[QGIS Commit] r9337 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Tue Sep 16 03:27:38 EDT 2008
Author: taraathan
Date: 2008-09-16 03:27:37 -0400 (Tue, 16 Sep 2008)
New Revision: 9337
docs/trunk/english_us/user_guide/conventions.tex
docs/trunk/english_us/user_guide/getting_started.tex
Changed the keystroke example in conventions to read
Ctrl+B instead of Ctrl-B for consistency with menus.
Added a paragraph on stopping QGIS in the starting QGIS section.
Changed the formatting in the menu option lists to tabbing rather than itemize.
Added tool icons, shortcuts, references and the names of the containing toolbar.
Included label and index for bookmark section.
Modified: docs/trunk/english_us/user_guide/conventions.tex
--- docs/trunk/english_us/user_guide/conventions.tex 2008-09-16 01:37:49 UTC (rev 9336)
+++ docs/trunk/english_us/user_guide/conventions.tex 2008-09-16 07:27:37 UTC (rev 9337)
@@ -31,7 +31,7 @@
\newcommand{\server}[1]{\textit{#1}}
% keystroke
% style for user input by individual keystrokes
-% usage: \keystroke{p}, \keystroke{Ctrl-B}
+% usage: \keystroke{p}, \keystroke{Ctrl+B}
\newcommand{\keystroke}[1]{\cornersize{.6}\ovalbox{\textsf{#1}}}
% guilabel
@@ -430,7 +430,7 @@
\item Hyperlinks: \url{http://qgis.org}
\item Single Keystroke: press \keystroke{p}
-\item Keystroke Combinations: press \keystroke{Ctrl-B}, meaning press and
+\item Keystroke Combinations: press \keystroke{Ctrl+B}, meaning press and
hold the Ctrl key and then press the B key.
\item Name of a File: \filename{lakes.shp}
%\item Name of a Field: \fieldname{NAMES}
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex 2008-09-16 01:37:49 UTC (rev 9336)
+++ docs/trunk/english_us/user_guide/getting_started.tex 2008-09-16 07:27:37 UTC (rev 9337)
@@ -81,8 +81,9 @@
% UNIT["meter",1]]
%\end{verbatim}
-\subsection{Starting QGIS}\label{label_startinqgis}
+\subsection{Starting and Stopping QGIS}\label{label_startinqgis}
+To start QGIS:
\begin{itemize}
\item \nix{assuming that QGIS is installed in the PATH, you can start QGIS
by typing: \usertext{qgis} at a command prompt or by double clicking on the QGIS
@@ -92,6 +93,16 @@
\item \osx{double click the icon in your Applications folder.}
\end{itemize}
+To stop QGIS, click the menu options \{\nix{}\win{File} \osx{QGIS}\} > Quit,
+or use the shortcut \keystroke{Ctrl+Q}.
+Other ways to exist QGIS include:
+\begin{itemize}
+\item \nix{type exit in the command window, or
+click on the "x" button on the upper left corner of the frame.}
+\item \win{click on the red "x" button on the upper left corner of the frame.}
+%\item \osx{.}
+\end{itemize}
\subsubsection{Command Line Options}\index{command line options}
\label{label_commandline}
@@ -196,119 +207,269 @@
The menu bar provides access to various QGIS features using a standard
hierarchical menu. The top-level menus and a summary of some of the
-functions provided are listed below.
-Many menu entries have an icon associated with them, indicating the icon
-of the corresponding tool as it appears on a toolbar.
+menu options are listed below, together with the icons of the corresponding
+tools as they appear on the toolbar, as well as keyboard shortcuts.
Although most menu options have a corresponding tool and vice-versa,
the menus are not organized quite like the toolbars.
-The toolbar containing the tool is listed after each menu entry as a checkbox
+The toolbar containing the tool is listed after each menu option as a checkbox
entry. For more information about tools and toolbars, see Section \ref{label_toolbars}.
