
@@ -100,14 +100,14 @@
     bool createFromSrid( const long theSrid );
     bool createFromWkt( const QString theWkt );
@@ -203,10 +203,6 @@
      *  is inconclusive.
     bool equals( QString theProj4String );
@@ -230,11 +226,6 @@
     bool writeXML( QDomNode & theNode, QDomDocument & theDoc ) const;
-    static QString getProj4FromSrsId( const int theSrsId );
@@ -251,40 +242,54 @@
     *  @return  long theSrsId The internal sqlite3 srs.db primary key for this srs
     long srsid() const;
     /*! Get the postgis srid for this srs
      * @return  long theSRID the Postgis spatial_ref_sys identifier for this srs (defaults to 0)
     long postgisSrid() const;
     /*! Get the EpsgCrsId identifier for this srs
      * @return  long theEpsg the ESPG identifier for this srs (defaults to 0)
     long epsg() const;
     /*! Get the Description
      * @return  QString the Description A textual description of the srs.
      * @note A zero length string will be returned if the description is uninitialised
     QString description() const;
     /*! Get the Projection Acronym
      * @return  QString theProjectionAcronym The official proj4 acronym for the projection family
      * @note A zero length string will be returned if the projectionAcronym is uninitialised
     QString projectionAcronym() const;
     /*! Get the Ellipsoid Acronym
      * @return  QString theEllipsoidAcronym The official proj4 acronym for the ellipoid
     QString ellipsoidAcronym() const;
-    /** Get the Proj Proj4String. If proj and ellps keys are found in the parameters,
+    /** Get the Proj Proj4 string representation of this srs.
+     * If proj and ellps keys are found in the parameters,
     bool geographicFlag() const;
     /*! Get the units that the projection is in
      * @return QGis::UnitType that gives the units for the coordinate system
@@ -303,6 +308,11 @@
     // We dont want to expose these to the public api since they wont create
     // a fully valid crs. Programmers should use the createFrom* methods rather
   private:
+    /** A static helper function to find out the proj4 string for a srsid
+      * @param int theSrsId The srsid used for the lookup
+      * @return QString The proj4 string
+    static QString proj4FromSrsId( const int theSrsId );
     /*! Set the QGIS  SrsId
      *  @param  long theSrsId The internal sqlite3 srs.db primary key for this srs
@@ -421,9 +431,9 @@
   mySummary += "\n\t\tProj4String  : " ;
-  if ( !r.proj4String().isNull() )
+  if ( !r.toProj4().isNull() )
-    mySummary += r.proj4String();
+    mySummary += r.toProj4();
   else
Modified: trunk/qgis/src/core/qgscoordinatetransform.cpp
--- trunk/qgis/src/core/qgscoordinatetransform.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgscoordinatetransform.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -72,13 +72,13 @@
 QgsCoordinateTransform::QgsCoordinateTransform( long theSourceSrid,
     QgsCoordinateReferenceSystem::CrsType theSourceCRSType ): QObject()
   setFinder();
   mSourceCRS.createFromId( theSourceSrid, theSourceCRSType );
-  mDestCRS.createFromWkt( theDestWKT );
+  mDestCRS.createFromWkt( theDestWkt );
   // initialize the coordinate system data structures
   //XXX Who spells initialize initialise?
   //XXX A: Its the queen's english....
@@ -145,12 +145,12 @@
     //No destination projection is set so we set the default output projection to
     //be the same as input proj. This only happens on the first layer loaded
     //whatever that may be...
-    mDestCRS.createFromProj4( mSourceCRS.proj4String() );
+    mDestCRS.createFromProj4( mSourceCRS.toProj4() );
   // init the projections (destination and source)
-  mDestinationProjection = pj_init_plus( mDestCRS.proj4String().toUtf8() );
-  mSourceProjection = pj_init_plus( mSourceCRS.proj4String().toUtf8() );
+  mDestinationProjection = pj_init_plus( mDestCRS.toProj4().toUtf8() );
+  mSourceProjection = pj_init_plus( mSourceCRS.toProj4().toUtf8() );
   mInitialisedFlag = true;
   if ( mDestinationProjection == NULL )
@@ -185,7 +185,7 @@
   //XXX todo overload == operator for QgsCoordinateReferenceSystem
   //at the moment srs.parameters contains the whole proj def...soon it wont...
