[QGIS Commit] r9274 - trunk/qgis/doc
svn_qgis at osgeo.org
Sun Sep 7 03:33:25 EDT 2008
Author: timlinux
Date: 2008-09-07 03:33:24 -0400 (Sun, 07 Sep 2008)
New Revision: 9274
trunk/qgis/doc/CODING.t2t
Fixed trac urls
Modified: trunk/qgis/doc/CODING.t2t
--- trunk/qgis/doc/CODING.t2t 2008-09-07 04:40:42 UTC (rev 9273)
+++ trunk/qgis/doc/CODING.t2t 2008-09-07 07:33:24 UTC (rev 9274)
@@ -421,10 +421,10 @@
=== Patch file naming ===
If the patch is a fix for a specific bug, please name the file with the bug number in it e.g.
-**bug777fix.diff**, and attach it to the original bug report in trac (https://svn.qgis.org/trac).
+**bug777fix.diff**, and attach it to the original bug report in trac (https://trac.osgeo.org/qgis/).
If the bug is an enhancement or new feature, its usually a good idea to create a ticket in
-trac (https://svn.qgis.org/trac) first and then attach you
+trac (https://trac.osgeo.org/qgis/) first and then attach you
=== Create your patch in the top level QGIS source dir ===
