[QGIS Commit] r9536 - in trunk/qgis: python/core python/gui src/app src/app/legend src/core src/gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Oct 24 17:47:48 EDT 2008
Author: timlinux
Date: 2008-10-24 17:47:48 -0400 (Fri, 24 Oct 2008)
New Revision: 9536
   trunk/qgis/python/core/qgsmaprenderer.sip
   trunk/qgis/python/gui/qgsmapcanvas.sip
   trunk/qgis/src/app/legend/qgslegend.cpp
   trunk/qgis/src/app/legend/qgslegend.h
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgisapp.h
   trunk/qgis/src/app/qgsmeasuredialog.cpp
   trunk/qgis/src/app/qgsmeasuretool.cpp
   trunk/qgis/src/core/qgsmaprenderer.h
   trunk/qgis/src/core/qgsproject.cpp
   trunk/qgis/src/core/qgsproject.h
   trunk/qgis/src/gui/qgsmapcanvas.cpp
   trunk/qgis/src/gui/qgsmapcanvas.h
   trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp
API cleanups to qgis project and maprenderer classes
Modified: trunk/qgis/python/core/qgsmaprenderer.sip
--- trunk/qgis/python/core/qgsmaprenderer.sip	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/python/core/qgsmaprenderer.sip	2008-10-24 21:47:48 UTC (rev 9536)
@@ -44,7 +44,7 @@
     void setMapUnits(QGis::UnitType u);
     //! sets whether map image will be for overview
-    void setOverview(bool isOverview = true);
+    void enableOverviewMode(bool isOverview = true);
     void setOutputSize(QSize size, int dpi);
Modified: trunk/qgis/python/gui/qgsmapcanvas.sip
--- trunk/qgis/python/gui/qgsmapcanvas.sip	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/python/gui/qgsmapcanvas.sip	2008-10-24 21:47:48 UTC (rev 9536)
@@ -58,7 +58,7 @@
     void updateOverview();
-    void setOverview(QgsMapOverviewCanvas* overview);
+    void enableOverviewMode(QgsMapOverviewCanvas* overview);
     QgsMapCanvasMap* map();
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/app/legend/qgslegend.cpp	2008-10-24 21:47:48 UTC (rev 9536)
@@ -1399,7 +1399,7 @@
   mMapCanvas->updateOverview();
-void QgsLegend::setOverviewAllLayers( bool isInOverview )
+void QgsLegend::enableOverviewModeAllLayers( bool isInOverview )
   QTreeWidgetItem* theItem = firstItem();
   while ( theItem )
Modified: trunk/qgis/src/app/legend/qgslegend.h
--- trunk/qgis/src/app/legend/qgslegend.h	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/app/legend/qgslegend.h	2008-10-24 21:47:48 UTC (rev 9536)
@@ -154,7 +154,7 @@
     /**Show/remove all layer in/from overview*/
-    void setOverviewAllLayers( bool isInOverview );
+    void enableOverviewModeAllLayers( bool isInOverview );
     /**Adds an entry to mPixmapWidthValues*/
     void addPixmapWidthValue( int width );
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-10-24 21:47:48 UTC (rev 9536)
@@ -1506,8 +1506,8 @@
   connect( mStopRenderButton, SIGNAL( clicked() ), this, SLOT( stopRendering() ) );
   // Connect warning dialog from project reading
-  connect( QgsProject::instance(), SIGNAL( warnOlderProjectVersion( QString ) ),
-           this, SLOT( warnOlderProjectVersion( QString ) ) );
+  connect( QgsProject::instance(), SIGNAL( oldProjectVersionWarning( QString ) ),
+           this, SLOT( oldProjectVersionWarning( QString ) ) );
 void QgisApp::createCanvas()
@@ -1580,7 +1580,7 @@
   // add to the Panel submenu
   mPanelMenu->addAction( mOverviewDock->toggleViewAction() );
-  mMapCanvas->setOverview( overviewCanvas );
+  mMapCanvas->enableOverviewMode( overviewCanvas );
   // moved here to set anti aliasing to both map canvas and overview
   QSettings mySettings;
@@ -3469,7 +3469,7 @@
   if ( mMapLegend )
-    mMapLegend->setOverviewAllLayers( true );
+    mMapLegend->enableOverviewModeAllLayers( true );
   // notify the project we've made a change
@@ -3481,7 +3481,7 @@
   if ( mMapLegend )
-    mMapLegend->setOverviewAllLayers( false );
+    mMapLegend->enableOverviewModeAllLayers( false );
@@ -5627,7 +5627,7 @@
 // Slot that gets called when the project file was saved with an older
 // version of QGIS
-void QgisApp::warnOlderProjectVersion( QString oldVersion )
+void QgisApp::oldProjectVersionWarning( QString oldVersion )
   QSettings settings;
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/app/qgisapp.h	2008-10-24 21:47:48 UTC (rev 9536)
@@ -548,7 +548,7 @@
     void showPythonDialog();
     //! Shows a warning when an old project file is read.