-  //if (mSourceCRS->proj4String() == mDestCRS->proj4String())
+  //if (mSourceCRS->toProj4() == mDestCRS->toProj4())
   if ( mSourceCRS == mDestCRS )
     // If the source and destination projection are the same, set the short
@@ -416,14 +416,14 @@
     QgsLogger::critical( tr( "The source spatial reference system (CRS) is not valid. " ) +
                          tr( "The coordinates can not be reprojected. The CRS is: " ) +
-                         mSourceCRS.proj4String() );
+                         mSourceCRS.toProj4() );
     return;
   if ( !mDestCRS.isValid() )
     QgsLogger::critical( tr( "The destination spatial reference system (CRS) is not valid. " ) +
-                         mDestCRS.proj4String() );
+                         mDestCRS.toProj4() );
     return;
Modified: trunk/qgis/src/core/qgscoordinatetransform.h
--- trunk/qgis/src/core/qgscoordinatetransform.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgscoordinatetransform.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -69,20 +69,20 @@
-    QgsCoordinateTransform( QString theSourceWKT, QString theDestWKT );
+    QgsCoordinateTransform( QString theSourceWkt, QString theDestWkt );
     //! destructor
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgsgeometry.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -404,7 +404,7 @@
   GEOSWKTReader_destroy( reader );
   return g;
 #else
-  return fromGeosGeom( GEOSGeomFromWKT( wkt.toLocal8Bit().data() ) );
+  return fromGeosGeom( GEOSGeomFromWkt( wkt.toLocal8Bit().data() ) );
 #endif
Modified: trunk/qgis/src/core/qgsgeometry.h
--- trunk/qgis/src/core/qgsgeometry.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgsgeometry.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -52,14 +52,14 @@
 /** \ingroup core
  * A geometry is the spatial representation of a feature.
  * Represents a geometry with input and output in formats specified by
- * (at least) the Open Geospatial Consortium (WKB / WKT), and containing
+ * (at least) the Open Geospatial Consortium (WKB / Wkt), and containing
  * various functions for geoprocessing of the geometry.
  * The geometry is represented internally by the OGC WKB format or
  * as GEOS geometry. Some functions use WKB for their work, others
  * use GEOS.
- * TODO: migrate completely to GEOS and only support WKB/WKT import/export.
+ * TODO: migrate completely to GEOS and only support WKB/Wkt import/export.
  * @author Brendan Morley
@@ -79,7 +79,7 @@
     //! Destructor
     ~QgsGeometry();
     static QgsGeometry* fromWkt( QString wkt );
@@ -317,7 +317,7 @@
     // Private variables
     // All of these are mutable since there may be on-the-fly
-    // conversions between WKB, GEOS and WKT;
+    // conversions between WKB, GEOS and Wkt;
     // However the intent is the const functions do not
     // semantically change the value that this object represents.
Modified: trunk/qgis/src/core/qgsmaprenderer.cpp
--- trunk/qgis/src/core/qgsmaprenderer.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgsmaprenderer.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -472,7 +472,7 @@
 void QgsMapRenderer::setDestinationSrs( const QgsCoordinateReferenceSystem& srs )
-  QgsDebugMsg( "* Setting destCRS : = " + srs.proj4String() );
+  QgsDebugMsg( "* Setting destCRS : = " + srs.toProj4() );
   QgsDebugMsg( "* DestCRS.srsid() = " + QString::number( srs.srsid() ) );
   if ( *mDestCRS != srs )
@@ -488,7 +488,7 @@
   QgsDebugMsg( "* Returning destCRS" );
   QgsDebugMsg( "* DestCRS.srsid() = " + QString::number( mDestCRS->srsid() ) );
-  QgsDebugMsg( "* DestCRS.proj4() = " + mDestCRS->proj4String() );
+  QgsDebugMsg( "* DestCRS.proj4() = " + mDestCRS->toProj4() );
   return *mDestCRS;
Modified: trunk/qgis/src/core/qgsrect.h
--- trunk/qgis/src/core/qgsrect.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/qgsrect.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -90,7 +90,7 @@
     void combineExtentWith( double x, double y );
     QString toString( bool automaticPrecision = false ) const;
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -443,13 +443,13 @@
   // QgsCoordinateTransform for this layer
   // NOTE: we must do this before getMetadata is called
-  QString mySourceWKT = getProjectionWKT();
+  QString mySourceWkt = getProjectionWkt();
   QgsDebugMsg( "--------------------------------------------------------------------------------------" );
-  QgsDebugMsg( "using wkt:\n" + mySourceWKT );
+  QgsDebugMsg( "using wkt:\n" + mySourceWkt );
-  mCRS->createFromWkt( mySourceWKT );
+  mCRS->createFromWkt( mySourceWkt );
   //get the project projection, defaulting to this layer's projection
   //if none exists....
