[QGIS Commit] r9506 - in trunk/qgis: python/core src/app src/core src/core/spatialindex src/plugins/grass src/providers/postgres src/providers/wfs
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Oct 20 17:44:16 EDT 2008
Author: timlinux
Date: 2008-10-20 17:44:15 -0400 (Mon, 20 Oct 2008)
New Revision: 9506
   trunk/qgis/python/core/qgsfeature.sip
   trunk/qgis/src/app/qgsattributetable.cpp
   trunk/qgis/src/app/qgsattributetabledisplay.cpp
   trunk/qgis/src/app/qgsmaptoolidentify.cpp
   trunk/qgis/src/app/qgsmaptoolmovefeature.cpp
   trunk/qgis/src/core/qgsfeature.cpp
   trunk/qgis/src/core/qgsfeature.h
   trunk/qgis/src/core/qgsvectordataprovider.cpp
   trunk/qgis/src/core/qgsvectorfilewriter.cpp
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/spatialindex/qgsspatialindex.cpp
   trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
   trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
   trunk/qgis/src/providers/wfs/qgswfsprovider.cpp
Api cleanups for qgsfeature
Modified: trunk/qgis/python/core/qgsfeature.sip
--- trunk/qgis/python/core/qgsfeature.sip	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/python/core/qgsfeature.sip	2008-10-20 21:44:15 UTC (rev 9506)
@@ -24,7 +24,7 @@
      * Get the feature id for this feature
      * @return Feature id
-    int featureId() const;
+    int id() const;
      * Set the feature id for this feature
@@ -87,7 +87,7 @@
      * Reset the dirtiness of the feature.  (i.e. make clean)
      * You would normally do this after it's saved to permanent storage (e.g. disk, an ACID-compliant database)
-    void resetDirty();
+    void clean();
      * Get the geometry object associated with this feature
Modified: trunk/qgis/src/app/qgsattributetable.cpp
--- trunk/qgis/src/app/qgsattributetable.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/app/qgsattributetable.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -501,7 +501,7 @@
   //id-field
-  int id = fet.featureId();
+  int id = fet.id();
   QTableWidgetItem *twi = new QTableWidgetItem( QString::number( id ) );
   twi->setTextAlignment( Qt::AlignRight | Qt::AlignVCenter );
   setItem( row, 0, twi );
Modified: trunk/qgis/src/app/qgsattributetabledisplay.cpp
--- trunk/qgis/src/app/qgsattributetabledisplay.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/app/qgsattributetabledisplay.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -379,7 +379,7 @@
     if ( searchTree->checkAgainst( mLayer->pendingFields(), f.attributeMap() ) )
-      mSearchIds << f.featureId();
+      mSearchIds << f.id();
     // check if there were errors during evaluating
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -317,12 +317,12 @@
     featureCount++;
     QTreeWidgetItem* featureNode = mResults->addNode( "foo" );
-    featureNode->setData( 0, Qt::UserRole, QVariant( f_it->featureId() ) ); // save feature id
-    lastFeatureId = f_it->featureId();
+    featureNode->setData( 0, Qt::UserRole, QVariant( f_it->id() ) ); // save feature id
+    lastFeatureId = f_it->id();
     featureNode->setText( 0, fieldIndex );
     if ( layer->isEditable() )
-      mResults->addEdit( featureNode, f_it->featureId() );
+      mResults->addEdit( featureNode, f_it->id() );
     const QgsAttributeMap& attr = f_it->attributeMap();
@@ -476,7 +476,7 @@
   for ( QgsFeatureList::iterator it = mFeatureList.begin(); it != mFeatureList.end(); it++ )
-    if ( it->featureId() == featureId )
+    if ( it->id() == featureId )
       editFeature( *it );
       break;
@@ -503,7 +503,7 @@
     for ( QgsAttributeMap::const_iterator it = dst.begin(); it != dst.end(); it++ )
       if ( !src.contains( it.key() ) || it.value() != src[it.key()] )
-        layer->changeAttributeValue( f.featureId(), it.key(), it.value() );
+        layer->changeAttributeValue( f.id(), it.key(), it.value() );
   delete ad;
Modified: trunk/qgis/src/app/qgsmaptoolmovefeature.cpp
--- trunk/qgis/src/app/qgsmaptoolmovefeature.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/app/qgsmaptoolmovefeature.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -107,7 +107,7 @@
   mStartPointMapCoords = toMapCoordinates( e->pos() );
-  mMovedFeature = cf.featureId(); //todo: take the closest feature, not the first one...
