[QGIS Commit] r9558 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Oct 31 16:06:55 EDT 2008
Author: timlinux
Date: 2008-10-31 16:06:55 -0400 (Fri, 31 Oct 2008)
New Revision: 9558
   trunk/qgis/python/plugins/plugin_installer/CMakeLists.txt
   trunk/qgis/python/plugins/plugin_installer/__init__.py
   trunk/qgis/python/plugins/plugin_installer/guibase.py
   trunk/qgis/python/plugins/plugin_installer/guibase.ui
   trunk/qgis/python/plugins/plugin_installer/installer_data.py
   trunk/qgis/python/plugins/plugin_installer/installer_gui.py
   trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
   trunk/qgis/python/plugins/plugin_installer/repositorybase.py
   trunk/qgis/python/plugins/plugin_installer/repositorybase.ui
   trunk/qgis/python/plugins/plugin_installer/resources.qrc
   trunk/qgis/python/plugins/plugin_installer/resources_rc.py
   trunk/qgis/python/plugins/plugin_installer/unzip.py
Plugin installer updates from Borys
Modified: trunk/qgis/python/plugins/plugin_installer/CMakeLists.txt
--- trunk/qgis/python/plugins/plugin_installer/CMakeLists.txt	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/CMakeLists.txt	2008-10-31 20:06:55 UTC (rev 9558)
@@ -1,27 +1,27 @@
 #TODO: Need to configure cmake to run pyrcc4 and pyuic4 as required when the resource
 #      file or the ui change
 SET(INSTALLER_FILES
-fetchingbase.py
+fetchingbase.py
 fetchingbase.ui
-guibase.py
-guibase.ui
+guibase.py
+guibase.ui
 __init__.py
-installer_data.py
-installer_gui.py
+installer_data.py
+installer_gui.py
 installer_plugin.py
-installingbase.py
-installingbase.ui
-pluginerrorbase.py
-pluginerrorbase.ui
+installingbase.py
+installingbase.ui
+pluginerrorbase.py
+pluginerrorbase.ui
-repositorybase.py
-repositorybase.ui
+repositorybase.py
+repositorybase.ui
-resources_rc.py
-unzip.py
+resources.qrc
+resources_rc.py
+unzip.py
 INSTALL(FILES ${INSTALLER_FILES} DESTINATION ${QGIS_DATA_DIR}/python/plugins/plugin_installer)
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py	2008-10-31 20:06:55 UTC (rev 9558)
@@ -1,5 +1,5 @@
-Copyright (C) 2008 Matthew Perry
+Copyright (C) 2007-2008 Matthew Perry
 Copyright (C) 2008 Borys Jurgiel
@@ -20,7 +20,7 @@
   return "perrygeo, borysiasty"
 def version():
-  return "Version 0.06.2"
+  return "Version 0.07.2"
 def classFactory(iface):
   from installer_plugin import InstallerPlugin
Modified: trunk/qgis/python/plugins/plugin_installer/guibase.py
--- trunk/qgis/python/plugins/plugin_installer/guibase.py	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/guibase.py	2008-10-31 20:06:55 UTC (rev 9558)
@@ -175,7 +175,7 @@
     def retranslateUi(self, QgsPluginInstallerDialog):
         QgsPluginInstallerDialog.setWindowTitle(QtGui.QApplication.translate("QgsPluginInstallerDialog", "QGIS Python Plugin Installer", None, QtGui.QApplication.UnicodeUTF8))
-        QgsPluginInstallerDialog.setWhatsThis(QtGui.QApplication.translate("QgsPluginInstallerDialog", "QGIS Plugin Installer", None, QtGui.QApplication.UnicodeUTF8))
+        QgsPluginInstallerDialog.setWhatsThis(QtGui.QApplication.translate("QgsPluginInstallerDialog", "QGIS Python Plugin Installer", None, QtGui.QApplication.UnicodeUTF8))
         self.label_5.setText(QtGui.QApplication.translate("QgsPluginInstallerDialog", "Filter:", None, QtGui.QApplication.UnicodeUTF8))
         self.lineFilter.setToolTip(QtGui.QApplication.translate("QgsPluginInstallerDialog", "Display only plugins containing this word in their metadata", None, QtGui.QApplication.UnicodeUTF8))
         self.lineFilter.setWhatsThis(QtGui.QApplication.translate("QgsPluginInstallerDialog", "Display only plugins containing this word in their metadata", None, QtGui.QApplication.UnicodeUTF8))
Modified: trunk/qgis/python/plugins/plugin_installer/guibase.ui
--- trunk/qgis/python/plugins/plugin_installer/guibase.ui	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/guibase.ui	2008-10-31 20:06:55 UTC (rev 9558)
@@ -17,7 +17,7 @@
    <iconset resource="resources.qrc" >:/plugins/installer/qgis-icon.png</iconset>
   </property>
   <property name="whatsThis" >
-   <string>QGIS Plugin Installer</string>
+   <string>QGIS Python Plugin Installer</string>
   </property>
   <layout class="QGridLayout" >
    <item row="0" column="0" >
Modified: trunk/qgis/python/plugins/plugin_installer/installer_data.py
--- trunk/qgis/python/plugins/plugin_installer/installer_data.py	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/installer_data.py	2008-10-31 20:06:55 UTC (rev 9558)
@@ -1,6 +1,5 @@
 # -*- coding: utf-8 -*-
-qgis_plugins.py
@@ -12,23 +11,29 @@
  *   (at your option) any later version.                                   *
+ This file contains some additional quote marks (for example in the lines 2 and 20), they are
+ for compatibility with lupdate, which doesn't properly recognize the comments in Python.
+ The use of lupdate instead of pylupdate is forced by integration with rest of QGIS files,
+ which are written mainly in C++. After editing this file make sure that lupdate and pylupdate
+ find the same number of strings and balance the quotemarks if doesn't.
