[QGIS Commit] r9526 - trunk/qgis/src/app
    svn_qgis at osgeo.org
    Thu Oct 23 09:39:25 EDT 2008
Author: wonder
Date: 2008-10-23 09:39:22 -0400 (Thu, 23 Oct 2008)
New Revision: 9526
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgisapp.h
   trunk/qgis/src/app/qgspluginitem.cpp
   trunk/qgis/src/app/qgspluginitem.h
   trunk/qgis/src/app/qgspluginmanager.cpp
   trunk/qgis/src/app/qgspluginregistry.cpp
   trunk/qgis/src/app/qgspluginregistry.h
- QgsPluginRegistry - metadata stored in QMap
- address plugins by their unique name:
  - library's basename for c++ plugins
  - module name for python plugins
(before plugins were addressed by their name, causing ambiguity)
- general cleanups in plugin handling
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-10-23 12:42:22 UTC (rev 9525)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-10-23 13:39:22 UTC (rev 9526)
@@ -119,6 +119,7 @@
 #include "qgspastetransformations.h"
 #include "qgspluginitem.h"
 #include "qgspluginmanager.h"
+#include "qgspluginmetadata.h"
 #include "qgspluginregistry.h"
 #include "qgspoint.h"
 #include "qgsproject.h"
@@ -1846,7 +1847,7 @@
     QString myFullPath = thePluginDirString + "/" + myPluginDir[i];
+    QString baseName = QFileInfo(myFullPath).baseName();
     QLibrary *myLib = new QLibrary( myFullPath );
     bool loaded = myLib->load();
     if ( loaded )
@@ -1858,15 +1859,15 @@
       if ( myName && myDescription  && myVersion )
         //check if the plugin was active on last session
-        QString myEntryName = myName();
         // Windows stores a "true" value as a 1 in the registry so we
         // have to use readBoolEntry in this function
-        if ( mySettings.value( "/Plugins/" + myEntryName ).toBool() )
+        if ( mySettings.value( "/Plugins/" + baseName ).toBool() )
           //QgsDebugMsg("Loading plugin: " + myEntryName);
-          loadPlugin( myName(), myDescription(), myFullPath );
+          loadPlugin( myFullPath, myName() );
         else
@@ -4142,7 +4143,7 @@
       else
-        loadPlugin( plugin.name(), plugin.description(), plugin.fullPath() );
+        loadPlugin( plugin.fullPath(), plugin.name() );
       it++;
@@ -4209,9 +4210,9 @@
   QgsPluginRegistry *pRegistry = QgsPluginRegistry::instance();
   // is loaded already?
-  if ( pRegistry->library( pluginName ).isEmpty() )
+  if ( ! pRegistry->isLoaded(packageName) )
     mPythonUtils->loadPlugin( packageName );
     mPythonUtils->startPlugin( packageName );
@@ -4219,7 +4220,7 @@
     // TODO: test success
     // add to plugin registry
-    pRegistry->addPythonPlugin( packageName, pluginName );
+    pRegistry->addPlugin( packageName, QgsPluginMetadata( packageName, pluginName, NULL, true) );
     // add to settings
     QSettings settings;
@@ -4230,13 +4231,15 @@
-void QgisApp::loadPlugin( QString name, QString description, QString theFullPathName )
+void QgisApp::loadPlugin( QString theFullPathName, QString name )
   QSettings settings;
   // first check to see if its already loaded
-  QString lib = pRegistry->library( name );
-  if ( lib.length() > 0 )
+  QString baseName = QFileInfo(theFullPathName).baseName();
+  if ( pRegistry->isLoaded(baseName) )
     // plugin is loaded
     // QMessageBox::warning(this, "Already Loaded", description + " is already loaded");
@@ -4269,9 +4272,9 @@
               pl->initGui();
               // add it to the plugin registry
-              pRegistry->addPlugin( myLib->fileName(), name, pl );
+              pRegistry->addPlugin(baseName, QgsPluginMetadata(myLib->fileName(), name, pl) );
