[QGIS Commit] r9251 - in trunk/qgis: python/core src/app
src/core/raster
svn_qgis at osgeo.org
Tue Sep 2 19:29:44 EDT 2008
Author: ersts
Date: 2008-09-02 19:29:44 -0400 (Tue, 02 Sep 2008)
New Revision: 9251
trunk/qgis/python/core/qgsrasterlayer.sip
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/core/raster/qgscolorrampshader.cpp
trunk/qgis/src/core/raster/qgscolorrampshader.h
trunk/qgis/src/core/raster/qgsrasterbandstats.h
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.h
-Cleaning out references to obsolete class QgsColorTable
-Changed how Paletted bands are drawn as gray scale
-Added cache to QgsColorRampShader to speed up rendering time when using large color tables (still poor)
-Fixed small bug in rendering the palette as a pixmap
Modified: trunk/qgis/python/core/qgsrasterlayer.sip
--- trunk/qgis/python/core/qgsrasterlayer.sip 2008-09-02 21:55:15 UTC (rev 9250)
+++ trunk/qgis/python/core/qgsrasterlayer.sip 2008-09-02 23:29:44 UTC (rev 9251)
@@ -100,7 +100,7 @@
void drawThumbnail(QPixmap * theQPixmap);
/** \brief Get an 8x8 pixmap of the colour palette. If the layer has no palette a white pixmap will be returned. */
- QPixmap getPaletteAsPixmap();
+ QPixmap getPaletteAsPixmap(int theBand=1);
/** \brief This is called when the view on the rasterlayer needs to be refreshed (redrawn).
@@ -498,7 +498,7 @@
* \param band number
* \return pointer to color table
- QgsColorTable *colorTable ( int theBandNoInt );
+ QList<QgsColorRampShader::ColorRampItem>* getColorTable ( int theBandNoInt );
protected:
/** reads vector layer specific state from project file Dom node.
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-09-02 21:55:15 UTC (rev 9250)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-09-02 23:29:44 UTC (rev 9251)
@@ -828,7 +828,7 @@
pixmapLegend->repaint();
//set the palette pixmap
- pixmapPalette->setPixmap( mRasterLayer->getPaletteAsPixmap() );
+ pixmapPalette->setPixmap( mRasterLayer->getPaletteAsPixmap(mRasterLayer->getRasterBandNumber(mRasterLayer->getGrayBandName())));
pixmapPalette->setScaledContents( true );
pixmapPalette->repaint();
@@ -1971,7 +1971,7 @@
== QgsRasterLayer::PALETTE ) //paletted layers have hard coded color entries
QPolygonF myPolygon;
- QgsColorTable *myColorTable = mRasterLayer->colorTable( 1 );
+ QgsColorRampShader* myRasterShaderFunction = ( QgsColorRampShader* )mRasterLayer->getRasterShader()->getRasterShaderFunction();
QgsDebugMsg( "Making paletted image histogram....computing band stats" );
QgsDebugMsg( QString( "myLastBinWithData = %1" ).arg( myLastBinWithData ) );
@@ -2002,8 +2002,7 @@
QgsDebugMsg( QString( "myMiddle = %1" ).arg( myMiddle ) );
- bool found = myColorTable->color( myMiddle, &c1, &c2, &c3 );
- if ( !found )
+ if ( myRasterShaderFunction->generateShadedValue(myMiddle, &c1, &c2, &c3))
QgsDebugMsg( "Color not found" );
c1 = c2 = c3 = 180; // grey
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.cpp
--- trunk/qgis/src/core/raster/qgscolorrampshader.cpp 2008-09-02 21:55:15 UTC (rev 9250)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.cpp 2008-09-02 23:29:44 UTC (rev 9251)
@@ -25,10 +25,22 @@
QgsColorRampShader::QgsColorRampShader( double theMinimumValue, double theMaximumValue ) : QgsRasterShaderFunction( theMinimumValue, theMaximumValue )
QgsDebugMsg( "called." );
+ mMaximumColorCacheSize = 256; //good starting value