 from PyQt4.QtCore import *
 from PyQt4.QtXml import QDomDocument
-from PyQt4.QtNetwork import QHttp, QNetworkProxy
+from PyQt4.QtNetwork import *
 from qgis.core import *
 from unzip import unzip
 Data structure:
 mRepositories = dict of dicts: {repoName : {"url" string,
                                             "enabled" bool,
                                             "valid" bool,
-                                            "QHttp" QHttp,
-                                            "Relay" Relay, # Relay object for transmitting signals from QHttp with adding the repoName information
+                                            "QPHttp" QPHttp,
+                                            "Relay" Relay, # Relay object for transmitting signals from QPHttp with adding the repoName information
                                             "xmlData" QDomDocument,
                                             "state" int,   (0 - disabled, 1-loading, 2-loaded ok, 3-error (to be retried), 4-rejected)
                                             "error" QString}}
@@ -45,25 +50,57 @@
                                 "repository" string,
                                 "localdir" string,
                                 "read-only" boolean}}
+QGIS_VER = 1
+try:
+  if str(QGis.qgisVersion)[0] == "0":
+    QGIS_VER = 0
+except:
+  pass
 reposGroup = "/Qgis/plugin-repos"
 settingsGroup = "/Qgis/plugin-installer"
 seenPluginGroup = "/Qgis/plugin-seen"
 # knownRepos: (name, url for QGIS 0.x, url for QGIS 1.x, possible depreciated url, another possible depreciated url)
 knownRepos = [("Official QGIS Repository","http://spatialserver.net/cgi-bin/pyqgis_plugin.rb","http://spatialserver.net/cgi-bin/pyqgis_plugin.rb","",""),
-              ("Carson Farmer's Repository","http://www.ftools.ca/cfarmerQgisRepo_0.xx.xml","","http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml",""),
-              ("Barry Rowlingson's Repository","http://www.maths.lancs.ac.uk/~rowlings/Qgis/Plugins/plugins.xml","","",""),
+              ("Carson Farmer's Repository","http://www.ftools.ca/cfarmerQgisRepo_0.xx.xml","http://www.ftools.ca/cfarmerQgisRepo.xml", "http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml",""),
               ("Borys Jurgiel's Repository","http://bwj.aster.net.pl/qgis-oldapi/plugins.xml","http://bwj.aster.net.pl/qgis/plugins.xml","",""),
               ("Faunalia Repository","http://faunalia.it/qgis/plugins.xml","http://faunalia.it/qgis/1.x/plugins.xml","","")]
+# --- class QPHttp  ----------------------------------------------------------------------- #
+# --- It's a temporary workaround for broken proxy handling in Qt ------------------------- #
+class QPHttp(QHttp):
+  def __init__(self,*args):
+    QHttp.__init__(self,*args)
+    settings = QSettings()
+    settings.beginGroup("proxy")
+    if settings.value("/proxyEnabled").toBool():
+      self.proxy=QNetworkProxy()
+      self.proxy.setType(QNetworkProxy.HttpProxy)
+      self.proxy.setHostName(settings.value("/proxyHost").toString())
+      self.proxy.setPort(settings.value("/proxyPort").toUInt()[0])
+      self.proxy.setUser(settings.value("/proxyUser").toString())
+      self.proxy.setPassword(settings.value("/proxyPassword").toString())
+      self.setProxy(self.proxy)
+    settings.endGroup()
+    return None
+# --- /class QPHttp  ---------------------------------------------------------------------- #
 # --- class Relay  ----------------------------------------------------------------------- #
 class Relay(QObject):
-  """ Relay object for transmitting signals from QHttp with adding the repoName information """
+  """ Relay object for transmitting signals from QPHttp with adding the repoName information """
   def __init__(self, key):
     QObject.__init__(self)
@@ -88,38 +125,41 @@
 # --- class Repositories ----------------------------------------------------------------- #
 class Repositories(QObject):
+  """ A dict-like class for handling repositories data """
   def __init__(self):
     self.mRepositories = {}
     self.httpId = {}   # {httpId : repoName}
-    self.QGISver = int(str(QGis.QGIS_VERSION)[0])
   def addKnownRepos(self):
+    """ add known 3rd party repositories to QSettings """
     presentURLs = []
     for i in self.all().values():
       presentURLs += [str(i["url"])]
     for i in knownRepos:
-      if i[self.QGISver+1] and presentURLs.count(i[self.QGISver+1]) == 0:
+      if i[QGIS_VER+1] and presentURLs.count(i[QGIS_VER+1]) == 0:
         settings.beginGroup(reposGroup)
         repoName = QString(i[0])
         if self.all().has_key(repoName):
           repoName = repoName + "(2)"
         # add to settings
-        settings.setValue(repoName+"/url", QVariant(i[self.QGISver+1]))
+        settings.setValue(repoName+"/url", QVariant(i[QGIS_VER+1]))
         settings.setValue(repoName+"/enabled", QVariant(True))
   def all(self):
+    """ return dict of all repositories """
     return self.mRepositories
   def allEnabled(self):
+    """ return dict of all enabled and valid repositories """
     repos = {}
     for i in self.mRepositories:
       if self.mRepositories[i]["enabled"] and self.mRepositories[i]["valid"]:
@@ -129,6 +169,7 @@
   def allUnavailable(self):
+    """ return dict of all unavailable repositories """
     repos = {}
       if self.mRepositories[i]["enabled"] and self.mRepositories[i]["valid"] and self.mRepositories[i]["state"] == 3:
@@ -138,11 +179,13 @@
   def setRepositoryData(self,reposName, key, value):
+    """ write data to the mRepositories dict """
     self.mRepositories[reposName][key] = value
-  def rename(self,oldName, newName):
+  def rename(self, oldName, newName):
+    """ rename repository key """
     if oldName == newName:
       return
     self.mRepositories[newName] = self.mRepositories[oldName]
@@ -151,12 +194,14 @@
   def checkingOnStart(self):
+    """ return true if checking for news and updates is enabled """
-    return settings.value(settingsGroup+"/checkOnStart", QVariant(True)).toBool()
+    return settings.value(settingsGroup+"/checkOnStart", QVariant(False)).toBool()
   def setCheckingOnStart(self, state):
+    """ set state of checking for news and updates """
     settings.setValue(settingsGroup+"/checkOnStart", QVariant(state))
@@ -169,15 +214,15 @@
     # first, update the QSettings repositories if needed
     if len(settings.childGroups()) == 0: # add the default repository when there isn't any
-      settings.setValue(knownRepos[0][0]+"/url", QVariant(knownRepos[0][self.QGISver+1]))
+      settings.setValue(knownRepos[0][0]+"/url", QVariant(knownRepos[0][QGIS_VER+1]))
     else: # else update invalid urls
       for key in settings.childGroups():
         url = settings.value(key+"/url", QVariant()).toString()
         allOk = True
         for repo in knownRepos:
-          if repo[3] == url or repo[4] == url or (repo[self.QGISver+1] != url and repo[int(not self.QGISver)+1] == url):
-            if repo[self.QGISver+1]: #update the URL
-              settings.setValue(key+"/url", QVariant(repo[self.QGISver+1]))
+          if repo[3] == url or repo[4] == url or (repo[QGIS_VER+1] != url and repo[int(not QGIS_VER)+1] == url):
+            if repo[QGIS_VER+1]: #update the URL
+              settings.setValue(key+"/url", QVariant(repo[QGIS_VER+1]))
               settings.setValue(key+"/valid", QVariant(True))
               allOk = False
             else: # mark as invalid
@@ -191,7 +236,7 @@
       self.mRepositories[key]["url"] = settings.value(key+"/url", QVariant()).toString()
       self.mRepositories[key]["enabled"] = settings.value(key+"/enabled", QVariant(True)).toBool()
       self.mRepositories[key]["valid"] = settings.value(key+"/valid", QVariant(True)).toBool()
-      self.mRepositories[key]["QHttp"] = QHttp()
+      self.mRepositories[key]["QPHttp"] = QPHttp()
       self.mRepositories[key]["Relay"] = Relay(key)
       self.mRepositories[key]["xmlData"] = QBuffer()
