[QGIS Commit] r9321 - trunk/qgis/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Sep 13 15:28:35 EDT 2008
Author: jef
Date: 2008-09-13 15:28:35 -0400 (Sat, 13 Sep 2008)
New Revision: 9321
   trunk/qgis/src/core/qgsgeometry.cpp
use WKB in QgsGeometry::vertexAt() only:
- includes multipolygons and inner rings again
- fixes #1300
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp	2008-09-13 18:30:20 UTC (rev 9320)
+++ trunk/qgis/src/core/qgsgeometry.cpp	2008-09-13 19:28:35 UTC (rev 9321)
@@ -2096,148 +2096,176 @@
   double x, y;
-  if ( mGeos ) //try to find the vertex from the Geos geometry (it present)
+  if ( mDirtyWkb )
-    try
-      const GEOSGeometry *g = GEOSGetExteriorRing( mGeos );
-      if ( !g )
-        return QgsPoint( 0, 0 );
-      const GEOSCoordSequence *cs = GEOSGeom_getCoordSeq( g );
-      GEOSCoordSeq_getX( cs, atVertex, &x );
-      GEOSCoordSeq_getY( cs, atVertex, &y );
-      return QgsPoint( x, y );
-    catch ( GEOSException &e )
-      Q_UNUSED( e );
+    exportGeosToWkb();
-  else if ( mGeometry )
+  if ( !mGeometry )
-    QGis::WKBTYPE wkbType;
-    bool hasZValue = false;
-    unsigned char* ptr;
+    QgsDebugMsg( "WKB geometry not available!" );
+    return QgsPoint( 0, 0 );
-    memcpy( &wkbType, ( mGeometry + 1 ), sizeof( int ) );
-    switch ( wkbType )
+  QGis::WKBTYPE wkbType;
+  bool hasZValue = false;
+  unsigned char* ptr;
+  memcpy( &wkbType, ( mGeometry + 1 ), sizeof( int ) );
+  switch ( wkbType )
+    case QGis::WKBPoint25D:
+    case QGis::WKBPoint:
-      case QGis::WKBPoint25D:
-      case QGis::WKBPoint:
+      if ( atVertex == 0 )
-        if ( atVertex == 0 )
-          ptr = mGeometry + 1 + sizeof( int );
-          memcpy( &x, ptr, sizeof( double ) );
-          ptr += sizeof( double );
-          memcpy( &y, ptr, sizeof( double ) );
-        else
-      case QGis::WKBLineString25D:
-        hasZValue = true;
-      case QGis::WKBLineString:
-        int *nPoints;
-        // get number of points in the line
-        ptr = mGeometry + 1 + sizeof( int );   // now at mGeometry.numPoints
-        nPoints = ( int * ) ptr;
-        // return error if underflow
-        if ( 0 > atVertex || *nPoints <= atVertex )
-        // copy the vertex coordinates
-        if ( hasZValue )
-          ptr = mGeometry + 9 + ( atVertex * 3 * sizeof( double ) );
-        else
-          ptr = mGeometry + 9 + ( atVertex * 2 * sizeof( double ) );
+        ptr = mGeometry + 1 + sizeof( int );
-      case QGis::WKBPolygon25D:
-        hasZValue = true;
-      case QGis::WKBPolygon:
+      else
-        int *nRings;
-        int *nPoints = 0;
-        nRings = ( int* )ptr;
+    case QGis::WKBLineString25D:
+      hasZValue = true;
+    case QGis::WKBLineString:
+      int *nPoints;
+      // get number of points in the line
+      ptr = mGeometry + 1 + sizeof( int );   // now at mGeometry.numPoints
+      nPoints = ( int * ) ptr;
+      // return error if underflow
+      if ( 0 > atVertex || *nPoints <= atVertex )
+      // copy the vertex coordinates
+      if ( hasZValue )
+        ptr = mGeometry + 9 + ( atVertex * 3 * sizeof( double ) );
+      else
+        ptr = mGeometry + 9 + ( atVertex * 2 * sizeof( double ) );
+      memcpy( &x, ptr, sizeof( double ) );
+      ptr += sizeof( double );
+      memcpy( &y, ptr, sizeof( double ) );
+      return QgsPoint( x, y );
+    case QGis::WKBPolygon25D:
+      hasZValue = true;
+    case QGis::WKBPolygon:
+      int *nRings;