+  mMovedFeature = cf.id(); //todo: take the closest feature, not the first one...
   mRubberBand = createRubberBand();
   mRubberBand->setToGeometry( cf.geometry(), *vlayer );
   mRubberBand->setColor( Qt::red );
Modified: trunk/qgis/src/core/qgsfeature.cpp
--- trunk/qgis/src/core/qgsfeature.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/core/qgsfeature.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -84,7 +84,7 @@
-int QgsFeature::featureId() const
+int QgsFeature::id() const
   return mFid;
@@ -204,7 +204,7 @@
   return mDirty;
-void QgsFeature::resetDirty()
+void QgsFeature::clean()
   mDirty = false;
Modified: trunk/qgis/src/core/qgsfeature.h
--- trunk/qgis/src/core/qgsfeature.h	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/core/qgsfeature.h	2008-10-20 21:44:15 UTC (rev 9506)
@@ -66,7 +66,7 @@
+    int id() const;
@@ -128,7 +128,7 @@
+    void clean();
Modified: trunk/qgis/src/core/qgsvectordataprovider.cpp
--- trunk/qgis/src/core/qgsvectordataprovider.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/core/qgsvectordataprovider.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -56,7 +56,7 @@
   while ( nextFeature( feature ) )
-    if ( feature.featureId() == featureId )
+    if ( feature.id() == featureId )
       return TRUE;
Modified: trunk/qgis/src/core/qgsvectorfilewriter.cpp
--- trunk/qgis/src/core/qgsvectorfilewriter.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/core/qgsvectorfilewriter.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -348,7 +348,7 @@
   // write all features
   while ( provider->nextFeature( fet ) )
-    if ( onlySelected && !ids.contains( fet.featureId() ) )
+    if ( onlySelected && !ids.contains( fet.id() ) )
       continue;
     if ( shallTransform )
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -318,7 +318,7 @@
         if ( mRenderer->willRenderFeature( &fet ) )
-          bool sel = mSelectedFeatureIds.contains( fet.featureId() );
+          bool sel = mSelectedFeatureIds.contains( fet.id() );
           mLabel->renderLabel( p, viewExtent, ct, theMapToPixelTransform, fet, sel, 0, scale );
         featureCount++;
@@ -742,13 +742,13 @@
         if ( mEditable )
           // Cache this for the use of (e.g.) modifying the feature's uncommitted geometry.
-          mCachedGeometries[fet.featureId()] = *fet.geometry();
+          mCachedGeometries[fet.id()] = *fet.geometry();
         // check if feature is selected
         // only show selections of the current layer
         // TODO: create a mechanism to let layer know whether it's current layer or not [MD]
         //QgsDebugMsg(QString("markerScale before renderFeature(): %1").arg(markerScaleFactor));
         // markerScalerFactore reflects the wanted scaling of the marker
@@ -843,7 +843,7 @@
   QgsFeature f;
   while ( nextFeature( f ) )
-    select( f.featureId(), false ); // don't emit signal (not to redraw it everytime)
+    select( f.id(), false ); // don't emit signal (not to redraw it everytime)
   emit selectionChanged(); // now emit signal to redraw layer
@@ -861,7 +861,7 @@
   QgsFeature fet;
   while ( nextFeature( fet ) )
-    select( fet.featureId(), false ); // don't emit signal
+    select( fet.id(), false ); // don't emit signal
   for ( QgsFeatureIds::iterator iter = tmp.begin(); iter != tmp.end(); ++iter )
@@ -994,7 +994,7 @@
   QgsFeature fet;
-    if ( mSelectedFeatureIds.contains( fet.featureId() ) )
+    if ( mSelectedFeatureIds.contains( fet.id() ) )
       if ( fet.geometry() )
@@ -1128,9 +1128,9 @@