   if ( !mCRS->isValid() )
@@ -598,20 +598,20 @@
 } // QgsRasterLayer::readFile
-QString QgsRasterLayer::getProjectionWKT()
+QString QgsRasterLayer::getProjectionWkt()
-  QString myWKTString;
+  QString myWktString;
   QgsCoordinateReferenceSystem myCRS;
-  myWKTString = QString( GDALGetProjectionRef( mGdalDataset ) );
-  myCRS.createFromWkt( myWKTString );
+  myWktString = QString( GDALGetProjectionRef( mGdalDataset ) );
+  myCRS.createFromWkt( myWktString );
   if ( !myCRS.isValid() )
     //try to get the gcp srs from the raster layer if available
-    myWKTString = QString( GDALGetGCPProjection( mGdalDataset ) );
+    myWktString = QString( GDALGetGCPProjection( mGdalDataset ) );
 // What is the purpose of this piece of code?
 // Sideeffects from validate()?
-//    myCRS.createFromWkt(myWKTString);
+//    myCRS.createFromWkt(myWktString);
 //    if (!myCRS.isValid())
 //      // use force and make CRS valid!
@@ -620,7 +620,7 @@
-  return myWKTString;
+  return myWktString;
 void QgsRasterLayer::closeDataset()
@@ -3235,7 +3235,7 @@
   myMetadata += tr( "Layer Spatial Reference System: " );
   myMetadata += "</p>\n";
   myMetadata += "<p>";
-  myMetadata += mCRS->proj4String();
+  myMetadata += mCRS->toProj4();
   // output coordinate system
@@ -3245,7 +3245,7 @@
       myMetadata += tr("Project Spatial Reference System: ");
-      myMetadata +=  mCoordinateTransform->destCRS().proj4String();
+      myMetadata +=  mCoordinateTransform->destCRS().toProj4();
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -265,8 +265,8 @@
     QString identifyAsText( const QgsPoint & point );
Modified: trunk/qgis/src/gui/qgsgenericprojectionselector.cpp
--- trunk/qgis/src/gui/qgsgenericprojectionselector.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/gui/qgsgenericprojectionselector.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -75,13 +75,13 @@
 QString QgsGenericProjectionSelector::selectedProj4String()
-  //@NOTE dont use getSelectedWKT as that just returns the name part!
+  //@NOTE dont use getSelectedWkt as that just returns the name part!
   return projectionSelector->selectedProj4String();
 long QgsGenericProjectionSelector::selectedCrsId()
   return projectionSelector->selectedCrsId();
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm	2008-10-19 19:20:42 UTC (rev 9495)
@@ -1,7 +1,7 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Print projection information from a georeferenced ASCII file containing a WKT projection description and create a new location based on it" module="g.proj">
+<qgisgrassmodule label="Print projection information from a georeferenced ASCII file containing a Wkt projection description and create a new location based on it" module="g.proj">
 	<file key="wkt" type="old" />
 	<option key="location" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm	2008-10-19 19:20:42 UTC (rev 9495)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from a georeferenced ASCII file containing a WKT projection description" module="g.proj">
+<qgisgrassmodule label="Print projection information from a georeferenced ASCII file containing a Wkt projection description" module="g.proj">
 	<flag key="p" />
 	<flag key="d" />
Modified: trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -460,7 +460,7 @@
       char *wkt = NULL;
       if (( errcode = OSRExportToWkt( hCRS, &wkt ) ) != OGRERR_NONE )
-        QgsDebugMsg( QString( "OGR can't get WKT-style parameter string\nOGR Error code was %1" ).arg( errcode ) );
+        QgsDebugMsg( QString( "OGR can't get Wkt-style parameter string\nOGR Error code was %1" ).arg( errcode ) );
       else
Modified: trunk/qgis/src/plugins/grid_maker/graticulecreator.cpp
--- trunk/qgis/src/plugins/grid_maker/graticulecreator.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/plugins/grid_maker/graticulecreator.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -16,7 +16,7 @@
 #include <qgsfeature.h> //we will need to pass a bunch of these for each rec
 #include <qgsgeometry.h> //each feature needs a geometry