               //add it to the qsettings file [ts]
-              settings.setValue( "/Plugins/" + name, true );
+              settings.setValue( "/Plugins/" + baseName, true );
             else
@@ -4280,7 +4283,7 @@
                                     "The following diagnostic information may help the QGIS developers resolve the issue:\n%1." ).arg
                                     ( myError ) );
               //disable it to the qsettings file [ts]
-              settings.setValue( "/Plugins/" + name, false );
+              settings.setValue( "/Plugins/" + baseName, false );
           else
@@ -4290,6 +4293,8 @@
         break;
+        // TODO: to be removed completely
         case QgisPlugin::MAPLAYER:
           // Map layer - requires interaction with the canvas
@@ -4320,6 +4325,7 @@
         break;
         default:
           // type is unknown
           QgsDebugMsg( "Plugin " + theFullPathName + " did not return a valid type and cannot be loaded" );
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h	2008-10-23 12:42:22 UTC (rev 9525)
+++ trunk/qgis/src/app/qgisapp.h	2008-10-23 13:39:22 UTC (rev 9526)
@@ -385,7 +385,7 @@
     //! load python support if possible
     void loadPythonSupport();
     //! plugin loader
-    void loadPlugin( QString name, QString description, QString mFullPath );
+    void loadPlugin( QString mFullPath, QString name );
     //! python plugin loader
     void loadPythonPlugin( QString packageName, QString pluginName );
     //! Find the QMenu with the given name (ie the user visible text on the menu item)
Modified: trunk/qgis/src/app/qgspluginitem.cpp
--- trunk/qgis/src/app/qgspluginitem.cpp	2008-10-23 12:42:22 UTC (rev 9525)
+++ trunk/qgis/src/app/qgspluginitem.cpp	2008-10-23 13:39:22 UTC (rev 9526)
@@ -17,8 +17,8 @@
 /* $Id$ */
-QgsPluginItem::QgsPluginItem( QString _name, QString _description, QString _fullPath, QString _type, bool _python ):
-    m_name( _name ), m_description( _description ), m_fullPath( _fullPath ), m_type( _type ), m_python( _python )
+QgsPluginItem::QgsPluginItem( QString _name, QString _fullPath, QString _type, bool _python ):
+    m_name( _name ), m_fullPath( _fullPath ), m_type( _type ), m_python( _python )
Modified: trunk/qgis/src/app/qgspluginitem.h
--- trunk/qgis/src/app/qgspluginitem.h	2008-10-23 12:42:22 UTC (rev 9525)
+++ trunk/qgis/src/app/qgspluginitem.h	2008-10-23 13:39:22 UTC (rev 9526)
@@ -26,7 +26,7 @@
 class QgsPluginItem
   public:
-    QgsPluginItem( QString name = 0, QString description = 0, QString fullPath = 0, QString type = 0, bool python = false );
+    QgsPluginItem( QString name = 0, QString fullPath = 0, QString type = 0, bool python = false );
     QString name();
     QString description();
     QString fullPath();
Modified: trunk/qgis/src/app/qgspluginmanager.cpp
--- trunk/qgis/src/app/qgspluginmanager.cpp	2008-10-23 12:42:22 UTC (rev 9525)
+++ trunk/qgis/src/app/qgspluginmanager.cpp	2008-10-23 13:39:22 UTC (rev 9526)
@@ -55,7 +55,7 @@
 const int PLUGIN_DATA_ROLE = Qt::UserRole;
 const int PLUGIN_LIBRARY_ROLE = Qt::UserRole + 1;
-const int PLUGIN_LIBRARY_NAME_ROLE = Qt::UserRole + 2;
+const int PLUGIN_BASE_NAME_ROLE = Qt::UserRole + 2;
 QgsPluginManager::QgsPluginManager( QgsPythonUtils* pythonUtils, QWidget * parent, Qt::WFlags fl )
     : QDialog( parent, fl )
@@ -151,9 +151,9 @@
     // filtering will be done on the display role so give it name and desription
     // user wont see this text since we are using a custome delegate
     QStandardItem * mypDetailItem = new QStandardItem( pluginName + " - " + description );