       self.mRepositories[key]["state"] = 0
@@ -201,20 +246,22 @@
   def requestFetching(self,key):
+    """ start fetching the repository given by key """
     self.mRepositories[key]["state"] = 1
     url = QUrl(self.mRepositories[key]["url"])
     path = QString(url.toPercentEncoding(url.path(), "!$&'()*+,;=:@/"))
-    self.mRepositories[key]["QHttp"] = QHttp(url.host())
-    self.connect(self.mRepositories[key]["QHttp"], SIGNAL("requestFinished (int, bool)"), self.xmlDownloaded)
-    self.connect(self.mRepositories[key]["QHttp"], SIGNAL("stateChanged ( int )"), self.mRepositories[key]["Relay"].stateChanged)
-    self.connect(self.mRepositories[key]["QHttp"], SIGNAL("dataReadProgress ( int , int )"), self.mRepositories[key]["Relay"].dataReadProgress)
+    self.mRepositories[key]["QPHttp"] = QPHttp(url.host())
+    self.connect(self.mRepositories[key]["QPHttp"], SIGNAL("requestFinished (int, bool)"), self.xmlDownloaded)
+    self.connect(self.mRepositories[key]["QPHttp"], SIGNAL("stateChanged ( int )"), self.mRepositories[key]["Relay"].stateChanged)
+    self.connect(self.mRepositories[key]["QPHttp"], SIGNAL("dataReadProgress ( int , int )"), self.mRepositories[key]["Relay"].dataReadProgress)
     self.connect(self.mRepositories[key]["Relay"], SIGNAL("anythingChanged(QString, int, int)"), self, SIGNAL("anythingChanged (QString, int, int)"))
-    i = self.mRepositories[key]["QHttp"].get(path, self.mRepositories[key]["xmlData"])
+    i = self.mRepositories[key]["QPHttp"].get(path, self.mRepositories[key]["xmlData"])
     self.httpId[i] = key
   def fetchingInProgress(self):
+    """ return true if fetching repositories is still in progress """
     for key in self.mRepositories:
       if self.mRepositories[key]["state"] == 1:
         return True
@@ -223,18 +270,20 @@
   def killConnection(self, key):
-    if self.mRepositories[key]["QHttp"].state():
-      self.mRepositories[key]["QHttp"].abort()
+    """ kill the fetching on demand """
+    if self.mRepositories[key]["QPHttp"].state():
+      self.mRepositories[key]["QPHttp"].abort()
   def xmlDownloaded(self,nr,state):
+    """ populate the plugins object with the fetched data """
     if not self.httpId.has_key(nr):
       return
     reposName = self.httpId[nr]
     if state:                             # fetching failed
       self.mRepositories[reposName]["state"] =  3
-      self.mRepositories[reposName]["error"] = self.mRepositories[reposName]["QHttp"].errorString()
+      self.mRepositories[reposName]["error"] = self.mRepositories[reposName]["QPHttp"].errorString()
       #print "Repository fetching failed! " , reposName , str(self.mRepositories[reposName]["error"])
     else:
       repoData = self.mRepositories[reposName]["xmlData"]
@@ -283,6 +332,7 @@
 # --- class Plugins ---------------------------------------------------------------------- #
 class Plugins(QObject):
+  """ A dict-like class for handling plugins data """
   def __init__(self):
@@ -291,11 +341,13 @@
   def all(self):
+    """ return all plugins """
     return self.mPlugins
   def keyByUrl(self, name):
+    """ return plugin key by given url """
     plugins = [i for i in self.mPlugins if self.mPlugins[i]["url"] == name]
     if plugins:
       return plugins[0]
@@ -304,6 +356,7 @@
   def setPluginData(self, pluginName, key, value):
+    """ write data to the mPlugins dict """
     self.mPlugins[pluginName][key] = value
@@ -315,6 +368,7 @@
   def normalizeVersion(self,ver):
+    """ remove the prefix from given version string """
     if not ver:
       return QString()
     if ver.toUpper().left(7) == "VERSION":
@@ -328,6 +382,7 @@
   def compareVersions(self,a,b):
+    """ compare two plugin versions """
     def classify(s):
       if s in [".","-","_"," "]:
@@ -353,20 +408,23 @@
       # check if the matter is easy solvable:
       if s1 == s2:
         return 0
-      # try to compare as numeric values:
-      try:
-        if s1[0] == '0' or s2[0] == '0':
-          s1 = '0.' + s1
-          s2 = '0.' + s2
-        if float(s1) == float(s2):
-          return 0
-        elif float(s1) > float(s2):
-          return 1
-        else:
-          return 2
-      except:
-        pass
-      # set ALPHA < BETA < RC < FINAL < ANYTHING_ELSE
+      if not s1:
+        return 2
+      if not s2:
+        return 1
+      # try to compare as numeric values (but only if the first character is not 0):
+      if s1[0] != '0' and s2[0] != '0':
+        try:
+          if float(s1) == float(s2):
+            return 0
+          elif float(s1) > float(s2):
+            return 1
+          else:
+            return 2
+        except:
+          pass
+      # if the strings aren't numeric or start from 0, compare them as a strings:
+      # but first, set ALPHA < BETA < RC < FINAL < ANYTHING_ELSE
       if s1 == 'FINAL':
         s1 = 'Z' + s1
       elif not s1 in ['ALPHA','BETA','RC']:
@@ -411,6 +469,7 @@
   def addPlugin(self, plugins):
+    """ add a plugin (first from given) to the mPlugins dict """
     key = plugins.keys()[0]
     plugin = plugins[key]
     plugin["version_avail"] = self.normalizeVersion(QString(plugin["version_avail"]))
@@ -421,11 +480,13 @@
   def remove(self, key):
+    """ remove given plugin from the mPlugins dict """
     del self.mPlugins[key]
   def updatePlugin(self, key, readOnly):
+    """ The mPlugins should contain available plugins first. Now, add installed one (add when not present, update if present) """
     try:
       exec("import "+ key)
       try:
@@ -460,7 +521,7 @@
       path = QgsApplication.pkgDataPath()
     else:
       path = QgsApplication.qgisSettingsDirPath()
-    path = QDir.cleanPath(unicode(path,"utf-8") + "python/plugins/" + key)
+    path = QDir.cleanPath(unicode(path) + "python/plugins/" + key)
     normVer = self.normalizeVersion(QString(ver))
     plugin = {
         "name"          : nam,
@@ -514,9 +575,10 @@
   def getAllInstalled(self):
     """ update the mPlugins dict with alredy installed plugins """
+    # ' PLEASE DO NOT REMOVE THIS QUOTE MARK - it is a balance for compatibility with lupdate
     # first, try to add the read-only plugins...
     try:
-      pluginDir = QDir.cleanPath(unicode(QgsApplication.pkgDataPath(),'utf-8') + "/python/plugins")
+      pluginDir = QDir.cleanPath(unicode(QgsApplication.pkgDataPath()) + "/python/plugins")
       pluginDir = QDir(pluginDir)
       pluginDir.setFilter(QDir.AllDirs)
     except:
@@ -527,7 +589,7 @@
         self.updatePlugin(key, True)
     # ...then try to add locally installed ones
     try:
-      pluginDir = QDir.cleanPath(unicode(QgsApplication.qgisSettingsDirPath(),'utf-8') + "/python/plugins")
+      pluginDir = QDir.cleanPath(unicode(QgsApplication.qgisSettingsDirPath()) + "/python/plugins")
     except:
@@ -562,6 +624,7 @@
   def isThereAnythingNew(self):
+    """ return true if an upgradeable or new plugin detected """
     for i in self.mPlugins.values():
       if i["status"] in ["upgradeable","new"]:
         return True
@@ -570,6 +633,7 @@
   def workarounds(self):
+    """ workarounds for particular plugins with wrong metadata """
     if self.mPlugins.has_key("postgps") and self.mPlugins["postgps"]["version_avail"] == "0.2":
       self.mPlugins["postgps"]["version_avail"] = "0.01"
     if self.mPlugins.has_key("select") and self.mPlugins["select"]["version_avail"] == "0.1":
Modified: trunk/qgis/python/plugins/plugin_installer/installer_gui.py
--- trunk/qgis/python/plugins/plugin_installer/installer_gui.py	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/installer_gui.py	2008-10-31 20:06:55 UTC (rev 9558)
@@ -1,6 +1,6 @@
@@ -11,7 +11,15 @@
 from PyQt4.QtGui import *
 from qgis.core import QgsApplication, QgsContextHelp
@@ -30,7 +38,7 @@
     result = QString()
     if not QFile(path).exists():
       result = QCoreApplication.translate("QgsPluginInstaller","Plugin directory doesn't exist: ") + path
-    elif QFile(path).remove(): # if it's only link, just remove it without resolving.