 #include <qgspoint.h> //we will use point geometry
-#include <qgis.h> //defines GEOWKT
+#include <qgis.h> //defines GEOWkt
 #include <qgslogger.h>
 #include <QFileInfo>
@@ -42,7 +42,7 @@
   mFields.insert( 5, myField6 );
   mFields.insert( 6, myField7 );
   mFields.insert( 7, myField8 );
-  mCRS = QgsCoordinateReferenceSystem( GEOWKT );
+  mCRS = QgsCoordinateReferenceSystem( GEOWkt );
   mFileName = theOutputFileName;
Modified: trunk/qgis/src/plugins/spit/qgsshapefile.cpp
--- trunk/qgis/src/plugins/spit/qgsshapefile.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/plugins/spit/qgsshapefile.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -410,7 +410,7 @@
         char *geo_temp;
         // 'GeometryFromText' supports only 2D coordinates
-        // TODO for proper 2.5D support we would need to use 'GeomFromEWKT'
+        // TODO for proper 2.5D support we would need to use 'GeomFromEWkt'
         if ( hasMoreDimensions )
           OGR_G_SetCoordinateDimension( geom, 2 );
         OGR_G_ExportToWkt( geom, &geo_temp );
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -1269,7 +1269,7 @@
 QgsCoordinateReferenceSystem QgsGrassProvider::getCRS()
-  QString WKT;
+  QString Wkt;
   struct Cell_head cellhd;
@@ -1297,14 +1297,14 @@
     struct Key_Value *projinfo = G_get_projinfo();
     struct Key_Value *projunits = G_get_projunits();
     char *wkt = GPJ_grass_to_wkt( projinfo, projunits,  0, 0 );
-    WKT = QString( wkt );
+    Wkt = QString( wkt );
     free( wkt );
   setlocale( LC_NUMERIC, oldlocale );
   QgsCoordinateReferenceSystem srs;
-  srs.createFromWkt( WKT );
+  srs.createFromWkt( Wkt );
   return srs;
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -1138,11 +1138,11 @@
   OGRSpatialReferenceH reference = NULL;
   QgsCoordinateReferenceSystem mySpatialRefSys;
   mySpatialRefSys.validate();
-  QString myWKT = mySpatialRefSys.toWkt();
+  QString myWkt = mySpatialRefSys.toWkt();
-  if ( !myWKT.isNull()  &&  myWKT.length() != 0 )
+  if ( !myWkt.isNull()  &&  myWkt.length() != 0 )
-    reference = OSRNewSpatialReference( myWKT.toLocal8Bit().data() );
+    reference = OSRNewSpatialReference( myWkt.toLocal8Bit().data() );
   // Map the qgis geometry type to the OGR geometry type
@@ -1247,13 +1247,13 @@
     char * ppszProj4;
     OSRExportToProj4( mySpatialRefSys, &ppszProj4 );
     QgsDebugMsg( ppszProj4 );
-    char    *pszWKT = NULL;
-    OSRExportToWkt( mySpatialRefSys, &pszWKT );
-    QString myWKTString = QString( pszWKT );
-    OGRFree( pszWKT );
+    char    *pszWkt = NULL;
+    OSRExportToWkt( mySpatialRefSys, &pszWkt );
+    QString myWktString = QString( pszWkt );
+    OGRFree( pszWkt );
-    // create CRS from WKT
-    srs.createFromWkt( myWKTString );
+    // create CRS from Wkt
+    srs.createFromWkt( myWktString );
   return srs;
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui	2008-10-19 19:20:42 UTC (rev 9495)
@@ -828,7 +828,7 @@
         </widget>
        </item>
        <item row="1" column="0" >
-        <widget class="QTextBrowser" name="txtGlobalWKT" />
+        <widget class="QTextBrowser" name="txtGlobalWkt" />
        </item>
        <item row="0" column="0" >
         <widget class="QGroupBox" name="grpProjectionBehaviour" >
@@ -1092,7 +1092,7 @@
   <tabstop>radPromptForProjection</tabstop>
   <tabstop>radUseProjectProjection</tabstop>
   <tabstop>radUseGlobalProjection</tabstop>
-  <tabstop>txtGlobalWKT</tabstop>
+  <tabstop>txtGlobalWkt</tabstop>
   <tabstop>pbnSelectProjection</tabstop>
   <tabstop>grpLocale</tabstop>
   <tabstop>cboLocale</tabstop>
Modified: trunk/qgis/tests/algorithms/projections/projectioncshandlingtest.h
--- trunk/qgis/tests/algorithms/projections/projectioncshandlingtest.h	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/tests/algorithms/projections/projectioncshandlingtest.h	2008-10-19 19:20:42 UTC (rev 9495)
@@ -95,7 +95,7 @@
     void testProjImportWkt()
       // create a spatial reference system object
-      std::cout << "\n\nCreating and OGRSpatialReference object from WKT" << std::endl;
