[QGIS Commit] r9353 - trunk/qgis/src/app/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Sep 19 03:50:18 EDT 2008
Author: mhugent
Date: 2008-09-19 03:50:17 -0400 (Fri, 19 Sep 2008)
New Revision: 9353
   trunk/qgis/src/app/composer/qgscomposer.cpp
   trunk/qgis/src/app/composer/qgscomposer.h
More cleanups
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp	2008-09-19 07:37:54 UTC (rev 9352)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp	2008-09-19 07:50:17 UTC (rev 9353)
@@ -834,87 +834,6 @@
   close();
-void QgsComposer::projectRead( void )
-  QgsDebugMsg( "entered." );
-  //if ( mComposition ) delete mComposition;
-  //mComposition  = new QgsComposition( this, 1 );
-  // Read composition if it is defined in project
-  QStringList l = QgsProject::instance()->subkeyList( "Compositions", "" );
-  bool found = false;
-  for ( QStringList::iterator it = l.begin(); it != l.end(); ++it )
-    QgsDebugMsg( QString( "key: %1" ).arg(( *it ) ) );
-    if (( *it ).compare( "composition_1" ) == 0 )
-      found = true;
-      break;
-  if ( found )
-    //mComposition->readSettings ( );
-    mFirstTime = false;
-  else
-    if ( isVisible() )
-      //mComposition->createDefault();
-    else
-      mFirstTime = true;
-  //mComposition->setActive ( true );
-void QgsComposer::newProject( void )
-  // If composer is visible, create default immediately, otherwise wait for the first open()
-  else
-bool QgsComposer::writeSettings( void )
-#ifdef WIN32
-  bool ok = true;
-#else
-  bool ok = false;
-#endif
-  return ok;
-bool QgsComposer::readSettings( void )
-#ifdef WIN32
-  bool ok = true;
-#else
-  bool ok = false;
-#endif
-  return ok;
 void  QgsComposer::writeXML( QDomDocument& doc )
   QDomNodeList nl = doc.elementsByTagName( "qgis" );
@@ -1084,6 +1003,8 @@
   mComposition->sortZList();
   mView->setComposition( mComposition );
+  setSelectionTool();
 void QgsComposer::addComposerMap( QgsComposerMap* map )
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h	2008-09-19 07:37:54 UTC (rev 9352)
+++ trunk/qgis/src/app/composer/qgscomposer.h	2008-09-19 07:50:17 UTC (rev 9353)
@@ -41,18 +41,6 @@
 /** \ingroup MapComposer
  * \brief A gui for composing a printable map.
- * The constructor creates empty composer, without compositions and mFirstTime set to true.
- * - if signal projectRead() is received all old compositions are deleted and
- *     - if the composition exists in project it is created from project settings (mFirstTime set to false)
- *     - if the composition does not exist in project
- *         - if the composer is visible new default composition is created (mFirstTime set to false)
- *         - if the composer is not visible the composer is left empty (mFirstTime set to true)
- * - if signal newProject() is received all old compositions are deleted and
- *     - if the composer is visible a new default composition is created (mFirstTime set to false)
- * If open() is called and mFirstTime == true, a new default composition is created.
 class QgsComposer: public QMainWindow, private Ui::QgsComposerBase
@@ -80,12 +68,6 @@
     //! Show composition options in widget
     void showCompositionOptions( QWidget *w );
-    /** \brief stores statei in project */
-    bool writeSettings( void );
-    /** \brief read state from project */
-    bool readSettings( void );
     //! Restore the window and toolbar state
     void restoreWindowState();
@@ -168,12 +150,6 @@
     //!Move selected items to bottom
     void moveSelectedItemsToBottom();
-    //! read project
-    void projectRead();
-    //! New project
-    void newProject();
     //! Save window state
     void saveWindowState();
More information about the QGIS-commit mailing list