+    elif QFile(path).remove(): # if it is only link, just remove it without resolving.
       #print " Link removing successfull: %s" % path
       pass
     else:
@@ -62,6 +70,9 @@
 # --- class QgsPluginInstallerFetchingDialog --------------------------------------------------------------- #
+""" " C++ style header for compability with lupdate
+QgsPluginInstallerFetchingDialog::foo(){
 class QgsPluginInstallerFetchingDialog(QDialog, Ui_QgsPluginInstallerFetchingDialog):
   def __init__(self, parent):
@@ -86,7 +97,7 @@
   def displayState(self,key,state,state2=None):
-    messages=[self.tr("Done"),self.tr("Resolving host name..."),self.tr("Connecting..."),self.tr("Host connected. Sending request..."),self.tr("Downloading data..."),self.tr("Idle"),self.tr("Closing connection..."),self.tr("Error")]
+    messages=[self.tr("Success"),self.tr("Resolving host name..."),self.tr("Connecting..."),self.tr("Host connected. Sending request..."),self.tr("Downloading data..."),self.tr("Idle"),self.tr("Closing connection..."),self.tr("Error")]
     message = messages[state]
     if state2:
       message += " (%s%%)" % state2
@@ -107,6 +118,7 @@
       self.displayState(repoName,7)
     if not repositories.fetchingInProgress():
       self.close()
+# } - C++ style footer for compability with lupdate
 # --- /class QgsPluginInstallerFetchingDialog -------------------------------------------------------------- #
@@ -114,6 +126,9 @@
 # --- class QgsPluginInstallerRepositoryDialog ------------------------------------------------------------- #
+QgsPluginInstallerRepositoryDialog::foo(){
 class QgsPluginInstallerRepositoryDialog(QDialog, Ui_QgsPluginInstallerRepositoryDetailsDialog):
   def __init__(self, parent=None):
@@ -128,6 +143,7 @@
   def textChanged(self, string):
     enable = (self.editName.text().count() > 0 and self.editURL.text().count() > 0)
     self.buttonBox.button(QDialogButtonBox.Ok).setEnabled(enable)
 # --- /class QgsPluginInstallerRepositoryDialog ------------------------------------------------------------ #
@@ -135,6 +151,9 @@
 # --- class QgsPluginInstallerInstallingDialog --------------------------------------------------------------- #
+QgsPluginInstallerInstallingDialog::foo(){
 class QgsPluginInstallerInstallingDialog(QDialog, Ui_QgsPluginInstallerInstallingDialog):
   def __init__(self, parent, plugin):
@@ -148,13 +167,13 @@
     self.connect(self.buttonBox, SIGNAL("clicked(QAbstractButton*)"), self.abort)
     url = QUrl(plugin["url"])
-    path = QString(url.toPercentEncoding(url.path(), "!$&'()*+,;=:@/"))
+    path = QString(url.toPercentEncoding(url.path(), "!$&'()*+,;=:/@"))
     fileName = plugin["filename"]
     #print "Retrieving from %s" % path
     tmpDir = QDir.tempPath()
     tmpPath = QDir.cleanPath(tmpDir+"/"+fileName)
     self.file = QFile(tmpPath)
-    self.http = QHttp(url.host())
+    self.http = QPHttp(url.host())
     self.connect(self.http, SIGNAL("stateChanged ( int )"), self.stateChanged)
     self.connect(self.http, SIGNAL("dataReadProgress ( int , int )"), self.readProgress)
     self.connect(self.http, SIGNAL("requestFinished (int, bool)"), self.requestFinished)
@@ -195,6 +214,10 @@
     # make sure that the parent directory exists
     if not QDir(pluginDir).exists():
       QDir().mkpath(pluginDir)
+    # if the target directory already exists as a link, remove the link without resolving:
+    QFile(pluginDir+QString(QDir.separator())+self.plugin["localdir"]).remove()
     #print "Extracting to plugin directory (%s)" % pluginDir
     try:
       un = unzip()
@@ -221,6 +244,7 @@
     self.http.abort()
     self.mResult = self.tr("Aborted by user")
     self.reject()
 # --- /class QgsPluginInstallerPluginErrorDialog ------------------------------------------------------------- #
@@ -228,21 +252,29 @@
 # --- class QgsPluginInstallerPluginErrorDialog -------------------------------------------------------------- #
+QgsPluginInstallerPluginErrorDialog::foo(){
 class QgsPluginInstallerPluginErrorDialog(QDialog, Ui_QgsPluginInstallerPluginErrorDialog):
   def __init__(self, parent, errorMessage):
     QDialog.__init__(self, parent)
     self.setupUi(self)
     if not errorMessage:
-      errorMessage = self.tr("No error message received. Try to restart QGIS and ensure the plugin isn't installed under different name. If it is, contact the plugin author and submit this issue, please.")
+      errorMessage = self.tr("No error message received. Try to restart QGIS and ensure the plugin isn't installed under a different name. If it is, contact the plugin author and submit this issue, please.")
     self.textBrowser.setText(errorMessage)
 # --- class QgsPluginInstallerDialog ------------------------------------------------------------------------- #
+QgsPluginInstallerDialog::foo(){
 class QgsPluginInstallerDialog(QDialog, Ui_QgsPluginInstallerDialog):
   def __init__(self, parent, fl):
@@ -296,7 +328,9 @@
       for key in repositories.allUnavailable():
         QMessageBox.warning(self, self.tr("QGIS Python Plugin Installer"), self.tr("Error reading repository: ") + key + "\n" + repositories.all()[key]["error"])
+    plugins.getAllInstalled()
   def populateMostWidgets(self):
     self.comboFilter1.clear()
@@ -331,8 +365,8 @@
     # filling the status filter comboBox
     self.comboFilter2.clear()
     self.comboFilter2.addItem(self.tr("any status"))
-    self.comboFilter2.addItem(self.tr("not installed"))
-    self.comboFilter2.addItem(self.tr("installed"))
+    self.comboFilter2.addItem(self.tr("not installed", "plural"))
+    self.comboFilter2.addItem(self.tr("installed", "plural"))
     if plugins.isThereAnythingNew():
       self.comboFilter2.addItem(self.tr("upgradeable and news"))
@@ -376,22 +410,22 @@
             "installed" : self.tr("This plugin is installed"),
             "upgradeable" : self.tr("This plugin is installed, but there is an updated version available"),
             "orphan" : self.tr("This plugin is installed, but I can't find it in any enabled repository"),
-            "new" : self.tr("This plugin is not installed and is seen first time"),
+            "new" : self.tr("This plugin is not installed and is seen for the first time"),
             "newer" : self.tr("This plugin is installed and is newer than its version available in a repository"),
             "invalid" : self.tr("This plugin seems to be invalid or have unfulfilled dependencies\nIt has been installed, but can't be loaded")}
-    status ={"not installed" : self.tr("not installed"),
-            "installed" : self.tr("installed"),
-            "upgradeable" : self.tr("upgradeable"),
-            "orphan" : self.tr("installed"),
-            "new" : self.tr("new!"),
-            "newer" : self.tr("installed"),
-            "invalid" : self.tr("invalid")}
+    status ={"not installed" : self.tr("not installed", "singular"),
+            "installed" : self.tr("installed", "singular"),
+            "upgradeable" : self.tr("upgradeable", "singular"),
+            "orphan" : self.tr("installed", "singular"),
+            "new" : self.tr("new!", "singular"),
+            "newer" : self.tr("installed", "singular"),
+            "invalid" : self.tr("invalid", "singular")}
     order = ["invalid","upgradeable","new","not installed","installed","orphan","newer"]
     def addItem(p):
       if self.filterCheck(p):
         statusTip = descrip[p["status"]]
         if p["read-only"]:
-          statusTip += "\n" + self.tr("Note that it's installed in the read-only location and you can't uninstall it")
+          statusTip += "\n" + self.tr("Note that it's a core plugin and I can't uninstall it")
         if p["status"] == "upgradeable":
           ver = p["version_inst"] + " -> " + p["version_avail"]
         elif p["status"] ==  "newer":
@@ -405,15 +439,15 @@
         elif p["status"] in ["not installed", "new"]:
           vd = self.tr("available version") + ": " + p["version_avail"]
         elif p["status"] == "installed":
-          vd = self.tr("installed version") + ": " + p["version_inst"] + "\n" + self.tr("That's the newest available version.")
