[QGIS Commit] r9515 - in trunk/qgis: python/core src/core src/plugins/interpolation src/providers/gpx src/providers/ogr src/providers/postgres src/providers/wfs
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Oct 22 03:31:06 EDT 2008
Author: timlinux
Date: 2008-10-22 03:31:05 -0400 (Wed, 22 Oct 2008)
New Revision: 9515
   trunk/qgis/python/core/qgsgeometry.sip
   trunk/qgis/src/core/qgsdistancearea.cpp
   trunk/qgis/src/core/qgsfeature.cpp
   trunk/qgis/src/core/qgsgeometry.cpp
   trunk/qgis/src/core/qgsgeometry.h
   trunk/qgis/src/core/qgslabel.cpp
   trunk/qgis/src/core/qgsvectorfilewriter.cpp
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/plugins/interpolation/qgsinterpolator.cpp
   trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp
   trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
   trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
   trunk/qgis/src/providers/wfs/qgswfsprovider.cpp
API cleanups for qgsgeometry
Modified: trunk/qgis/python/core/qgsgeometry.sip
--- trunk/qgis/python/core/qgsgeometry.sip	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/python/core/qgsgeometry.sip	2008-10-22 07:31:05 UTC (rev 9515)
@@ -59,25 +59,25 @@
        Set the geometry, feeding in the buffer containing OGC Well-Known Binary and the buffer's length.
        This class will take ownership of the buffer.
-    void setWkbAndOwnership(unsigned char * wkb /Array/, size_t length /ArraySize/);
+    void fromWkb(unsigned char * wkb /Array/, size_t length /ArraySize/);
 %MethodCode
-  // create copy of Python's string and pass it to setWkbAndOwnership()
+  // create copy of Python's string and pass it to fromWkb()
   unsigned char * copy = new unsigned char[a1];
   memcpy(copy, a0, a1);
-  sipCpp->setWkbAndOwnership(copy, a1);
+  sipCpp->fromWkb(copy, a1);
 %End
        Returns the buffer containing this geometry in WKB format.
        You may wish to use in conjunction with wkbSize().
-    SIP_PYOBJECT wkbBuffer();
+    SIP_PYOBJECT asWkb();
 %MethodCode
-  sipRes = PyString_FromStringAndSize((const char *)sipCpp->wkbBuffer(), sipCpp->wkbSize());
+  sipRes = PyString_FromStringAndSize((const char *)sipCpp->asWkb(), sipCpp->wkbSize());
 %End
-       Returns the size of the WKB in wkbBuffer().
+       Returns the size of the WKB in asWkb().
     size_t wkbSize();
@@ -94,7 +94,7 @@
        Set the geometry, feeding in a geometry in GEOS format.
     // TODO: unsupported class... would be possible to use PyGEOS?
-    //void setGeos(geos::Geometry* geos);
+    //void fromGeos(geos::Geometry* geos);
     double distance(QgsGeometry& geom);
@@ -116,7 +116,7 @@
           account the first vertex is equal to the last vertex (and will
           skip equal vertex positions).
-    void adjacentVerticies(int atVertex, int& beforeVertex /Out/, int& afterVertex /Out/);
+    void adjacentVertices(int atVertex, int& beforeVertex /Out/, int& afterVertex /Out/);
     /** Insert a new vertex before the given vertex index,
      *  ring and item (first number is index 0)
Modified: trunk/qgis/src/core/qgsdistancearea.cpp
--- trunk/qgis/src/core/qgsdistancearea.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/core/qgsdistancearea.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -176,7 +176,7 @@
 double QgsDistanceArea::measure( QgsGeometry* geometry )
-  unsigned char* wkb = geometry->wkbBuffer();
+  unsigned char* wkb = geometry->asWkb();
   unsigned char* ptr;
   unsigned int wkbType;
   double res, resTotal = 0;
Modified: trunk/qgis/src/core/qgsfeature.cpp
--- trunk/qgis/src/core/qgsfeature.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/core/qgsfeature.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -184,7 +184,7 @@
 void QgsFeature::setGeometryAndOwnership( unsigned char *geom, size_t length )
   QgsGeometry *g = new QgsGeometry();
-  g->setWkbAndOwnership( geom, length );
+  g->fromWkb( geom, length );
   setGeometry( g );
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/core/qgsgeometry.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -392,7 +392,7 @@
     return 0;
   QgsGeometry* g = new QgsGeometry;
-  g->setGeos( geom );
+  g->fromGeos( geom );
   return g;