 void QgsVectorLayer::updateFeatureAttributes( QgsFeature &f )
-  if ( mChangedAttributeValues.contains( f.featureId() ) )
+  if ( mChangedAttributeValues.contains( f.id() ) )
-    const QgsAttributeMap &map = mChangedAttributeValues[f.featureId()];
+    const QgsAttributeMap &map = mChangedAttributeValues[f.id()];
     for ( QgsAttributeMap::const_iterator it = map.begin(); it != map.end(); it++ )
       f.changeAttribute( it.key(), it.value() );
@@ -1141,8 +1141,8 @@
 void QgsVectorLayer::updateFeatureGeometry( QgsFeature &f )
-  if ( mChangedGeometries.contains( f.featureId() ) )
-    f.setGeometry( mChangedGeometries[f.featureId()] );
+  if ( mChangedGeometries.contains( f.id() ) )
+    f.setGeometry( mChangedGeometries[f.id()] );
@@ -1234,7 +1234,7 @@
             for ( QgsFeatureList::iterator it = mAddedFeatures.begin(); it != mAddedFeatures.end(); it++ )
-              if ( fid != it->featureId() )
+              if ( fid != it->id() )
                 found = true;
                 f.setAttributeMap( it->attributeMap() );
@@ -1243,7 +1243,7 @@
             if ( !found )
-              QgsLogger::warning( QString( "No attributes for the added feature %1 found" ).arg( f.featureId() ) );
+              QgsLogger::warning( QString( "No attributes for the added feature %1 found" ).arg( f.id() ) );
           else
@@ -1265,7 +1265,7 @@
     for ( ; mFetchAddedFeaturesIt != mAddedFeatures.end(); mFetchAddedFeaturesIt++ )
-      int fid = mFetchAddedFeaturesIt->featureId();
+      int fid = mFetchAddedFeaturesIt->id();
       if ( mFetchConsidered.contains( fid ) )
         // must have changed geometry outside rectangle
@@ -1297,7 +1297,7 @@
   while ( dataProvider()->nextFeature( f ) )
-    if ( mFetchConsidered.contains( f.featureId() ) )
+    if ( mFetchConsidered.contains( f.id() ) )
       continue;
     if ( mEditable )
@@ -1333,7 +1333,7 @@
-          if ( featureId != it->featureId() )
+          if ( featureId != it->id() )
             found = true;
@@ -1342,7 +1342,7 @@
         if ( !found )
       else
@@ -1359,9 +1359,9 @@
   //added features
   for ( QgsFeatureList::iterator iter = mAddedFeatures.begin(); iter != mAddedFeatures.end(); ++iter )
-    if ( iter->featureId() == featureId )
+    if ( iter->id() == featureId )
-      f.setFeatureId( iter->featureId() );
+      f.setFeatureId( iter->id() );
       if ( fetchGeometries )
         f.setGeometry( *iter->geometry() );
@@ -1574,7 +1574,7 @@
     addRingReturnCode = f.geometry()->addRing( ring );
     if ( addRingReturnCode == 0 )
-      mChangedGeometries.insert( f.featureId(), *f.geometry() );
+      mChangedGeometries.insert( f.id(), *f.geometry() );
       setModified( true, true );
       break;
@@ -1610,7 +1610,7 @@
   //look if id of selected feature belongs to an added feature
   for ( QgsFeatureList::iterator addedIt = mAddedFeatures.begin(); addedIt != mAddedFeatures.end(); ++addedIt )
-    if ( addedIt->featureId() == selectedFeatureId )
+    if ( addedIt->id() == selectedFeatureId )
       return addedIt->geometry()->addIsland( ring );
@@ -1644,7 +1644,7 @@
-    if ( addedIt->featureId() == featureId )
+    if ( addedIt->id() == featureId )
       return addedIt->geometry()->translate( dx, dy );
@@ -1729,7 +1729,7 @@
     if ( splitFunctionReturn == 0 )
       //change this geometry
-      mChangedGeometries.insert( select_it->featureId(), *( select_it->geometry() ) );
+      mChangedGeometries.insert( select_it->id(), *( select_it->geometry() ) );
       //insert new features
       for ( int i = 0; i < newGeometries.size(); ++i )
