[QGIS Commit] r9498 - in trunk/qgis: python/core src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Oct 19 16:16:08 EDT 2008
Author: timlinux
Date: 2008-10-19 16:16:08 -0400 (Sun, 19 Oct 2008)
New Revision: 9498
   trunk/qgis/python/core/qgscoordinatetransform.sip
   trunk/qgis/src/core/qgscoordinatetransform.cpp
   trunk/qgis/src/core/qgscoordinatetransform.h
   trunk/qgis/src/core/qgsmaprenderer.cpp
Fix naming of reverse coordinate transform enum
Modified: trunk/qgis/python/core/qgscoordinatetransform.sip
--- trunk/qgis/python/core/qgscoordinatetransform.sip	2008-10-19 19:52:34 UTC (rev 9497)
+++ trunk/qgis/python/core/qgscoordinatetransform.sip	2008-10-19 20:16:08 UTC (rev 9498)
@@ -57,7 +57,7 @@
     //! Enum used to indicate the direction (forward or inverse) of the transform
     enum TransformDirection{
       ForwardTransform,     /*!< Transform from source to destination CRS. */
-      INVERSE      /*!< Transform from destination to source CRS. */
+      ReverseTransform      /*!< Transform from destination to source CRS. */
Modified: trunk/qgis/src/core/qgscoordinatetransform.cpp
--- trunk/qgis/src/core/qgscoordinatetransform.cpp	2008-10-19 19:52:34 UTC (rev 9497)
+++ trunk/qgis/src/core/qgscoordinatetransform.cpp	2008-10-19 20:16:08 UTC (rev 9498)
@@ -436,7 +436,7 @@
   QString dir;
   // if the source/destination projection is lat/long, convert the points to radians
   // prior to transforming
-  if (( pj_is_latlong( mDestinationProjection ) && ( direction == INVERSE ) )
+  if (( pj_is_latlong( mDestinationProjection ) && ( direction == ReverseTransform ) )
       || ( pj_is_latlong( mSourceProjection ) && ( direction == ForwardTransform ) ) )
     for ( int i = 0; i < numPoints; ++i )
@@ -448,10 +448,10 @@
   int projResult;
-  if ( direction == INVERSE )
+  if ( direction == ReverseTransform )
 #if 0
-    QgsDebugMsg( "!!!! INVERSE PROJ4 TRANSFORM !!!!" );
+    QgsDebugMsg( "!!!! ReverseTransform PROJ4 TRANSFORM !!!!" );
     QgsDebugMsg( QString( "     numPoint: %1" ).arg( numPoints ) );
     QgsDebugMsg( QString( "     x       : %1" ).arg( x ) );
     QgsDebugMsg( QString( "     y       : %1" ).arg( y ) );
@@ -505,7 +505,7 @@
   // if the result is lat/long, convert the results from radians back
   // to degrees
   if (( pj_is_latlong( mDestinationProjection ) && ( direction == ForwardTransform ) )
-      || ( pj_is_latlong( mSourceProjection ) && ( direction == INVERSE ) ) )
+      || ( pj_is_latlong( mSourceProjection ) && ( direction == ReverseTransform ) ) )
Modified: trunk/qgis/src/core/qgscoordinatetransform.h
--- trunk/qgis/src/core/qgscoordinatetransform.h	2008-10-19 19:52:34 UTC (rev 9497)
+++ trunk/qgis/src/core/qgscoordinatetransform.h	2008-10-19 20:16:08 UTC (rev 9498)
@@ -92,7 +92,7 @@
Modified: trunk/qgis/src/core/qgsmaprenderer.cpp
--- trunk/qgis/src/core/qgsmaprenderer.cpp	2008-10-19 19:52:34 UTC (rev 9497)
+++ trunk/qgis/src/core/qgsmaprenderer.cpp	2008-10-19 20:16:08 UTC (rev 9498)
@@ -518,10 +518,10 @@
         // Note: ll = lower left point
         //   and ur = upper right point
         QgsPoint ll = tr.transform( extent.xMin(), extent.yMin(),
-                                    QgsCoordinateTransform::INVERSE );
+                                    QgsCoordinateTransform::ReverseTransform );
         QgsPoint ur = tr.transform( extent.xMax(), extent.yMax(),
         if ( ll.x() > ur.x() )
@@ -531,12 +531,12 @@
         else // no need to split
-          extent = tr.transformBoundingBox( extent, QgsCoordinateTransform::INVERSE );
+          extent = tr.transformBoundingBox( extent, QgsCoordinateTransform::ReverseTransform );
       else // can't cross 180
     catch ( QgsCsException &cse )
@@ -601,7 +601,7 @@
     try
       QgsCoordinateTransform tr( theLayer->srs(), *mDestCRS );
-      point = tr.transform( point, QgsCoordinateTransform::INVERSE );
+      point = tr.transform( point, QgsCoordinateTransform::ReverseTransform );
@@ -623,7 +623,7 @@
     try
-      rect = tr.transform( rect, QgsCoordinateTransform::INVERSE );
+      rect = tr.transform( rect, QgsCoordinateTransform::ReverseTransform );
More information about the QGIS-commit mailing list