+\begin{tabbing}
+\hspace{5.5cm}\=\hspace{3cm}\=\hspace{3.5cm}\= \kill
+\hspace{1cm} Menu Option \> Shortcut \> Reference \> Toolbar\\
+\end{tabbing}
\begin{itemize}
\item \mainmenuopt{File}
-\begin{itemize}
-\item \dropmenuopttwo{mActionFileNew}{New Project}
- \dropmenucheck{File}
- - see Section \ref{sec:projects}
-\item \dropmenuopttwo{mActionFileOpen}{Open Project}
-\item \dropmenuopt{Open Recent Projects}
-\item \dropmenuopttwo{mActionFileSave}{Save Project}
-\item \dropmenuopttwo{mActionFileSaveAs}{Save Project As}
-\item \dropmenuopttwo{mActionSaveMapAsImage}{Save as Image}
- - see Section \ref{sec:output}
-%\item \dropmenuopt{Export to MapServer Map} - see Section \ref{sec:mapserver_export}
-\item \dropmenuopttwo{mActionFilePrint}{Print Composer}
- - see Section \ref{label_mapcomposer}
-\item \dropmenuopttwo{mActionFileExit}{Exit}
-\end{itemize}
+\begin{tabbing}
+\hspace{4.5cm}\=\hspace{3cm}\=\hspace{3.5cm}\= \kill
+\dropmenuopttwo{mActionFileNew}{New Project}
+ \> \keystroke{Ctrl+N}
+ \> see Section \ref{sec:projects}
+ \> \dropmenucheck{File} \\
+\dropmenuopttwo{mActionFileOpen}{Open Project}
+ \> \keystroke{Ctrl+O}
+\dropmenuopt{Open Recent Projects}
+ \> see Section \ref{sec:projects} \\
+\dropmenuopttwo{mActionFileSave}{Save Project}
+ \> \keystroke{Ctrl+S}
+\dropmenuopttwo{mActionFileSaveAs}{Save Project As}
+ \> \keystroke{Ctrl+Shift+S}
+\dropmenuopttwo{mActionSaveMapAsImage}{Save as Image}
+ \> see Section \ref{sec:output} \\
+%\dropmenuopt{Export to MapServer Map} - see Section \ref{sec:mapserver_export}
+\dropmenuopttwo{mActionFilePrint}{Print Composer}
+ \> \keystroke{Ctrl+P}
+ \> see Section \ref{label_mapcomposer}
+\dropmenuopttwo{mActionFileExit}{Exit}
+ \> \keystroke{Ctrl+Q} \\
+\end{tabbing}
-\item \mainmenuopt{Edit} -see Section \ref{sec:edit_existing_layer}
-\begin{itemize}
-\item \dropmenuopt{Cut Features}
-\item \dropmenuopt{Copy Features}
-\item \dropmenuopt{Paste Features}
-\item \dropmenuopt{Capture Point}
-\item \dropmenuopt{Capture Line}
-\item \dropmenuopt{Capture Polygon}
-\item \dropmenuopt{Move Feature}
-\item \dropmenuopt{Split Features}
-\item \dropmenuopt{Delete Selected}
-\item \dropmenuopt{Add Vertex}
-\item \dropmenuopt{Move Vertex}
-\item \dropmenuopt{Delete Vertex}
-\item \dropmenuopt{Add Ring} - \textbf{New since v0.9}
-\item \dropmenuopt{Add Island} - \textbf{New since v0.9}
-\end{itemize}
+\item \mainmenuopt{Edit}
+\begin{tabbing}
+\dropmenuopttwo{mActionEditCut}{Cut Features}
+ \> \keystroke{Ctrl+X}
+ \> see Section \ref{sec:edit_existing_layer}
+ \> \dropmenucheck{Digitizing} \\
+\dropmenuopttwo{mActionEditCopy}{Copy Features}
+ \> \keystroke{Ctrl+C}
+\dropmenuopttwo{mActionEditPaste}{Paste Features}
+ \> \keystroke{Ctrl+V}
+\dropmenuopttwo{mActionCapturePoint}{Capture Point}
+ \> \keystroke{.}
+\dropmenuopttwo{mActionCaptureLine}{Capture Line}
+ \> \keystroke{/}
+\dropmenuopttwo{mActionCapturePolygon}{Capture Polygon}
+ \> \keystroke{Ctrl+/}
+And Other Edit Menu Items
+%\dropmenuopt{Move Feature}
+% \> \> \dropmenucheck{Edit} \\