@@ -2504,7 +2504,7 @@
     // updated added feature
     int i;
-    for ( i = 0; i < mAddedFeatures.size() && mAddedFeatures[i].featureId() != fid; i++ )
+    for ( i = 0; i < mAddedFeatures.size() && mAddedFeatures[i].id() != fid; i++ )
     if ( i == mAddedFeatures.size() )
@@ -2783,21 +2783,21 @@
-        if ( mDeletedFeatureIds.contains( iter->featureId() ) )
+        if ( mDeletedFeatureIds.contains( iter->id() ) )
-          mDeletedFeatureIds.remove( iter->featureId() );
+          mDeletedFeatureIds.remove( iter->id() );
-          if ( mChangedGeometries.contains( iter->featureId() ) )
-            mChangedGeometries.remove( iter->featureId() );
+          if ( mChangedGeometries.contains( iter->id() ) )
+            mChangedGeometries.remove( iter->id() );
           mAddedFeatures.erase( iter );
           continue;
-          iter->setGeometry( mChangedGeometries.take( iter->featureId() ) );
+          iter->setGeometry( mChangedGeometries.take( iter->id() ) );
@@ -2973,7 +2973,7 @@
     // Check this selected item against the uncommitted added features
-      if ( *it == iter->featureId() )
+      if ( *it == iter->id() )
         feat = QgsFeature( *iter );
         selectionIsAddedFeature = TRUE;
@@ -3024,7 +3024,7 @@
     if ( makeSelected )
-      mSelectedFeatureIds.insert( iter->featureId() );
+      mSelectedFeatureIds.insert( iter->id() );
@@ -3146,7 +3146,7 @@
   QgsFeature f;
-    snapToGeometry( startPoint, f.featureId(), f.geometry(), sqrSnappingTolerance, snappingResults, snap_to );
+    snapToGeometry( startPoint, f.id(), f.geometry(), sqrSnappingTolerance, snappingResults, snap_to );
     ++n;
Modified: trunk/qgis/src/core/spatialindex/qgsspatialindex.cpp
--- trunk/qgis/src/core/spatialindex/qgsspatialindex.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/core/spatialindex/qgsspatialindex.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -94,7 +94,7 @@
   if ( !g )
     return false;
-  id = f.featureId();
+  id = f.id();
   r = rectToRegion( g->boundingBox() );
   return true;
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -2967,7 +2967,7 @@
   int i = 0;
   while ( provider->nextFeature( feature ) )
-    if ( !selected.contains( feature.featureId() ) )
+    if ( !selected.contains( feature.id() ) )
       continue;
     QgsAttributeMap attr = feature.attributeMap();
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -616,7 +616,7 @@
     feature.setGeometryAndOwnership( 0, 0 );
-  feature.setFeatureId( mFeatureQueue.front().featureId() );
+  feature.setFeatureId( mFeatureQueue.front().id() );
   feature.setAttributeMap( mFeatureQueue.front().attributeMap() );
   mFeatureQueue.pop();
Modified: trunk/qgis/src/providers/wfs/qgswfsprovider.cpp
--- trunk/qgis/src/providers/wfs/qgswfsprovider.cpp	2008-10-20 21:35:05 UTC (rev 9505)
+++ trunk/qgis/src/providers/wfs/qgswfsprovider.cpp	2008-10-20 21:44:15 UTC (rev 9506)
@@ -72,7 +72,7 @@
       return 0;
-    feature.setFeatureId( mFeatures[*mFeatureIterator]->featureId() );
+    feature.setFeatureId( mFeatures[*mFeatureIterator]->id() );
     if ( mFetchGeom )
       QgsGeometry* geometry = mFeatures[*mFeatureIterator]->geometry();
@@ -305,7 +305,7 @@
   for ( QList<QgsFeature*>::iterator it = mFeatures.begin(); it != mFeatures.end(); ++it )
-    QgsDebugMsg( "feature " + QString::number(( *it )->featureId() ) );
+    QgsDebugMsg( "feature " + QString::number(( *it )->id() ) );
     mSpatialIndex->insertFeature( **it );
More information about the QGIS-commit mailing list