bool QgsColorRampShader::generateShadedValue( double theValue, int* theReturnRedValue, int* theReturnGreenValue, int* theReturnBlueValue )
+ //Get the shaded from the cache if it exists already
+ QColor myColor = mColorCache.value(theValue);
+ if(myColor.isValid())
+ *theReturnRedValue = myColor.red();
+ *theReturnGreenValue = myColor.green();
+ *theReturnBlueValue = myColor.blue();
+ return true;
+ //Else we have to generate the shaded value
if ( QgsColorRampShader::INTERPOLATED == mColorRampType )
return getInterpolatedColor( theValue, theReturnRedValue, theReturnGreenValue, theReturnBlueValue );
@@ -81,15 +93,16 @@
myCurrentRampValue = it->value;
if ( theValue <= myCurrentRampValue )
- if ( last_it != mColorRampItemList.end() )
+ *theReturnRedValue = it->color.red();
+ *theReturnGreenValue = it->color.green();
+ *theReturnBlueValue = it->color.blue();
+ //Cache the shaded value
+ if(mMaximumColorCacheSize <= mColorCache.size())
- *theReturnRedValue = last_it->color.red();
- *theReturnGreenValue = last_it->color.green();
- *theReturnBlueValue = last_it->color.blue();
- return true;
+ mColorCache.insert(theValue, it->color);
+ return true;
- last_it = it;
return false; // value not found
@@ -109,6 +122,11 @@
return true;
@@ -143,6 +161,11 @@
*theReturnRedValue = ( int )(( it->color.red() * myDiffTheValueLastRampValue + last_it->color.red() * myDiffCurrentRampValueTheValue ) / myCurrentRampRange );
*theReturnGreenValue = ( int )(( it->color.green() * myDiffTheValueLastRampValue + last_it->color.green() * myDiffCurrentRampValueTheValue ) / myCurrentRampRange );
*theReturnBlueValue = ( int )(( it->color.blue() * myDiffTheValueLastRampValue + last_it->color.blue() * myDiffCurrentRampValueTheValue ) / myCurrentRampRange );
return true;
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.h
--- trunk/qgis/src/core/raster/qgscolorrampshader.h 2008-09-02 21:55:15 UTC (rev 9250)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.h 2008-09-02 23:29:44 UTC (rev 9251)
@@ -22,6 +22,7 @@
#define QGSCOLORRAMPSHADER_H
#include <QColor>
+#include <QMap>
#include "qgsrastershaderfunction.h"
@@ -62,6 +63,9 @@
QgsColorRampShader::COLOR_RAMP_TYPE getColorRampType() {return mColorRampType;}
QString getColorRampTypeAsQString();
+ /**Get the maximum size the color cache can be*/
+ int getMaximumColorCacheSize() { return mMaximumColorCacheSize; }
/**Set custom colormap */
void setColorRampItemList( const QList<QgsColorRampShader::ColorRampItem>& theList ) { mColorRampItemList = theList; }
@@ -70,6 +74,9 @@
/**Set the color ramp type*/
void setColorRampType( QString );
+ /**Set the maximum size the color cache can be */
+ void setMaximumColorCacheSize(int theSize) { mMaximumColorCacheSize = theSize; }
@@ -85,6 +92,8 @@
QList<QgsColorRampShader::ColorRampItem> mColorRampItemList;
QgsColorRampShader::COLOR_RAMP_TYPE mColorRampType;
+ QMap<double, QColor> mColorCache;
+ int mMaximumColorCacheSize; //The color cache could eat a ton of memory if you have 32-bit data
#endif
Modified: trunk/qgis/src/core/raster/qgsrasterbandstats.h
--- trunk/qgis/src/core/raster/qgsrasterbandstats.h 2008-09-02 21:55:15 UTC (rev 9250)
+++ trunk/qgis/src/core/raster/qgsrasterbandstats.h 2008-09-02 23:29:44 UTC (rev 9251)
@@ -24,7 +24,7 @@
#include <limits>
-#include "qgscolortable.h"
+#include "qgscolorrampshader.h"
/** \ingroup core
* The RasterBandStats struct is a container for statistics about a single
* raster band.
