[QGIS Commit] r9285 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Sep 9 02:18:26 EDT 2008
Author: sholl
Date: 2008-09-09 02:18:23 -0400 (Tue, 09 Sep 2008)
New Revision: 9285
   docs/trunk/english_us/user_guide/ChangeLog
   docs/trunk/english_us/user_guide/working_with_raster.tex
	* working_with_raster.tex: missing images included
Modified: docs/trunk/english_us/user_guide/ChangeLog
--- docs/trunk/english_us/user_guide/ChangeLog	2008-09-08 13:42:21 UTC (rev 9284)
+++ docs/trunk/english_us/user_guide/ChangeLog	2008-09-09 06:18:23 UTC (rev 9285)
@@ -1,3 +1,7 @@
+2008-09-09  Stephan Holl  <stephan at keto>
+	* working_with_raster.tex: missing images included
 2008-09-05  Stephan Holl  <stephan at keto>
 	* title.tex, qgis_style.sty, qgis_style.tex: bumped
Modified: docs/trunk/english_us/user_guide/working_with_raster.tex
--- docs/trunk/english_us/user_guide/working_with_raster.tex	2008-09-08 13:42:21 UTC (rev 9284)
+++ docs/trunk/english_us/user_guide/working_with_raster.tex	2008-09-09 06:18:23 UTC (rev 9285)
@@ -221,8 +221,7 @@
  rasterfile-name in the legend or by right-clicking and choosing
  \dropmenuopt{Properties} from the popup meun.
  \item select the \tab{Transparency} tab
- % FIXME: the correct icon is missing!!
- \item \label{enum:add} Click the \toolbtntwo{mActionAddRasterLayer}{Add values manually}
+ \item \label{enum:add} Click the \toolbtntwo{mActionNewAttribute}{Add values manually}
  button. A new row will appear in the pixel-list.
  \item \label{enum:transp} enter the the raster-value (we use 0 here) and adjust the
  transparency to 20\%
@@ -234,8 +233,7 @@
 As you can see this is quite easy set custom transparency, but it can be
 quite a lot of work. Therefor you can use the button
-% FIXME: the correct icon is missing!!
-\toolbtntwo{mActionAddRasterLayer}{Export to file} to save your
+\toolbtntwo{mActionFileSave}{Export to file} to save your
 transparency-list to a file. The button
 \toolbtntwo{mActionAddRasterLayer}{Import from file} loads your
 transparency-settings and applies them to the current rasterlayer.
@@ -259,7 +257,7 @@
 color} where you can select a color to apply on that value.
 Alternativly you can click on the button
-% FIXME: images is missing\toolbtntwo{}{Load colormap from Band}
+\toolbtntwo{mActionNewAttribute}{Load colormap from Band}
 , which tries to
 load the table from the band (if it has any).
More information about the QGIS-commit mailing list