+          vd = self.tr("installed version") + ": " + p["version_inst"] + "\n" + self.tr("That's the newest available version")
         elif p["status"] == "orphan":
-          vd = self.tr("installed version") + ": " + p["version_inst"] + "\n" + self.tr("There is no version available for download.")
+          vd = self.tr("installed version") + ": " + p["version_inst"] + "\n" + self.tr("There is no version available for download")
         else:
           vd = ""
         if p["status"] == "invalid":
           p["desc_local"] = self.tr("This plugin seems to be invalid or have unfulfilled dependencies")
           p["desc_repo"] = self.tr("This plugin seems to be invalid or have unfulfilled dependencies\nIt has been installed, but can't be loaded")
-        if p["status"] == "orphan":
+        if not p["repository"]:
           repository = self.tr("only locally available")
         else:
           repository = p["repository"]
@@ -467,7 +501,7 @@
     """ the pluginsTree has been clicked """
     buttons={"not installed":(True,False,self.tr("Install plugin")),
             "installed":(True,True,self.tr("Reinstall plugin")),
-            "upgradeable":(True,True,self.tr("Upgrade plugin",)),
+            "upgradeable":(True,True,self.tr("Upgrade plugin")),
             "orphan":(False,True,self.tr("Install/upgrade plugin")),
             "new":(True, False,self.tr("Install plugin")),
             "newer":(True,True,self.tr("Downgrade plugin")),
@@ -528,11 +562,9 @@
           if result:
             QMessageBox.warning(self, self.tr("Plugin uninstall failed"), result)
         plugins.updatePlugin(key, False)
-        self.populateMostWidgets()
         self.populatePluginTree()
         return
     QMessageBox.information(self, infoString[0], infoString[1])
@@ -546,7 +578,6 @@
     plugin = plugins.all()[key]
     if not plugin:
       return
     warning = self.tr("Are you sure you want to uninstall the plugin ") + plugin["name"] + "?"
     if plugin["status"] == "orphan":
       warning += "\n\n"+self.tr("Warning: this plugin isn't available in any accessible repository!")
@@ -563,7 +594,7 @@
         exec ("del sys.modules[%s]" % plugin["localdir"])
       except:
         pass
-      if plugin["status"] == "orphan":
+      if not plugin["repository"]:
         plugins.remove(key)
       else:
         plugins.setPluginData(key, "status", "not installed")
@@ -586,9 +617,8 @@
   def addKnownRepositories(self):
     """ update list of known repositories - in the future it will be replaced with an online fetching """
     #print "add known repositories"
-    message = "You are going to add some plugin repositories neither authorized nor supported by the QGIS team, however provided by folks associated with us.\n"
-    message += "Plugin authors generally make efforts to make their works useful and safe, but we can't assume any responsibility for them. FEEL WARNED!"
-    if QMessageBox.question(self, self.tr("QGIS Python Plugin Installer"), self.tr(message), QMessageBox.Ok, QMessageBox.Abort) == QMessageBox.Ok:
+    message = self.tr("You are going to add some plugin repositories neither authorized nor supported by the QGIS team, however provided by folks associated with us. Plugin authors generally make efforts to make their works useful and safe, but we can't assume any responsibility for them. FEEL WARNED!")
+    if QMessageBox.question(self, self.tr("QGIS Python Plugin Installer"), message, QMessageBox.Ok, QMessageBox.Abort) == QMessageBox.Ok:
       repositories.addKnownRepos()
       # refresh lists and populate widgets
       QApplication.setOverrideCursor(Qt.WaitCursor)
@@ -704,4 +734,5 @@
     """ update the list of seen plugins before exit (both 'done' and 'x' buttons emit 'reject' signal) """
     plugins.updateSeenPluginsList()
     QDialog.reject(self)
 # --- /class QgsPluginInstallerDialog ------------------------------------------------------------------------ #
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py	2008-10-31 20:06:55 UTC (rev 9558)
@@ -1,6 +1,6 @@
@@ -11,7 +11,15 @@
@@ -20,34 +28,34 @@
 import resources_rc
 class InstallerPlugin:
   def __init__(self, iface):
     self.iface = iface
-    if str(QGis.QGIS_VERSION)[0] == "0": # old plugin API
+    if QGIS_VER: # new plugin API
+      self.mainWindow = self.iface.mainWindow
+    else: # old plugin API
       self.mainWindow = self.iface.getMainWindow
-    else: # new plugin API
-      self.mainWindow = self.iface.mainWindow
   def initGui(self):
     """ create action that will start plugin window and then add it to menu """
-    self.action = QAction(QIcon(":/plugins/installer/PluginInstaller.png"), QCoreApplication.translate("QgsPluginInstaller","Fetch Python Plugins..."), self.mainWindow())
+    self.action = QAction(QIcon(":/plugins/installer/plugin_installer.png"), QCoreApplication.translate("QgsPluginInstaller","Fetch Python Plugins..."), self.mainWindow())
     self.action.setWhatsThis(QCoreApplication.translate("QgsPluginInstaller","Install more plugins from remote repositories"))
     self.action.setStatusTip(QCoreApplication.translate("QgsPluginInstaller","Install more plugins from remote repositories"))
+      nextAction = self.iface.actionManagePlugins()
+      self.iface.pluginMenu().insertAction(nextAction,self.action)
       nextAction = self.mainWindow().menuBar().actions()[4].menu().actions()[1]
       self.mainWindow().menuBar().actions()[4].menu().insertAction(nextAction,self.action)
-    else:
-      nextAction = self.iface.actionManagePlugins()  #actionPluginSeparator1()
-      self.iface.pluginMenu().insertAction(nextAction,self.action)
     QObject.connect(self.action, SIGNAL("activated()"), self.run)
     self.statusLabel = None
     repositories.load()
     plugins.clear()
-    if repositories.checkingOnStart():
+    if repositories.checkingOnStart() and repositories.allEnabled():
       self.statusLabel = QLabel(QCoreApplication.translate("QgsPluginInstaller","Looking for new plugins..."), self.mainWindow().statusBar())
       self.mainWindow().statusBar().insertPermanentWidget(0,self.statusLabel)
       QObject.connect(self.statusLabel, SIGNAL("linkActivated (QString)"), self.run)
@@ -112,11 +120,13 @@
     QApplication.restoreOverrideCursor()
-    # display error messages for every unavailable reposioty, except the case if all repositories are unavailable!