+      int *nPoints = 0;
+      nRings = ( int* )ptr;
+      ptr += sizeof( int );
+      int pointindex = 0;
+      for ( int ringnr = 0; ringnr < *nRings; ++ringnr )
+        nPoints = ( int* )ptr;
-        int pointindex = 0;
-        for ( int ringnr = 0; ringnr < *nRings; ++ringnr )
+        for ( int pointnr = 0; pointnr < *nPoints; ++pointnr )
-          nPoints = ( int* )ptr;
-          ptr += sizeof( int );
-          for ( int pointnr = 0; pointnr < *nPoints; ++pointnr )
+          if ( pointindex == atVertex )
-            if ( pointindex == atVertex )
-            ptr += 2 * sizeof( double );
-            if ( hasZValue )
-            ++pointindex;
+          ptr += 2 * sizeof( double );
+          if ( hasZValue )
+          ++pointindex;
+    case QGis::WKBMultiPoint25D:
+      hasZValue = true;
+    case QGis::WKBMultiPoint:
+      int* nPoints = ( int* )ptr;
+      if ( atVertex < 0 || atVertex >= *nPoints )
-      case QGis::WKBMultiPoint25D:
-        hasZValue = true;
-      case QGis::WKBMultiPoint:
+      if ( hasZValue )
-        int* nPoints = ( int* )ptr;
-        if ( atVertex < 0 || atVertex >= *nPoints )
+        ptr += atVertex * ( 3 * sizeof( double ) + 1 + sizeof( int ) );
+      else
+        ptr += atVertex * ( 2 * sizeof( double ) + 1 + sizeof( int ) );
+      ptr += 1 + sizeof( int );
+    case QGis::WKBMultiLineString25D:
+      hasZValue = true;
+    case QGis::WKBMultiLineString:
+      int* nLines = ( int* )ptr;
+      int* nPoints = 0; //number of points in a line
+      int pointindex = 0; //global point counter
+      for ( int linenr = 0; linenr < *nLines; ++linenr )
+        ptr += sizeof( int ) + 1;
+          if ( hasZValue )
+          ++pointindex;
-        if ( hasZValue )
-          ptr += atVertex * ( 3 * sizeof( double ) + 1 + sizeof( int ) );
-        else
-          ptr += atVertex * ( 2 * sizeof( double ) + 1 + sizeof( int ) );
-        ptr += 1 + sizeof( int );
-      case QGis::WKBMultiLineString25D:
-        hasZValue = true;
-      case QGis::WKBMultiLineString:
+    case QGis::WKBMultiPolygon25D:
+      hasZValue = true;
+    case QGis::WKBMultiPolygon:
+      int* nRings = 0;//number of rings in a polygon
+      int* nPoints = 0;//number of points in a ring
+      int* nPolygons = ( int* )ptr;
+      for ( int polynr = 0; polynr < *nPolygons; ++polynr )
-        int* nLines = ( int* )ptr;
-        int* nPoints = 0; //number of points in a line
-        int pointindex = 0; //global point counter
+        ptr += ( 1 + sizeof( int ) ); //skip endian and polygon type
-        for ( int linenr = 0; linenr < *nLines; ++linenr )
-          ptr += sizeof( int ) + 1;
@@ -2249,66 +2277,21 @@
+            ++pointindex;
             if ( hasZValue )
-            ++pointindex;
-      case QGis::WKBMultiPolygon25D:
-        hasZValue = true;
-      case QGis::WKBMultiPolygon:
-        int* nRings = 0;//number of rings in a polygon
-        int* nPoints = 0;//number of points in a ring
-        int* nPolygons = ( int* )ptr;
-        for ( int polynr = 0; polynr < *nPolygons; ++polynr )
-          ptr += ( 1 + sizeof( int ) ); //skip endian and polygon type
-              ++pointindex;
-              if ( hasZValue )
-      default:
-        QgsDebugMsg( "error: mGeometry type not recognized" );
+    default:
+      QgsDebugMsg( "error: mGeometry type not recognized" );
-  else
-    QgsDebugMsg( "error: no mGeometry pointer" );
More information about the QGIS-commit mailing list