@@ -82,6 +82,6 @@
/** whehter histogram compuation should include out of range values */
bool histogramOutOfRangeFlag;
/** Color table */
- QgsColorTable colorTable;
+ QList<QgsColorRampShader::ColorRampItem> colorTable;
#endif
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-09-02 21:55:15 UTC (rev 9250)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-09-02 23:29:44 UTC (rev 9251)
@@ -521,9 +521,9 @@
myRasterBandStats.bandNo = i;
myRasterBandStats.statsGatheredFlag = false;
myRasterBandStats.histogramVector = new QgsRasterBandStats::HistogramVector();
- // Read color table
- readColorTable( myGdalBand, &( myRasterBandStats.colorTable ) );
+ //Store the default color table
+ readColorTable(i, &myRasterBandStats.colorTable);
mRasterStatsList.push_back( myRasterBandStats );
//Build a new contrast enhancement for the band and store in list
@@ -562,14 +562,11 @@
drawingStyle = PALETTED_COLOR; //sensible default
- //Load the color table from the band
- QList<QgsColorRampShader::ColorRampItem> myColorRampList;
- readColorTable( 1, &myColorRampList );
//Set up a new color ramp shader
setColorShadingAlgorithm( COLOR_RAMP );
QgsColorRampShader* myColorRampShader = ( QgsColorRampShader* ) mRasterShader->getRasterShaderFunction();
myColorRampShader->setColorRampType( QgsColorRampShader::EXACT );
- myColorRampShader->setColorRampItemList( myColorRampList );
+ myColorRampShader->setColorRampItemList( *getColorTable(1) );
else if ( rasterLayerType == MULTIBAND )
@@ -886,27 +883,23 @@
-QPixmap QgsRasterLayer::getPaletteAsPixmap()
+QPixmap QgsRasterLayer::getPaletteAsPixmap(int theBandNumber)
QgsDebugMsg( "entered." );
// Only do this for the non-provider (hard-coded GDAL) scenario...
// Maybe WMS can do this differently using QImage::numColors and QImage::color()
- if (
- ( mProviderKey.isEmpty() ) &&
- ( hasBand( "Palette" ) ) //dont tr() this its a gdal word!
+ if (mProviderKey.isEmpty() && hasBand( "Palette" ) && theBandNumber > 0) //dont tr() this its a gdal word!
QgsDebugMsg( "....found paletted image" );
- QgsColorTable *myColorTable = colorTable( 1 );
- GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, 1 );
- if ( GDALGetRasterColorInterpretation( myGdalBand ) == GCI_PaletteIndex && myColorTable->defined() )
+ QgsColorRampShader myShader;
+ QList<QgsColorRampShader::ColorRampItem> myColorRampItemList = myShader.getColorRampItemList();
+ if(readColorTable(1, &myColorRampItemList))
- QgsDebugMsg( "....found GCI_PaletteIndex" );
- double myMin = myColorTable->rmin();
- double myMax = myColorTable->rmax();
- QgsDebugMsg( "myMin = " + QString::number( myMin ) + " myMax = " + QString::number( myMax ) );
+ QgsDebugMsg( "....got color ramp item list" );
+ myShader.setColorRampItemList(myColorRampItemList);
+ myShader.setColorRampType(QgsColorRampShader::DISCRETE);
// Draw image
int mySize = 100;
QPixmap myPalettePixmap( mySize, mySize );
@@ -916,20 +909,17 @@
myQImage.fill( 0 );
myPalettePixmap.fill();
- double myStep = ( myMax - myMin ) / ( mySize * mySize );
+ double myStep = ( (double)myColorRampItemList.size() - 1 ) / (double)( mySize * mySize );
+ double myValue = 0.0;
for ( int myRow = 0; myRow < mySize; myRow++ )
for ( int myCol = 0; myCol < mySize; myCol++ )
- double myValue = myMin + myStep * ( myCol + myRow * mySize );
+ myValue = myStep * (double)( myCol + myRow * mySize );
int c1, c2, c3;
- bool found = myColorTable->color( myValue, &c1, &c2, &c3 );
- if ( found )
- myQImage.setPixel( myCol, myRow, qRgb( c1, c2, c3 ) );
+ myShader.generateShadedValue( myValue, &c1, &c2, &c3 );
+ myQImage.setPixel( myCol, myRow, qRgb( c1, c2, c3 ) );
@@ -1257,7 +1247,7 @@
int myBandNo = 1;
drawPalettedSingleBandGray( theQPainter, theRasterViewPort,
- theQgsMapToPixel, myBandNo, mGrayBandName );
+ theQgsMapToPixel, myBandNo);
break;
@@ -1498,6 +1488,7 @@
double myPixelValue = 0.0;
int myAlphaValue = 0;
+ QgsDebugMsg( "Starting main render loop" );
for ( int myColumn = 0; myColumn < theRasterViewPort->drawableAreaYDim; ++myColumn )
for ( int myRow = 0; myRow < theRasterViewPort->drawableAreaXDim; ++myRow )
@@ -1581,7 +1572,8 @@
int myGreenValue = 0;
int myBlueValue = 0;
@@ -1637,8 +1629,7 @@
* @param theColorQString - QString containing either 'Red' 'Green' or 'Blue' indicating which part of the rgb triplet will be used to render gray.