+    # display an error message for every unavailable reposioty, except the case if all repositories are unavailable!
     if repositories.allUnavailable() and repositories.allUnavailable() != repositories.allEnabled():
         QMessageBox.warning(self.mainWindow(), QCoreApplication.translate("QgsPluginInstaller","QGIS Python Plugin Installer"), QCoreApplication.translate("QgsPluginInstaller","Error reading repository:") + u' %s\n%s' % (key,repositories.all()[key]["error"]))
     flags = Qt.WindowTitleHint | Qt.WindowSystemMenuHint | Qt.WindowMaximizeButtonHint
     self.guiDlg = QgsPluginInstallerDialog(self.mainWindow(),flags)
     self.guiDlg.show()
Modified: trunk/qgis/python/plugins/plugin_installer/repositorybase.py
--- trunk/qgis/python/plugins/plugin_installer/repositorybase.py	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/repositorybase.py	2008-10-31 20:06:55 UTC (rev 9558)
@@ -2,7 +2,7 @@
 # Form implementation generated from reading ui file 'repositorybase.ui'
-# Created: Fri Sep 12 19:21:37 2008
+# Created: Wed Sep 17 14:22:09 2008
 #      by: PyQt4 UI code generator 4.3
 # WARNING! All changes made in this file will be lost!
@@ -118,6 +118,5 @@
         self.checkBoxEnabled.setToolTip(QtGui.QApplication.translate("QgsPluginInstallerRepositoryDetailsDialog", "Enable or disable the repository (disabled repositories will be omitted)", None, QtGui.QApplication.UnicodeUTF8))
         self.checkBoxEnabled.setWhatsThis(QtGui.QApplication.translate("QgsPluginInstallerRepositoryDetailsDialog", "Enable or disable the repository (disabled repositories will be omitted)", None, QtGui.QApplication.UnicodeUTF8))
         self.checkBoxEnabled.setText(QtGui.QApplication.translate("QgsPluginInstallerRepositoryDetailsDialog", "Enabled", None, QtGui.QApplication.UnicodeUTF8))
-        self.labelInfo.setText(QtGui.QApplication.translate("QgsPluginInstallerRepositoryDetailsDialog", "[place for a warning message]", None, QtGui.QApplication.UnicodeUTF8))
 import resources_rc
Modified: trunk/qgis/python/plugins/plugin_installer/repositorybase.ui
--- trunk/qgis/python/plugins/plugin_installer/repositorybase.ui	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/repositorybase.ui	2008-10-31 20:06:55 UTC (rev 9558)
@@ -187,7 +187,7 @@
       <enum>QFrame::NoFrame</enum>
      </property>
      <property name="text" >
-      <string>[place for a warning message]</string>
+      <string/>
      </property>
     </widget>
    </item>
Modified: trunk/qgis/python/plugins/plugin_installer/resources.qrc
--- trunk/qgis/python/plugins/plugin_installer/resources.qrc	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/resources.qrc	2008-10-31 20:06:55 UTC (rev 9558)
@@ -1,6 +1,6 @@
 <RCC>
     <qresource prefix="/plugins/installer">
-        <file>PluginInstaller.png</file>
+        <file>plugin_installer.png</file>
         <file>qgis-icon.png</file>
         <file>repoDisabled.png</file>
         <file>repoUnavailable.png</file>
Modified: trunk/qgis/python/plugins/plugin_installer/resources_rc.py
--- trunk/qgis/python/plugins/plugin_installer/resources_rc.py	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/resources_rc.py	2008-10-31 20:06:55 UTC (rev 9558)
@@ -2,7 +2,7 @@
 # Resource object code
-# Created: pt. wrz 12 19:21:37 2008
+# Created: sob. wrz 13 00:34:16 2008
 #      by: The Resource Compiler for PyQt (Qt v4.3.2)
@@ -162,58 +162,6 @@
 \xae\xad\x5d\xf1\x5c\xcf\x3f\x9c\xe8\xa1\xcd\x18\x70\x3e\x28\xa8\
 \x1e\x34\x9b\x57\xff\xfb\x3f\xc8\x9f\xa2\x63\x68\x95\x98\xd0\x55\
 \x56\x00\x00\x00\x00\x49\x45\x4e\x44\xae\x42\x60\x82\
-\x00\x00\x03\x11\
-\x89\
-\x50\x4e\x47\x0d\x0a\x1a\x0a\x00\x00\x00\x0d\x49\x48\x44\x52\x00\
-\x00\x00\x10\x00\x00\x00\x10\x08\x06\x00\x00\x00\x1f\xf3\xff\x61\
-\x00\x00\x00\x06\x62\x4b\x47\x44\x00\xff\x00\xff\x00\xff\xa0\xbd\
-\xa7\x93\x00\x00\x00\x09\x70\x48\x59\x73\x00\x00\x0b\x12\x00\x00\
-\x0b\x12\x01\xd2\xdd\x7e\xfc\x00\x00\x00\x07\x74\x49\x4d\x45\x07\
-\xd4\x0c\x0e\x14\x29\x37\x87\x80\x5f\xe3\x00\x00\x02\x9e\x49\x44\
-\x41\x54\x78\xda\x95\x92\x5b\x48\x53\x01\x18\xc7\xff\x3b\x3b\xd3\