-    QString myLibraryName = "python:" + packageName;;
+    QString myLibraryName = "python:" + packageName;
     mypDetailItem->setData( myLibraryName, PLUGIN_LIBRARY_ROLE ); //for loading libs later
-    mypDetailItem->setData( pluginName, PLUGIN_LIBRARY_NAME_ROLE ); //for matching in registry later
+    mypDetailItem->setData( packageName, PLUGIN_BASE_NAME_ROLE ); //for matching in registry later
     mypDetailItem->setCheckable( false );
     mypDetailItem->setEditable( false );
     // setData in the delegate with a variantised QgsDetailedItemData
@@ -167,19 +167,15 @@
     // check to see if the plugin is loaded and set the checkbox accordingly
-    QString libName = pRegistry->library( pluginName );
-    if ( libName.length() == 0 || !pRegistry->isPythonPlugin( pluginName ) )
+    if ( pRegistry->isLoaded(packageName) && pRegistry->isPythonPlugin(packageName) )
-      QgsDebugMsg( "Couldn't find library name in the registry" );
+      QgsDebugMsg( "Found plugin in the registry" );
+      // set the checkbox
+      myData.setChecked( true );
     else
-      QgsDebugMsg( "Found library name in the registry" );
-      if ( libName == packageName )
-        // set the checkbox
-        myData.setChecked( true );
+      QgsDebugMsg( "Couldn't find plugin in the registry: " + packageName );
     QVariant myVariant = qVariantFromValue( myData );
     mypDetailItem->setData( myVariant, PLUGIN_DATA_ROLE );
@@ -297,40 +293,40 @@
       delete myLib;
       continue;
+    QString pluginName = pName();
+    QString pluginDesc = pDesc();
+    QString pluginVersion = pVersion();
+    QString baseName = QFileInfo(lib).baseName();
     QString myLibraryName = pluginDir[i];
-    QStandardItem * mypDetailItem = new QStandardItem( pName() + " - " + pDesc() );
+    QStandardItem * mypDetailItem = new QStandardItem( pluginName + " - " + pluginDesc );
-    mypDetailItem->setData( pName(), PLUGIN_LIBRARY_NAME_ROLE ); //for matching in registry later
+    mypDetailItem->setData( baseName, PLUGIN_BASE_NAME_ROLE ); //for matching in registry later
     QgsDetailedItemData myData;
-    myData.setTitle( pName() );
-    myData.setDetail( pDesc() );
+    myData.setTitle( pluginName );
+    myData.setDetail( pluginDesc );
     myData.setRenderAsWidget( false );
     myData.setCheckable( true );
     myData.setChecked( false ); //start unchecked - we will check it later if needed
-    //round trip test - delete this...no need to uncomment
-    //QgsDetailedItemData myData2 = qVariantValue<QgsDetailedItemData>(myVariant);
-    //Q_ASSERT(myData.title() == myData2.title());
-    //round trip test ends
     QgsDebugMsg( "Getting an instance of the QgsPluginRegistry" );
-    QString libName = pRegistry->library( pName() );
     // get the library using the plugin description
-    if ( libName.length() == 0 )
+    if ( !pRegistry->isLoaded(baseName) )
+      QgsDebugMsg( "Couldn't find plugin in the registry" );
     else
-      if ( libName == myLib->fileName() )
+      // TODO: this check shouldn't be necessary, plugin base names must be unique
+      if ( pRegistry->library(baseName) == myLib->fileName() )
         // set the checkbox
@@ -367,32 +363,36 @@
       myIndex = mModelPlugins->index( row, 0 );
       // its off -- see if it is loaded and if so, unload it
-      QgsDebugMsg( QString( "Checking to see if %1 is loaded" ).arg( mModelPlugins->data( myIndex, PLUGIN_LIBRARY_NAME_ROLE ).toString() ) );
-      QString pluginName = mModelPlugins->data( myIndex, PLUGIN_LIBRARY_NAME_ROLE ).toString();
-      if ( pRegistry->isPythonPlugin( pluginName ) )
+      // is loaded?