@@ -538,7 +538,7 @@
 } // QgsGeometry::operator=( QgsGeometry const & rhs )
-void QgsGeometry::setWkbAndOwnership( unsigned char * wkb, size_t length )
+void QgsGeometry::fromWkb( unsigned char * wkb, size_t length )
   // delete any existing WKB geometry before assigning new one
   if ( mGeometry )
@@ -559,7 +559,7 @@
   mDirtyGeos  = TRUE;
-unsigned char * QgsGeometry::wkbBuffer()
+unsigned char * QgsGeometry::asWkb()
   if ( mDirtyWkb )
@@ -583,7 +583,7 @@
 QGis::WkbType QgsGeometry::wkbType()
-  unsigned char *geom = wkbBuffer(); // ensure that wkb representation exists
+  unsigned char *geom = asWkb(); // ensure that wkb representation exists
   if ( geom )
@@ -640,7 +640,7 @@
-void QgsGeometry::setGeos( GEOSGeometry* geos )
+void QgsGeometry::fromGeos( GEOSGeometry* geos )
   // TODO - make this more heap-friendly
@@ -939,7 +939,7 @@
-void QgsGeometry::adjacentVerticies( int atVertex, int& beforeVertex, int& afterVertex )
+void QgsGeometry::adjacentVertices( int atVertex, int& beforeVertex, int& afterVertex )
   // TODO: implement with GEOS
   if ( mDirtyWkb )
Modified: trunk/qgis/src/core/qgsgeometry.h
--- trunk/qgis/src/core/qgsgeometry.h	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/core/qgsgeometry.h	2008-10-22 07:31:05 UTC (rev 9515)
@@ -96,15 +96,25 @@
     static QgsGeometry* fromMultiPolygon( const QgsMultiPolygon& multipoly );
     /** construct geometry from a rectangle */
     static QgsGeometry* fromRect( const QgsRect& rect );
+      Set the geometry, feeding in a geometry in GEOS format.
+      This class will take ownership of the buffer.
+    void fromGeos( GEOSGeometry* geos );
+      Set the geometry, feeding in the buffer containing OGC Well-Known Binary and the buffer's length.
+    void fromWkb( unsigned char * wkb, size_t length );
-    unsigned char * wkbBuffer();
+    unsigned char * asWkb();
     size_t wkbSize();
@@ -117,17 +127,7 @@
     /** Returns true if wkb of the geometry is of WKBMulti* type */
     bool isMultipart();
-      Set the geometry, feeding in a geometry in GEOS format.
-      This class will take ownership of the buffer.
-    void setGeos( GEOSGeometry* geos );
-      Set the geometry, feeding in the buffer containing OGC Well-Known Binary and the buffer's length.
-    void setWkbAndOwnership( unsigned char * wkb, size_t length );
     double distance( QgsGeometry& geom );
@@ -151,7 +151,7 @@
-    void adjacentVerticies( int atVertex, int& beforeVertex, int& afterVertex );
+    void adjacentVertices( int atVertex, int& beforeVertex, int& afterVertex );
@@ -245,7 +245,10 @@
     @param topological true if topological editing is enabled
     @topologyTestPoints OUT: points that need to be tested for topological completeness in the dataset
     @return 0 in case of success, 1 if geometry has not been split, error else*/
-    int splitGeometry( const QList<QgsPoint>& splitLine, QList<QgsGeometry*>& newGeometries, bool topological, QList<QgsPoint>& topologyTestPoints );
+    int splitGeometry( const QList<QgsPoint>& splitLine,
+        QList<QgsGeometry*>&newGeometries,
+        bool topological,
+        QList<QgsPoint>& topologyTestPoints );
     /**Changes this geometry such that it does not intersect the other geometry
        @param other geometry that should not be intersect
Modified: trunk/qgis/src/core/qgslabel.cpp
--- trunk/qgis/src/core/qgslabel.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/core/qgslabel.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -507,7 +507,7 @@
 void QgsLabel::labelPoint( std::vector<QgsPoint>& points, QgsFeature & feature )
   QgsGeometry *geometry = feature.geometry();
-  unsigned char *geom = geometry->wkbBuffer();
+  unsigned char *geom = geometry->asWkb();
   size_t geomlen = geometry->wkbSize();
   QGis::WkbType wkbType = geometry->wkbType();
   QgsPoint point;
Modified: trunk/qgis/src/core/qgsvectorfilewriter.cpp
--- trunk/qgis/src/core/qgsvectorfilewriter.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/core/qgsvectorfilewriter.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -236,7 +236,7 @@
     OGRGeometryH mGeom2 = createEmptyGeometry( geom->wkbType() );