-\xb9\xa6\x39\x2f\x9b\x97\xb4\x24\x13\xa7\xb9\x12\xb1\xde\x7a\xb1\
-\x0c\xc4\x4c\x34\x08\xc5\x34\x8d\x0a\x0c\x34\x7b\x29\x84\x8c\x22\
-\x33\xd0\x61\x3d\x16\x51\x12\x2a\x09\xf9\x50\xa1\xf8\x30\x12\xba\
-\x4b\x37\x9b\x28\xa3\x79\x69\xa6\xa6\xe7\xec\xd2\xe6\xe6\x39\x67\
-\x3b\x97\x5e\x5a\x99\x5b\x50\xdf\xdb\xf7\x7d\xfc\x7f\x1f\xfc\xbf\
-\x3f\xf0\x1f\x15\x73\x1e\xd9\x9a\x2e\x3c\x24\x33\xb1\x3b\x38\x23\
-\xfe\x45\x18\xdd\x82\x54\x4d\x27\x6e\xcb\xb5\x98\x10\x56\x50\xc2\
-\x4f\x43\x0c\xee\xc8\x70\x82\x95\x95\x9e\x84\xd8\x58\xa9\x66\xca\
-\x32\xb9\x43\x4e\xb2\xfc\x3b\xdb\x1c\xd5\xd4\x3f\x5c\x44\xe8\x24\
-\x52\xa0\x41\x01\xb0\xff\xf5\x1a\xc3\xf4\x95\xf0\x82\xd1\xf1\x78\
-\xa4\xdc\xab\x89\x53\xd6\xd4\x9d\xd4\x1f\x7d\x69\xad\x10\x53\x8c\
-\xa4\xa4\x3e\x8e\x6f\x11\x7b\xf1\x02\x80\x3a\xac\x78\x75\xf5\x8e\
-\x21\x20\x5c\x63\xe6\x1c\xc7\xa4\xba\x53\xd9\x23\x00\x54\x64\x06\
-\x48\x7d\xa7\x7a\x5e\xd7\x46\x4a\xcd\x17\x0d\xd3\x91\x5a\x79\x01\
-\x00\x79\x58\x0f\x94\xca\xef\xed\x94\xcf\xaa\xf4\xad\x05\x30\x6b\
-\xf5\xbc\x01\xc0\xa8\x8e\xa0\x79\x59\xf4\xa6\x1d\x8a\xc8\x44\x7d\
-\x7d\xf6\xf6\xc6\x86\xbc\xfd\xc0\x6f\x0f\x7e\x01\x86\x86\xce\xa8\
-\x78\x19\x5d\xcc\x70\x7e\xf8\x39\x01\xd4\x0a\x63\x53\x37\x42\x4f\
-\xc4\xe3\x6a\x16\x95\xb0\x76\xba\x72\x27\xd4\xd1\x0a\xa4\x67\xa8\
-\xcb\x00\x44\x86\x00\x72\x73\xa5\x24\x2e\xe0\x89\x08\xf6\x7e\x41\
-\x08\xc8\x93\xd0\x23\xd2\x60\x0f\xeb\xf4\xc3\xc9\xc9\x9b\x00\x00\
-\x2a\x95\x3c\x05\x80\x2a\x04\x60\x36\x3b\xdd\x3c\x38\x09\x00\x08\
-\x42\x86\x2d\x45\x9a\x73\x07\xb2\xf3\x0a\x8b\xb8\x9c\xc1\xda\xea\
-\x82\x31\x99\x4c\x06\x00\xb0\xd3\x1c\x0b\x40\x0a\x01\x94\x95\x3d\
-\x70\xd9\x5d\xac\x19\x00\xa2\x54\x24\x0e\x1a\xb6\xe6\x47\x8c\x8a\
-\x96\xa6\xaa\x9c\xd2\xd8\x44\xf2\x0a\x2f\x8a\xe0\x38\x01\x1f\xde\
-\xd2\x13\x00\x7c\xe1\x4c\x14\x5f\x3f\xa7\xba\x58\x86\x07\x41\xc8\
-\x30\x69\x59\x72\xf6\xdf\x9a\xac\xcd\x48\x8f\xeb\x76\x31\x54\x94\
-\x3f\x20\xe0\xd5\xb3\xe5\x35\xd3\xf0\xc2\x3d\x00\xfe\x10\x00\xb9\
-\x0d\xc4\x59\xb3\x69\xa9\xf3\xd1\x47\x87\x9d\x66\x50\x55\x96\x45\
-\x1a\x76\x25\xba\xb5\xf1\x9a\x48\x00\x98\x9a\x70\x06\x6e\x5c\x37\
-\x1b\xdd\x6e\x6e\xb4\xa3\xa3\xea\xcf\x37\x46\x55\x42\xa1\x2c\x46\
-\xbb\x40\xa3\x77\xf0\xd3\xe7\xb8\x13\x97\x9f\x7e\x99\x18\x77\xcc\
-\xb4\xb6\xed\x19\x98\xb1\xb1\x0d\x82\x28\xc2\xeb\xe5\x7d\x4e\xbb\
-\xd0\xc7\xb2\x77\x5b\xd7\x58\x7b\x43\xb8\x1c\x29\x00\x68\x55\x15\
-\xb8\x1f\xb9\x0f\xdd\x3f\xd3\x96\xf6\xc4\x54\x7a\xc1\x4a\x55\x4b\
-\x56\xaa\x5a\x72\xf9\x5a\xfc\xbd\x03\xe5\x76\x85\x82\x28\x0c\x8a\
-\xe4\xeb\x3d\x00\xe0\x53\xe4\x63\x41\xa4\x01\x61\x11\x63\x00\x3c\
-\x8b\x5f\x99\x71\x8f\xdb\x9f\x6a\x9b\x5d\x8d\x19\x1c\xb4\xcc\xdf\
-\x34\xbe\xbf\xe4\x71\xfb\x4d\xeb\xc3\xb4\xb1\x08\xb9\x0e\x9b\x37\
-\xcc\x48\x00\x1a\x00\x31\x00\x64\xeb\x17\x3f\x00\x3d\x4b\x18\xbb\
-\x0e\x57\x7e\xbc\x00\x00\x00\x00\x49\x45\x4e\x44\xae\x42\x60\x82\
 \x00\x00\x13\x3e\
 \x89\
@@ -524,6 +472,58 @@
 \x2e\x17\x0c\xed\x7d\x65\xf2\x6f\x00\x36\x2d\x10\x9f\x17\x4e\x01\
 \xc4\x00\x4e\x03\x38\xf2\x9f\x01\x00\x7c\x97\x4a\xe1\x34\x7b\x75\
 \xb6\x00\x00\x00\x00\x49\x45\x4e\x44\xae\x42\x60\x82\
+\x00\x00\x03\x11\
+\x89\
+\x50\x4e\x47\x0d\x0a\x1a\x0a\x00\x00\x00\x0d\x49\x48\x44\x52\x00\
+\x00\x00\x10\x00\x00\x00\x10\x08\x06\x00\x00\x00\x1f\xf3\xff\x61\
+\x00\x00\x00\x06\x62\x4b\x47\x44\x00\xff\x00\xff\x00\xff\xa0\xbd\
+\xa7\x93\x00\x00\x00\x09\x70\x48\x59\x73\x00\x00\x0b\x12\x00\x00\
+\x0b\x12\x01\xd2\xdd\x7e\xfc\x00\x00\x00\x07\x74\x49\x4d\x45\x07\
+\xd4\x0c\x0e\x14\x29\x37\x87\x80\x5f\xe3\x00\x00\x02\x9e\x49\x44\
+\x41\x54\x78\xda\x95\x92\x5b\x48\x53\x01\x18\xc7\xff\x3b\x3b\xd3\
+\xb9\xa6\x39\x2f\x9b\x97\xb4\x24\x13\xa7\xb9\x12\xb1\xde\x7a\xb1\
+\x0c\xc4\x4c\x34\x08\xc5\x34\x8d\x0a\x0c\x34\x7b\x29\x84\x8c\x22\
+\x33\xd0\x61\x3d\x16\x51\x12\x2a\x09\xf9\x50\xa1\xf8\x30\x12\xba\
+\x4b\x37\x9b\x28\xa3\x79\x69\xa6\xa6\xe7\xec\xd2\xe6\xe6\x39\x67\
+\x3b\x97\x5e\x5a\x99\x5b\x50\xdf\xdb\xf7\x7d\xfc\x7f\x1f\xfc\xbf\
+\x3f\xf0\x1f\x15\x73\x1e\xd9\x9a\x2e\x3c\x24\x33\xb1\x3b\x38\x23\
+\xfe\x45\x18\xdd\x82\x54\x4d\x27\x6e\xcb\xb5\x98\x10\x56\x50\xc2\
+\x4f\x43\x0c\xee\xc8\x70\x82\x95\x95\x9e\x84\xd8\x58\xa9\x66\xca\
+\x32\xb9\x43\x4e\xb2\xfc\x3b\xdb\x1c\xd5\xd4\x3f\x5c\x44\xe8\x24\