+%\dropmenuopt{Split Features}
+%\dropmenuopt{Delete Selected}
+%\dropmenuopt{Add Vertex}
+%\dropmenuopt{Move Vertex}
+%\dropmenuopt{Delete Vertex}
+%\dropmenuopt{Add Ring}\footnote{New since v0.9}
+% \> \dropmenucheck{Edit} \\
+%\dropmenuopt{Add Island} \footnotemark[\value{footnote}]
+\end{tabbing}
\item \mainmenuopt{View}
-\begin{itemize}
-\item \dropmenuopt{Pan Map}
-\item \dropmenuopt{Zoom In}
-\item \dropmenuopt{Zoom Out}
-\item \dropmenuopt{Select Features}
-\item \dropmenuopt{Identify Features}
-\item \dropmenuopt{Measure Line}
-\item \dropmenuopt{Measure Area}
-\item \dropmenuopt{Zoom Full}
-\item \dropmenuopt{Zoom To Layer}
-\item \dropmenuopt{Zoom To Selection}
-\item \dropmenuopt{Zoom Last}
-\item \dropmenuopt{Zoom Actual Size}
-\item \dropmenuopt{Map Tips}
-\item \dropmenuopt{New Bookmark}
-\item \dropmenuopt{Show Bookmarks}
-\item \dropmenuopt{Refresh}
-\end{itemize}
+\begin{tabbing}
+\dropmenuopttwo{mActionPan}{Pan Map}
+ \> \> \dropmenucheck{Map Navigation} \\
+\dropmenuopttwo{mActionZoomIn}{Zoom In}
+ \> \keystroke{Ctrl++}
+\dropmenuopttwo{mActionZoomOut}{Zoom Out}
+ \> \keystroke{Ctrl+-}
+\dropmenuopttwo{mActionSelect}{Select Features}
+ \> \> \dropmenucheck{Attributes} \\
+\dropmenuopttwo{mActionIdentify}{Identify Features}
+ \> \keystroke{I}
+\dropmenuopttwo{mActionMeasure}{Measure Line}
+ \> \keystroke{M}
+\dropmenuopttwo{mActionMeasureArea}{Measure Area}
+ \> \keystroke{J}
+\dropmenuopttwo{mActionOpenTable}{Zoom Full}
+ \> \keystroke{F}
+\dropmenuopttwo{mActionZoomToLayer}{Zoom To Layer}
+\dropmenuopttwo{mActionZoomToSelected}{Zoom To Selection}
+ \> \keystroke{Ctrl+J}
+\dropmenuopttwo{mActionZoomLast}{Zoom Last}
+\dropmenuopt{Zoom Actual Size}
+\dropmenuopttwo{mActionMapTips}{Map Tips}
+\dropmenuopttwo{mActionNewBookmark}{New Bookmark}
+ \> \keystroke{Ctrl+B}
+ \> see Section \ref{bookmarks}
+\> \dropmenucheck{Attributes} \\
+\dropmenuopttwo{mActionShowBookmarks}{Show Bookmarks}
+ \> \keystroke{B}
+ \> \dropmenucheck{Attributes} \\
+\dropmenuopttwo{mActionDraw}{Refresh}
+ \> \keystroke{Ctrl+R}
+\end{tabbing}
\item \mainmenuopt{Layer}
-\begin{itemize}
-\item \dropmenuopt{New Vector Layer} - see Section \ref{sec:create shape}
-\item \dropmenuopt{Add a Vector Layer} - see Section \ref{label_workingvector}
-\item \dropmenuopt{Add a Raster Layer} - see Section \ref{label_raster}
-\item \dropmenuopt{Add a PostGIS Layer} - see Section \ref{label_postgis}
-\item \dropmenuopt{Add a WMS Layer} - see Section \ref{sec:ogc-wms}
-\item \dropmenuopt{Open Attribute Table}
-\item \dropmenuopt{Toggle Editting}
-\item \dropmenuopt{Save As Shapefile}
-\item \dropmenuopt{Save Selection As Shapefile}
-\item \dropmenuopt{Remove Layer}
-\item \dropmenuopt{Properties}
-\item \dropmenuopt{Add to Overview}
-\item \dropmenuopt{Add All To Overview}
-\item \dropmenuopt{Remove All From Overview}
-\item \dropmenuopt{Hide All Layers}
-\item \dropmenuopt{Show All Layers}
-\end{itemize}
+\begin{tabbing}
+\dropmenuopttwo{mActionNewVectorLayer}{New Vector Layer}
+ \> \keystroke{N}
+ see Section \ref{sec:create shape}