void QgsRasterLayer::drawPalettedSingleBandGray( QPainter * theQPainter, QgsRasterViewPort * theRasterViewPort,
- const QgsMapToPixel* theQgsMapToPixel, int theBandNo,
- QString const & theColorQString )
+ const QgsMapToPixel* theQgsMapToPixel, int theBandNo)
//Invalid band number, segfault prevention
@@ -1647,7 +1638,11 @@
return;
- QgsRasterBandStats myRasterBandStats = getRasterBandStats( theBandNo );
+ if ( NULL == mRasterShader )
+ return;
GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
GDALDataType myDataType = GDALGetRasterDataType( myGdalBand );
void *myGdalScanData = readData( myGdalBand, theRasterViewPort );
@@ -1658,41 +1653,23 @@
return;
- QgsColorTable *myColorTable = &( myRasterBandStats.colorTable );
QImage myQImage = QImage( theRasterViewPort->drawableAreaXDim, theRasterViewPort->drawableAreaYDim, QImage::Format_ARGB32 );
myQImage.fill( qRgba( 255, 255, 255, 0 ) ); // fill transparent
- bool found = false;
- int myRedLUTValue = 0;
- int myGreenLUTValue = 0;
- int myBlueLUTValue = 0;
+ int myRedValue = 0;
+ int myGreenValue = 0;
+ int myBlueValue = 0;
- //Set a pointer to the LUT color channel
- int* myGrayValue;
- if ( theColorQString == mRedBandName )
- myGrayValue = &myRedLUTValue;
- else if ( theColorQString == mGreenBandName )
- myGrayValue = &myGreenLUTValue;
- else
- myGrayValue = &myBlueLUTValue;
- myRedLUTValue = 0;
- myGreenLUTValue = 0;
- myBlueLUTValue = 0;
- found = false;
+ myRedValue = 0;
+ myGreenValue = 0;
+ myBlueValue = 0;
myPixelValue = readValue( myGdalScanData, ( GDALDataType )myDataType,
myColumn * theRasterViewPort->drawableAreaXDim + myRow );
@@ -1707,15 +1684,23 @@
continue;
- found = myColorTable->color( myPixelValue, &myRedLUTValue, &myGreenLUTValue, &myBlueLUTValue );
- if ( !found ) continue;
+ if ( !mRasterShader->generateShadedValue( myPixelValue, &myRedValue, &myGreenValue, &myBlueValue ) )
+ continue;
if ( mInvertPixelsFlag )
- *myGrayValue = 255 - *myGrayValue;
+ //Invert flag, flip blue and read
+ double myGrayValue = (0.3 * (double)myRedValue) + (0.59 * (double)myGreenValue) + (0.11 * (double)myBlueValue);
+ myQImage.setPixel( myRow, myColumn, qRgba( (int)myGrayValue, (int)myGrayValue, (int)myGrayValue, myAlphaValue ) );
- myQImage.setPixel( myRow, myColumn, qRgba( *myGrayValue, *myGrayValue, *myGrayValue, myAlphaValue ) );
+ else
+ //Normal
+ double myGrayValue = (0.3 * (double)myBlueValue) + (0.59 * (double)myGreenValue) + (0.11 * (double)myRedValue);
CPLFree( myGdalScanData );
@@ -1787,6 +1772,7 @@
@@ -1964,6 +1950,8 @@
QgsContrastEnhancement* myRedContrastEnhancement = getContrastEnhancement( myRedBandNo );
QgsContrastEnhancement* myGreenContrastEnhancement = getContrastEnhancement( myGreenBandNo );
QgsContrastEnhancement* myBlueContrastEnhancement = getContrastEnhancement( myBlueBandNo );
@@ -2209,10 +2197,6 @@
QString myColorerpretation = GDALGetColorInterpretationName( GDALGetRasterColorInterpretation( myGdalBand ) );
- //declare a colorTable to hold a palette - will only be used if the layer color interp is palette ???
- //get the palette colour table
// XXX this sets the element count to a sensible value; but then you ADD to
// XXX it later while iterating through all the pixels?
