[QGIS Commit] r9532 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Oct 24 10:33:50 EDT 2008
Author: jef
Date: 2008-10-24 10:33:50 -0400 (Fri, 24 Oct 2008)
New Revision: 9532
   trunk/qgis/src/app/qgspythondialog.cpp
   trunk/qgis/src/app/qgspythondialog.h
fix #1376
Modified: trunk/qgis/src/app/qgspythondialog.cpp
--- trunk/qgis/src/app/qgspythondialog.cpp	2008-10-24 11:49:51 UTC (rev 9531)
+++ trunk/qgis/src/app/qgspythondialog.cpp	2008-10-24 14:33:50 UTC (rev 9532)
@@ -30,6 +30,8 @@
 #endif
   mIface = pIface;
   mPythonUtils = pythonUtils;
+  pos = 0;
 QgsPythonDialog::~QgsPythonDialog()
@@ -41,12 +43,51 @@
   return text.replace( "<", "&lt;" ).replace( ">", "&gt;" );
+void QgsPythonDialog::keyPressEvent( QKeyEvent *ev )
+  switch( ev->key() )
+  case Qt::Key_Up:
+      if(pos>0)
+        if( pos==history.size() )
+          history << edtCmdLine->text();
+        else
+          history[pos] = edtCmdLine->text();
+        pos--;
+        edtCmdLine->setText(history[pos]);
+    break;
+  case Qt::Key_Down:
+      if( pos<history.size()-1 )
+        pos++;
+    break;
+  default:
+    QWidget::keyPressEvent(ev);
+    break;
 void QgsPythonDialog::on_edtCmdLine_returnPressed()
   QString command = edtCmdLine->text();
+  if( !command.isEmpty() )
+    history << command;
+    pos = history.size();
   QString output;
   // when using Py_single_input the return value will be always null
   // we're using custom hooks for output and exceptions to show output in console
   if ( mPythonUtils->runStringUnsafe( command ) )
Modified: trunk/qgis/src/app/qgspythondialog.h
--- trunk/qgis/src/app/qgspythondialog.h	2008-10-24 11:49:51 UTC (rev 9531)
+++ trunk/qgis/src/app/qgspythondialog.h	2008-10-24 14:33:50 UTC (rev 9532)
@@ -41,13 +41,17 @@
   protected:
-    void closeEvent( QCloseEvent* event );
-    void showEvent( QShowEvent* event );
+    void keyPressEvent( QKeyEvent *event );
+    void closeEvent( QCloseEvent *event );
+    void showEvent( QShowEvent *event );
   private:
     QgisInterface* mIface;
     QgsPythonUtils* mPythonUtils;
+    QStringList history;
+    int pos;
 #endif
More information about the QGIS-commit mailing list