+      QString baseName = mModelPlugins->data( myIndex, PLUGIN_BASE_NAME_ROLE ).toString();
+      if ( ! pRegistry->isLoaded( baseName ) )
+        continue;
+      if ( pRegistry->isPythonPlugin( baseName ) )
         if ( mPythonUtils && mPythonUtils->isEnabled() )
-          QString packageName = pRegistry->library( pluginName );
-          mPythonUtils->unloadPlugin( packageName );
+          mPythonUtils->unloadPlugin( baseName );
-          settings.setValue( "/PythonPlugins/" + packageName, false );
+          settings.setValue( "/PythonPlugins/" + baseName, false );
       else // C++ plugin
-        QgisPlugin *plugin = pRegistry->plugin( pluginName );
+        QgisPlugin *plugin = pRegistry->plugin( baseName );
         if ( plugin )
           plugin->unload();
-        settings.setValue( "/Plugins/" + pluginName, false );
       // remove the plugin from the registry
-      pRegistry->removePlugin( pluginName );
+      pRegistry->removePlugin( baseName );
+  QgsPluginRegistry::instance()->dump();
 std::vector < QgsPluginItem > QgsPluginManager::getSelectedPlugins()
@@ -406,7 +406,8 @@
     if ( myData.isChecked() )
-      QString pluginName = mModelPlugins->item( row, 0 )->data( PLUGIN_LIBRARY_NAME_ROLE ).toString();
+      //QString baseName = mModelPlugins->item( row, 0 )->data( PLUGIN_BASE_NAME_ROLE ).toString();
+      QString pluginName = mModelPlugins->item( row, 0 )->data( Qt::DisplayRole ).toString();
       bool pythonic = false;
       QString library = mModelPlugins->item( row, 0 )->data( PLUGIN_LIBRARY_ROLE ).toString();
@@ -425,9 +426,7 @@
       //              QString fullPath=0,
       //              QString type=0,
       //              bool python=false);
-      pis.push_back( QgsPluginItem( pluginName,
-                                    mModelPlugins->item( row, 0 )->data( Qt::DisplayRole ).toString(), //display role
-                                    library, 0, pythonic ) );
+      pis.push_back( QgsPluginItem( pluginName, library, 0, pythonic ) );
@@ -472,9 +471,10 @@
     // the index row in the underlying model so we need to jump through this
     // little hoop to get the correct item
-    QStandardItem * mypItem =
-      mModelPlugins->findItems( theIndex.data( Qt ::DisplayRole ).toString() ).first();
-    QgsDetailedItemData myData =
+    QModelIndex realIndex = mModelProxy->mapToSource(theIndex);
+    QStandardItem* mypItem = mModelPlugins->itemFromIndex(realIndex);
+    QgsDetailedItemData myData =
       qVariantValue<QgsDetailedItemData>( mypItem->data( PLUGIN_DATA_ROLE ) );
Modified: trunk/qgis/src/app/qgspluginregistry.cpp
--- trunk/qgis/src/app/qgspluginregistry.cpp	2008-10-23 12:42:22 UTC (rev 9525)
+++ trunk/qgis/src/app/qgspluginregistry.cpp	2008-10-23 13:39:22 UTC (rev 9526)
@@ -44,77 +44,88 @@
   mPythonUtils = pythonUtils;
-QString QgsPluginRegistry::library( QString pluginKey )
+bool QgsPluginRegistry::isLoaded( QString key )
-  QgsPluginMetadata *pmd = plugins[pluginKey];
-  QString retval;
-  if ( pmd )
-    retval = pmd->library();
-  return retval;
+  QMap<QString, QgsPluginMetadata>::iterator it = mPlugins.find(key);
+  return (it != mPlugins.end());
-QgsPluginMetadata *QgsPluginRegistry::pluginMetadata( QString name )
+QString QgsPluginRegistry::library( QString key )
-  return plugins[name];
+  if (it == mPlugins.end())
+    return QString();
+  return it->library();
-QgisPlugin *QgsPluginRegistry::plugin( QString name )
+QgisPlugin *QgsPluginRegistry::plugin( QString key )
-  QgsPluginMetadata *pmd = plugins[name];
-  QgisPlugin *retval = 0;
-  if ( pmd )
-    retval = pmd->plugin();
-  return retval;
+    return NULL;
+  return it->plugin();
-bool QgsPluginRegistry::isPythonPlugin( QString name )
+bool QgsPluginRegistry::isPythonPlugin( QString key )
-  QgsPluginMetadata* pmd = plugins[name];
-  if ( pmd )
-    return pmd->isPython();
-  else
     return false;
+  return it->isPython();
-void QgsPluginRegistry::addPlugin( QString library, QString name, QgisPlugin * plugin )
+void QgsPluginRegistry::addPlugin( QString key, QgsPluginMetadata metadata )
-  plugins[name] = new QgsPluginMetadata( library, name, plugin );
