[QGIS Commit] r9357 - in trunk/qgis/src: app/composer core/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Sep 19 06:02:39 EDT 2008
Author: mhugent
Date: 2008-09-19 06:02:39 -0400 (Fri, 19 Sep 2008)
New Revision: 9357
   trunk/qgis/src/app/composer/qgscomposer.cpp
   trunk/qgis/src/app/composer/qgscomposer.h
   trunk/qgis/src/core/composer/qgscomposermap.cpp
   trunk/qgis/src/core/composer/qgscomposermap.h
Show a warning before printing WMS layers. Some WMS servers have a limit for WIDTH and HEIGHT parameters
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp	2008-09-19 09:58:51 UTC (rev 9356)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp	2008-09-19 10:02:39 UTC (rev 9357)
@@ -435,6 +435,11 @@
     return;
+  if(containsWMSLayer())
+      showWMSPrintingWarning();
   QPrinter printer;
   //try to set most of the print dialog settings based on composer properties
@@ -487,6 +492,11 @@
 void QgsComposer::on_mActionExportAsImage_activated( void )
   // Image size
   int width = ( int )( mComposition->printoutResolution() * mComposition->paperWidth() / 25.4 );
   int height = ( int )( mComposition-> printoutResolution() * mComposition->paperHeight() / 25.4 );
@@ -608,6 +618,11 @@
 void QgsComposer::on_mActionExportAsSVG_activated( void )
   QString myQSettingsLabel = "/UI/displaySVGWarning";
   QSettings myQSettings;
@@ -1080,3 +1095,43 @@
   mActionSelectMoveItem->setChecked( true );
   on_mActionSelectMoveItem_activated();
+bool QgsComposer::containsWMSLayer() const
+  QMap<QgsComposerItem*, QWidget*>::const_iterator item_it = mItemWidgetMap.constBegin();
+  QgsComposerItem* currentItem = 0;
+  QgsComposerMap* currentMap = 0;
+  for(; item_it != mItemWidgetMap.constEnd(); ++item_it)
+      currentItem = item_it.key();
+      currentMap = dynamic_cast<QgsComposerMap*>(currentItem);
+      if(currentMap)
+	  if(currentMap->containsWMSLayer())
+	      return true;
+  return false;
+void QgsComposer::showWMSPrintingWarning()
+  QString myQSettingsLabel = "/UI/displayComposerWMSWarning";
+  QSettings myQSettings;
+  bool displayWMSWarning = myQSettings.value( myQSettingsLabel, true ).toBool();
+  if(displayWMSWarning)
+      QgsMessageViewer* m = new QgsMessageViewer( this );
+      m->setWindowTitle( tr( "Project contains WMS layers" ) );
+      m->setMessage(tr("Some WMS servers (e.g. UMN mapserver) have a limit for the WIDTH and HEIGHT parameter. Printing layers from such servers may exceed this limit. If this is the case, the WMS layer will not be printed"), QgsMessageOutput::MessageText);
+      m->setCheckBoxText( tr( "Don't show this message again" ) );
+      m->setCheckBoxState( Qt::Unchecked );
+      m->setCheckBoxVisible( true );
+      m->setCheckBoxQSettingsLabel( myQSettingsLabel );
+      m->exec();
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h	2008-09-19 09:58:51 UTC (rev 9356)
+++ trunk/qgis/src/app/composer/qgscomposer.h	2008-09-19 10:02:39 UTC (rev 9357)
@@ -204,6 +204,12 @@
     //! returns new world matrix for canvas view after zoom with factor scaleChange
     QMatrix updateMatrix( double scaleChange );
+    //! True if a composer map contains a WMS layer
+    bool containsWMSLayer() const;
+    //! Displays a warning because of possible min/max size in WMS
+    void showWMSPrintingWarning();
     //! Pointer to composer view
     QgsComposerView *mView;
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp	2008-09-19 09:58:51 UTC (rev 9356)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp	2008-09-19 10:02:39 UTC (rev 9357)
@@ -25,6 +25,7 @@
 #include "qgsmaptopixel.h"
 #include "qgsproject.h"
 #include "qgsmaprenderer.h"
+#include "qgsrasterlayer.h"
 #include "qgsrendercontext.h"
 #include "qgsscalecalculator.h"
 #include "qgsvectorlayer.h"
@@ -402,6 +403,40 @@
   mYOffset = yOffset;
+bool QgsComposerMap::containsWMSLayer() const
+  if(!mMapRenderer)
+      return false;
+  QStringList layers = mMapRenderer->layerSet();
+  QStringList::const_iterator layer_it = layers.constBegin();
+  QgsMapLayer* currentLayer = 0;
+  for(; layer_it != layers.constEnd(); ++layer_it)
+      currentLayer = QgsMapLayerRegistry::instance()->mapLayer(*layer_it);
+      if(currentLayer)
+	  QgsRasterLayer* currentRasterLayer = dynamic_cast<QgsRasterLayer*>(currentLayer);
+	  if(currentRasterLayer)
+	      const QgsRasterDataProvider* rasterProvider = 0;
+	      if(rasterProvider = currentRasterLayer->dataProvider())
+		  if(rasterProvider->name() == "wms")
+		      return true;
+  return false;
 double QgsComposerMap::horizontalViewScaleFactor() const
   double result = 1;
Modified: trunk/qgis/src/core/composer/qgscomposermap.h
--- trunk/qgis/src/core/composer/qgscomposermap.h	2008-09-19 09:58:51 UTC (rev 9356)
+++ trunk/qgis/src/core/composer/qgscomposermap.h	2008-09-19 10:02:39 UTC (rev 9357)
@@ -118,6 +118,9 @@
     /**Sets offset values to shift image (useful for live updates when moving item content)*/
     void setOffset( double xOffset, double yOffset );
+    /**True if composer map renders a WMS layer*/
     /** stores state in Dom node
      * @param elem is Dom element corresponding to 'Composer' tag
      * @param temp write template file
More information about the QGIS-commit mailing list