+      std::cout << "\n\nCreating and OGRSpatialReference object from Wkt" << std::endl;
       OGRSpatialReferenceH myInputSpatialRefSys = OSRNewSpatialReference( NULL );
       char *pWkt = ( char* )wkt.ascii();
       CPPUNIT_ASSERT( OSRImportFromWkt( myInputSpatialRefSys, &pWkt ) == OGRERR_NONE );
@@ -164,7 +164,7 @@
     void testProjEpsgExportToProj4()
-      std::cout << "\n\nGetting NAD83 proj4 parameters from an EpsgCrsId format WKT" << std::endl;
+      std::cout << "\n\nGetting NAD83 proj4 parameters from an EpsgCrsId format Wkt" << std::endl;
       // set up the spatial ref
       OGRSpatialReference myInputSpatialRefSys;
       char *pWkt = ( char* )wktEpsg.ascii();
@@ -219,7 +219,7 @@
     void testFetchWktAttributes()
-      std::cout << "\n\nFetching states.prj WKT attributes using OGRSpatialReference::GetAttrValue" << std::endl;
+      std::cout << "\n\nFetching states.prj Wkt attributes using OGRSpatialReference::GetAttrValue" << std::endl;
       // set up the spatial ref - use the nad83 from states.prj
       char *pWkt = ( char* )wktDestNad83.ascii();
@@ -230,7 +230,7 @@
       std::cout << "\tDatum: " << datum << std::endl;
-    // Test the WKT contained in wkt.txt in the current directory to see if
+    // Test the Wkt contained in wkt.txt in the current directory to see if
     // the datum can be determined
     void testWktFromFile()
@@ -293,15 +293,15 @@
   private:
-    // WKT for default projection hardcoded in QgsCoordinateTransform class
+    // Wkt for default projection hardcoded in QgsCoordinateTransform class
     QString wkt;
-    // WKT for an ESRI style GEOGCS in NAD27
+    // Wkt for an ESRI style GEOGCS in NAD27
     QString wktDest;
-    // WKT for an ESRI style GEOGCS in NAD83 (from states.shp shapefile)
+    // Wkt for an ESRI style GEOGCS in NAD83 (from states.shp shapefile)
     QString wktDestNad83;
-    // WKT for an EpsgCrsId style GEOGCS
+    // Wkt for an EpsgCrsId style GEOGCS
     QString wktEpsg;
-    // WKT for an ESRI style PROJCS as read from a shapefile
+    // Wkt for an ESRI style PROJCS as read from a shapefile
     QString wktAkAlbers;
Modified: trunk/qgis/tests/src/core/regression1141.cpp
--- trunk/qgis/tests/src/core/regression1141.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/tests/src/core/regression1141.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -34,7 +34,7 @@
 #include <qgscoordinatereferencesystem.h> //needed for creating a srs
 #include <qgsapplication.h> //search path for srs.db
 #include <qgsfield.h>
 #include <qgsproviderregistry.h>
@@ -97,7 +97,7 @@
   mEncoding = "UTF-8";
   QgsField myField( "ąęćń", QVariant::Int, "int", 10, 0, "Value on lon" );
   mFields.insert( 0, myField );
   qDebug( "Checking test dataset exists..." );
   qDebug( mFileName.toLocal8Bit() );
Modified: trunk/qgis/tests/src/core/testqgsmaprenderer.cpp
--- trunk/qgis/tests/src/core/testqgsmaprenderer.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/tests/src/core/testqgsmaprenderer.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -34,7 +34,7 @@
 #include <qgsmaprenderer.h>
 #include <qgsmaplayer.h>
 #include <qgsvectorlayer.h>
@@ -89,7 +89,7 @@
   QgsField myField1("Value",QVariant::Int,"int",10,0,"Value on lon");
   mFields.insert(0, myField1);
-  mCRS = QgsCoordinateReferenceSystem(GEOWKT);
+  mCRS = QgsCoordinateReferenceSystem(GEOWkt);
   // Create the test dataset if it doesnt exist
Modified: trunk/qgis/tests/src/core/testqgsvectorfilewriter.cpp
--- trunk/qgis/tests/src/core/testqgsvectorfilewriter.cpp	2008-10-19 17:05:48 UTC (rev 9494)
+++ trunk/qgis/tests/src/core/testqgsvectorfilewriter.cpp	2008-10-19 19:20:42 UTC (rev 9495)
@@ -29,7 +29,7 @@
 /** \ingroup UnitTests
  * This is a unit test for the QgsVectorFileWriter class.
@@ -100,7 +100,7 @@
   QgsField myField1("Field1",QVariant::String,"String",10,0,"Field 1 comment");
   mPoint1 = QgsPoint(10.0,10.0);
   mPoint2 = QgsPoint(15.0,10.0);
   mPoint3 = QgsPoint(15.0,12.0);
More information about the QGIS-commit mailing list
