[QGIS Commit] r9291 - in trunk/qgis/src: plugins/grass providers/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Sep 10 13:21:24 EDT 2008
Author: telwertowski
Date: 2008-09-10 13:21:24 -0400 (Wed, 10 Sep 2008)
New Revision: 9291
   trunk/qgis/src/plugins/grass/qgsgrassattributes.cpp
   trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
   trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
   trunk/qgis/src/plugins/grass/qgsgrassplugin.h
   trunk/qgis/src/plugins/grass/qgsgrassregion.cpp
   trunk/qgis/src/plugins/grass/qgsgrassselect.cpp
   trunk/qgis/src/providers/grass/qgsgrass.cpp
   trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
Addendum to r9288. Header adjustments for Linux and removal of const for GRASS 6.2 compatibility.
Modified: trunk/qgis/src/plugins/grass/qgsgrassattributes.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassattributes.cpp	2008-09-10 16:30:00 UTC (rev 9290)
+++ trunk/qgis/src/plugins/grass/qgsgrassattributes.cpp	2008-09-10 17:21:24 UTC (rev 9291)
@@ -22,7 +22,7 @@
 #include <QHeaderView>
 #include <QKeyEvent>
-#include <QMessagebox>
+#include <QMessageBox>
 #include <QSettings>
 #include <QTableWidget>
Modified: trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp	2008-09-10 16:30:00 UTC (rev 9290)
+++ trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp	2008-09-10 17:21:24 UTC (rev 9291)
@@ -1256,13 +1256,13 @@
     //       database path
     QgsGrass::activeMode(); // because it calls private gsGrass::init()
 #if defined(WIN32)
-    G__setenv( "GISDBASE", getShortPath( mDatabaseLineEdit->text() ).toAscii() );
+    G__setenv( "GISDBASE", getShortPath( mDatabaseLineEdit->text() ).toAscii().data() );
 #else
-    G__setenv( "GISDBASE", mDatabaseLineEdit->text().toAscii() );
+    G__setenv( "GISDBASE", mDatabaseLineEdit->text().toAscii().data() );
 #endif
     QgsGrass::resetError();
-    int ret = G_make_location( location.toAscii(), &mCellHead,
+    int ret = G_make_location( location.toAscii().data(), &mCellHead,
                                mProjInfo, mProjUnits, stdout );
     if ( ret != 0 )
Modified: trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp	2008-09-10 16:30:00 UTC (rev 9290)
+++ trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp	2008-09-10 17:21:24 UTC (rev 9291)
@@ -548,7 +548,7 @@
   QgsGrass::setLocation( gisdbase, location );
   struct Cell_head window;
-  char *err = G__get_window( &window, "", "WIND", mapset.toLatin1().constData() );
+  char *err = G__get_window( &window, "", "WIND", mapset.toLatin1().data() );
   if ( err )
Modified: trunk/qgis/src/plugins/grass/qgsgrassplugin.h
--- trunk/qgis/src/plugins/grass/qgsgrassplugin.h	2008-09-10 16:30:00 UTC (rev 9290)
+++ trunk/qgis/src/plugins/grass/qgsgrassplugin.h	2008-09-10 17:21:24 UTC (rev 9291)
@@ -29,6 +29,7 @@
 class QAction;
 class QIcon;
+class QPainter;
 class QToolBar;
Modified: trunk/qgis/src/plugins/grass/qgsgrassregion.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassregion.cpp	2008-09-10 16:30:00 UTC (rev 9290)
+++ trunk/qgis/src/plugins/grass/qgsgrassregion.cpp	2008-09-10 17:21:24 UTC (rev 9291)
@@ -165,7 +165,7 @@
-  char *err = G__get_window( &mWindow, "", "WIND", mapset.toLatin1() );
+  char *err = G__get_window( &mWindow, "", "WIND", mapset.toLatin1().data() );
   if ( err )
@@ -426,7 +426,7 @@
   QgsGrass::setLocation( QgsGrass::getDefaultGisdbase(), QgsGrass::getDefaultLocation() );
-  G__setenv( "MAPSET", QgsGrass::getDefaultMapset().toLatin1() );
+  G__setenv( "MAPSET", QgsGrass::getDefaultMapset().toLatin1().data() );
   if ( G_put_window( &mWindow ) == -1 )
Modified: trunk/qgis/src/plugins/grass/qgsgrassselect.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassselect.cpp	2008-09-10 16:30:00 UTC (rev 9290)
+++ trunk/qgis/src/plugins/grass/qgsgrassselect.cpp	2008-09-10 17:21:24 UTC (rev 9291)
@@ -20,7 +20,7 @@
 #include "qgslogger.h"
 #include <QFileDialog>
 extern "C"