//myRasterBandStats.elementCount = mRasterXDim * mRasterYDim;
@@ -2395,32 +2379,6 @@
continue; // NULL
- //get the nth element from the current row
- if ( myColorerpretation == "Palette" ) // dont translate this its a gdal string
- //this is a palette layer so red / green / blue 'layers are 'virtual'
- //in that we need to obtain the palette entry and then get the r,g or g
- //component from that palette entry
- int c1, c2, c3;
- bool found = myColorTable->color( my, &c1, &c2, &c3 );
- //check for alternate color mappings
- switch ( theBandNo )
- case 1:
- my = c1;
- break;
- case 2:
- my = c2;
- break;
- case 3:
- my = c3;
- break;
myRasterBandStats.sumSqrDev += static_cast < double >
( pow( my - myRasterBandStats.mean, 2 ) );
@@ -3770,68 +3728,8 @@
return true;
-void QgsRasterLayer::readColorTable( GDALRasterBandH gdalBand, QgsColorTable *theColorTable )
+QList<QgsColorRampShader::ColorRampItem>* QgsRasterLayer::getColorTable( int theBandNo )
- QgsDebugMsg( "entered." );
- // First try to read color table from metadata
- char **metadata = GDALGetMetadata( gdalBand, NULL );
- theColorTable->clear();
- while ( metadata && metadata[0] )
- QStringList metadataTokens = QString( *metadata ).split( "=", QString::SkipEmptyParts );
- if ( metadataTokens.count() < 2 ) continue;
- if ( metadataTokens[0].contains( "COLOR_TABLE_RULE_RGB_" ) )
- double min, max;
- int min_c1, min_c2, min_c3, max_c1, max_c2, max_c3;
- if ( sscanf( metadataTokens[1].toLocal8Bit().data(), "%lf %lf %d %d %d %d %d %d",
- &min, &max, &min_c1, &min_c2, &min_c3, &max_c1, &max_c2, &max_c3 ) != 8 )
- continue;
- theColorTable->add( min, max,
- ( unsigned char )min_c1, ( unsigned char )min_c2, ( unsigned char )min_c3, 0,
- ( unsigned char )max_c1, ( unsigned char )max_c2, ( unsigned char )max_c3, 0 );
- found = true;
- ++metadata;
- theColorTable->sort();
- // If no color table was found, try to read it from GDALColorTable
- if ( !found )
- GDALColorTableH gdalColorTable = GDALGetRasterColorTable( gdalBand );
- if ( gdalColorTable )
- int count = GDALGetColorEntryCount( gdalColorTable );
- for ( int i = 0; i < count; i++ )
- const GDALColorEntry *colorEntry = GDALGetColorEntry( gdalColorTable, i );
- if ( !colorEntry ) continue;
- theColorTable->add( i, ( unsigned char ) colorEntry->c1, ( unsigned char ) colorEntry->c2,
- ( unsigned char ) colorEntry->c3 );
-#ifdef QGISDEBUG
- theColorTable->print();
-#endif
-QgsColorTable *QgsRasterLayer::colorTable( int theBandNo )
return &( mRasterStatsList[theBandNo-1].colorTable );
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-09-02 21:55:15 UTC (rev 9250)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-09-02 23:29:44 UTC (rev 9251)
@@ -55,7 +55,6 @@
// Forward declarations
-class QgsColorTable;
class QgsMapToPixel;
class QgsRect;
class QgsRasterBandStats;
@@ -276,7 +275,7 @@
void drawThumbnail( QPixmap * theQPixmap );
/** \brief Get an 8x8 pixmap of the color palette. If the layer has no palette a white pixmap will be returned. */
/** \brief This is called when the view on the raster layer needs to be refreshed (redrawn).
@@ -885,7 +884,7 @@
- QgsColorTable *colorTable( int theBandNoInt );
+ QList<QgsColorRampShader::ColorRampItem>* getColorTable( int theBandNoInt );
protected:
@@ -947,8 +946,7 @@
void drawPalettedSingleBandGray( QPainter * theQPainter,
- int theBandNoInt,
- const QString & theColorQString );
+ int theBandNoInt);
/** \brief Drawing routine for paletted image, rendered as a single band image in pseudocolor. */
void drawPalettedSingleBandPseudoColor( QPainter * theQPainter,
@@ -988,9 +986,6 @@
void paintImageToCanvas( QPainter* theQPainter, QgsRasterViewPort * theRasterViewPort,
const QgsMapToPixel* theQgsMapToPixel, QImage* theImage );
- /** \brief Read color table from GDAL raster band */
- void readColorTable( GDALRasterBandH gdalBand, QgsColorTable *theColorTable );
/** \brief Allocate memory and load data to that allocated memory, data type is the same
* as raster band. The memory must be released later!
* \return pointer to the memory