-    void warnOlderProjectVersion( QString );
+    void oldProjectVersionWarning( QString );
     //! Toggle map tips on/off
     void toggleMapTips();
Modified: trunk/qgis/src/app/qgsmeasuredialog.cpp
--- trunk/qgis/src/app/qgsmeasuredialog.cpp	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/app/qgsmeasuredialog.cpp	2008-10-24 21:47:48 UTC (rev 9536)
@@ -88,14 +88,14 @@
     QList<QgsPoint> tmpPoints = mTool->points();
     tmpPoints.append( point );
-    double area = mTool->canvas()->mapRenderer()->distArea()->measurePolygon( tmpPoints );
+    double area = mTool->canvas()->mapRenderer()->distanceArea()->measurePolygon( tmpPoints );
     editTotal->setText( formatArea( area ) );
   else if ( !mMeasureArea && mTool->points().size() > 0 )
     QgsPoint p1( mTool->points().last() ), p2( point );
-    double d = mTool->canvas()->mapRenderer()->distArea()->measureLine( p1, p2 );
+    double d = mTool->canvas()->mapRenderer()->distanceArea()->measureLine( p1, p2 );
     QTreeWidgetItem *item = mTable->topLevelItem( mTable->topLevelItemCount() - 1 );
     item->setText( 0, QLocale::system().toString( d, 'f', 2 ) );
     editTotal->setText( formatDistance( mTotal + d ) );
@@ -107,7 +107,7 @@
   int numPoints = mTool->points().size();
   if ( mMeasureArea && numPoints > 2 )
-    double area = mTool->canvas()->mapRenderer()->distArea()->measurePolygon( mTool->points() );
+    double area = mTool->canvas()->mapRenderer()->distanceArea()->measurePolygon( mTool->points() );
   else if ( !mMeasureArea && numPoints > 1 )
@@ -116,7 +116,7 @@
     QgsPoint p1 = mTool->points()[last], p2 = mTool->points()[last+1];
     mTotal += d;
     editTotal->setText( formatDistance( mTotal ) );
Modified: trunk/qgis/src/app/qgsmeasuretool.cpp
--- trunk/qgis/src/app/qgsmeasuretool.cpp	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/app/qgsmeasuretool.cpp	2008-10-24 21:47:48 UTC (rev 9536)
@@ -67,7 +67,7 @@
   // If we suspect that they have data that is projected, yet the
   // map CRS is set to a geographic one, warn them.
-  if ( mCanvas->mapRenderer()->distArea()->geographic() &&
+  if ( mCanvas->mapRenderer()->distanceArea()->geographic() &&
        ( mCanvas->extent().height() > 360 ||
          mCanvas->extent().width() > 720 ) )
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/core/qgsmaprenderer.h	2008-10-24 21:47:48 UTC (rev 9536)
@@ -82,12 +82,12 @@
     void updateScale();
     //! Return the measuring object
-    QgsDistanceArea* distArea() { return mDistArea; }
+    QgsDistanceArea* distanceArea() { return mDistArea; }
     QGis::UnitType mapUnits() const;
     void setMapUnits( QGis::UnitType u );
-    void setOverview( bool isOverview = true ) { mOverview = isOverview; }
+    void enableOverviewMode( bool isOverview = true ) { mOverview = isOverview; }
     void setOutputSize( QSize size, int dpi );
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/core/qgsproject.cpp	2008-10-24 21:47:48 UTC (rev 9536)
@@ -797,8 +797,8 @@
     QgsProjectFileTransform projectFile( *doc, fileVersion );
-    emit warnOlderProjectVersion( fileVersion.text() );
-    QgsDebugMsg( "Emitting warnOlderProjectVersion(oldVersion)." );
+    emit oldProjectVersionWarning( fileVersion.text() );
+    QgsDebugMsg( "Emitting oldProjectVersionWarning(oldVersion)." );
     projectFile.dump();
Modified: trunk/qgis/src/core/qgsproject.h
--- trunk/qgis/src/core/qgsproject.h	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/core/qgsproject.h	2008-10-24 21:47:48 UTC (rev 9536)
@@ -264,7 +264,7 @@
     void writeProject( QDomDocument & );
     //! emitted when an old project file is read.
   private:
Modified: trunk/qgis/src/gui/qgsmapcanvas.cpp
--- trunk/qgis/src/gui/qgsmapcanvas.cpp	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/gui/qgsmapcanvas.cpp	2008-10-24 21:47:48 UTC (rev 9536)
@@ -306,7 +306,7 @@
 } // addLayer
-void QgsMapCanvas::setOverview( QgsMapOverviewCanvas* overview )
+void QgsMapCanvas::enableOverviewMode( QgsMapOverviewCanvas* overview )
   if ( mMapOverview )
Modified: trunk/qgis/src/gui/qgsmapcanvas.h
--- trunk/qgis/src/gui/qgsmapcanvas.h	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/gui/qgsmapcanvas.h	2008-10-24 21:47:48 UTC (rev 9536)
@@ -110,7 +110,7 @@
-    void setOverview( QgsMapOverviewCanvas* overview );
+    void enableOverviewMode( QgsMapOverviewCanvas* overview );
Modified: trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp
--- trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp	2008-10-24 21:20:16 UTC (rev 9535)
+++ trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp	2008-10-24 21:47:48 UTC (rev 9536)
@@ -72,7 +72,7 @@
   mPanningWidget = new QgsPanningWidget( this );
   mMapRenderer = new QgsMapRenderer;
-  mMapRenderer->setOverview();
+  mMapRenderer->enableOverviewMode();
   setBackgroundColor( palette().window().color() );
More information about the QGIS-commit mailing list