+  mPlugins.insert(key, metadata);
-void QgsPluginRegistry::addPythonPlugin( QString packageName, QString pluginName )
+void QgsPluginRegistry::dump()
-  plugins[pluginName] = new QgsPluginMetadata( packageName, pluginName, NULL, true ); // true == python plugin
+  QgsDebugMsg("PLUGINS IN REGISTRY: key -> (name, library, isPython)");
+  for ( QMap<QString, QgsPluginMetadata>::iterator it = mPlugins.begin();
+        it != mPlugins.end();
+        it++ )
+    QgsDebugMsg(QString("PLUGIN: %1 -> (%2, %3, %4)")
+        .arg(it.key())
+        .arg(it->name())
+        .arg(it->library())
+        .arg(it->isPython()));
-void QgsPluginRegistry::removePlugin( QString name )
+void QgsPluginRegistry::removePlugin( QString key )
-  plugins.erase( name );
+  QgsDebugMsg("removing plugin: "+key);
+  if (it != mPlugins.end())
+    mPlugins.erase( it );
 void QgsPluginRegistry::unloadAll()
-  for ( std::map<QString, QgsPluginMetadata*>::iterator it = plugins.begin();
-        it != plugins.end();
         it++ )
-    if ( isPythonPlugin( it->second->name() ) )
+    if (isPythonPlugin(it.key()))
-      if ( mPythonUtils )
-        mPythonUtils->unloadPlugin( it->second->library() );
+      if (mPythonUtils)
+        mPythonUtils->unloadPlugin(it->library());
       else
         QgsDebugMsg( "warning: python utils is NULL" );
     else
-      if ( it->second->plugin() )
-        it->second->plugin()->unload();
+      if ( it->plugin() )
+        it->plugin()->unload();
       else
-        QgsDebugMsg( "warning: plugin is NULL:" + it->second->name() );
+        QgsDebugMsg("warning: plugin is NULL:" + it.key());
Modified: trunk/qgis/src/app/qgspluginregistry.h
--- trunk/qgis/src/app/qgspluginregistry.h	2008-10-23 12:42:22 UTC (rev 9525)
+++ trunk/qgis/src/app/qgspluginregistry.h	2008-10-23 13:39:22 UTC (rev 9526)
@@ -19,45 +19,63 @@
 #ifndef QGSPLUGINREGISTRY_H
 #define QGSPLUGINREGISTRY_H
-#include <map>
+#include <QMap>
 class QgsPluginMetadata;
 class QgsPythonUtils;
 class QgisPlugin;
 class QString;
 * \class QgsPluginRegistry
 * \brief This class tracks plugins that are currently loaded an provides
 * a means to fetch a pointer to a plugin and unload it
+* plugin key is:
+* - C++ plugins: base name of plugin library, e.g. libgrassplugin
+* - Python plugins: module name (directory) of plugin, e.g. plugin_installer
   public:
     //! Returns the instance pointer, creating the object on the first call
     static QgsPluginRegistry* instance();
-    //! Return the full path to the plugins library using the plugin name as a key
-    QString library( QString pluginKey );
-    //! Retrieve the metadata for a plugin by name
-    QgsPluginMetadata * pluginMetadata( QString name );
-    //! Retrieve a pointer to a loaded plugin by name
-    QgisPlugin * plugin( QString name );
+    //! Check whether this module is loaded
+    bool isLoaded( QString key );
+    //! Retrieve library of the plugin
+    QString library( QString key );
+    //! Retrieve a pointer to a loaded plugin
+    QgisPlugin * plugin( QString key );
     //! Return whether the plugin is pythonic
-    bool isPythonPlugin( QString name );
+    bool isPythonPlugin( QString key );
     //! Add a plugin to the map of loaded plugins
-    void addPlugin( QString _library, QString _name, QgisPlugin * _plugin );
-    //! Add a plugin written in python
-    void addPythonPlugin( QString packageName, QString pluginName );
+    void addPlugin( QString key, QgsPluginMetadata metadata );
     //! Remove a plugin from the list of loaded plugins
-    void removePlugin( QString name );
+    void removePlugin( QString key );
     //! Unload plugins
     void unloadAll();
     //! Save pointer for python utils (needed for unloading python plugins)
     void setPythonUtils( QgsPythonUtils* pythonUtils );
+    //! Dump list of plugins
+    void dump();
   protected:
     //! protected constructor
     QgsPluginRegistry();
   private:
     static QgsPluginRegistry* _instance;
-    std::map<QString, QgsPluginMetadata*> plugins;
+    QMap<QString, QgsPluginMetadata> mPlugins;
     QgsPythonUtils* mPythonUtils;
 #endif //QgsPluginRegistry_H