Modified: trunk/qgis/src/providers/grass/qgsgrass.cpp
--- trunk/qgis/src/providers/grass/qgsgrass.cpp	2008-09-10 16:30:00 UTC (rev 9290)
+++ trunk/qgis/src/providers/grass/qgsgrass.cpp	2008-09-10 17:21:24 UTC (rev 9291)
@@ -314,11 +314,11 @@
   // Set principal GRASS variables (in memory)
 #if defined(WIN32)
-  G__setenv( "GISDBASE", getShortPath( gisdbase ).toAscii().constData() );
+  G__setenv( "GISDBASE", getShortPath( gisdbase ).toAscii().data() );
 #else
-  G__setenv( "GISDBASE", gisdbase.toAscii().constData() );
+  G__setenv( "GISDBASE", gisdbase.toAscii().data() );
 #endif
-  G__setenv( "LOCATION_NAME", location.toAscii().constData() );
+  G__setenv( "LOCATION_NAME", location.toAscii().data() );
   G__setenv( "MAPSET", "PERMANENT" ); // PERMANENT must always exist
   // Add all available mapsets to search path
@@ -333,12 +333,12 @@
 #if defined(WIN32)
 #else
 #endif
-  G__setenv( "MAPSET", mapset.toAscii().constData() );
+  G__setenv( "MAPSET", mapset.toAscii().data() );
   char **ms = G_available_mapsets();
@@ -557,14 +557,14 @@
   putenv( gisrcEnvChar );
   // Reinitialize GRASS
-  G__setenv( "GISRC", gisrcEnv.toAscii().constData() );
+  G__setenv( "GISRC", gisrcEnv.toAscii().data() );
 #if defined(WIN32)
 #else
 #endif
   defaultGisdbase = gisdbase;
   defaultLocation = location;
   defaultMapset = mapset;
@@ -876,7 +876,7 @@
   QgsGrass::setLocation( gisbase, location );
-  if ( G__get_window( window, "", "WIND", mapset.toLocal8Bit().constData() ) )
+  if ( G__get_window( window, "", "WIND", mapset.toLocal8Bit().data() ) )
     return false;
@@ -957,8 +957,8 @@
   if ( type == Raster )
-    if ( G_get_cellhd( map.toLocal8Bit().constData(),
-                       mapset.toLocal8Bit().constData(), window ) < 0 )
+    if ( G_get_cellhd( map.toLocal8Bit().data(),
+                       mapset.toLocal8Bit().data(), window ) < 0 )
       QMessageBox::warning( 0, QObject::tr( "Warning" ),
                             QObject::tr( "Cannot read raster map region" ) );
@@ -1010,8 +1010,8 @@
   else if ( type == Region )
     if ( G__get_window( window, "windows",
-                        map.toLocal8Bit().constData(),
-                        mapset.toLocal8Bit().constData() ) != NULL )
+                        map.toLocal8Bit().data(),
+                        mapset.toLocal8Bit().data() ) != NULL )
                             QObject::tr( "Cannot read region" ) );
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2008-09-10 16:30:00 UTC (rev 9290)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2008-09-10 17:21:24 UTC (rev 9291)
@@ -985,7 +985,7 @@
   QgsDebugMsg( QString( "Setting  gisdbase, location: %1, %2" ).arg( gisdbase ).arg( location ) );
   // Find the vector
-  char *ms = G_find_vector2( mapName.toAscii().constData(), mapset.toAscii().constData() ) ;
+  char *ms = G_find_vector2( mapName.toAscii().data(), mapset.toAscii().data() ) ;
   if ( ms == NULL )
@@ -1074,7 +1074,7 @@
   // TODO: Should be done better / in other place ?
   // TODO: Is it necessary for close ?
-  G__setenv( "MAPSET", map->mapset.toAscii().constData() );
+  G__setenv( "MAPSET", map->mapset.toAscii().data() );
   if ( closeMap ) Vect_close( map->map );
@@ -1345,7 +1345,7 @@
     return false;
   /* Check if current user is owner of mapset */
-  if ( G__mapset_permissions2( mGisdbase.toAscii().constData(), mLocation.toAscii().constData(), mMapset.toAscii().constData() ) != 1 )
+  if ( G__mapset_permissions2( mGisdbase.toAscii().data(), mLocation.toAscii().data(), mMapset.toAscii().data() ) != 1 )
     return false;
   // TODO: check format? (cannot edit OGR layers)
@@ -1423,7 +1423,7 @@
   // Set current mapset (mapset was previously checked by isGrassEditable() )
@@ -1499,7 +1499,7 @@
   // TODO: Is it necessary for build/close ?
   Vect_build_partial( map->map, GV_BUILD_NONE, NULL );
   Vect_build( map->map, stderr );
More information about the QGIS-commit mailing list