-    OGRErr err = OGR_G_ImportFromWkb( mGeom2, geom->wkbBuffer(), geom->wkbSize() );
+    OGRErr err = OGR_G_ImportFromWkb( mGeom2, geom->asWkb(), geom->wkbSize() );
     if ( err != OGRERR_NONE )
       QgsDebugMsg( "Failed to import geometry from WKB: " + QString::number( err ) );
@@ -249,7 +249,7 @@
   else
-    OGRErr err = OGR_G_ImportFromWkb( mGeom, geom->wkbBuffer(), geom->wkbSize() );
+    OGRErr err = OGR_G_ImportFromWkb( mGeom, geom->asWkb(), geom->wkbSize() );
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -3301,7 +3301,7 @@
 #endif
   QgsGeometry* geom = fet.geometry();
-  unsigned char* feature = geom->wkbBuffer();
+  unsigned char* feature = geom->asWkb();
   QGis::WkbType wkbType = geom->wkbType();
Modified: trunk/qgis/src/plugins/interpolation/qgsinterpolator.cpp
--- trunk/qgis/src/plugins/interpolation/qgsinterpolator.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/plugins/interpolation/qgsinterpolator.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -107,7 +107,7 @@
   bool hasZValue = false;
-  unsigned char* currentWkbPtr = geom->wkbBuffer();
+  unsigned char* currentWkbPtr = geom->asWkb();
   vertexData theVertex; //the current vertex
Modified: trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp
--- trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -229,7 +229,7 @@
         //create QgsGeometry and use it for intersection test
         //if geometry is to be fetched, it is attached to the feature, otherwise we delete it
         QgsGeometry* theGeometry = new QgsGeometry();
-        theGeometry->setWkbAndOwnership(( unsigned char * )geo, 9 + 16 * nPoints );
+        theGeometry->fromWkb(( unsigned char * )geo, 9 + 16 * nPoints );
         bool intersection = theGeometry->intersects( b );//use geos for precise intersection test
         if ( !intersection )
@@ -344,7 +344,7 @@
-        theGeometry->setWkbAndOwnership(( unsigned char * )geo, 9 + 16 * totalPoints );
+        theGeometry->fromWkb(( unsigned char * )geo, 9 + 16 * totalPoints );
         if ( !intersection ) //no intersection, delete geometry and move on
@@ -522,7 +522,7 @@
 bool QgsGPXProvider::addFeature( QgsFeature& f )
-  unsigned char* geo = f.geometry()->wkbBuffer();
+  unsigned char* geo = f.geometry()->asWkb();
   QGis::WkbType wkbType = f.geometry()->wkbType();
   bool success = false;
   GPSObject* obj = NULL;
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -477,7 +477,7 @@
   bool returnValue = true;
   OGRFeatureDefnH fdef = OGR_L_GetLayerDefn( ogrLayer );
   OGRFeatureH feature = OGR_F_Create( fdef );
-  unsigned char* wkb = f.geometry()->wkbBuffer();
+  unsigned char* wkb = f.geometry()->asWkb();
   if ( f.geometry()->wkbSize() > 0 )
@@ -688,7 +688,7 @@
     //create an OGRGeometry
-    if ( OGR_G_CreateFromWkb( it->wkbBuffer(),
+    if ( OGR_G_CreateFromWkb( it->asWkb(),
                               OGR_L_GetSpatialRef( ogrLayer ),
                               &theNewGeometry,
                               it->wkbSize() ) != OGRERR_NONE )
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -2075,7 +2075,7 @@
 void QgsPostgresProvider::appendGeomString( QgsGeometry *geom, QString &geomString ) const
-  unsigned char *buf = geom->wkbBuffer();
+  unsigned char *buf = geom->asWkb();
   for ( uint i = 0; i < geom->wkbSize(); ++i )
     if ( connectionRW->useWkbHex() )
@@ -2118,7 +2118,7 @@
       QgsDebugMsg( "iterating over the map of changed geometries..." );
-      if ( iter->wkbBuffer() )
+      if ( iter->asWkb() )
         QgsDebugMsg( "iterating over feature id " + QString::number( iter.key() ) );
Modified: trunk/qgis/src/providers/wfs/qgswfsprovider.cpp
--- trunk/qgis/src/providers/wfs/qgswfsprovider.cpp	2008-10-21 23:30:48 UTC (rev 9514)
+++ trunk/qgis/src/providers/wfs/qgswfsprovider.cpp	2008-10-22 07:31:05 UTC (rev 9515)
@@ -76,7 +76,7 @@
     //we need geometry anyway, e.g. for intersection tests
     QgsGeometry* geometry = mFeatures[*mFeatureIterator]->geometry();
     int geomSize = geometry->wkbSize();
     unsigned char* copiedGeom = new unsigned char[geomSize];
     memcpy( copiedGeom, geom, geomSize );
More information about the QGIS-commit mailing list