+\x52\xa0\x41\x01\xb0\xff\xf5\x1a\xc3\xf4\x95\xf0\x82\xd1\xf1\x78\
+\xa4\xdc\xab\x89\x53\xd6\xd4\x9d\xd4\x1f\x7d\x69\xad\x10\x53\x8c\
+\xa4\xa4\x3e\x8e\x6f\x11\x7b\xf1\x02\x80\x3a\xac\x78\x75\xf5\x8e\
+\x21\x20\x5c\x63\xe6\x1c\xc7\xa4\xba\x53\xd9\x23\x00\x54\x64\x06\
+\x48\x7d\xa7\x7a\x5e\xd7\x46\x4a\xcd\x17\x0d\xd3\x91\x5a\x79\x01\
+\x00\x79\x58\x0f\x94\xca\xef\xed\x94\xcf\xaa\xf4\xad\x05\x30\x6b\
+\xf5\xbc\x01\xc0\xa8\x8e\xa0\x79\x59\xf4\xa6\x1d\x8a\xc8\x44\x7d\
+\x7d\xf6\xf6\xc6\x86\xbc\xfd\xc0\x6f\x0f\x7e\x01\x86\x86\xce\xa8\
+\x78\x19\x5d\xcc\x70\x7e\xf8\x39\x01\xd4\x0a\x63\x53\x37\x42\x4f\
+\xc4\xe3\x6a\x16\x95\xb0\x76\xba\x72\x27\xd4\xd1\x0a\xa4\x67\xa8\
+\xcb\x00\x44\x86\x00\x72\x73\xa5\x24\x2e\xe0\x89\x08\xf6\x7e\x41\
+\x08\xc8\x93\xd0\x23\xd2\x60\x0f\xeb\xf4\xc3\xc9\xc9\x9b\x00\x00\
+\x2a\x95\x3c\x05\x80\x2a\x04\x60\x36\x3b\xdd\x3c\x38\x09\x00\x08\
+\x42\x86\x2d\x45\x9a\x73\x07\xb2\xf3\x0a\x8b\xb8\x9c\xc1\xda\xea\
+\x82\x31\x99\x4c\x06\x00\xb0\xd3\x1c\x0b\x40\x0a\x01\x94\x95\x3d\
+\x70\xd9\x5d\xac\x19\x00\xa2\x54\x24\x0e\x1a\xb6\xe6\x47\x8c\x8a\
+\x96\xa6\xaa\x9c\xd2\xd8\x44\xf2\x0a\x2f\x8a\xe0\x38\x01\x1f\xde\
+\xd2\x13\x00\x7c\xe1\x4c\x14\x5f\x3f\xa7\xba\x58\x86\x07\x41\xc8\
+\x30\x69\x59\x72\xf6\xdf\x9a\xac\xcd\x48\x8f\xeb\x76\x31\x54\x94\
+\x3f\x20\xe0\xd5\xb3\xe5\x35\xd3\xf0\xc2\x3d\x00\xfe\x10\x00\xb9\
+\x0d\xc4\x59\xb3\x69\xa9\xf3\xd1\x47\x87\x9d\x66\x50\x55\x96\x45\
+\x1a\x76\x25\xba\xb5\xf1\x9a\x48\x00\x98\x9a\x70\x06\x6e\x5c\x37\
+\x1b\xdd\x6e\x6e\xb4\xa3\xa3\xea\xcf\x37\x46\x55\x42\xa1\x2c\x46\
+\xbb\x40\xa3\x77\xf0\xd3\xe7\xb8\x13\x97\x9f\x7e\x99\x18\x77\xcc\
+\xb4\xb6\xed\x19\x98\xb1\xb1\x0d\x82\x28\xc2\xeb\xe5\x7d\x4e\xbb\
+\xd0\xc7\xb2\x77\x5b\xd7\x58\x7b\x43\xb8\x1c\x29\x00\x68\x55\x15\
+\xb8\x1f\xb9\x0f\xdd\x3f\xd3\x96\xf6\xc4\x54\x7a\xc1\x4a\x55\x4b\
+\x56\xaa\x5a\x72\xf9\x5a\xfc\xbd\x03\xe5\x76\x85\x82\x28\x0c\x8a\
+\xe4\xeb\x3d\x00\xe0\x53\xe4\x63\x41\xa4\x01\x61\x11\x63\x00\x3c\
+\x8b\x5f\x99\x71\x8f\xdb\x9f\x6a\x9b\x5d\x8d\x19\x1c\xb4\xcc\xdf\
+\x34\xbe\xbf\xe4\x71\xfb\x4d\xeb\xc3\xb4\xb1\x08\xb9\x0e\x9b\x37\
+\xcc\x48\x00\x1a\x00\x31\x00\x64\xeb\x17\x3f\x00\x3d\x4b\x18\xbb\
+\x0e\x57\x7e\xbc\x00\x00\x00\x00\x49\x45\x4e\x44\xae\x42\x60\x82\
 qt_resource_name = "\
@@ -549,24 +549,24 @@
 \x00\x72\
 \x00\x65\x00\x70\x00\x6f\x00\x55\x00\x6e\x00\x61\x00\x76\x00\x61\x00\x69\x00\x6c\x00\x61\x00\x62\x00\x6c\x00\x65\x00\x2e\x00\x70\
 \x00\x6e\x00\x67\
+\x00\x14\
+\x04\x88\x2d\xc7\
+\x00\x70\
+\x00\x6c\x00\x75\x00\x67\x00\x69\x00\x6e\x00\x5f\x00\x69\x00\x6e\x00\x73\x00\x74\x00\x61\x00\x6c\x00\x6c\x00\x65\x00\x72\x00\x2e\
+\x00\x70\x00\x6e\x00\x67\
 \x00\x0d\
 \x09\xa1\x91\x67\
 \x00\x71\
 \x00\x67\x00\x69\x00\x73\x00\x2d\x00\x69\x00\x63\x00\x6f\x00\x6e\x00\x2e\x00\x70\x00\x6e\x00\x67\
-\x00\x13\
-\x06\x9f\x85\x27\
-\x00\x50\
-\x00\x6c\x00\x75\x00\x67\x00\x69\x00\x6e\x00\x49\x00\x6e\x00\x73\x00\x74\x00\x61\x00\x6c\x00\x6c\x00\x65\x00\x72\x00\x2e\x00\x70\
-\x00\x6e\x00\x67\
 qt_resource_struct = "\
 \x00\x00\x00\x00\x00\x02\x00\x00\x00\x01\x00\x00\x00\x01\
 \x00\x00\x00\x00\x00\x02\x00\x00\x00\x01\x00\x00\x00\x02\
 \x00\x00\x00\x14\x00\x02\x00\x00\x00\x05\x00\x00\x00\x03\
+\x00\x00\x00\xa6\x00\x00\x00\x00\x00\x01\x00\x00\x09\x11\
 \x00\x00\x00\x2c\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\
-\x00\x00\x00\xc6\x00\x00\x00\x00\x00\x01\x00\x00\x0c\x26\
-\x00\x00\x00\xa6\x00\x00\x00\x00\x00\x01\x00\x00\x09\x11\
+\x00\x00\x00\xd4\x00\x00\x00\x00\x00\x01\x00\x00\x1c\x53\
 \x00\x00\x00\x7a\x00\x00\x00\x00\x00\x01\x00\x00\x05\x7f\
 \x00\x00\x00\x52\x00\x00\x00\x00\x00\x01\x00\x00\x01\xe6\
Modified: trunk/qgis/python/plugins/plugin_installer/unzip.py
--- trunk/qgis/python/plugins/plugin_installer/unzip.py	2008-10-31 12:09:27 UTC (rev 9557)
+++ trunk/qgis/python/plugins/plugin_installer/unzip.py	2008-10-31 20:06:55 UTC (rev 9558)
@@ -26,7 +26,7 @@
     def extract(self, file, dir):
         if not dir.endswith(':') and not os.path.exists(dir):
-            os.mkdir(dir)
+            os.makedirs(dir)
         zf = zipfile.ZipFile(file)
More information about the QGIS-commit mailing list