+ \> \dropmenucheck{Manage Layers} \\
+\dropmenuopttwo{mActionAddNonDbLayer}{Add a Vector Layer}
+ \> \keystroke{V}
+ see Section \ref{label_workingvector}
+\dropmenuopttwo{mActionAddRasterLayer}{Add a Raster Layer}
+ \> \keystroke{R}
+ see Section \ref{label_raster}
+\dropmenuopttwo{mActionAddLayer}{Add a PostGIS Layer}
+ \> \keystroke{D}
+ see Section \ref{label_postgis}
+\dropmenuopttwo{mActionAddWmsLayer}{Add a WMS Layer}
+ \> \keystroke{W}
+ see Section \ref{sec:ogc-wms}
+\dropmenuopttwo{mActionOpenTable}{Open Attribute Table}
+\dropmenuopttwo{mActionToggleEditing}{Toggle editing}
+\dropmenuopt{Save As Shapefile}
+\dropmenuopt{Save Selection As Shapefile}
+\dropmenuopttwo{mActionRemoveLayer}{Remove Layer}
+ \> \keystroke{Ctrl+D}
+\dropmenuopt{Properties}
+\dropmenuopttwo{mActionInOverview}{Add to Overview}
+ \> \keystroke{O}
+\dropmenuopttwo{mActionAddAllToOverview}{Add All To Overview}
+ \> \keystroke{+}
+\dropmenuopttwo{mActionRemoveAllFromOverview}{Remove All From Overview}
+ \> \hspace{1cm}\keystroke{-}
+\dropmenuopttwo{mActionHideAllLayers}{Hide All Layers}
+ \> \keystroke{H}
+\dropmenuopttwo{mActionShowAllLayers}{Show All Layers}
+ \> \keystroke{S}
+\end{tabbing}
\item \mainmenuopt{Settings}
-\begin{itemize}
-\item \dropmenuopt{Project Properties} - see Section \ref{sec:projects}
-\item \dropmenuopt{Custom CRS} - see Section \ref{sec:customprojections}
-\item \dropmenuopt{Options} - see Section \ref{subsec:gui_options}
-\end{itemize}
+\begin{tabbing}
+\dropmenuopttwo{mActionProjectProperties}{Project Properties}
+ \> \keystroke{P}
+ see Section \ref{sec:projects}
+\dropmenuopttwo{mActionCustomProjection}{Custom CRS}
+see Section \ref{sec:customprojections}
+\dropmenuopttwo{mActionOptions}{Options}
+see Section \ref{subsec:gui_options}
+\end{tabbing}
\item \mainmenuopt{Plugins} - (Futher menu items are added by plugins as they are loaded.)
-\begin{itemize}
-\item \dropmenuopt{Plugin Manager} - see Section \ref{sec:managing_plugins}
-\end{itemize}
+\begin{tabbing}
+\dropmenuopttwo{mActionShowPluginManager}{Plugin Manager}
+see Section \ref{sec:managing_plugins}
+ \dropmenucheck{Plugins}\\
+\end{tabbing}
\item \mainmenuopt{Help}
-\begin{itemize}
-\item \dropmenuopt{Help Contents}
-\item \dropmenuopt{QGIS Homepage}
-\item \dropmenuopt{Check QGIS Version}
-\item \dropmenuopt{About}
-\end{itemize}
+\begin{tabbing}
+\dropmenuopttwo{mActionHelpContents}{Help Contents}
+ \> \keystroke{F1}
+ \> \dropmenucheck{Help}\\
+\dropmenuopttwo{mActionQgisHomePage}{QGIS Homepage}
+ \> \keystroke{Ctrl+H}
+\dropmenuopttwo{mActionCheckQgisVersion}{Check QGIS Version}
+\dropmenuopttwo{mActionHelpAbout}{About}
+\end{tabbing}
\end{itemize}
@@ -738,6 +899,8 @@
Note that you can have multiple bookmarks with the same name.
\subsubsection{Working with Bookmarks}
+\label{sec:bookmarks}
+\index{bookmarks}
To use or manage bookmarks, select the menu
option \mainmenuopt{View} > \dropmenuopt{Show Bookmarks}.
The \dialog{Geospatial Bookmarks} dialog allows you to zoom to or delete a bookmark.
