[QGIS Commit] r9551 - in trunk/qgis/src: app gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Oct 27 13:35:28 EDT 2008
Author: homann
Date: 2008-10-27 13:35:28 -0400 (Mon, 27 Oct 2008)
New Revision: 9551
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsclipboard.cpp
   trunk/qgis/src/app/qgsclipboard.h
   trunk/qgis/src/gui/qgsmapcanvas.cpp
   trunk/qgis/src/gui/qgsmapcanvas.h
Fixes #929. Only enable copy/cut action when there is a selection, and only enable paste action when there is something in the clipboard.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-10-26 05:33:50 UTC (rev 9550)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-10-27 17:35:28 UTC (rev 9551)
@@ -1498,6 +1498,8 @@
   connect( mMapCanvas, SIGNAL( scaleChanged( double ) ), this, SLOT( showScale( double ) ) );
   connect( mMapCanvas, SIGNAL( scaleChanged( double ) ), this, SLOT( updateMouseCoordinatePrecision() ) );
   connect( mMapCanvas, SIGNAL( mapToolSet( QgsMapTool * ) ), this, SLOT( mapToolChanged( QgsMapTool * ) ) );
+  connect( mMapCanvas, SIGNAL( selectionChanged( QgsMapLayer * ) ),
+           this, SLOT( activateDeactivateLayerRelatedActions( QgsMapLayer * ) ) );
   connect( mRenderSuppressionCBox, SIGNAL( toggled( bool ) ), mMapCanvas, SLOT( setRenderFlag( bool ) ) );
@@ -5029,17 +5031,18 @@
   /***********Vector layers****************/
   if ( layer->type() == QgsMapLayer::VectorLayer )
+    QgsVectorLayer* vlayer = dynamic_cast<QgsVectorLayer*>( layer );
+    const QgsVectorDataProvider* dprovider = vlayer->dataProvider();
+    bool layerHasSelection = ( vlayer->selectedFeatureCount() != 0 );
     mActionSelect->setEnabled( true );
     mActionIdentify->setEnabled( true );
     mActionZoomActualSize->setEnabled( false );
     mActionOpenTable->setEnabled( true );
     mActionLayerSaveAs->setEnabled( true );
     mActionLayerSelectionSaveAs->setEnabled( true );
-    mActionCopyFeatures->setEnabled( true );
+    mActionCopyFeatures->setEnabled( layerHasSelection );
-    const QgsVectorLayer* vlayer = dynamic_cast<const QgsVectorLayer*>( layer );
-    const QgsVectorDataProvider* dprovider = vlayer->dataProvider();
     if ( !vlayer->isEditable() && mMapCanvas->mapTool() && mMapCanvas->mapTool()->isEditTool() )
       mMapCanvas->setMapTool( mNonEditMapTool );
@@ -5052,7 +5055,7 @@
         mActionToggleEditing->setEnabled( true );
         mActionToggleEditing->setChecked( vlayer->isEditable() );
-        mActionPasteFeatures->setEnabled( vlayer->isEditable() );
+        mActionPasteFeatures->setEnabled( vlayer->isEditable() and not clipboard()->empty());
       else
@@ -5063,8 +5066,8 @@
       //does provider allow deleting of features?
       if ( vlayer->isEditable() && dprovider->capabilities() & QgsVectorDataProvider::DeleteFeatures )
-        mActionDeleteSelected->setEnabled( true );
-        mActionCutFeatures->setEnabled( true );
+        mActionDeleteSelected->setEnabled( layerHasSelection );
+        mActionCutFeatures->setEnabled( layerHasSelection );
       else
Modified: trunk/qgis/src/app/qgsclipboard.cpp
--- trunk/qgis/src/app/qgsclipboard.cpp	2008-10-26 05:33:50 UTC (rev 9550)
+++ trunk/qgis/src/app/qgsclipboard.cpp	2008-10-27 17:35:28 UTC (rev 9551)
@@ -135,3 +135,7 @@
   QgsDebugMsg( "inserted " + feature.geometry()->exportToWkt() );
+bool QgsClipboard::empty()
+  return mFeatureClipboard.empty();
Modified: trunk/qgis/src/app/qgsclipboard.h
--- trunk/qgis/src/app/qgsclipboard.h	2008-10-26 05:33:50 UTC (rev 9550)
+++ trunk/qgis/src/app/qgsclipboard.h	2008-10-27 17:35:28 UTC (rev 9551)
@@ -84,6 +84,11 @@
     void insert( QgsFeature& feature );
+     *  Returns true if the internal clipboard is empty, else false.
+    bool empty();
   private:
     /** QGIS-internal vector feature clipboard.
Modified: trunk/qgis/src/gui/qgsmapcanvas.cpp
--- trunk/qgis/src/gui/qgsmapcanvas.cpp	2008-10-26 05:33:50 UTC (rev 9550)
+++ trunk/qgis/src/gui/qgsmapcanvas.cpp	2008-10-27 17:35:28 UTC (rev 9551)
@@ -259,7 +259,7 @@
       QgsVectorLayer *isVectLyr = dynamic_cast < QgsVectorLayer * >( currentLayer );
       if ( isVectLyr )
-        disconnect( currentLayer, SIGNAL( selectionChanged() ), this, SLOT( refresh() ) );
+        disconnect( currentLayer, SIGNAL( selectionChanged() ), this, SLOT( selectionChangedSlot() ) );
@@ -275,7 +275,7 @@
       if ( isVectLyr )
-        connect( currentLayer, SIGNAL( selectionChanged() ), this, SLOT( refresh() ) );
+        connect( currentLayer, SIGNAL( selectionChanged() ), this, SLOT(  selectionChangedSlot() ) );
@@ -1278,3 +1278,11 @@
   refresh();
+void QgsMapCanvas::selectionChangedSlot()
+  // Find out which layer it was that sent the signal.
+  QgsMapLayer * layer = ( QgsMapLayer * )QObject::sender();
+  emit selectionChanged( layer );
+  refresh();
Modified: trunk/qgis/src/gui/qgsmapcanvas.h
--- trunk/qgis/src/gui/qgsmapcanvas.h	2008-10-26 05:33:50 UTC (rev 9550)
+++ trunk/qgis/src/gui/qgsmapcanvas.h	2008-10-27 17:35:28 UTC (rev 9551)
@@ -240,6 +240,9 @@
     /**Repaints the canvas map*/
     void refresh();
+    //! Receives signal about selection change, and pass it on with layer info
+    void selectionChangedSlot();
     //! Save the convtents of the map canvas to disk as an image
     void saveAsImage( QString theFileName, QPixmap * QPixmap = 0, QString = "PNG" );
@@ -301,8 +304,11 @@
     void keyReleased( QKeyEvent * e );
     //! Emit map tool changed event
-    void mapToolSet( QgsMapTool *tool );
+    void mapToolSet( QgsMapTool * tool );
+    //! Emit map tool changed event
+    void selectionChanged( QgsMapLayer * layer );
   protected:
     //! Overridden key press event
     void keyPressEvent( QKeyEvent * e );
More information about the QGIS-commit mailing list
